Problem zu "HM-LC-Sw1PBU-FM Alternative Firmware"
Begonnen von flipkill, 08 August 2015, 14:19:27
flipkill
folgende Meldungen kommen nun nach dem autocreate.
Zitat2015.08.11 13:42:37.892 4: CUL_Parse: CUL1 A 14 0E 805E 29F26F F11234 000000000000000100000000 -74
2015.08.11 13:42:39.346 1: PERL WARNING: Argument "ondemand" isn't numeric in addition (+) at ./FHEM/00_MAXLAN.pm line 799.
2015.08.11 13:42:50.012 0: HourCounter Gasverbrauch Run.598 first run done countsOverall:11
2015.08.11 13:42:51.416 4: CUL_Parse: CUL1 A 14 0F 805E 29F26F F11234 0000000000000001000000FE -75
2015.08.11 13:42:58.524 1: nothing to do...
2015.08.11 13:43:10.219 4: CUL_Parse: CUL1 A 14 10 805E 29F26F F11234 0000000000000001000000FE -75
2015.08.11 13:43:29.112 4: CUL_Parse: CUL1 A 14 11 805E 29F26F F11234 000000000000000100000001 -73.5
2015.08.11 13:43:41.522 4: CUL_send:  CUL1As 10 12 A001 F11234 29F26F 00040000000000
2015.08.11 13:43:41.621 4: CUL_Parse: CUL1 A 18 12 A010 29F26F F11234 02020105000AF10B120C3412000000FF -74.5
2015.08.11 13:43:41.722 4: CUL_send:  CUL1As 0A 12 8002 F11234 29F26F 00
2015.08.11 13:43:48.020 4: CUL_Parse: CUL1 A 14 12 805E 29F26F F11234 000000000000000300000000 -74
2015.08.11 13:44:06.820 4: CUL_Parse: CUL1 A 14 13 805E 29F26F F11234 000000000000000100000001 -73.5
2015.08.11 13:44:25.722 4: CUL_Parse: CUL1 A 14 14 805E 29F26F F11234 0000000000000001000000FF -74.5
2015.08.11 13:44:36.009 4: CUL_send:  CUL1As 10 15 A001 F11234 29F26F 00040000000000
2015.08.11 13:44:36.113 4: CUL_Parse: CUL1 A 18 15 A010 29F26F F11234 02020105000AF10B120C341200000000 -74
2015.08.11 13:44:36.214 4: CUL_send:  CUL1As 0A 15 8002 F11234 29F26F 00
2015.08.11 13:44:44.624 4: CUL_Parse: CUL1 A 14 15 805E 29F26F F11234 0000000000000003000000FF -74.5
2015.08.11 13:45:03.432 4: CUL_Parse: CUL1 A 14 16 805E 29F26F F11234 0000000000000001000000FF -74.5
2015.08.11 13:45:22.325 4: CUL_Parse: CUL1 A 14 17 805E 29F26F F11234 0000000000000001000000FF -74.5
2015.08.11 13:45:31.428 4: CUL_send:  CUL1As 10 18 A001 F11234 29F26F 00040000000000
2015.08.11 13:45:31.526 4: CUL_Parse: CUL1 A 18 18 A010 29F26F F11234 02020105000AF10B120C3412000000FE -75
2015.08.11 13:45:31.626 4: CUL_send:  CUL1As 0A 18 8002 F11234 29F26F 00
2015.08.11 13:45:44.127 4: CUL_Parse: CUL1 A 14 18 805E 29F26F F11234 0000000000000003000000FF -74.5
2015.08.11 13:46:00.127 4: CUL_Parse: CUL1 A 14 19 805E 29F26F F11234 0000000000000001000000FF -74.5
2015.08.11 13:46:18.929 4: CUL_Parse: CUL1 A 14 1A 805E 29F26F F11234 000000000000000100000000 -74
2015.08.11 13:46:37.829 4: CUL_Parse: CUL1 A 14 1B 805E 29F26F F11234 0000000000000001000000FF -74.5
2015.08.11 13:46:56.729 4: CUL_Parse: CUL1 A 14 1C 805E 29F26F F11234 0000000000000001000000FF -74.5
2015.08.11 13:47:15.632 4: CUL_Parse: CUL1 A 14 1D 805E 29F26F F11234 000000000000000100000000 -74
2015.08.11 13:47:34.432 4: CUL_Parse: CUL1 A 14 1E 805E 29F26F F11234 000000000000000100000000 -74
2015.08.11 13:47:53.333 4: CUL_Parse: CUL1 A 14 1F 805E 29F26F F11234 000000000000000100000000 -74
2015.08.11 13:48:12.234 4: CUL_Parse: CUL1 A 14 20 805E 29F26F F11234 0000000000000001000000FF -74.5
