günstige Wetterstation CTW-600, WS-0101, WS/WH1080 sduino
Begonnen von chris1284, 26 Juli 2015, 19:56:57
maddinthebrain
ich habe keinen promini als Controller sondern einen nano.
Ein list mit den cmds sieht so aus:
   Clients    :IT:CUL_TCM97001:SD_RSL:OREGON:CUL_TX:SD_AS:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_UT:SD_WS_Maverick:FLAMINGO:CUL_WS:Revolt: :FS10:CUL_FHTTK:Siro:FHT:FS20:SIGNALduino_un:
   DEF        /dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0@57600
   DMSG       nothing
   DevState   initialized
   DeviceName /dev/serial/by-path/platform-3f980000.usb-usb-0:1.3:1.0-port0@57600
   FD         18
   LASTDMSG   nothing
   NAME       sduino2
   NR         60
   PARTIAL
   STATE      opened
   TIME       1539201665
   TYPE       SIGNALduino
   sendworking 0
   unknownmessages
   version    V 3.3.1-RC7 SIGNALduino cc1101  - compiled at May 11 2018 23:00:28
   MatchList:
     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}F[A-Fa-f0-9]{2}(#R[A-F0-9][A-F0-9]){0,1}$
     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
     12:SD_WS   ^W\d+x{0,1}#.*
     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
     14:Dooya   ^P16#[A-Fa-f0-9]+
     15:SOMFY   ^Ys[0-9A-F]+
     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
     17:SD_UT   ^u30#.*
     18:FLAMINGO ^P13#[A-Fa-f0-9]+
     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
     1:IT       ^i......
     20:Revolt  ^r[A-Fa-f0-9]{22}
     21:FS10    ^P61#[A-F0-9]+
     22:Siro    ^P72#[A-Fa-f0-9]+
     23:FHT     ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     24:FS20    ^81..(04|0c)..0101a001
     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     5:CUL_TX   ^TX..........
     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
     7:Hideki   ^P12#75[A-F0-9]+
     9:CUL_FHTTK ^T[A-F0-9]{8}
     X:SIGNALduino_un ^[u]\d+#.*
   QUEUE:
     2018-10-10 22:01:55   ccconf          freq:868.350MHz bWidth:650KHz rAmpl:42dB sens:4dB  (DataRate:350.24Baud)
     2017-10-10 19:06:07   ccpatable       C3E = 00 84 00 00 00 00 00 00  => 5_dBm
     2018-10-11 08:24:58   cmds             V R t X F S P C r W x e
     2017-10-08 11:38:43   config          MS=1;MU=1;MC=1
     2018-10-11 08:01:10   ping            OK
     2018-10-10 22:01:24   state           opened
     2018-10-10 22:01:24   version         V 3.3.1-RC7 SIGNALduino cc1101  - compiled at May 11 2018 23:00:28
   getcmd:
   keepalive:
     ok         1
     retry      0
   mcIdList:
   msIdList:
   muIdList:
     9
   DbLogExclude .*
   WS09_CRCAUS 0
   event-on-change-reading state
   flashCommand avrdude -c arduino -b [BAUDRATE] -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
   hardware   nanoCC1101
   icon       cul_868
   room       Funk & Kommunikation
   verbose    0
   whitelist_IDs 9
Martin
Futro mit Proxmox und Debian: FHEM, Signalduino 433MHz & 868MHz, MAX!, WeeWX, FHEM2FHEM,
Raspi 4 mit ConBee mit deCONZ und Phoscon für ZigBee Aktoren und Sensoren
Neuhier
#361
Ich habe auch einen Arduino Nano mit dem Modul für 868MHz.
Aber eben die Hardware, in den Attributen, auf den o.g. Wert eingestellt.
Es funktioniert damit, problemlos.
Hast Du das Modul direkt am Arduino oder noch Widerstände dazwischen?
