Gelöst: hmcfgusb "flackert"
Begonnen von macfly, 05 August 2015, 20:44:24
macfly
ich habe mir für die Interaktion mit homematic-komponenten den USB-Stick zugelegt.
Dann habe hmcfgusb via git runtergeladen, kompiliert, gestartet, lt. Logfile meldet der sich mit:
2015-08-05 20:35:59.031146: Client 127.0.0.1 connected!
2015-08-05 20:35:59.102923: LAN > A424242
2015-08-05 20:35:59.103031: LAN < HHM-USB-IF,03C7,LEQ1198360,308749,424242,00B8DF40,0002,06
2015-08-05 20:35:59.166915: LAN > C
2015-08-05 20:35:59.230912: LAN > +2A8681,00,01,00
2015-08-05 20:35:59.294907: LAN > +36B361,00,01,1E
2015-08-05 20:35:59.358907: LAN > Y01,00,
2015-08-05 20:35:59.422916: LAN > Y02,00,
2015-08-05 20:35:59.422955: LAN < I00,00,00,00
2015-08-05 20:35:59.486908: LAN > Y03,00,
2015-08-05 20:35:59.486955: LAN < I00,00,00,00
2015-08-05 20:35:59.550907: LAN > T1D55140F,04,00,00000000
2015-08-05 20:35:59.550954: LAN < I00,00,00,00
2015-08-05 20:35:59.614906: LAN > SFF260806,00,00000000,01,FF260806,998112424242000000
2015-08-05 20:35:59.678960: LAN < RFF260806,0002,00000000,FF,7FFF,998112424242000000
2015-08-05 20:36:24.033069: LAN > K
2015-08-05 20:36:24.094777: LAN < HHM-USB-IF,03C7,LEQ1198360,308749,424242,00B940E0,0002,06
2015-08-05 20:36:25.033718: LAN > K
2015-08-05 20:36:25.086769: LAN < HHM-USB-IF,03C7,LEQ1198360,308749,424242,00B944C0,0002,06
2015-08-05 20:36:26.034801: LAN > K
2015-08-05 20:36:26.078761: LAN < HHM-USB-IF,03C7,LEQ1198360,308749,424242,00B948A0,0002,06
2015-08-05 20:36:27.035998: LAN > K
2015-08-05 20:36:27.070755: LAN < HHM-USB-IF,03C7,LEQ1198360,308749,424242,00B94C80,0002,06
2015-08-05 20:36:28.039729: Connection to 127.0.0.1 closed!
hmusb habe ich in fhem zugefügt, allerdings sehe ich im Logfile *dauernd*
2015.08.05 20:38:53 1: HMLAN_Parse: hmusb new condition timeout
2015.08.05 20:38:53 1: 127.0.0.1:1234 disconnected, waiting to reappear (hmusb)
2015.08.05 20:38:53 1: HMLAN_Parse: hmusb new condition disconnected
2015.08.05 20:38:53 1: 127.0.0.1:1234 reappeared (hmusb)
2015.08.05 20:38:53 1: HMLAN_Parse: hmusb new condition init
2015.08.05 20:38:54 1: HMLAN_Parse: hmusb new condition ok
2015.08.05 20:39:22 1: HMLAN_Parse: hmusb new condition timeout
2015.08.05 20:39:22 1: 127.0.0.1:1234 disconnected, waiting to reappear (hmusb)
2015.08.05 20:39:22 1: HMLAN_Parse: hmusb new condition disconnected
2015.08.05 20:39:22 1: 127.0.0.1:1234 reappeared (hmusb)
2015.08.05 20:39:22 1: HMLAN_Parse: hmusb new condition init
2015.08.05 20:39:23 1: HMLAN_Parse: hmusb new condition ok
2015.08.05 20:39:51 1: HMLAN_Parse: hmusb new condition timeout
2015.08.05 20:39:51 1: 127.0.0.1:1234 disconnected, waiting to reappear (hmusb)
2015.08.05 20:39:51 1: HMLAN_Parse: hmusb new condition disconnected
2015.08.05 20:39:51 1: 127.0.0.1:1234 reappeared (hmusb)
2015.08.05 20:39:51 1: HMLAN_Parse: hmusb new condition init
2015.08.05 20:39:52 1: HMLAN_Parse: hmusb new condition ok
irgendwas, was ich falsch mache?
