IOErr wegen "disconnected" HMUSB?
Begonnen von Motivierte linke Hände, 10 Juni 2015, 17:53:17
Hi Martin, alle!
Gestern habe ich das FHEM-Update gemacht, einschließlich 10_CUL_HM. Seitdem haben nun über den Tag verteilt ca. 70% meiner HM-SEC-SCo den Status "IOErr":
List auf ein Beispiel:
   DEF        35C1DE
   HMLAN1_MSGCNT 59
   HMLAN1_RAWMSG E35C1DE,0000,036A1460,FF,FFAC,E3A61035C1DEAA100106010000
   HMLAN1_RSSI -84
   HMLAN1_TIME 2015-06-10 17:06:15
   HMLAN2_MSGCNT 60
   HMLAN2_RAWMSG E35C1DE,0000,118F17E3,FF,FFB3,E3A61035C1DEAA100106010000
   HMLAN2_RSSI -77
   HMLAN2_TIME 2015-06-10 17:06:15
   IODev      HMUSB
   LASTInputDev HMLAN2
   MSGCNT     119
   NAME       Fstr_Bad1
   NR         172
   NTFY_ORDER 50-Fstr_Bad1
   STATE      IOerr
   TYPE       CUL_HM
   lastMsg    No:E3 - t:10 s:35C1DE d:AA1001 06010000
   peerList   Hzg_Bad_WindowRec,
   protCmdDel 70
   protIOerr  11 last_at:2015-06-10 17:07:11
   protLastRcv 2015-06-10 17:06:15
   protState  CMDs_done_Errors:1
   rssi_at_HMLAN1 max:-81 cnt:59 avg:-88.28 lst:-84 min:-99
   rssi_at_HMLAN2 min:-79 cnt:60 avg:-76.71 lst:-77 max:-76
   Readings:
     2015-06-10 08:36:28   Activity        alive
     2015-05-22 08:36:23   CommandAccepted no
     2015-01-31 11:43:03   D-firmware      1.0
     2015-01-31 11:43:03   D-serialNr      LEQ1467507
     2015-06-03 12:00:41   PairedTo        0xAA1001
     2015-01-31 11:43:08   R-Hzg_Bad_WindowRec-expectAES off
     2015-01-31 11:43:08   R-Hzg_Bad_WindowRec-peerNeedsBurst on
     2015-01-31 11:34:24   R-cyclicInfoMsg on
     2015-01-31 11:34:24   R-eventDlyTime  0 s
     2015-01-31 11:34:24   R-msgScPosA     open
     2015-01-31 11:34:24   R-msgScPosB     closed
     2015-01-31 11:34:24   R-pairCentral   0xAA1001
     2015-01-31 11:34:24   R-sabotageMsg   on
     2015-01-31 11:34:24   R-sign          on
     2015-01-31 11:34:24   R-transmDevTryMax 6
     2015-01-31 11:34:24   R-transmitTryMax 6
     2015-06-03 12:00:41   RegL_00:        02:01 09:01 0A:CD 0B:20 0C:07 10:01 14:06 00:00
     2015-06-03 12:00:41   RegL_01:        08:01 20:9C 21:00 30:06 00:00
     2015-06-03 12:00:42   RegL_04:Hzg_Bad_WindowRec 01:01 00:00
     2015-01-31 11:43:06   aesKeyNbr       00
     2015-06-10 17:06:15   alive           yes
     2015-06-10 17:06:15   battery         ok
     2015-06-10 17:06:15   contact         closed (to vccu)
     2015-06-10 08:36:28   peerList        Hzg_Bad_WindowRec,
     2015-05-29 03:35:24   powerOn         2015-05-29 03:35:24
     2015-06-10 17:06:15   recentStateType info
     2015-06-03 12:01:31   sabotageAttack  ErrIoAttack cnt:3
     2015-06-10 17:06:15   sabotageError   off
     2015-06-10 17:07:11   state           IOerr
     2015-01-31 15:28:56   trigDst_AA1001  noConfig
     2015-06-10 12:40:32   trigDst_vccu    noConfig
     2015-06-10 12:40:32   trigger_cnt     212
   Helper:
     HM_CMDNR   227
     mId        00C7
     rxType     28
     Io:
       newChn     +35C1DE,00,01,1E
       nextSend   1433948775.83208
       rxt        2
       vccu       vccu
       p:
         35C1DE
         00
         01
         1E
       prefIO:
         HMLAN1
     Mrssi:
       mNo        E3
       Io:
         HMLAN1     -84
         HMLAN2     -77
     Prt:
       bErr       0
       sProc      0
       sleeping   0
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HMLAN1
       flg        A
       ts         1433948775.74436
       ack:
         HASH(0x412f768)