2015.08.11 13:48:31.043 4: CUL_Parse: CUL1 A 14 21 805E 29F26F F11234 0000000000000001000000FD -75.5
Habe dann auch das gemacht:
Zitatset HM_29F26F regSet pairCentral F11234
set HM_29F26F getConfig
set <HM-LC-SW1PBU-FM_Btn_01 peerChan 0 <HM-LC-SW1PBU-FM_Sw_01 dual set
Aber erhat bis jetzt immer noch nocht mehr gezogen als das hier:
ZitatCUL1_MSGCNT
223
CUL1_RAWMSG
A14E9805E29F26FF112340000000000000001000000::-72.5:CUL1
CUL1_RSSI
-72.5
CUL1_TIME
2015-08-11 14:51:25
DEF
29F26F
IODev
CUL1
LASTInputDev
CUL1
MSGCNT
223
NAME
HM_29F26F
NR
164
NTFY_ORDER
50-HM_29F26F
STATE
TYPE
CUL_HM
lastMsg
No:E9 - t:5E s:29F26F d:F11234 0000000000000001000000
protLastRcv
2015-08-11 14:51:25
protSnd
6 last_at:2015-08-11 13:45:31
protState
CMDs_done
rssi_at_CUL1
max:-71.5 avg:-73.68 lst:-72.5 cnt:223 min:-77.5
Readings
PairedTo
0xF11234
2015-08-11 13:45:31
R-pairCentral
0xF11234
2015-08-11 13:43:41
RegL_00:
02:01 05:00 0A:F1 0B:12 0C:34 12:00 00:00
2015-08-11 13:45:31
Mach ich noch was falsch? :)
frank
tippe doch mal in die befehlszeile und poste. am besten mit code-tags.
list HM_29F26F
FHEM: 6.0(SVN) => Pi3(buster)
flipkill
Hier das Ergebniss von
Zitatlist HM_29F26F
   CUL1_MSGCNT 289
   CUL1_RAWMSG A142B805E29F26FF112340000000000000001000000::-80.5:CUL1
   CUL1_RSSI  -80.5
   CUL1_TIME  2015-08-11 15:12:11
   DEF        29F26F
   IODev      CUL1
   LASTInputDev CUL1
   MSGCNT     289
   NAME       HM_29F26F
   NR         164
   NTFY_ORDER 50-HM_29F26F
   STATE      ???
   TYPE       CUL_HM
   lastMsg    No:2B - t:5E s:29F26F d:F11234 0000000000000001000000
   protLastRcv 2015-08-11 15:12:11
   protSnd    6 last_at:2015-08-11 13:45:31
   protState  CMDs_done
   rssi_at_CUL1 max:-71.5 avg:-74.61 lst:-80.5 cnt:289 min:-81.5
   CHANGETIME:
   Helper:
     Dblog:
       R-paircentral:
         Mydblog:
           TIME       1439293421.73528
           VALUE      0xF11234
   Readings:
     2015-08-11 13:45:31   PairedTo        0xF11234
     2015-08-11 13:43:41   R-pairCentral   0xF11234
     2015-08-11 13:45:31   RegL_00:          02:01 05:00 0A:F1 0B:12 0C:34 12:00 00:00
   Helper:
     HM_CMDNR   43
     PONtest    1
     cSnd       01F1123429F26F00040000000000,01F1123429F26F00040000000000
     Io:
       newChn     +29F26F,00,00,00
       nextSend   1439298731.51906
       prefIO
       rxt        0
       vccu
       p:
         29F26F
         00
         00
         00
     Mrssi:
       mNo        2B
       Io:
         CUL1       -78.5
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
       At_cul1:
         avg        -74.6193771626298
         cnt        289
         lst        -80.5
         max        -71.5
         min        -81.5
     Shadowreg:
   IODev      CUL1
   autoReadReg 4_reqStatus
   expert     2_full
   room       CUL_HM
LuckyDay
flipkill
#19
habe ich nun gemacht mit
Zitatattr HM_29F26F model HM-LC-Sw1PBU-FM
Nun sieht ein List so aus
   CUL1_MSGCNT 405
   CUL1_RAWMSG A149C805E29F26FF112340000000000000001000000::-75:CUL1
   CUL1_RSSI  -75
   CUL1_TIME  2015-08-11 15:47:44
   DEF        29F26F
   IODev      CUL1
   LASTInputDev CUL1
   MSGCNT     405
   NAME       HM_29F26F
   NR         164
   STATE      ???
