(gelöst) TEK603 liefert keine verlässlichen Daten, bzw. wie lege ich Plots an
Begonnen von Burny4600, 07 Oktober 2015, 12:30:01
Burny4600
Ich bin schon am Verzweifeln.
Kriege nur sporadisch Daten aus dem Logger TEK603 (Proteus).
Schnittstelle ist die richtige und die Definition wie angegeben müsste auch richtig sein.
Schnittstellendefinition ist: define TEK603 TEK603 /dev/ttyUSB0
Zitatpi@ccs-ht-rasp ~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.10-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #820 SMP PREEMPT Sun Oct 4 16:26:51 BST 2015
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[    0.000000] cma: Reserved 8 MiB at 0x3a800000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 8085afc0, node_mem_map b9fa6000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 13 pages/cpu @b9f64000 s20608 r8192 d24448 u53248
[    0.000000] pcpu-alloc: s20608 r8192 d24448 u53248 alloc=13*4096
    0
    1
    2
    3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x19142f2d smsc95xx.macaddr=B8:27:EB:14:2F:2D bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 cgroup_enable=memory elevator=deadline fsck.repair=yes rootwait
[    0.000000] Enabling memory control group subsystem
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939512K/966656K available (5958K kernel code, 534K rwdata, 1648K rodata, 416K init, 757K bss, 18952K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff000000   (1080 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x80775d0c   (7608 kB)
      .init : 0x80776000 - 0x807de000   ( 416 kB)
      .data : 0x807de000 - 0x80863b34   ( 535 kB)
       .bss : 0x80866000 - 0x8092378c   ( 758 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:608
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000032] Switching to timer-based delay loop, resolution 52ns
[    0.000316] Console: colour dummy device 80x30
[    0.002223] console [tty1] enabled
[    0.002293] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.002393] pid_max: default: 32768 minimum: 301
[    0.002758] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002828] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.004157] Initializing cgroup subsys blkio
[    0.004244] Initializing cgroup subsys memory
[    0.004347] Initializing cgroup subsys devices
[    0.004411] Initializing cgroup subsys freezer
[    0.004485] Initializing cgroup subsys net_cls
[    0.004596] CPU: Testing write buffer coherency: ok
[    0.004717] ftrace: allocating 20208 entries in 60 pages
[    0.054318] CPU0: update cpu_capacity 1024
[    0.054403] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.054449] [bcm2709_smp_prepare_cpus] enter
[    0.054615] Setting up static identity map for 0x8240 - 0x8274
[    0.114172] [bcm2709_boot_secondary] cpu:1 started (0) 17
[    0.114609] [bcm2709_secondary_init] enter cpu:1
[    0.114663] CPU1: update cpu_capacity 1024
[    0.114671] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.134154] [bcm2709_boot_secondary] cpu:2 started (0) 18
[    0.134514] [bcm2709_secondary_init] enter cpu:2
[    0.134545] CPU2: update cpu_capacity 1024
[    0.134554] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.154199] [bcm2709_boot_secondary] cpu:3 started (0) 17
[    0.154456] [bcm2709_secondary_init] enter cpu:3
[    0.154485] CPU3: update cpu_capacity 1024
[    0.154493] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.154585] Brought up 4 CPUs
[    0.154721] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.154763] CPU: All CPU(s) started in HYP mode.
[    0.154798] CPU: Virtualization extensions available.
[    0.155830] devtmpfs: initialized
[    0.180179] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.180575] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.181739] pinctrl core: initialized pinctrl subsystem
[    0.182577] NET: Registered protocol family 16
[    0.188412] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.189706] bcm2709.uart_clock = 3000000
[    0.195025] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.195097] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.195317] Serial: AMBA PL011 UART driver
[    0.195534] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[    0.708716] console [ttyAMA0] enabled
[    0.712981] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.786750] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[    0.795508] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[    0.803932] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[    0.810859] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[    0.816841] SCSI subsystem initialized
[    0.820883] usbcore: registered new interface driver usbfs
[    0.826498] usbcore: registered new interface driver hub
[    0.831988] usbcore: registered new device driver usb
[    0.837763] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-10-04 17:39
[    0.873380] Switched to clocksource arch_sys_counter
[    0.927993] FS-Cache: Loaded
[    0.931276] CacheFiles: Loaded
[    0.946139] NET: Registered protocol family 2
[    0.951837] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.959105] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.965821] TCP: Hash tables configured (established 8192 bind 8192)
[    0.972315] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.978346] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.985111] NET: Registered protocol family 1
[    0.989930] RPC: Registered named UNIX socket transport module.
