günstige Wetterstation CTW-600, WS-0101, WS/WH1080 sduino
Begonnen von chris1284, 26 Juli 2015, 19:56:57
FEHMPiDi
#180
Hallo Pejonp, wie versprochen kommt hier mein Logfile. Ich hoffe du kannst damit etwas anfangen.
2016.04.11 10:10:11 5: sduino: applying filterfunc SIGNALduino_filterSign
2016.04.11 10:10:11 4: Fingerprint for MU Protocol id 28 -> IC Ledspot matches, trying to demodulate
2016.04.11 10:10:11 5: sduino: Starting demodulation at Position 1
2016.04.11 10:10:11 4: Fingerprint for MU Protocol id 31 -> pollin isotronic matches, trying to demodulate
2016.04.11 10:10:11 5: sduino: Starting demodulation at Position 3
2016.04.11 10:10:11 4: Fingerprint for MU Protocol id 8 -> TX3 Protocol matches, trying to demodulate
2016.04.11 10:10:11 5: sduino: Starting demodulation at Position 2
2016.04.11 10:10:11 4: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2016.04.11 10:10:11 5: dispatching bits: 1 1 1 1 1 1 1 1 1 0 1 0 0 1 1 0 1 0 1 0 0 0 0 1 1 1 1 1 0 0 1 1 0 1 0 0 0 0 1 0 0 0 0 0 0 1 1 0 0 0 0 0 0 1 1 1 0 0 0 0 0 0 1 1 0 0 0 0 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0
2016.04.11 10:10:11 4: decoded matched MU Protocol id 9 dmsg P9#FFA6A1F3420607030C1018 length 88
2016.04.11 10:10:11 5: converted Data to (P9#FFA6A1F3420607030C1018)
2016.04.11 10:10:11 5: sduino dispatch P9#FFA6A1F3420607030C1018
2016.04.11 10:10:11 4: SD_WS09_Parse HEX=P9#FFA6A1F3420607030C1018 length: 22
2016.04.11 10:10:11 3: SD_WS09_Parse Bin=1111111110100110101000011111001101000010000001100000011100000011000011000001000000011000 syncp=2 length:88
2016.04.11 10:10:11 3: WH SD_WS09_Parse WH=11111111 msg=10100110101000011111001101000010000001100000011100000011000011000001000000011000 syncp=2 length:80
2016.04.11 10:10:11 3: SD_WS09_Parse WH1080 Windspeed bit: 00000110 Dec: 2.0
2016.04.11 10:10:11 3: SD_WS09_Parse WH1080 Windguest bit: 00000111 Dec: 2.4
2016.04.11 10:10:11 3: SD_WS09_Parse WH1080 Rain bit: 00001100 Dec: 3.6
2016.04.11 10:10:11 3: SD_WS09_Parse WH1080 id:106 :10100110101000011111001101000010000001100000011100000011000011000001000000011000
2016.04.11 10:10:11 3: SD_WS09_Parse WH1080 id:106, bat:low, temp=9.9, hum=66, winddir=0:N wS=2.0, wG=2.4, rain=3.6
550
2016.04.11 10:10:58 4: SIGNALduino/msg READ: MU;P0=176;P1=-32001;P2=1305;P3=-1059;P4=538;P5=-1636;D=5012323232343234323232323232343234323234343234343232323232323232343234343232323232343434341;CP=2;
2016.04.11 10:10:58 5: sduino: applying filterfunc SIGNALduino_filterSign
2016.04.11 10:10:58 4: Fingerprint for MU Protocol id 28 -> IC Ledspot matches, trying to demodulate
2016.04.11 10:10:58 5: sduino: Starting demodulation at Position 1
2016.04.11 10:10:58 4: Fingerprint for MU Protocol id 31 -> pollin isotronic matches, trying to demodulate
2016.04.11 10:10:58 5: sduino: Starting demodulation at Position 13
2016.04.11 10:10:58 4: Fingerprint for MU Protocol id 8 -> TX3 Protocol matches, trying to demodulate
2016.04.11 10:10:58 5: sduino: Starting demodulation at Position 2
2016.04.11 10:10:58 5: dispatching bits: 0 0 0 0 1 0 1 0 0 0 0 0 0 1 0 1 0 0 1 1 0 1 1 0 0 0 0 0 0 0 0 1 0 1 1 0 0 0 0 0 1 1 1 0