Nachtrag: oder hole Dir das RX868SH_DV von HM, sind nur 3 Kabel anzuschließen.
pejonp
@maddinthebrain
ich finde bei die die Baudrate von   (DataRate:350.24Baud)  etwas komisch. bei mir steht da immer 5603...
freq:868.300MHz bWidth:325KHz rAmpl:42dB sens:4dB  (DataRate:5603.79Baud)
Hast du mal den SignalDuino per
set sduino2 raw e
zurückgesetzt. Beim abfragen kommt dann
ccconf: freq:433.920MHz bWidth:325KHz rAmpl:42dB sens:4dB (DataRate:5603.79Baud)
und dann wieder auf 868.3 MHz setzten
set sduino2  cc1101_freq 868.300
pejonp
LaCrossGW 868MHz:WT470+TFA+TX37-IT+EMT7110+W136+WH25A HP1003+WH2621
SignalD(CC1101):Bresser+WS-0101(868MHz WH1080)+Velux KLF200+MAX!+HM-MOD-UART:Smoke HM-SEC-SD+VITOSOLIC 200 RESOL VBUS-LAN+SolarEdge SE5K(Modbus)+Sonnen!eco8(10kWh)+TD3511+DRT710M(Modbus)+ZigBee+Z-Wave+MQTT+vitoconnect
maddinthebrain
Habe ich vor einigen Tagen mal geprüft und noch mal wie beschrieben neu konfiguriert. Bringt im Ergebnis nix. Wenn ein Messpunkt pro Tag erkannt wird ist es viel...
Hier noch mal ein aktuelles Listing:
   DMSG       P9#2994011010180BD023C
   FD         19
   LASTDMSG   P9#2994011010180BD023C
   LASTInputDev sduino2
   MSGCNT     4577
   NAME       sduino2
   NR         60
   PARTIAL
   RAWMSG     MU;P0=-20956;P1=457;P2=-15322;P3=1428;P4=-1014;P5=-31040;D=01234341434143434141434341434143434343434343434341434343414343434343434341434343434343434141434343434343434143414141414341434343434343414343434141414143434351234341434143434141434341434143434343434343434341434343414343434343434341434343434343434141434343;CP=3;R=38;O;
   RSSI       -55
   STATE      opened
   TIME       1539697727
   TYPE       SIGNALduino
   sduino2_DMSG P9#FF6A7528080030A02C8B74
   sduino2_MSGCNT 42
   sduino2_RAWMSG MU;P0=-993;P1=473;P3=1461;D=010101010101010103010103010301030301010103010301030301030103030303030303010303030303030303030303030301010303030301030103030303030303010301010303010303030103010103010101030103;CP=1;R=3;
   sduino2_RSSI -72.5
   sduino2_TIME 2018-10-16 14:04:00
   sendworking 0
   unknownmessages
   DoubleMsgIDs:
   MatchList:
     17:SD_UT   ^u30#.*
     1:IT       ^i......
   QUEUE:
     2018-10-11 20:44:47   ccconf          freq:868.300MHz bWidth:325KHz rAmpl:42dB sens:4dB  (DataRate:5603.79Baud)
     2018-10-11 20:45:04   cmds            V R t X F S P C r W x e
     2018-10-16 14:00:35   ping            OK
     2018-10-14 01:04:06   state           opened
     2018-10-14 01:04:06   version         V 3.3.1-RC7 SIGNALduino cc1101  - compiled at May 11 2018 23:00:28
   getcmd:
   keepalive:
     ok         1
     retry      0
   mcIdList:
   msIdList:
   muIdList:
     9
   DbLogExclude .*
   WS09_CRCAUS 0
   hardware   nanoCC1101
   icon       cul_868
   verbose    0
   whitelist_IDs 9
viele Grüße
Martin
RaspiLED
sind wir der Frequenz mal nachgegangen? Ich habe gehört, dass einige cc1101 Module etwas verstellt sind (z.B. wenn Widerstände in der Antennenabstimmung nicht ganz passen). Das ist ja nicht schlimm, wenn man die eben etwas nachjustiert (oder konketer neben der Standardfrequenz einstellt, weil man dann besseren Empfang hat). Außerdem senden die Sender häufig gestreut, da die viel einfachere Sender eingebaut haben.
Kurzum: Hast Du einen VDR (z.B. alten DVB-T USB Stick) zum testen?
Gruß Arnd
Raspi2 mit FHEM, CUL, Signalduino, MySensors, HomeBridge, Presence, Bravia, ...
pejonp
@maddinthebrain
schau mal hier (https://forum.fhem.de/index.php/topic,91740.0/topicseen.html). Da geht es um fehlerhaft CC1101 und schlechten Empfang.