achso, ich habe vorher die Firmware aktualisiert:
root@storage:/opt/hmcfgusb# ./flash-hmcfgusb hmusbif.03c7.enc
HM-CFG-USB flasher version 0.101-git
Reading firmware from hmusbif.03c7.enc...
Firmware with 368 blocks successfully read.
HM-CFG-USB not in bootloader mode, entering bootloader.
Waiting for device to reappear...
Interrupt transfer not completed: Unknown error code 5 / 0x05!
Can't send null frame: No such device (it may have been disconnected)
Can't release interface: No such device (it may have been disconnected)
Can't find/open hmcfgusb!
HM-CFG-USB opened.
Flashing 368 blocks: |
Firmware update successfull!
der Stick meldet sich mit:
./hmland -i
HHM-USB-IF,03C7,LEQ1198360,308749,424242,00009A69,0000,00
bin etwas verwirrt, wegen des dauernden ab- und anmelden des Sticks ....
schöne Grüße,
Friedhelm
Sunny
Moin Friedhelm,
hatte bis vor kurzem auch den HM-CFG-USB-2genutzt (ca. 6 Monate), und hatte keine Probleme.
Ich war nach HomeMatic USB Konfigurations-Adapter (HM-CFG-USB) in Fhem nutzen
vorgegangen.
Hast Du ein aktuelles FHEM ? ( Bekannte_Probleme )
Zitatroot@storage:/opt/hmcfgusb# ./flash-hmcfgusb hmusbif.03c7.enc
HM-CFG-USB opened.
Bin zwar kein Linux Experte, aber das markierte hätte mich zumindest irritiert...
Bist Du Dir sicher das der "Flashvorgang" so OK ist ?
Hatte über Win, das Update von Homematic durchgeführt.
Sunny
FHEM 6.0 (RPi's 1b-4,CeleronM,Odroid C1+)
1-Wire (DS18B20,DS2406) |miniCUL|miniCUL868WLAN|HM|IT(-1500,LR-3500) |FB6591,FB7490,FB7580|DECT200|Powerline546E|520E|openwrt
Anfänger: Linux,FHEM+Perl
DerBodo
An welcher Hardware betreibst du den USB Stick ?
Wenn Raspberry dann versuch doch mal ein aktives USB HUB (mit eigener Spannungsversorgung) dazwischenzustecken.
Weiß nicht mehr genau wo ich hier drübergestolpert bin, allerdings gab es da mal Probleme wenn man bei CUL/HM-CFG-USB/WLAN direkt an die USB Ports gegangen ist.
Just a try....
macfly
danke für den Tipp mit dem Parameter I
Seitdem läuft der Stick ohne Probleme (seit gestern abend ohne abmeldung/anmeldung) ...
Ich werde dann mal weiterspielen!
frank
Zitatdanke für den Tipp mit dem Parameter I
den tip hast du aber schlecht umgesetzt. fhem updaten wäre doch viel sinnvoller.  ;)
FHEM: 6.0(SVN) => Pi3(buster)
Sunny
Moin Friedhelm,
freut mich, das Du "eine" Lösung gefunden hast.
Dann noch viel Spaß beim
Zitat von: macfly am 06 August 2015, 09:02:03
weiterspielen!
( Kreativ, scheinst Du ja zu sein.  :) )
Mit attr WEB menuEntries restart,cmd=shutdown+restart,update,cmd=update,updatecheck,cmd=update+check wärst Du nur noch ein Klick vom Update entfernt...
Sunny