         E38002AA100135C1DE00
     Rssi:
       At_hmlan1:
         avg        -88.2881355932203
         cnt        59
         lst        -84
         max        -81
         min        -99
       At_hmlan2:
         avg        -76.7166666666667
         cnt        60
         lst        -77
         max        -76
         min        -79
   IODev      HMUSB
   IOgrp      vccu:HMLAN1
   actCycle   001:05
   actStatus  alive
   autoReadReg 4_reqStatus
   devStateIcon open:fts_window_1w_tilt@orange closed:fts_window_1w IOerr:it_wifi@red
   event-on-change-reading state
   expert     2_full
   firmware   1.0
   fp_EG      60,450,0,
   fp_fp_Grundriss_EG 180,450,0,
   group      EG,Fenster
   model      HM-SEC-SCo
   peerIDs    00000000,3018CA03,
   room       Bad,Cfg_Fenster
   serialNr   LEQ1467507
   struc_chkFstrKlein struc_FstrKlein
   subType    threeStateSensor
   userattr   struc_chkFstrKlein struc_chkFstrKlein_map structexclude
Auffällig finde ich, dass bei den Fenstern mit Fehlern "IODev HMUSB" steht, während "IOgrp vccu:HMLAN1" angegeben ist. Erschwerend kommt hinzu, dass es HMUSB derzeit gar nicht gibt (state disconnected - weil ich den mit hmland am Raspi derzeit nicht ordentlich zum Laufen bekomme, wie unter http://forum.fhem.de/index.php/topic,13071.msg302381.html#msg302381 beschrieben).
Laut Wiki "Das Attribut IODev wird automatisch gesetzt, Usereinträge sind irrelevant. Es zeigt indirekt das letzte genutzte output-device." könnte das die Ursache des Fehlers sein. Aber warum versucht die vccu den einzigen IO zu benutzen, der "disconnected" ist?
Meine vccu ist so definiert:
   DEF        AA1001
   HMLAN1_MSGCNT 104
   HMLAN1_RAWMSG EAA1001,0000,0384BDAA,FF,FFD4,4A8002AA100135E15100
   HMLAN1_RSSI -44
   HMLAN1_TIME 2015-06-10 17:35:22
   HMLAN2_MSGCNT 296
   HMLAN2_RAWMSG EAA1001,0000,11A769E6,FF,FFD3,898002AA100135C24E00
   HMLAN2_RSSI -45
   HMLAN2_TIME 2015-06-10 17:32:49
   IODev      HMUSB
   LASTInputDev HMLAN1
   MSGCNT     400
   NAME       vccu
   NR         200
   NTFY_ORDER 50-vccu
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 vccu_Btn1
   channel_02 vccu_Btn2
   channel_03 Btn_HUE_Kamin_Kueche
   lastMsg    No:4A - t:02 s:AA1001 d:35E151 00
   protLastRcv 2015-06-10 17:35:22
   rssi_at_HMLAN1 min:-44 max:-43 avg:-43.78 cnt:104 lst:-44
   rssi_at_HMLAN2 min:-46 lst:-45 avg:-45.72 cnt:296 max:-45
   Readings:
     2015-06-10 17:35:22   CommandAccepted yes
     2015-03-26 09:17:02   aesKeyNbr       04
     2015-02-02 16:36:12   recentStateType ack
     2015-04-27 22:33:50   state           CMDs_done
     2015-02-22 21:49:10   unknown_1389FB  received
     2015-02-21 15:25:56   unknown_2422C4  received
     2015-02-22 22:15:33   unknown_2881AC  received
     2015-02-22 21:45:17   unknown_2881D4  received
     2015-02-01 09:37:42   unknown_2A7855  received
     2015-02-01 11:03:15   unknown_2A7989  received
     2015-03-12 07:50:20   unknown_2C7C23  received
     2015-02-10 21:50:56   unknown_2DDE87  received
     2015-02-10 20:35:16   unknown_2DDF45  received
     2015-06-05 13:57:11   unknown_2F2452  received
     2015-02-05 11:12:09   unknown_2F2828  received
     2015-02-06 10:31:10   unknown_2F57B6  received
     2015-02-14 08:43:42   unknown_301BF1  received
     2015-03-22 16:45:38   unknown_31898C  received
     2015-03-22 11:29:09   unknown_3189B1  received
     2015-05-17 10:46:03   unknown_324531  received