Wenn du etwas Zeit hast kannst du ja die Frequenz um .500 MHz anpassen und 3-4min warten ob etwas empfangen wird. Am besten verbose=5 beim Signalduino und bei der Wh1080. Wie weit sind den Sender und Empfänger entfernt ?
pejonp
maddinthebrain
Der Sender ist ca. 8m vom Empfänger (sduino) entfernt. Dazwischen sind Fenster. Der cc1101 ist auch schon neu. Und definitiv nicht aus der gleichen Charge wie der Vorgänger. Ich habe auch die beiliegende Billigstantenne gegen eine gute getauscht. Hat sich in deutlich besseren rssi Werten auch gleich gezeigt.
Wie man den Logauszügen ja auch entnehmen kann, wird ja was empfangen, nur scheint die Auswertung fehl zu gehen.
Mittlerweile überlege ich, den 868MHz Sduino abzubauen. Das einzige Teil was man mit ihm nutzen könnte, ist die Wetterstation. Deren Basisstation lese ich jedoch schon mit einem weiteren Raspi mit der Software CumulusMX aus. Die schreibt einmal pro Minute ein Text file mit den Messdaten. Diese lese ich dann in Fhem ein, um z. B. Bei starkem Wind die Markise zu schließen. Das funktioniert recht zuverlässig.
Das mit dem sduino und Wetterstation geht nun schon seit einem Jahr so. Und langsam macht sich Frust breit...
Schade.
Mit freundlichen Grüßen
Martin
Martin
Sidey
Kannst Du uns ein Log beereistellen, mit den empfangenen Daten?
Ein Zeitraum von 15 Minuten reicht denke ich.
Wenn bei der Dekodierung abgebrochen wird, gibt es vielleicht einfach nur einen blöden Fehler im Modul.
Grüße Sidey
Maintainer von: SIGNALduino, SD_WS*, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth, fhem-mcp, midea-mqtt, whatsmeow-mqtt, alexa-cookie-service
maddinthebrain
Martin
Sidey
Zitat von: maddinthebrain am 18 Oktober 2018, 08:05:12
Es gibt einen Logauszug weiter vorne im Thread,
Den hatte ich gesehen, allerdings hast Du den mit einer sehr geringen Datenrate erstellt.
Die Datenrate von deiner Station ist zwar auch niedrig, allerdings wäre es besser, wenn Du uns ein Log senden könntest, mit den angepassten Cc1101 Einstellungen.
Damit ist die Wahrscheinlichkeit am höchsten, etwas zu finden.
So wie das aussieht, empfängt der Empfänger auch etwas, aber es passt nicht zu dem von uns definiertem Muster.
Grüße Sidey
Gesendet von meinem XT1650 mit Tapatalk
RaspiLED
Hi Sidey,
Erklär uns mal die Datenrate bzw. Wie man die ändert!?
Es geht um die letzte Klammer bei der ccconf Abfrage, oder?
Mit ist klar wie ich die Freq, Bandwidth und Sens einstelle, aber über die Datenrate habe ich mir noch nie Gedangen gemacht.
Danke und Gruß
Arnd
Sidey
Richtig die Datenrate ist Default 5603 Baud. Das Einstellen geht bislang noch nicht über einen Schieberegler. Wollte ich aber mal einbauen.
Bis da hin, kann man die Datenrate nur über die Register 10 und 11 direkt Setzen.
DRATE_E[3:0]  sind die Bits 0 bis 3 im Register 10 (Default ist 0111 was 7 entspricht)
DRATE_M[7:0]  sind alle Bits aus Register 11 (Default 0xC4)
Aus diesen Werten wir die Datenrate wie folgt berechnet:
Zur Formel:(256+DRATE_M)*2^DRATE_E/2^28 * 26000
Die Datenrate beeinflusst die Abtastrate des Empfängers. Angenommen meine Datenrate ist 500 Baud und der Sender sendet mit 1000 Baud. Dann bekomme ich nur jedes 2. Bit mit. Setze ich die Datenrate auf genau 1000 Baud, dann habe ich eine Chance jedes Bit zu erkennen, unter Umständen bekomme ich aber sehr ungenaue Pegelzeiten. Eine hohe Datenrate sorgt dafür, dass der Übergang von low zu high schnell erkannt wird.