[    0.995949] RPC: Registered udp transport module.
[    1.000679] RPC: Registered tcp transport module.
[    1.005437] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.013171] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.022794] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    1.045024] VFS: Disk quotas dquot_6.6.0
[    1.049356] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.058965] FS-Cache: Netfs 'nfs' registered for caching
[    1.065489] NFS: Registering the id_resolver key type
[    1.070623] Key type id_resolver registered
[    1.074862] Key type id_legacy registered
[    1.081728] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    1.089407] io scheduler noop registered
[    1.093394] io scheduler deadline registered (default)
[    1.098872] io scheduler cfq registered
[    1.105363] BCM2708FB: allocated DMA memory fac00000
[    1.110392] BCM2708FB: allocated DMA channel 0 @ f3007000
[    1.121425] Console: switching to colour frame buffer device 82x26
[    1.132908] Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[    1.142244] vc-cma: Videocore CMA driver
[    1.147887] vc-cma: vc_cma_base      = 0x00000000
[    1.154286] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.161300] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.168493] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.195723] brd: module loaded
[    1.209352] loop: module loaded
[    1.215052] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[    1.225392] Loading iSCSI transport class v2.0-870.
[    1.232779] usbcore: registered new interface driver smsc95xx
[    1.240222] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.447882] Core Release: 2.80a
[    1.452486] Setting default values for core params
[    1.458827] Finished setting default values for core params
[    1.666333] Using Buffer DMA mode
[    1.671156] Periodic Transfer Interrupt Enhancement - disabled
[    1.678564] Multiprocessor Interrupt Enhancement - disabled
[    1.685747] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.691664] Dedicated Tx FIFOs mode
[    1.697016] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[    1.710058] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[    1.733277] dwc_otg: Microframe scheduler enabled
[    1.733358] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8040147c
[    1.740903] WARN::hcd_init_fiq:413: FIQ ASM at 0x804017d8 length 36
[    1.748805] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89a000
[    1.756435] dwc_otg 3f980000.usb: DWC OTG Controller
[    1.763026] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    1.771993] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[    1.779199] Init: Port Power? op_state=1
[    1.784681] Init: Power Port (0)
[    1.789712] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.798113] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.806932] usb usb1: Product: DWC OTG Controller
[    1.813177] usb usb1: Manufacturer: Linux 4.1.10-v7+ dwc_otg_hcd
[    1.820758] usb usb1: SerialNumber: 3f980000.usb
[    1.827799] hub 1-0:1.0: USB hub found
[    1.833121] hub 1-0:1.0: 1 port detected
[    1.839089] dwc_otg: FIQ enabled
[    1.839103] dwc_otg: NAK holdoff enabled
[    1.839115] dwc_otg: FIQ split-transaction FSM enabled
[    1.839154] Module dwc_common_port init
[    1.839555] usbcore: registered new interface driver usb-storage
[    1.847353] mousedev: PS/2 mouse device common for all mice
[    1.855311] bcm2835-cpufreq: min=600000 max=900000
[    1.861957] sdhci: Secure Digital Host Controller Interface driver
[    1.869692] sdhci: Copyright(c) Pierre Ossman
[    1.876045] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    1.883457] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[    1.923783] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.933773] ledtrig-cpu: registered to indicate activity on CPUs
[    1.941575] hidraw: raw HID events driver (C) Jiri Kosina
[    1.948806] usbcore: registered new interface driver usbhid
[    1.955965] usbhid: USB HID core driver
[    1.961652] Initializing XFRM netlink socket
[    1.967531] NET: Registered protocol family 17
[    1.973694] Key type dns_resolver registered
[    1.979986] Registering SWP/SWPB emulation handler
[    1.987189] registered taskstats version 1
[    1.992037] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.995290] mmc0: new high speed SDHC card at address 0002
[    1.995935] mmcblk0: mmc0:0002 SD16G 14.9 GiB
[    2.006359]  mmcblk0: p1 p2
[    2.021679] vc-sm: Videocore shared memory driver
[    2.028005] [vc_sm_connected_init]: start