     2015-02-15 09:32:34   unknown_324549  received
     2015-03-12 08:35:04   unknown_3255F7  received
     2015-02-05 06:54:11   unknown_33B27B  received
     2015-02-04 08:59:56   unknown_33B27F  received
     2015-02-02 07:32:34   unknown_33B492  received
     2015-03-26 08:58:20   unknown_349F19  received
     2015-02-05 08:58:41   unknown_359EAC  received
     2015-02-05 07:51:36   unknown_359ED6  received
     2015-02-05 09:00:36   unknown_359ED7  received
     2015-02-05 08:40:00   unknown_359EFA  received
     2015-02-05 08:51:20   unknown_359F54  received
     2015-02-05 08:36:05   unknown_359F61  received
     2015-02-05 08:53:56   unknown_359FB8  received
     2015-02-01 20:00:10   unknown_35C264  received
     2015-02-22 21:48:44   unknown_CD2006  received
   Helper:
     HM_CMDNR   74
     mId        FFF0
     rxType     1
     Io:
       nextSend   1433950522.82236
       prefIO
       vccu
     Mrssi:
       mNo        4A
       Io:
         HMLAN1     -44
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_hmlan1:
         avg        -43.7884615384615
         cnt        104
         lst        -44
         max        -43
         min        -44
       At_hmlan2:
         avg        -45.7263513513514
         cnt        296
         lst        -45
         max        -45
         min        -46
   IODev      HMUSB
   IOList     HMUSB,HMLAN1,HMLAN2
   expert     2_full
   model      CCU-FHEM
   room       Cfg_HM
   subType    virtual
   webCmd     virtual:update
Bis vor dem Update funktionierte es hier - auch wenn der HMUSB disconnected war.
Im Log finden sich keine Fehler.
Danke, Christian
Edith hat den sinnlosen Betreff korrigiert.
FHEM 6 in einer KVM VM mit Ubuntu
HM-CFG-USB2, 2xHM-CFG-HMLAN, HM-HMUARTLGW mit 100+ HomeMatic Devices, Geofencing, Fritzbox, Unifi, HUE, Harmony-Hub, Denon-Receiver-Modul, Calendar, GardenaSmartDevice, Shelly, MQTT (zigbee2mqtt, Tasmota und Shelly) und ein wenig 1Wire.
cruser1800
Ich hatte das gleich Problem nach einem Update mit den HM-LC-Bl1PBU-FM. Selbt ein Reset und neu anlernen des Device hat nicht geholfen. Habe ein Restore der letzten Sicherung gemacht und alles ist wieder i.O.  :D
Also erstmal kein Update für mich!
Ralli
Ralli
Proxmox 9 Cluster mit HP ED800G2i7, Intel NUC11TNHi7+NUC7i5BNH, virtualisiertes fhem 6.4 dev, virtualisierte OpenCCU (3.89.11.20260919) mit HB-RF-ETH 1.3.0 / RPI-RF-MOD, HM-LAN-GW (1.4.1) und HMW-GW, FRITZBOX 7490 (07.62), FBDECT, Siri und Alexa
Noch 3 Infos: Die Fensterkontakte leuchten bei Öffnen/Schließen rot, nicht mehr grün. Thermostate machen auch Probleme. Die Rausnahme des HMUSB aus der IOList hat nichts geändert.
Nach Einspielen des Backups funktioniert es wieder.
martinp876
hm - seltsam. Da hat sich nichts geändert.
wie sieht es mit dem HMUSB aus? Welchen Status hat der? und was steht in XmitOpen (Internal)?
was gibt ein
{my $n = "sw";;CUL_HM_assignIO($defs{$n});;return AttrVal($n,"IODev","keiner")}
zurück? sw musst du gegen den Namen des Devices ersetzen - klar.
Danke, dass Du Dich kümmerst.
Status HMUSB "disconnected". Den Rest liefere ich morgen Abend oder am Freitag nach. Dafür müsste ich wieder die andere Version zurückspielen. Da dann keine Homematic-Komponente mehr funktioniert und ich morgen früh raus muss, geht's jetzt erstmal in die Horizontale.  :)
Gute Nacht, Christian
Rince
Habe keine AES Komponenten, aber nach einem Update wohl das gleiche Problem (IOerr, kann nix schalten...)