maddinthebrain
So hier ist mal ein Logauszug:10.22 20:48:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:48:34 4: sduino2/msg READ: MU;P0=-19028;P1=482;P2=-987;P3=1462;D=012121212121212123212323212321232321212323232121212121232123212321232123212123232323232323212323232323232321212323232323232321232121212123212323232323212323232123232121232121;CP=1;R=3;
2018.10.22 20:48:34 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:48:34 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:48:34 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 1 0 1 0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 0 0 1 0 0 1 1 0 1 0 0
2018.10.22 20:48:34 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63EAAC040602F41134 length 88 RSSI = -72.5
2018.10.22 20:48:34 5: sduino2 Dispatch: P9#FF4A63EAAC040602F41134, test ungleich: disabled
2018.10.22 20:48:34 5: sduino2 Dispatch: P9#FF4A63EAAC040602F41134, -72.5 dB, dispatch
2018.10.22 20:48:34 5: sduino2: dispatch P9#FF4A63EAAC040602F41134
2018.10.22 20:48:34 4: sduino2: SD_WS09_Parse0 msg=FF4A63EAAC040602F41134 Bin=1111111101001010011000111110101010101100000001000000011000000010111101000001000100110100 syncp=1 length:88
2018.10.22 20:48:34 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:48:34 4: sduino2: SD_WS09_SHIFT_1 NOK  rwa:FFA531F5560203017A089A
2018.10.22 20:48:34 4: sduino2: SD_WS09_SHIFT_3 NOK rwa:FFD298FAAB010180BD044D
2018.10.22 20:48:34 4: sduino2: SD_WS09_SHIFT_5 NOK rwa:FF4A63EAAC040602F41134 msg:P9#FF4A63EAAC040602F41134
2018.10.22 20:48:34 4: sduino2: SD_WS09_CRC_test2 rwa:FF4A63EAAC040602F41134 msg:P9#FF4A63EAAC040602F41134 CRC:132
2018.10.22 20:48:34 4: sduino2: SD_WS09_Parse_18 CTW600 EXIT: msg=1111111101001010011000111110101010101100000001000000011000000010111101000001000100110100 length:88
2018.10.22 20:48:34 3: sduino2: Unknown code P9#FF4A63EAAC040602F41134, help me!
2018.10.22 20:49:21 4: sduino2/msg READ: MU;P0=-21688;P1=477;P2=-995;P3=1457;P4=-31036;D=01212121212121212321232321232123232121232323212121212123212321232123212321212323232323232323212323232323232123232323232323232123212121212321232323232321232123232321232321212341212121212121212321232321232123232121232323212121212123212321232123212321212323;CP=1;R=29;O;
2018.10.22 20:49:21 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:49:21 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:49:21 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 1 0 1 0 1 0 1 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 1 0 0 0 1 0 0 1 1 0 0
2018.10.22 20:49:21 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63EAAC020402F4144C length 88 RSSI = -59.5
2018.10.22 20:49:21 5: sduino2 Dispatch: P9#FF4A63EAAC020402F4144C, test ungleich: disabled
2018.10.22 20:49:21 5: sduino2 Dispatch: P9#FF4A63EAAC020402F4144C, -59.5 dB, dispatch
2018.10.22 20:49:21 5: sduino2: dispatch P9#FF4A63EAAC020402F4144C
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse0 msg=FF4A63EAAC020402F4144C Bin=1111111101001010011000111110101010101100000000100000010000000010111101000001010001001100 syncp=1 length:88
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:49:21 4: sduino2: SD_WS09_SHIFT_1 NOK  rwa:FFA531F5560102017A0A26
2018.10.22 20:49:21 4: sduino2: SD_WS09_SHIFT_2 OK rwa:FFA531F5560102017A0A26 msg:P9#FFA531F5560102017A0A26
2018.10.22 20:49:21 4: sduino2: SD_WS09_CRC_test2 rwa:FFA531F5560102017A0A26 msg:P9#FFA531F5560102017A0A26 CRC:0
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_1 msg=10100101001100011111010101010110000000010000001000000001011110100000101000100110 length:80
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_2 WH1080 id:83, Windspeed bit: 00000001 Dec: 0.3
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_3 WH1080 id:83, Windguest bit: 00000010 Dec: 0.7
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_4 WH1080 id:83, Rain bit: 000101111010 Dec: 113.4
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_5 WH1080 id:83, bat:ok, temp=10.1, hum=86, winddir=10:SW wS=0.3, wG=0.7, rain=113.4
2018.10.22 20:49:21 4: sduino2: SD_WS09_Parse_19 WH1080 id:83 :10100101001100011111010101010110000000010000001000000001011110100000101000100110
2018.10.22 20:49:22 4: sduino2/msg READ: MU;P0=-992;P1=481;P2=1463;D=0101010201020102020202020201020202020202020201020101010102010202020202010201020202010202010102;CP=1;R=29;