   TYPE       CUL_HM
   lastMsg    No:9C - t:5E s:29F26F d:F11234 0000000000000001000000
   protLastRcv 2015-08-11 15:47:44
   protSnd    12 last_at:2015-08-11 15:45:37
   protState  CMDs_done
   rssi_at_CUL1 max:-71.5 avg:-75.09 lst:-75 cnt:405 min:-82
   CHANGETIME:
   Helper:
     Dblog:
       R-paircentral:
         Mydblog:
           VALUE      0xF11234
   Readings:
     2015-08-11 15:45:36   PairedTo        0xF11234
     2015-08-11 15:45:35   RegL_00:          02:01 05:00 0A:F1 0B:12 0C:34 12:00 00:00
     2015-08-11 15:45:36   RegL_01:          04:00 08:00 09:00 00:00
   Helper:
     HM_CMDNR   156
     PONtest    1
     cSnd       01F1123429F26F01040000000001,01F1123429F26F0103
     mId        0069
     peerIDsRaw ,00000000
     rxType     1
     Io:
       nextSend   1439300864.25581
       prefIO
       rxt        0
       vccu
       p:
         29F26F
         00
         00
         00
     Mrssi:
       mNo        9C
       Io:
         CUL1       -73
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
       At_cul1:
         avg        -75.0901234567901
         cnt        405
         lst        -75
         max        -71.5
         min        -82
     Shadowreg:
   IODev      CUL1
   expert     2_full
   peerIDs    00000000,
   room       CUL_HM
frank
Zitatfolgende Meldungen kommen nun nach dem autocreate.
da ist aber keine anlernmessage enthalten.
da fehlt einiges in deinem schalter, weil keine anlernmessage kommt. 5s taster drücken, loslassen. beim loslassen darf die led nicht leuchten, sonst war es kein langer tastendruck. und immer schön loggen.
ZitatHallo fhem-hm-knecht, Vielen dank wie und wo muss ich das noch nachtragen?
gar nicht!!!!!!!!! entweder es kommt automatisch, oder nicht.
flipkill
habe jetzt noch das im LOG gefunden da ist doch auch noch was komisch oder?
Zitat2015.08.11 15:55:03.449 1: Including fhem.cfg
2015.08.11 15:55:03.469 1: reload: Error:Modul 99_Asksin_HM_LC_Sw1PBU_FM_CustomFW deactivated:
Can't locate Switch.pm in @INC (you may need to install the Switch module) (@INC contains: /etc/perl /usr/local/lib/perl/5.18.2 /usr/local/share/perl/5.18.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.18 /usr/share/perl/5.18 /usr/local/lib/site_perl . ./FHEM) at ./FHEM/99_Asksin_HM_LC_Sw1PBU_FM_CustomFW.pm line 6, <$fh> line 5.
BEGIN failed--compilation aborted at ./FHEM/99_Asksin_HM_LC_Sw1PBU_FM_CustomFW.pm line 6, <$fh> line 5.
frank
Zitathabe jetzt noch das im LOG gefunden da ist doch auch noch was komisch oder?
na toll, das steht doch wohl schon häufiger drinnen.
ZitatCan't locate Switch.pm
such mal im forum. irgendwo habe ich schon was zum thema "switch.pm" gesehen.
flipkill
Zitatsudo apt-get install libswitch-perl
Sollte man vllt mal mit in das Wiki aufnehmen das das Modul "99_Asksin_HM_LC_Sw1PBU_FM_CustomFW.pm" das benötigt, werde heut abend nochmal ganz neu Pairen und dann schauen was passiert :)
Vielen Dank für Eure Hilfe vllt geht ja heut abend dann schon alles :)
frank
/perl/5.18.2
oder downgraden.
meine liebe kleine fritziboxi hat damit kein problem.  :)
v5.12.2
flipkill
Ich habe nun nochmal den Pairing Button am schalter für 5 Sekunden gedrückt es leuchtete auch keine LED am Schalter danach.
Das hab ich nun im Log
Zitat2015.08.11 18:43:15.368 1: readingsUpdate(,current,3) missed to call readingsBeginUpdate first.