[    2.033722] Indeed it is in host mode hprt0 = 00021501
[    2.044153] [vc_sm_connected_init]: end - returning 0
[    2.055440] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    2.064484] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    2.213433] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.221743] Indeed it is in host mode hprt0 = 00001101
[    2.423791] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.432211] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.442262] hub 1-1:1.0: USB hub found
[    2.448004] hub 1-1:1.0: 5 ports detected
[    2.733434] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.751825] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    2.759968] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[    2.766988] EXT4-fs (mmcblk0p2): recovery complete
[    2.810689] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.822076] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.832653] devtmpfs: mounted
[    2.838079] Freeing unused kernel memory: 416K (80776000 - 807de000)
[    2.853807] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.862651] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.874847] smsc95xx v1.0.4
[    2.937981] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:14:2f:2d
[    3.033503] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[    3.162516] usb 1-1.3: New USB device found, idVendor=10c4, idProduct=ea60
[    3.171357] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.180903] usb 1-1.3: Product: CP2102 USB to UART Bridge Controller
[    3.189455] usb 1-1.3: Manufacturer: Silicon Labs
[    3.196482] usb 1-1.3: SerialNumber: 0001
[    3.274324] random: systemd urandom read with 86 bits of entropy available
[    3.284226] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[    3.288554] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    3.289095] systemd[1]: Detected architecture 'arm'.
[    3.438308] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6001
[    3.447210] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.456528] usb 1-1.4: Product: RFXtrx433
[    3.462459] usb 1-1.4: Manufacturer: RFXCOM
[    3.468503] usb 1-1.4: SerialNumber: A1YUXLCQ
[    3.471527] NET: Registered protocol family 10
[    3.482091] systemd[1]: Inserted module 'ipv6'
[    3.501461] systemd[1]: Set hostname to <ccs-ht-rasp>.
[    3.583511] usb 1-1.5: new high-speed USB device number 6 using dwc_otg
[    3.601215] uart-pl011 3f201000.uart: no DMA platform data
[    3.694930] usb 1-1.5: New USB device found, idVendor=05e3, idProduct=0606
[    3.703617] usb 1-1.5: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.712669] usb 1-1.5: Product: USB2.0 Hub
[    3.719632] hub 1-1.5:1.0: USB hub found
[    3.725605] hub 1-1.5:1.0: 4 ports detected
[    4.003458] usb 1-1.5.1: new full-speed USB device number 7 using dwc_otg
[    4.383798] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.395215] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.406275] systemd[1]: Expecting device dev-ttyAMA0.device...
[    4.416297] systemd[1]: Starting Remote File Systems (Pre).
[    4.425941] systemd[1]: Reached target Remote File Systems (Pre).
[    4.434236] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.449814] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.463303] systemd[1]: Starting Encrypted Volumes.
[    4.472700] systemd[1]: Reached target Encrypted Volumes.
[    4.480225] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    4.488341] usb 1-1.5.1: New USB device found, idVendor=0403, idProduct=6001
[    4.497521] usb 1-1.5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.509028] usb 1-1.5.1: Product: FT232R USB UART
[    4.509038] usb 1-1.5.1: Manufacturer: FTDI
[    4.509056] usb 1-1.5.1: SerialNumber: A98J3XX9
[    4.530460] systemd[1]: Expecting device dev-disk-by\x2duuid-14819217\x2d645a\x2d4c45\x2d951d\x2dadca9a21708f.device...
[    4.547349] systemd[1]: Expecting device dev-disk-by\x2duuid-f50683f8\x2dbfec\x2d4ae8\x2d86d3\x2dde62e059d965.device...
[    4.564434] systemd[1]: Starting Root Slice.
[    4.573051] systemd[1]: Created slice Root Slice.
[    4.579711] systemd[1]: Starting User and Session Slice.
[    4.589460] systemd[1]: Created slice User and Session Slice.
[    4.597172] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.608318] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.617328] systemd[1]: Starting Delayed Shutdown Socket.
[    4.627158] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.633451] usb 1-1.5.2: new full-speed USB device number 8 using dwc_otg
[    4.643749] systemd[1]: Starting Journal Socket (/dev/log).