Habe es so gelöst bekommen:
1. ssh Terminal aufmachen, anmelden
2. fhem stoppen
/etc/init.d/fhem stop
3. via git den aktuellen HMLAND gezogen
git clone git://git.zerfleddert.de/hmcfgusb
4. in das Verzeichnis gewechselt
cd hmcfgusb
5. den Kompiler angeworfen
make
6. fhem wieder angeworfen
/etc/init.d/fhem start
Alles wieder so wie es sein soll :)
Wenn der Beitrag unsinnig ist, bitte ignorieren...
Ich teste morgen mal. Die Probleme oben waren mit originalen HMLAN-Adaptern, ohne hmland und HMUSB.
Rince
In dem Fall brauchst nicht testen, obiges Prozedere hilft nicht :(
Ralli
#9
Und auch bei mir bringt das nix, den hmland für die HM-CFG-USB2 hatte ich nämlich vorher schon geupdatet.
Bei mir ist der Fehler reproduzierbar; sobald ich von diesen funktionierenden Versionen
# $Id: fhem.pl 8690 2015-06-04 16:47:20Z rudolfkoenig $
# $Id: 00_CUL.pm 8679 2015-06-02 12:19:23Z rudolfkoenig $
# $Id: 10_CUL_HM.pm 8683 2015-06-03 21:26:40Z martinp876 $
# $Id: 00_HMLAN.pm 7822 2015-02-01 16:28:10Z martinp876 $
# $Id: 98_HMinfo.pm 8632 2015-05-25 09:09:05Z martinp876 $
ein Update auf die aktuellen Versionen durchführe, klappen keine HomeMatic-Devices mehr. Ich habe mit Verbose 5 ein Log vom Start mitgeschnitten, das ist aber riesig.
Die IO stehen auf opened und laut Log scheint es zu/von den HMLANs auch Funkverkehr zu geben aber die CCU scheint das nicht korrekt weiter zu verarbeiten. Das Log habe ich Dir, Martin, per PN geschickt.
Ralli
Philipp
eben bei meinem Kollegen auch passiert, neue aktuelle FHEM Installation, 2 HMLAN, 2 6fach Taster, 11 Rollädenaktoren.
HMLAN definiert, VCCU angelegt, ,alles angelernt. Kein Problem.
Dann den Fehlerfall simuliert und einen HMLAN ausgesteckt und nix geht. Kein Neustart hilft, sendet immer nur über den letzten HMLAN.
Hab dann meine 10_CUL_HM.pm 8426 eingespielt und alles läuft. Rückmeldungen auf den 6fach Tastern, nach kurzer Wartezeit funktionieren auch die Aktoren wieder. Vielleicht liegt der Fehler schon weiter zurück und ist noch Niemanden aufgefallen?
lg
Philipp
#11
Also, die gute Nachricht ist, das ist reproduzierbar. Eben update&restart, Fenster auf, Fenstermelder leuchtet grün. Ich denke mir, alles in Ordnung, gehe joggen, komme wieder - lauter IOErr auf dem Statustablet. Selbes Fenster wieder auf - rot. Logfile ist frei von Meldungen (was natürlich auch am Loglevel liegen kann).
IODev wurde auch überall wieder auf HMUSB geändert, das einzige "disconnected" IO Device. Die beiden HMLAN existieren, scheinen aber nicht verwendet zu werden.
Die von Martin erbetenen Informationen, bevor ich jetzt wieder die alte Version einspiele:
State disconnected, XmitOpen "0"
was gibt ein
HMUSB wird zurückgegeben.
Hilft das? Mache gerne weitere Tests. Interessant ist vielleicht wirklich auch die oben erwähnte Tatsache, dass es am Anfang nach dem Update kurz funktionierte.
Edith weiß was!
Da ich den HMUSB am Raspi inzwischen wieder relativ verlässlich zum Laufen bringe, habe ich hmland auf dem Raspi wieder gestartet. Erwartungsgemäß ging der HMUSB in FHEM nach kurzer Zeit über init auf ok und - der Fenstersensor funktioniert wieder.