2016.04.11 10:10:58 4: decoded matched MU Protocol id 8 dmsg TXA05360160E length 44
2016.04.11 10:10:58 5: converted Data to (TXA05360160E)
2016.04.11 10:10:58 5: sduino dispatch TXA05360160E
2016.04.11 10:10:58 4: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2016.04.11 10:10:58 4: SIGNALduino/msg READ: MU;P0=1354;P1=-32001;P2=788;P4=-1152;P5=374;D=24545404540404545404540454040404045454545454045404540454040404045404040404040454045404040404045454540404040404045454040404045454040404040454040404040454040454040451;CP=5;
FEHMPiDi
FHEM5.7@RaspPi.3|NanoCUL868-HM|NanoCUL868-Max|SDuino|DS18B20|1xHM-Sen-MDIR-WM55|
2xHM-LC-Sw1PBU-FM|HM-LC-SW4-DR|I2C_MCP23017|2xMAX-ShutterContact|11xHM-LC-Bl1PBU-FM|CTW600|VCONTROL|1xHM-Sen-MDIR-O|2xMilight
djbone92
Hallo
Habe solche Einträge im Logfile:
2016.04.15 16:28:38 4: sduino/msg READ: MU;P0=-188;P1=199;P2=477;P3=-991;P4=1449;D=001010101023232323232323234323432323232343234323434323434343234323432323434323232343232343434343232343234343432343432343434343434343434343232323234343234343434323434343434323432343432;CP=2;
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 21 -> einhell garagedoor matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 26 -> remote26 matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 27 -> remote27 matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 28 -> IC Ledspot matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: decoded matched MU Protocol id 28 dmsg u28#00 length 8
2016.04.15 16:28:38 4: SIGNALduino_unknown incomming msg: u28#00
2016.04.15 16:28:38 4: SIGNALduino_unknown rawData: 00
2016.04.15 16:28:38 4: SIGNALduino_unknown Protocol: 28
2016.04.15 16:28:38 4: SIGNALduino_unknown converted to bits: 00000000
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 31 -> pollin isotronic matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 36 -> socket36 matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 5 -> unitec6899 matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 8 -> TX3 Protocol matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2016.04.15 16:28:38 4: sduino: decoded matched MU Protocol id 9 dmsg P9#FF5EA456761A2400F21050 length 88
2016.04.15 16:28:38 4: SD_WS09_Parse HEX=P9#FF5EA456761A2400F21050 length: 22
2016.04.15 16:28:38 3: SD_WS09_Parse Bin=1111111101011110101001000101011001110110000110100010010000000000111100100001000001010000 syncp=1 length:88
2016.04.15 16:28:38 3: Zeitmeldung SD_WS09_Parse msg=FF5EA456761A2400F21050 syncp=1 length:80
2016.04.15 16:28:38 4: SIGNALduino_unknown incomming msg: P9#FF5EA456761A2400F21050
2016.04.15 16:28:38 4: SIGNALduino_unknown rawData: FF5EA456761A2400F21050
2016.04.15 16:28:38 4: SIGNALduino_unknown Protocol: 9
2016.04.15 16:28:38 4: SIGNALduino_unknown converted to bits: 1111111101011110101001000101011001110110000110100010010000000000111100100001000001010000
2016.04.15 16:28:38 4: SIGNALduino_unknown found ctw600 syncpos at 1 message is: 1011110101001000101011001110110000110100010010000000000111100100001000001010000 - sensor id:110101, bat:101, temp=1000101011, hum=00111011, wind=0000110100010010, rain=0000000001111001, winddir=1000