2018.10.22 20:49:22 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:49:22 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:49:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:50:10 4: sduino2/msg READ: MU;P0=-30388;P1=474;P2=-981;P3=1463;D=012121212121212123212323212321232321212323232121212121232123232321232123212123232323232321232123232323232121232323232323232321232121212123212323232323212323232123212121212323;CP=1;R=29;
2018.10.22 20:50:10 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:50:10 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:50:10 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 0 0 1 0 1 0 1 1 0 0 0 0 0 0 1 0 1 0 0 0 0 0 1 1 0 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 0 0 1 0 1 1 1 1 0 0 0
2018.10.22 20:50:10 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E8AC0A0C02F41178 length 88 RSSI = -59.5
2018.10.22 20:50:10 5: sduino2 Dispatch: P9#FF4A63E8AC0A0C02F41178, test ungleich: disabled
2018.10.22 20:50:10 5: sduino2 Dispatch: P9#FF4A63E8AC0A0C02F41178, -59.5 dB, dispatch
2018.10.22 20:50:10 5: sduino2: dispatch P9#FF4A63E8AC0A0C02F41178
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse0 msg=FF4A63E8AC0A0C02F41178 Bin=1111111101001010011000111110100010101100000010100000110000000010111101000001000101111000 syncp=1 length:88
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:50:10 4: sduino2: SD_WS09_SHIFT_1 NOK  rwa:FFA531F4560506017A08BC
2018.10.22 20:50:10 4: sduino2: SD_WS09_SHIFT_2 OK rwa:FFA531F4560506017A08BC msg:P9#FFA531F4560506017A08BC
2018.10.22 20:50:10 4: sduino2: SD_WS09_CRC_test2 rwa:FFA531F4560506017A08BC msg:P9#FFA531F4560506017A08BC CRC:0
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_1 msg=10100101001100011111010001010110000001010000011000000001011110100000100010111100 length:80
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_2 WH1080 id:83, Windspeed bit: 00000101 Dec: 1.7
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_3 WH1080 id:83, Windguest bit: 00000110 Dec: 2.0
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_4 WH1080 id:83, Rain bit: 000101111010 Dec: 113.4
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_5 WH1080 id:83, bat:ok, temp=10, hum=86, winddir=8:S wS=1.7, wG=2.0, rain=113.4
2018.10.22 20:50:10 4: sduino2: SD_WS09_Parse_19 WH1080 id:83 :10100101001100011111010001010110000001010000011000000001011110100000100010111100
2018.10.22 20:50:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:50:57 4: sduino2/msg READ: MU;P0=-18408;P1=467;P2=-999;P3=1442;P4=-31032;P5=-5436;D=01212121212121212321232321232123232121232323212121212123212323232123212321212323232323232321232323232323232121232323232323232123212121212321232323232323212123232121232121232141512121212321232321232123232121232323212121212123212323232123212321212323232323;CP=1;R=28;O;
2018.10.22 20:50:57 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:50:57 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:50:57 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 1 0 0 0 1 0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 0 1 1 0 0 1 1 0 1 1 0 0 0
2018.10.22 20:50:57 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E8AC040602F40CD8 length 88 RSSI = -60
2018.10.22 20:50:57 5: sduino2 Dispatch: P9#FF4A63E8AC040602F40CD8, test ungleich: disabled
2018.10.22 20:50:57 5: sduino2 Dispatch: P9#FF4A63E8AC040602F40CD8, -60 dB, dispatch
2018.10.22 20:50:57 5: sduino2: dispatch P9#FF4A63E8AC040602F40CD8
2018.10.22 20:50:57 4: sduino2: SD_WS09_Parse0 msg=FF4A63E8AC040602F40CD8 Bin=1111111101001010011000111110100010101100000001000000011000000010111101000000110011011000 syncp=1 length:88
2018.10.22 20:50:57 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:50:57 4: sduino2: SD_WS09_SHIFT_1 NOK  rwa:FFA531F4560203017A066C
2018.10.22 20:50:57 4: sduino2: SD_WS09_SHIFT_3 NOK rwa:FFD298FA2B010180BD0336
2018.10.22 20:50:57 4: sduino2: SD_WS09_SHIFT_5 NOK rwa:FF4A63E8AC040602F40CD8 msg:P9#FF4A63E8AC040602F40CD8
2018.10.22 20:50:57 4: sduino2: SD_WS09_CRC_test2 rwa:FF4A63E8AC040602F40CD8 msg:P9#FF4A63E8AC040602F40CD8 CRC:132
2018.10.22 20:50:57 4: sduino2: SD_WS09_Parse_18 CTW600 EXIT: msg=1111111101001010011000111110100010101100000001000000011000000010111101000000110011011000 length:88
2018.10.22 20:50:57 3: sduino2: Unknown code P9#FF4A63E8AC040602F40CD8, help me!