Vielleicht funktioniert ja "nur" der "Failover" in der vccu jetzt anders/nicht mehr? Oder die HMLANs werden in ihrer Funkkapazität durch irgendwelche Probleme erschöpft, gar nicht genutzt...? Strenggenommen ist es übrigens m.E sinnfrei, den HMUSB als IO zu nutzen. Der hängt nämlich im Garten, die beiden HMLANs sind im Haus, je Stockwerk einer. RSSI des HMUSB ist für die meisten Devices hier mit am schlechtesten. Beispiel des Testfensters von eben:
HMLAN1_RSSI -64
HMLAN2_RSSI -64
HMUSB_RSSI -72
Der HMUSB hängt nur für zwei Sensoren da draußen, weil die wegen der Distanz teilweise Probleme haben und ich den HMUSB halt übrig hatte...  :)
Ich lasse jetzt mal - solange der HMUSB durchhält - die neue Version laufen. Wenn ich was testen soll, bitte melden.
Grüße, Christian
Ralli
Ich könnte raten, dass es was mit der IOList bzw. der darin befindlichen Reihenfolge zu tun haben könnte - das darin als erstes aufgeführte Device, ein CUL0, ist zur Zeit nämlich nicht in Betrieb. Und eigentlich sollte die vCCU ja damit umgehen können (was sie bis zum Update auch problemlos tut). Aber das ist jetzt ein Stochern im Nebel.
Ralli
@Ralli: Siehe mein Edit oben: Kannst Du den CUL0 testweise in Betrieb nehmen?
Vielleicht hat die neue Version von CUL_HM ja tatsächlich eine andere Logik, welcher IO genutzt wird, die Funkstärke und Verbindung "falsch" oder "krumm" interpretiert?
#14
    Hab noch ein wenig getestet: Wenn der HMUSB auf "disconnected" geht, ist das oben beschriebene Verhalten jederzeit reproduzierbar.
    Ich habe dann mal HMUSB aus der IOList der vccu gelöscht. Wenn der HMUSB dann auf disconnected geht
    • können die Fenstermelder weiter Statusänderungen melden (LED leuchtet grün),
    • werden die Statusänderungen auch in FHEM empfangen und verarbeitet,
    • ABER: nach einer Zeit ohne Statusänderung gehen die Devices trotzdem alle auf "IOErr"; eine erneute Statusänderung dann setzt den Status richtig und überschreibt "IOErr" dadurch; allerdings tritt nach einiger Zeit wieder IOErr auf.
    • Edith hat festgestellt: Wenn der HMUSB aus der IOList der vccu entfernt wurde, gehen auch dann alle Devices nach einiger Zeit auf "IOErr", wenn HMUSB wieder "opened" statt disconnected ist. Offenbar will die vccu zwingend was über HMUSB machen, meint aber, dass es nicht geht, schon wenn HMUSB nicht mehr in der IOList steht. Ich füge daher jetzt HMUSB wieder der IOList hinzu.
    • Und Edith hat festgestellt: Wenn ich statt HMUSB HMLAN2 abhänge, entstehen keine IOErr.
    Irgendwie scheint die vccu mir zu sehr an HMUSB zu hängen.  ;) Ich habe nach dem Löschen von HMUSB aus der IOList auch die Config einmal gespeichert und FHEM neu gestartet. Das Logfile ist nach wie vor fehlermeldungslos.
    Schönes Wochenende,
    Christian
    Edith liefert noch nach:
    list auf das Fenster mit State "IOErr", bei dem das IODev aus irgendeinem Grund immer noch HMUSB ist:
   DEF        35BF3A
   HMLAN1_MSGCNT 21
   HMLAN1_RAWMSG E35BF3A,0000,1308945A,FF,FFC5,C4A64135BF3AAA100101FFC8
   HMLAN1_RSSI -59
   HMLAN1_TIME 2015-06-13 17:52:58
   HMLAN2_MSGCNT 22
   HMLAN2_RAWMSG E35BF3A,0000,212D9B6B,FF,FFBE,C4A64135BF3AAA100101FFC8
   HMLAN2_RSSI -66
   HMLAN2_TIME 2015-06-13 17:52:58
   IODev      HMUSB
   LASTInputDev HMLAN1
   MSGCNT     43
   NAME       Fstr_Buero
   NR         31
   NTFY_ORDER 50-Fstr_Buero
   STATE      IOerr
   TYPE       CUL_HM
   lastMsg    No:C4 - t:41 s:35BF3A d:AA1001 01FFC8
   peerList   Hzg_Buero_WindowRec,Hzg_Flur_WindowRec,
   protCmdDel 14
   protIOerr  4 last_at:2015-06-13 17:53:49
   protLastRcv 2015-06-13 17:52:58
   rssi_at_HMLAN1 max:-59 cnt:21 lst:-59 avg:-60.28 min:-64