2016.04.15 16:28:38 4: sduino/msg READ: MU;P0=-208;P1=120;P2=-412;P3=473;P4=-996;P5=1446;D=001234343434343434345434543434343454345434545434545454345434543434545434343454343454545454343454345454543454543454545454545454545454343434345454345454545434545454545434543454543;CP=3;
2016.04.15 16:28:38 4: sduino: Fingerprint for MU Protocol id 16 -> Dooya shutter matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 26 -> remote26 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 27 -> remote27 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 28 -> IC Ledspot matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 29 -> HT12e remote matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 30 -> unitec47031 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 31 -> pollin isotronic matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 34 -> unknown34 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 36 -> socket36 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 37 -> weather37 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 5 -> unitec6899 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 8 -> TX3 Protocol matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2016.04.15 16:28:39 4: sduino: decoded matched MU Protocol id 9 dmsg P9#FF5EA456761A2400F21050 length 88
2016.04.15 16:28:39 4: sduino: Dropped (P9#FF5EA456761A2400F21050) due to short time or equal msg
Im Logfile der Wetterstation habe ich aber keine Werte mit diesem Timestamp.
Was könnte da los sein?!?
mfg
Mike
chris1284
ich würde gerne im post 1 festhalten welche der ws nun zu welchem status implementiert sind
(zb WH1080  --> 100%, CTW-600 -->50% usw usw). kann man a schon eine finale aussage zu einer der stationen geben (bin als ersteller des themas immer noch stationslos  ;) und bin drauf und dran den mast der wh1080 zu bestellen statt der ctw-600, wobei mich da natürlich das display zum mast für das gleiche geld reizt)
pejonp
Hallo FEHMPiDik,
mit diesen Daten wird bei mir eine WH1080 angelegt. Mit den dort angezeigten Werten.
WH1080_106 T: 9.9 H: 66 Ws: 2.0 Wg: 2.4 Wd: N R: 3.6
Jetzt muß du nur sagen ob die Werte so stimmen, also auch auf dem Display angezeigt werden.
Wenn nicht, muß ich einen Schalter, wie von Ralf vorgeschlagen, einbauen.
Bei der CRC-Prüfung bin ich noch nicht weitergekommen.
pejonp
LaCrossGW 868MHz:WT470+TFA+TX37-IT+EMT7110+W136+WH25A HP1003+WH2621
SignalD(CC1101):Bresser+WS-0101(868MHz WH1080)+Velux KLF200+MAX!+HM-MOD-UART:Smoke HM-SEC-SD+VITOSOLIC 200 RESOL VBUS-LAN+SolarEdge SE5K(Modbus)+Sonnen!eco8(10kWh)+TD3511+DRT710M(Modbus)+ZigBee+Z-Wave+MQTT+vitoconnect
Sidey
Bei der ctw600 sind doch gewisse Bits immer 0 oder 1.
Ist das bei der wh1080 auch so?
Signalduino, Homematic, Raspberry Pi, Mysensors, MQTT, Alexa, Docker, AlexaFhem,zigbee2mqtt
Maintainer von: SIGNALduino, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth
pejonp
Hallo djbone92,
schwer zu sagen. Empfängst du den von der Wetterstation etwas. Hier sah es doch schon gut aus (https://forum.fhem.de/index.php/topic,39451.msg438675.html#msg438675). Es gibt bestimmt noch andere Wetterstationen bei dir in der Umgebung.
Du kannst ja mal einen log anhängen verbose vorher auf 5.
