(gelöst) TEK603 wie lege ich Plots an
Begonnen von Burny4600, 08 Oktober 2015, 15:40:14
Burny4600
Komme irgendwie nicht weiter mit der Anlegung der Plots für die Niveaumessung.
Folgende Konfiguration habe ich durchgeführt.
Zitat# Proteus
define TEK603 TEK603 /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
attr TEK603 alias Muehlbachniveau
attr TEK603 icon time_graph
attr TEK603 room _RxTx
define FileLog_TEK603_RUL FileLog /media/hdd/fhem/log/TEK603_RUL-%Y-%m.log TEK603:RemainingUsableLevel:.*|TEK603_RUL
attr FileLog_TEK603_RUL room _LOG
define SVG_FileLog_TEK603_RUL SVG FileLog_TEK603_RUL:SVG_FileLog_TEK603_RUL:CURRENT
attr SVG_FileLog_TEK603_RUL label "TEK603_RUL Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FileLog_TEK603_RUL room Wetterstation
define FileLog_TEK603_TEMP FileLog /media/hdd/fhem/log/TEK603_TEMP-%Y-%m.log TEK603:Temperature:.*|TEK603_TEMP
attr FileLog_TEK603_TEMP room _LOG
define SVG_FileLog_TEK603_TEMP SVG FileLog_TEK603_TEMP:SVG_FileLog_TEK603_TEMP:CURRENT
attr SVG_FileLog_TEK603_TEMP label "TEK603_TEMP Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FileLog_TEK603_TEMP room Wetterstation
define FileLog_TEK603_TUC FileLog /media/hdd/fhem/log/TEK603_TUC-%Y-%m.log TEK603:TotalUsableCapacity:.*|TEK603_TUC
attr FileLog_TEK603_TUC room _LOG
define SVG_FileLog_TEK603_TUC SVG FileLog_TEK603_TUC:SVG_FileLog_TEK603_TUC:CURRENT
attr SVG_FileLog_TEK603_TUC label "TEK603_TUC Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FileLog_TEK603_TUC room Wetterstation
define FileLog_TEK603_U FileLog /media/hdd/fhem/log/TEK603_U-%Y-%m.log TEK603:Ullage:.*|TEK603_U
attr FileLog_TEK603_U room _LOG
define SVG_FileLog_TEK603_U SVG FileLog_TEK603_U:SVG_FileLog_TEK603_U:CURRENT
attr SVG_FileLog_TEK603_U label "TEK603_U Min $data{min1}, Max $data{max1}, Last $data{currval1}"
attr SVG_FileLog_TEK603_U room Wetterstation
Was muß ich korrigieren damit ich die Daten in die Plots bekomme?
LG Chris
Raspberry Pi 2-5, Bullseye Lite, Bookworm Lite
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
Tommy82
Hast du die Frage nicht gestern oder vorgestern schon mal in einem anderen Thread gestellt?!
Und auch Antworten drauf bekommen!?
Allnetl Wandtablett mit FTUI