[    4.654019] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.662027] systemd[1]: Starting udev Control Socket.
[    4.671508] systemd[1]: Listening on udev Control Socket.
[    4.678909] systemd[1]: Starting udev Kernel Socket.
[    4.688011] systemd[1]: Listening on udev Kernel Socket.
[    4.695265] systemd[1]: Starting Journal Socket.
[    4.704101] systemd[1]: Listening on Journal Socket.
[    4.711019] systemd[1]: Starting System Slice.
[    4.719695] systemd[1]: Created slice System Slice.
[    4.726492] systemd[1]: Starting File System Check on Root Device...
[    4.740313] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    4.751068] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    4.759326] systemd[1]: Starting system-autologin.slice.
[    4.769266] systemd[1]: Created slice system-autologin.slice.
[    4.776941] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.787173] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.795624] systemd[1]: Starting Increase datagram queue length...
[    4.798152] random: nonblocking pool is initialized
[    4.816433] systemd[1]: Starting Restore / save the current clock...
[    4.839786] systemd[1]: Mounting POSIX Message Queue File System...
[    4.854186] systemd[1]: Mounted Huge Pages File System.
[    4.862262] systemd[1]: Mounting Debug File System...
[    4.895075] systemd[1]: Started Set Up Additional Binary Formats.
[    4.953226] systemd[1]: Starting Load Kernel Modules...
[    4.967802] systemd[1]: Starting udev Coldplug all Devices...
[    4.984592] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    5.005311] systemd[1]: Starting Slices.
[    5.014469] systemd[1]: Reached target Slices.
[    5.028785] systemd[1]: Mounted Debug File System.
[    5.038885] systemd[1]: Mounted POSIX Message Queue File System.
[    5.051983] systemd[1]: Started Increase datagram queue length.
[    5.085715] fuse init (API version 7.23)
[    5.095800] systemd[1]: Started Restore / save the current clock.
[    5.110841] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    5.124574] usb 1-1.5.2: New USB device found, idVendor=0403, idProduct=6001
[    5.134246] usb 1-1.5.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.147143] usb 1-1.5.2: Product: FT232R USB UART
[    5.148820] systemd[1]: Time has been changed
[    5.160493] usb 1-1.5.2: Manufacturer: FTDI
[    5.167659] usb 1-1.5.2: SerialNumber: A9ULXRVF
[    5.206072] systemd[1]: Started File System Check on Root Device.
[    5.217514] i2c /dev entries driver
[    5.225537] systemd[1]: Started udev Coldplug all Devices.
[    5.238112] systemd[1]: Started Load Kernel Modules.
[    5.313473] usb 1-1.5.4: new high-speed USB device number 9 using dwc_otg
[    5.397769] systemd[1]: Starting Apply Kernel Variables...
[    5.412285] systemd[1]: Mounting Configuration File System...
[    5.426936] systemd[1]: Mounting FUSE Control File System...
[    5.436193] usb 1-1.5.4: New USB device found, idVendor=059b, idProduct=047a
[    5.436219] usb 1-1.5.4: New USB device strings: Mfr=10, Product=11, SerialNumber=5
[    5.436229] usb 1-1.5.4: Product: Iomega Select HDD
[    5.436240] usb 1-1.5.4: Manufacturer: Iomega
[    5.436249] usb 1-1.5.4: SerialNumber: 88A11FFFFFFF
[    5.466446] usb-storage 1-1.5.4:1.0: USB Mass Storage device detected
[    5.467424] scsi host0: usb-storage 1-1.5.4:1.0
[    5.472605] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.479511] systemd[1]: Starting Syslog Socket.
[    5.482879] systemd[1]: Listening on Syslog Socket.
[    5.483210] systemd[1]: Starting Journal Service...
[    5.493987] systemd[1]: Started Journal Service.