Für meine WH1080/WS-01010 setzte ich immer noch die Firmware
version: V 3.2.0-b11 SIGNALduino - compiled at Jan 15 2016 22:44:39 ein. Vielleicht mache ich am WE mal ein Update.
pejonp
pejonp
Hallo Sidey,
hier habe ich mal das Protokoll angehangen. (https://forum.fhem.de/index.php/topic,39451.msg382670.html#msg382670)
Jörg
Ralf9
Hallo pejonp,
In dieser Protokollbeschreibung "CTW600-WH1080-WS1600.txt" steht:
CTW 600
0 - 9 Synchronisation - 1111111110
Bei der WH1080 fehlt aber die Definition vom der Premable und Synchronisation.
Hast Du darüber was?
Gruß Ralf
pejonp
CTW 600
Hi Ralf9,
ich denke bei der WH1080/..  ist
* Payload definition:
* Weather sensor reading Message Format:
* AAAABBBBBBBBCCCCCCCCCCCCDDDDDDDDEEEEEEEEFFFFFFFFGGGGHHHHHHHHHHHHIIIIJJJJKKKKKKKK
* 0xA4    0xF0    0x27    0x47    0x00    0x00    0x03    0xC6    0x0C    0xFE
* 10100100111100000010011101000111000000000000000000000011110001100000110011111110
with:
* AAAA = 1010    Message type: 0xA: sensor readings
das was du suchst. Die Daten werden ja richtig erkannt, bei mir zumindestens. Nur es ist keine Unterscheidung der WH1080 und CTW-600 möglich. Vielleicht geht es über die CRC-Prüfung.
Jörg
Ralf9
with:
Wie ich in Deinen logs gesehen habe, sieht es so aus, daß beim WH1080 am Anfang mindestens acht "1" stehen.
Der CTW 600 wird momentan als WH1080 erkannt, wenn am Anfang acht "1"  stehen und der Batterieladungszustand mit "10" beginnt (z.B. 1001).
Gruß Ralf
Sidey
Leider kann man das verlinkte PDF nicht mehr laden.
Mir ist aber im Gedächtnis, dass gewisse Bits sich nicht verändern, sondern konstant sind.
pejonp
Hallo sidey,
meinst du dieses hier  CTW600_Funkprotokoll.pdf  (https://forum.fhem.de/index.php/topic,39451.msg350495.html#msg350495) das steht aber auch hier drin  CTW600-WH1080-WS1600.txt  (https://forum.fhem.de/index.php/topic,39451.msg382670.html#msg382670).
Jörg
Sidey
Ja, das meinte ich.
Demnach sind Bit 21 und 22 sowie 76-79 immer 0 bei der CTW600.
Grüße Sidey
pejonp
Zitat von: Sidey am 16 April 2016, 14:52:49
Demnach sind Bit 21 und 22 sowie 76-79 immer 0 bei der CTW600...
Hallo Sidey,
ich denke die WH1080 sollten wir über die CRC-Prüfung herrausbekommen. Ich bin schon am probieren, bekomme aber mit Perl noch nicht die CRC-Prüfung hin. Diese Seite als Grundlage (http://www.perl-community.de/bat/poard/thread/19672).
Ich hänge mal noch des Protokoll der W155 als PDF an.
In diesem Forum (https://forum.fhem.de/index.php/topic,35064.msg440187.html#msg440187) wird auch an der Erkennung der Wettersonsoren gearbeitet. Dort wird der CUL bzw. Weiterentwicklungen eingesetzt.
Jörg
pejonp
habe eine neue Version vom 14_SD_WS09.pm eingecheckt. Kann mit
update all https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/dev-r32/controls_signalduino.txt
eingespielt werden.
Es muß das Perl-Modul Digest::CRC installiert sein, ansonsten kommt eine Fehlermeldung und das Modul wird nicht geladen.
Befehl zum nachinstallieren unter linux.
    cpan install Digest::CRC
Es wird jetzt bei WH1080/WS-1010/WX-2008 (868MHz OOK Sensoren) die CRC-Prüfung durchgeführt. Bei der CTW-600 erfolgt keine  CRC-Prüfung. Bitte prüfen und bitte Rückmeldungen (gute wie schlechte) geben. Danke.
pejonp