2015.08.11 18:43:36.170 4: CUL_Parse: CUL1 A 14 D4 805E 29F26F F11234 0000000000000001000000FA -77
2015.08.11 18:43:36.170 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:43:53.168 4: CUL_Parse: CUL1 A 14 D5 805E 29F26F F11234 0000000000000001000000FA -77
2015.08.11 18:43:53.170 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:44:11.977 4: CUL_Parse: CUL1 A 14 D6 805E 29F26F F11234 0000000000000001000000FA -77
2015.08.11 18:44:11.978 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:44:30.869 4: CUL_Parse: CUL1 A 14 D7 805E 29F26F F11234 0000000000000001000000FB -76.5
2015.08.11 18:44:30.870 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:44:49.770 4: CUL_Parse: CUL1 A 14 D8 805E 29F26F F11234 0000000000000001000000FB -76.5
2015.08.11 18:44:49.771 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:45:08.686 4: CUL_Parse: CUL1 A 14 D9 805E 29F26F F11234 0000000000000001000000FB -76.5
2015.08.11 18:45:08.688 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:45:27.587 4: CUL_Parse: CUL1 A 14 DA 805E 29F26F F11234 0000000000000001000000FC -76
2015.08.11 18:45:27.589 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:45:46.373 4: CUL_Parse: CUL1 A 14 DB 805E 29F26F F11234 0000000000000001000000F9 -77.5
2015.08.11 18:45:46.374 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:46:05.274 4: CUL_Parse: CUL1 A 14 DC 805E 29F26F F11234 0000000000000001000000FC -76
2015.08.11 18:46:05.275 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
2015.08.11 18:46:24.094 4: CUL_Parse: CUL1 A 14 DD 805E 29F26F F11234 0000000000000001000000FA -77
2015.08.11 18:46:24.095 1: readingsUpdate(,current,1) missed to call readingsBeginUpdate first.
Und das wenn ich "list HM_29F26F" aufrufe
   BNO        54
   BNOCNT     1
   CUL1_MSGCNT 530
   CUL1_RAWMSG A14E9805E29F26FF112340000000000000001000000::-77:CUL1
   CUL1_RSSI  -77
   CUL1_TIME  2015-08-11 18:50:10
   DEF        29F26F
   IODev      CUL1
   LASTInputDev CUL1
   MSGCNT     530
   NAME       HM_29F26F
   NR         164
   STATE      ???
   TYPE       CUL_HM
   lastMsg    No:E9 - t:5E s:29F26F d:F11234 0000000000000001000000
   protLastRcv 2015-08-11 18:50:10
   protSnd    27 last_at:2015-08-11 18:48:15
   protState  CMDs_done
   rssi_at_CUL1 max:-72 min:-82 lst:-77 cnt:530 avg:-75.76
   CHANGETIME:
   Helper:
     Dblog:
       D-firmware:
         Mydblog:
           TIME       1439311376.6995
           VALUE      1.5
       D-serialnr:
         Mydblog:
           VALUE      PS00000002
       Trigdst_f11234:
         Mydblog:
           TIME       1439311349.27791
           VALUE      noConfig
       Trigger:
         Mydblog:
           VALUE      Long_54
       Trigger_cnt:
         Mydblog:
           VALUE      54
   Readings:
     2015-08-11 18:42:56   D-firmware      1.5
     2015-08-11 18:42:56   D-serialNr      PS00000002
     2015-08-11 18:48:13   PairedTo        0xF11234
     2015-08-11 18:48:13   RegL_00:          02:01 05:00 0A:F1 0B:12 0C:34 12:00 00:00
     2015-08-11 18:48:14   RegL_01:          04:00 08:00 09:00 00:00
     2015-08-11 18:42:29   trigDst_F11234  noConfig
     2015-08-11 18:42:29   trigger         Long_54
     2015-08-11 18:42:29   trigger_cnt     54
   Helper:
     HM_CMDNR   233
     PONtest    1
     mId        0069
     rxType     1
     Io:
       nextSend   1439311810.69711
       prefIO
       rxt        0
       vccu
       p:
         29F26F
         00
         00
         00
     Mrssi:
       mNo        E9
       Io:
         CUL1       -75
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       chn        1
       dev        1
     Rssi:
       At_cul1:
         avg        -75.766037735849
         cnt        530
         lst        -77
         max        -72
         min        -82
     Shadowreg:
   IODev      CUL1
   expert     2_full
   firmware   1.5
   model      HM-LC-Sw1PBU-FM-CustomFW
   peerIDs    00000000,
   room       CUL_HM
   serialNr   PS00000002
   subType    remoteAndSwitch
frank
ZitatIch habe nun nochmal den Pairing Button am schalter für 5 Sekunden gedrückt es leuchtete auch keine LED am Schalter danach.