[    5.694843] systemd-udevd[113]: starting version 215
[    6.276249] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    6.397466] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.464402] scsi 0:0:0:0: Direct-Access     TOSHIBA  MK1252GSX             PQ: 0 ANSI: 2 CCS
[    6.466567] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[    6.467190] sd 0:0:0:0: [sda] Write Protect is off
[    6.467223] sd 0:0:0:0: [sda] Mode Sense: 34 00 00 00
[    6.467911] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    6.508842]  sda: sda1 sda2
[    6.512256] sd 0:0:0:0: [sda] Attached SCSI disk
[    6.646590] usbcore: registered new interface driver usbserial
[    6.647333] usbcore: registered new interface driver usbserial_generic
[    6.647493] usbserial: USB Serial support registered for generic
[    6.668240] usbcore: registered new interface driver cp210x
[    6.668396] usbserial: USB Serial support registered for cp210x
[    6.668555] cp210x 1-1.3:1.0: cp210x converter detected
[    6.669026] usb 1-1.3: cp210x converter now attached to ttyUSB0
[    6.677598] usbcore: registered new interface driver ftdi_sio
[    6.677791] usbserial: USB Serial support registered for FTDI USB Serial Device
[    6.678229] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
[    6.678448] usb 1-1.4: Detected FT232RL
[    6.679739] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB1
[    6.680018] ftdi_sio 1-1.5.1:1.0: FTDI USB Serial Device converter detected
[    6.680215] usb 1-1.5.1: Detected FT232RL
[    6.682780] usb 1-1.5.1: FTDI USB Serial Device converter now attached to ttyUSB2
[    6.683034] ftdi_sio 1-1.5.2:1.0: FTDI USB Serial Device converter detected
[    6.683273] usb 1-1.5.2: Detected FT232RL
[    6.693733] usb 1-1.5.2: FTDI USB Serial Device converter now attached to ttyUSB3
[    6.826097] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    6.837905] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    6.838220] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.619323] EXT4-fs (sda1): recovery complete
[    7.619365] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    8.369789] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[    8.372103] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    8.941347] EXT4-fs (sda2): recovery complete
[    8.941932] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    9.153631] systemd-journald[111]: Received request to flush runtime journal from PID 1
[    9.807728] cfg80211: Calling CRDA to update world regulatory domain
[   10.646076] Adding 204796k swap on /var/swap.  Priority:-1 extents:8 across:2047996k SSFS
[   12.963453] cfg80211: Calling CRDA to update world regulatory domain
[   13.230203] bcm2708_fb soc:fb: Unknown ioctl 0x40187a22
[   16.123531] cfg80211: Calling CRDA to update world regulatory domain
[   19.283517] cfg80211: Calling CRDA to update world regulatory domain
[   22.443524] cfg80211: Calling CRDA to update world regulatory domain
[   25.603472] cfg80211: Calling CRDA to update world regulatory domain
[   28.763473] cfg80211: Calling CRDA to update world regulatory domain
[   31.923475] cfg80211: Calling CRDA to update world regulatory domain
[   35.083549] cfg80211: Calling CRDA to update world regulatory domain
[   38.243520] cfg80211: Calling CRDA to update world regulatory domain
[   41.403542] cfg80211: Calling CRDA to update world regulatory domain
[   44.563500] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
[  167.528685] ftdi_sio ttyUSB3: usb_serial_generic_read_bulk_callback - urb stopped: -32
[  167.528773] ftdi_sio ttyUSB3: usb_serial_generic_read_bulk_callback - urb stopped: -32
[  167.690200] usb 1-1.5.2: USB disconnect, device number 8
[  167.690652] ftdi_sio ttyUSB3: error from flowcontrol urb
[  167.691123] ftdi_sio ttyUSB3: FTDI USB Serial Device converter now disconnected from ttyUSB3
[  167.691222] ftdi_sio 1-1.5.2:1.0: device disconnected
[  169.973790] usb 1-1.5.2: new full-speed USB device number 10 using dwc_otg
[  170.445585] usb 1-1.5.2: New USB device found, idVendor=0403, idProduct=6001
[  170.445630] usb 1-1.5.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  170.445648] usb 1-1.5.2: Product: FT232R USB UART
[  170.445664] usb 1-1.5.2: Manufacturer: FTDI
[  170.445681] usb 1-1.5.2: SerialNumber: A9ULXRVF
[  170.495111] ftdi_sio 1-1.5.2:1.0: FTDI USB Serial Device converter detected
[  170.495364] usb 1-1.5.2: Detected FT232RL
[  170.499250] usb 1-1.5.2: FTDI USB Serial Device converter now attached to ttyUSB3
pi@ccs-ht-rasp ~ $ sudo reboot
LG Chris
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