   rssi_at_HMLAN2 avg:-63.77 lst:-66 min:-68 cnt:22 max:-57
   Readings:
     2015-06-13 17:13:16   Activity        alive
     2015-02-14 08:54:03   CommandAccepted yes
     2015-02-14 08:54:02   D-firmware      1.0
     2015-02-14 08:54:02   D-serialNr      LEQ1468201
     2015-05-23 14:14:55   PairedTo        0xAA1001
     2015-01-16 12:56:41   R-Hzg_Buero_WindowRec-expectAES on
     2015-01-16 12:56:41   R-Hzg_Buero_WindowRec-peerNeedsBurst on
     2015-01-31 10:50:54   R-Hzg_Flur_WindowRec-expectAES off
     2015-01-31 10:50:54   R-Hzg_Flur_WindowRec-peerNeedsBurst on
     2015-01-15 20:30:53   R-cyclicInfoMsg on
     2015-01-15 20:30:53   R-eventDlyTime  0 s
     2015-01-15 20:30:53   R-msgScPosA     open
     2015-01-15 20:30:53   R-msgScPosB     closed
     2015-01-15 20:30:53   R-pairCentral   0xAA1001
     2015-01-15 20:30:53   R-sabotageMsg   on
     2015-01-15 20:30:53   R-sign          on
     2015-01-15 20:30:53   R-transmDevTryMax 6
     2015-01-15 20:30:53   R-transmitTryMax 6
     2015-05-23 14:14:55   RegL_00:        02:01 09:01 0A:CD 0B:20 0C:07 10:01 14:06 00:00
     2015-05-23 14:14:55   RegL_01:        08:01 20:9C 21:00 30:06 00:00
     2015-05-23 14:14:56   RegL_04:Hzg_Buero_WindowRec 01:81 00:00
     2015-05-23 14:14:57   RegL_04:Hzg_Flur_WindowRec 01:01 00:00
     2015-02-14 08:54:02   aesKeyNbr       04
     2015-06-13 17:37:37   alive           yes
     2015-06-13 17:52:58   battery         ok
     2015-06-13 17:52:58   contact         open (to vccu)
     2015-06-13 17:13:16   peerList        Hzg_Buero_WindowRec,Hzg_Flur_WindowRec,
     2015-05-23 12:22:47   powerOn         2015-05-23 12:22:47
     2015-06-13 17:37:37   recentStateType info
     2015-06-13 17:37:37   sabotageError   off
     2015-06-13 17:53:49   state           IOerr
     2015-01-31 09:51:29   trigDst_AA1001  noConfig
     2015-01-15 20:30:48   trigDst_broadcast noConfig
     2015-06-13 17:52:58   trigDst_vccu    noConfig
     2015-06-13 17:52:58   trigger_cnt     255
   Helper:
     HM_CMDNR   196
     mId        00C7
     rxType     28
     Io:
       newChn     +35BF3A,00,01,1E
       nextSend   1434210778.80116
       rxt        2
       vccu       vccu
       p:
         35BF3A
         00
         01
         1E
       prefIO:
         HMLAN2
     Mrssi:
       mNo        C4
       Io:
         HMLAN1     -59
         HMLAN2     -66
     Prt:
       bErr       0
       sProc      0
       sleeping   0
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rpt:
       IO         HMLAN2
       flg        A
       ts         1434210778.71313
       ack:
         HASH(0x28570a8)
         C48002AA100135BF3A0101C800
     Rssi:
       At_hmlan1:
         avg        -60.2857142857143
         cnt        21
         lst        -59
         max        -59
         min        -64
       At_hmlan2:
         avg        -63.7727272727273
         cnt        22
         lst        -66
         max        -57
         min        -68
   IODev      HMUSB
   IOgrp      vccu:HMLAN2
   actCycle   001:05
   actStatus  alive
   devStateIcon closed:fts_window_1w open:fts_window_1w_open@red IOerr:it_wifi@red
   expert     2_full
   firmware   1.0
   fp_UG      390,610,0,
   fp_fp_Grundriss_UG 606,628,0,,
   group      UG,Fenster
   model      HM-SEC-SCo
   peerIDs    00000000,2E59EB03,301BF103,
   room       Büro,Cfg_Fenster,Flur
   serialNr   LEQ1468201
   struc_chkFstrGross struc_FstrGross
   userattr   struc_ChkFstrGross struc_ChkFstrGross_map struc_Fenster struc_Fenster_map struc_chkFenster struc_chkFenster_map struc_chkFstrGross struc_chkFstrGross_map structexclude