ist zwar nicht im log vorhanden, aber die anlernmessage muss wohl davor gewesen sein. jedenfalls sieht es nun schon halbwegs gut aus. es fehlen aber noch die 4 channel.
es hört sich so an, als ob du nur den taster am schalter gedrückt hättest, ohne hmpairforsec am cul. mach das nochmal. also noch mal richtig drüberpairen. dann werden vielleicht auch endlich die channel angelegt.
flipkill
Hmm :(  set CUL1 hmPairForSec 600 hatte ich schon gehabt.
Ich Pair nochmal neu.
Grus Jan
flipkill
So ich habe nochmal neu gepaired und tada :)
Nochmal Danke an alle jetzt muss ich dann noch das machen oder? dann sollter der Schalter gehen?
Zitatset HM_29F26F_Btn_01 peerChan 0 HM_29F26F_Sw_01 dual set
   CFGFN
   CUL1_MSGCNT 62
   CUL1_RAWMSG A14B4805E29F26FF112340000000000000011000000::-76:CUL1
   CUL1_RSSI  -76
   CUL1_TIME  2015-08-11 19:53:24
   DEF        29F26F
   IODev      CUL1
   LASTInputDev CUL1
   MSGCNT     62
   NAME       HM_29F26F
   NR         160
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 HM_29F26F_Btn_01
   channel_02 HM_29F26F_Btn_02
   channel_03 HM_29F26F_Sw_01
   channel_04 HM_29F26F_Sw_02
   lastMsg    No:B4 - t:5E s:29F26F d:F11234 0000000000000011000000
   protLastRcv 2015-08-11 19:53:24
   protSnd    39 last_at:2015-08-11 19:53:22
   protState  CMDs_done
   rssi_at_CUL1 avg:-76.25 cnt:62 lst:-76 max:-75 min:-77
   CHANGETIME:
   Helper:
     Dblog:
       D-firmware:
         Mydblog:
           TIME       1439314846.4228
           VALUE      1.5
       D-serialnr:
         Mydblog:
           VALUE      PS00000002
       R-paircentral:
         Mydblog:
           TIME       1439315023.79031
           VALUE      0xF11234
       State:
         Mydblog:
           TIME       1439315602.5153
           VALUE      CMDs_done
   Readings:
     2015-08-11 19:40:46   D-firmware      1.5
     2015-08-11 19:40:46   D-serialNr      PS00000002
     2015-08-11 19:53:16   PairedTo        0xF11234
     2015-08-11 19:43:43   R-pairCentral   0xF11234
     2015-08-11 19:53:16   RegL_00:          02:01 05:00 0A:F1 0B:12 0C:34 12:00 00:00
     2015-08-11 19:53:22   state           CMDs_done
   Helper:
     HM_CMDNR   180
     cSnd       01F1123429F26F04040000000001,01F1123429F26F0403
     mId        F0A9
     rxType     1
     Io:
       nextSend   1439315604.41102
       prefIO
       rxt        0
       vccu
       p:
         29F26F
         00
         00
         00
     Mrssi:
       mNo        B4
       Io:
         CUL1       -74
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat   03,04
     Role:
       dev        1
     Rssi:
       At_cul1:
         avg        -76.25
         cnt        62
         lst        -76
         max        -75
         min        -77
     Shadowreg:
   IODev      CUL1
   expert     2_full
   firmware   1.5
   room       CUL_HM
   serialNr   PS00000002
   webCmd     getConfig:clear msgEvents
flipkill
Ich kann den Schalter nun mit einem Druck nach oben anschalten aber ich bekomme ihn nicht mehr aus.
Das Problem ist das ich mit dem Schalter ein Relais schalte das dann im Flur das Licht anmacht also als Treppenautomat. Wie kann ich das hier schalten das er wenn man nochmal drückt wieder ausschaltet.
IN FHEM wird auch noch nicht erkannt das ich das Licht z.B. von einem anderen Schalter aus angeschaltet hab.
Wie kann ich das noch anpassen?
Gruß Jan
