HM-LC-SW1-FM -> fehlendes Register shCtValLo
Begonnen von CQuadrat, 03 Juni 2015, 08:37:24
CQuadrat
Hallo Zusammen,
bei meinem HM-LC-SW1-FM vermisse ich das Register shCtValLo. Ein getConfig habe ich natürlich durchgeführt.
Handelt es sich hier um einen Bug?
   DEF        2A426E
   HMLAN1_MSGCNT 112
   HMLAN1_RAWMSG E2A426E,0000,38DCB92F,FF,FFAF,79A0102A426ECC0007030000
   HMLAN1_RSSI -81
   HMLAN1_TIME 2015-06-03 07:44:02
   HMUSB1_MSGCNT 108
   HMUSB1_RAWMSG E2A426E,0000,39F8C227,FF,FFAD,79A0102A426ECC0007030000
   HMUSB1_RSSI -83
   HMUSB1_TIME 2015-06-03 07:44:03
   IODev      HMLAN1
   LASTInputDev HMUSB1
   MSGCNT     220
   NAME       Licht_Treppe
   NR         1118
   STATE      an
   TYPE       CUL_HM
   lastMsg    No:79 - t:10 s:2A426E d:CC0007 030000
   peerList   Waechter_Treppe,
   protLastRcv 2015-06-03 07:44:03
   protSnd    40 last_at:2015-06-03 07:44:02
   protState  CMDs_done
   rssi_HMLAN1 avg:-87 min:-90 max:-84 lst:-87 cnt:3
   rssi_Waechter_Treppe avg:-56.79 min:-69 max:-55 lst:-55 cnt:84
   rssi_at_HMLAN1 avg:-82.2 min:-104 max:-75 lst:-81 cnt:112
   rssi_at_HMUSB1 avg:-83.43 min:-90 max:-78 lst:-83 cnt:108
   Readings:
     2015-06-01 22:22:18   Activity        alive
     2015-06-03 07:09:35   CommandAccepted yes
     2015-05-11 10:38:45   D-firmware      1.12
     2015-05-11 10:38:45   D-serialNr      LEQ0242297
     2015-06-03 07:44:00   PairedTo        0xCC0007
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgActionType
jmpToTarget
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgCtDlyOff geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgCtDlyOn geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgCtOff geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgCtOn geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgCtValHi 100
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgCtValLo 50
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgMultiExec on
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgOffDly 0 s
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgOffTime unused
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgOffTimeMode absolut
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgOnDly 0 s
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgOnTime unused
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgOnTimeMode absolut
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgSwJtDlyOff off
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgSwJtDlyOn on
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgSwJtOff dlyOn
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-lgSwJtOn dlyOff
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shActionType
jmpToTarget
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shCtDlyOff geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shCtDlyOn geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shCtOff geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shCtOn geLo
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shCtValHi 100
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shOffDly 0 s
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shOffTime unused
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shOffTimeMode absolut
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shOnDly 0 s
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shOnTime 3600 s
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shOnTimeMode absolut
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shSwJtDlyOff off
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shSwJtDlyOn on
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shSwJtOff dlyOn
     2015-06-03 07:44:02   R-Waechter_Treppe_chn-01-shSwJtOn on
     2015-04-22 15:49:23   R-intKeyVisib   invisib
     2015-04-22 15:49:23   R-pairCentral   0xCC0007
     2015-04-22 15:49:24   R-sign          off
     2015-06-03 07:44:00   RegL_00:         02:01 03:00 04:00 05:00
06:00 07:00 08:00 09:00 0A:CC 0B:00 0C:07 00:00
     2015-06-03 07:44:01   RegL_01:         08:00 00:00
     2015-06-03 07:44:02   RegL_03:Waechter_Treppe_chn:01  02:00 03:00
04:00 05:64 06:00 07:AC 08:00 09:FF 0A:01 0B:13 0C:63 82:00 83:00 84:32
85:64 86:00 87:FF 88:00 89:FF 8A:21 8B:14 8C:63 00:00
     2015-06-03 07:09:35   deviceMsg       on (to Waechter_Treppe)
     2015-06-03 07:09:35   level           100
     2015-06-03 07:09:35   pct             100
     2015-06-03 07:44:01   peerList        Waechter_Treppe,
     2015-05-26 18:47:33   powerOn         2015-05-26 18:47:33
     2015-06-03 07:09:35   recentStateType ack
     2015-05-26 18:49:37   sabotageAttack  ErrIoAttack cnt:4
     2015-06-03 07:09:35   state           on
     2015-06-03 07:09:35   timedOn         running
   Helper:
     cSnd       01CC00072A426E010425F2F70103
     dlvlCmd    ++A011CC00072A426E0201000000
     mId        0004
     peerIDsRaw ,25F2F701,00000000
     rxType     1
     Io:
       newChn     +2A426E,00,01,00
       nextSend   1433310243.20389
       rxt        0
       vccu       vCCU
       p:
         2A426E
         00
         01
         00
     Mrssi:
       mNo        79
       Io:
         HMLAN1     -79
         HMUSB1     -83
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
       prs        1
     Rpt:
       IO         HMLAN1
       flg        A
       ts         1433310242.88809
       ack:
         HASH(0xb905f6c)
         798002CC00072A426E00
     Rssi:
       Hmlan1:
         avg        -87
         cnt        3
         lst        -87
         max        -84
         min        -90
       Waechter_treppe:
         avg        -56.7976190476191
         cnt        84
         lst        -55
         max        -55
         min        -69
       At_hmlan1:
         avg        -82.2053571428571
         cnt        112
         lst        -81
         max        -75
         min        -104
       At_hmusb1:
         avg        -83.4351851851852
         cnt        108
         lst        -83
         max        -78
         min        -90
     Shadowreg:
   IODev      HMLAN1
   IOgrp      vCCU
   actCycle   025:00
   actStatus  alive
   alias      Treppenlicht
   autoReadReg 5_readMissing
   eventMap   statusRequest:Status toggle:umschalten on:an off:aus
   expert     2_full
   firmware   1.12
   group      Licht
   icon       light_stairs@red
   model      HM-LC-SW1-FM
   peerIDs    00000000,25F2F701,
   room       Wohnen
   serialNr   LEQ0242297
   subType    switch
   webCmd     Status:umschalten:an:aus
Danke und Gruß
Christop
FHEM auf Mini-ITX-Server mit Intel Quad-Core J1900:
+ HM: HM-LAN, HM-USB, HM-MOD-UART mit div. HM-Komponenten
+ RFXtrx: Funkwetterstation Bresser mit ext. Thermometer, Regenmesser und Windmesser
+ TUL (KNX-Anbindung), MQTT, SONOS (div. Gimmicks), OneWire, Hue
martinp876
behoben. Register mit dem Wert 0 waren schlecht berücksichtigt.
CQuadrat