2018.10.22 20:50:58 4: sduino2/msg READ: MU;P0=-1005;P1=1443;P2=470;D=0102010101010101010102020101010101010102010202020201020101010101010202010102020102020102;CP=2;R=28;
2018.10.22 20:50:58 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:50:58 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:51:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:51:46 4: sduino2/msg READ: MU;P0=-9212;P1=469;P2=-1004;P3=1440;D=012121212121212123212323212321232321212323232121212121232321212321232123212123232323232321212323232323212323212323232323232321232121212123212323232323212123232321232321212121;CP=1;R=29;
2018.10.22 20:51:46 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:51:46 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:51:46 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 0 1 1 0 1 0 1 0 1 1 0 0 0 0 0 0 1 1 0 0 0 0 0 1 0 0 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 1 0 0 0 1 0 0 1 1 1 0 0
2018.10.22 20:51:46 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E6AC0C1202F4189C length 88 RSSI = -59.5
2018.10.22 20:51:46 5: sduino2 Dispatch: P9#FF4A63E6AC0C1202F4189C, test ungleich: disabled
2018.10.22 20:51:46 5: sduino2 Dispatch: P9#FF4A63E6AC0C1202F4189C, -59.5 dB, dispatch
2018.10.22 20:51:46 5: sduino2: dispatch P9#FF4A63E6AC0C1202F4189C
2018.10.22 20:51:46 4: sduino2: SD_WS09_Parse0 msg=FF4A63E6AC0C1202F4189C Bin=1111111101001010011000111110011010101100000011000001001000000010111101000001100010011100 syncp=1 length:88
2018.10.22 20:51:46 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:51:46 4: sduino2: SD_WS09_SHIFT_1 NOK  rwa:FFA531F3560609017A0C4E
2018.10.22 20:51:46 4: sduino2: SD_WS09_SHIFT_3 NOK rwa:FFD298F9AB030480BD0627
2018.10.22 20:51:46 4: sduino2: SD_WS09_SHIFT_5 NOK rwa:FF4A63E6AC0C1202F4189C msg:P9#FF4A63E6AC0C1202F4189C
2018.10.22 20:51:46 4: sduino2: SD_WS09_CRC_test2 rwa:FF4A63E6AC0C1202F4189C msg:P9#FF4A63E6AC0C1202F4189C CRC:132
2018.10.22 20:51:46 4: sduino2: SD_WS09_Parse_18 CTW600 EXIT: msg=1111111101001010011000111110011010101100000011000001001000000010111101000001100010011100 length:88
2018.10.22 20:51:46 3: sduino2: Unknown code P9#FF4A63E6AC0C1202F4189C, help me!
2018.10.22 20:52:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:52:34 4: sduino2/msg READ: MU;P0=-989;P1=1453;P2=478;D=0101010101020101010101010101010102010202020201020101010101020101010201010101020202;CP=1;R=28;
2018.10.22 20:52:34 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:52:34 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:53:22 4: sduino2/msg READ: MU;P0=-32001;P1=356;P2=-991;P3=1447;P4=477;D=0123232424242424232324232324232423242324232323232323242323232323232423242323232323232324232424242423242323232323242323232423232423242423;CP=4;R=3;
2018.10.22 20:53:22 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:53:22 5: sduino2: Starting demodulation at Position 3
2018.10.22 20:53:22 5: sduino2: dispatching bits: 0 0 1 1 1 1 1 0 0 1 0 0 1 0 1 0 1 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 1 0 0 0 1 0 0 1 0 1 1 0 0
2018.10.22 20:53:22 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#3E4AA040A02F4112C length 68 RSSI = -72.5
2018.10.22 20:53:22 5: sduino2 Dispatch: P9#3E4AA040A02F4112C, test ungleich: disabled
2018.10.22 20:53:22 5: sduino2 Dispatch: P9#3E4AA040A02F4112C, -72.5 dB, dispatch
2018.10.22 20:53:22 5: sduino2: dispatch P9#3E4AA040A02F4112C
2018.10.22 20:53:22 3: sduino2: Unknown code P9#3E4AA040A02F4112C, help me!
