gelöst -Enigma verursacht scheinbar PERL WARNINGS in eventTypes
Begonnen von Dietmar63, 21 Mai 2015, 20:52:43
Dietmar63
2015.05.21 20:13:52 3:     main::__ANON__                      called by fhem.pl (604)
2015.05.21 20:13:52 3:     main::ENIGMA2_ReceiveCommand        called by FHEM/HttpUtils.pm (256)
2015.05.21 20:13:52 3:     main::readingsEndUpdate             called by ./FHEM/70_ENIGMA2.pm (2289)
2015.05.21 20:13:52 3:     main::DoTrigger                     called by fhem.pl (3650)
2015.05.21 20:13:52 3:     main::CallFn                        called by fhem.pl (2886)
2015.05.21 20:13:52 3:     main::eventTypes_Notify             called by fhem.pl (2963)
2015.05.21 20:13:52 3:     main::et_addEvt                     called by ./FHEM/91_eventTypes.pm (109)
2015.05.21 20:13:52 3:     main::__ANON__                      called by ./FHEM/91_eventTypes.pm (39)
2015.05.21 20:13:52 3: stacktrace:
2015.05.21 20:13:52 1: PERL WARNING: Use of uninitialized value $evt in substitution (s///) at ./FHEM/91_eventTypes.pm line 39.
2015.05.21 19:53:56 3: ENIGMA2 Sat: Adding attribute bouquet-radio = 1:7:2:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favourites.radio" ORDER BY bouquet
2015.05.21 19:53:55 3: ENIGMA2 Sat: Adding attribute bouquet-tv = 1:7:1:0:0:0:0:0:0:0:FROM BOUQUET "userbouquet.favoriten_alle.tv" ORDER BY bouquet
2015.05.21 19:53:54 3:     main::__ANON__                      called by fhem.pl (604)
2015.05.21 19:53:54 3:     main::ENIGMA2_ReceiveCommand        called by FHEM/HttpUtils.pm (256)
2015.05.21 19:53:54 3:     main::readingsEndUpdate             called by ./FHEM/70_ENIGMA2.pm (2289)
2015.05.21 19:53:54 3:     main::DoTrigger                     called by fhem.pl (3650)
2015.05.21 19:53:54 3:     main::CallFn                        called by fhem.pl (2886)
2015.05.21 19:53:54 3:     main::eventTypes_Notify             called by fhem.pl (2963)
2015.05.21 19:53:54 3:     main::et_addEvt                     called by ./FHEM/91_eventTypes.pm (109)
2015.05.21 19:53:54 3:     main::__ANON__                      called by ./FHEM/91_eventTypes.pm (39)
2015.05.21 19:53:54 3: stacktrace:
2015.05.21 19:53:54 1: PERL WARNING: Use of uninitialized value $evt in substitution (s///) at ./FHEM/91_eventTypes.pm line 39.
2015.05.21 19:53:54 3:     main::__ANON__                      called by ./FHEM/91_eventTypes.pm (34)
2015.05.21 19:53:54 1: PERL WARNING: Use of uninitialized value $evt in pattern match (m//) at ./FHEM/91_eventTypes.pm line 34.
Ich bekomme seitdem ich eventTypes  eingeschaltet habe PERL WARNING in eventTypes.
Sie scheinen aus Enigma zu kommen.
@Loredo:
Vielleicht kannst du bei Gelegenheit ja mal nachsehen woran das liegt.
Gruß Dietmar
FB7390, CUL, 2 FHT, FS20
Loredo
Spontan würde ich jetz sagen, dass das eventTypes Modul nicht (richtig) mit leeren Events umgehen kann.
Ich kann in das ENIGMA2 Modul zwar jede Menge trim() einbauen, bin aber nicht sicher, ob das zielführend wäre.
Kannst du herausfinden bei welchem Reading der Fehler auftritt und das Logging des ENIGMA2 Moduls entsprechend erhöhen?
Maintainer:
Dietmar63
Ich habe die neueste Version von evnttypes nachinstalliert.
Es schien danach kein Problem mehr zu sein.
EEs war immer nur beim StartUp
Gruß Dietmar