2018.10.22 20:53:28 4: sduino2/keepalive ok, retry = 0
2018.10.22 20:54:09 4: sduino2/msg READ: MU;P0=-31072;P1=486;P2=-986;P3=1454;D=01212121212121212321232321232123232121232323212121212123232123232123212321232123232323232321232323232323212323232323232323232123212121212321232323232323232323212321212321232301212121212121212321232321232123232121232323212121212123232123232123212321232123;CP=1;R=29;O;
2018.10.22 20:54:09 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:54:09 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:54:09 5: sduino2: dispatching bits: 1 1 1 1 1 1 1 1 0 1 0 0 1 0 1 0 0 1 1 0 0 0 1 1 1 1 1 0 0 1 0 0 1 0 1 0 1 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 1 0 1 1 1 1 0 1 0 0 0 0 0 0 0 0 0 1 0 1 1 0 1 0 0 0
2018.10.22 20:54:09 4: sduino2: decoded matched MU Protocol id 9 dmsg P9#FF4A63E4AA040802F40168 length 88 RSSI = -59.5
2018.10.22 20:54:09 5: sduino2 Dispatch: P9#FF4A63E4AA040802F40168, test ungleich: disabled
2018.10.22 20:54:09 5: sduino2 Dispatch: P9#FF4A63E4AA040802F40168, -59.5 dB, dispatch
2018.10.22 20:54:09 5: sduino2: dispatch P9#FF4A63E4AA040802F40168
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse0 msg=FF4A63E4AA040802F40168 Bin=1111111101001010011000111110010010101010000001000000100000000010111101000000000101101000 syncp=1 length:88
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse CRC_AUS:0
2018.10.22 20:54:09 4: sduino2: SD_WS09_SHIFT_1 NOK  rwa:FFA531F2550204017A00B4
2018.10.22 20:54:09 4: sduino2: SD_WS09_SHIFT_2 OK rwa:FFA531F2550204017A00B4 msg:P9#FFA531F2550204017A00B4
2018.10.22 20:54:09 4: sduino2: SD_WS09_CRC_test2 rwa:FFA531F2550204017A00B4 msg:P9#FFA531F2550204017A00B4 CRC:0
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_1 msg=10100101001100011111001001010101000000100000010000000001011110100000000010110100 length:80
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_2 WH1080 id:83, Windspeed bit: 00000010 Dec: 0.7
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_3 WH1080 id:83, Windguest bit: 00000100 Dec: 1.4
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_4 WH1080 id:83, Rain bit: 000101111010 Dec: 113.4
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_5 WH1080 id:83, bat:ok, temp=9.8, hum=85, winddir=0:N wS=0.7, wG=1.4, rain=113.4
2018.10.22 20:54:09 4: sduino2: SD_WS09_Parse_19 WH1080 id:83 :10100101001100011111001001010101000000100000010000000001011110100000000010110100
2018.10.22 20:54:10 4: sduino2/msg READ: MU;P0=-980;P1=481;P2=1459;D=0101010202010202020202020102020202020202020201020101010102010202020202020202020102010102010202;CP=2;R=3;
2018.10.22 20:54:10 4: sduino2: Fingerprint for MU Protocol id 9 -> CTW 600 matches, trying to demodulate
2018.10.22 20:54:10 5: sduino2: Starting demodulation at Position 1
2018.10.22 20:54:28 4: sduino2/keepalive ok, retry = 0
Ich hoffe es hilft weiter.
Grüße Martin
Martin
pejonp
@maddinthebrain
Stell mal bitte im Signalduino WS09_CRCAUS=2, dann wird bei mir eine WH1080 angelegt.
pejonp
maddinthebrain
Martin
