FHEM Tablet Ui Widget für Rolladensteuerung
Begonnen von eburkon, 14 Oktober 2015, 21:36:01
Thorsten Pferdekaemper
Zitat von: Ban-ya am 17 Februar 2016, 17:24:26
Die Prozentauswahl sendet keinen Befehl ab  :'(
Sorry, bin noch am lernen mit der Syntax
Danke, für Deine Hilfe
Es kann sein, dass da auch noch "\" drin sind. Such mal danach und mach die alle raus.
   Thorsten
FUIP
Ban-ya
Danke, dass Du mir so unermüdlich hilfst.
Ich habe (leider) kein "\" mehr entdeckt.
hier mal mein kompletter Code:
<li data-row="4" data-col="4" data-sizex="4" data-sizey="3">
<header>TEST-CONTAINER</header>
<table>
<tr>
<td>
<div data-type="symbol" class="cell bigger left" data-device="Az.Rolladen" data-get="level"
    data-icons='["oa-fts_shutter_100","oa-fts_shutter_90","oa-fts_shutter_80","oa-fts_shutter_70",
"oa-fts_shutter_60","oa-fts_shutter_50","oa-fts_shutter_40","oa-fts_shutter_30",
"oa-fts_shutter_20","oa-fts_shutter_10","oa-fts_window_2w"]'
        data-get-on='["0","10","20","30","40","50","60","70","80","90","100"]' data-on-color="#2A2A2A"
data-on-background-color="#aa6900" data-background-icon="fa-square">
</div>
</td>
<td>
<div class="triplebox-v left" >
<div data-type="push" data-device="Az.Rolladen" data-icon="fa-chevron-up" data-background-icon="fa-square-o" data-set-on="on" class=""> </div>
<div data-type="push" data-device="Az.Rolladen" data-icon="fa-minus" data-background-icon="fa-square-o" data-set-on="stop" class=""> </div>
<div data-type="push" data-device="Az.Rolladen" data-icon="fa-chevron-down" data-background-icon="fa-square-o" data-set-on="off" class=""> </div>
</div>
</td>
<td>
          <div data-type="select" data-device="Az.Rolladen'" data-items='["0","10","20","30","40","50","60","70","80","90","100"]'
        data-alias='["Auf","10%","20%","30%","40%","50%","60%","70%","80%","90%","Zu"]' data-get="" data-set="" class="cell" ></div>
</td>
</tr>
<tr>
<td>
<div style="position:absolute; bottom:0; right:0;"
          data-type="wdtimer"
          data-style="round"
          data-theme="dark"
          data-title="Rollladen Arbeitszimmer"
          data-cmdlist='{"Auf":"0","Zu":"100","10%":"10","20%":"20","30%":"30","40%":"40","50%":"50","60%":"60","70%":"70","80%":"80","90%":"90"}'>
        <div data-type="button" class="cell small readonly" data-icon="oa-edit_settings" data-background-icon="fa-square-o"
        data-on-color="#505050" data-on-background-color="#505050">
</div>
        </div>
</td>
</tr>
</table>
Vielleicht kannst Du den Fehler entdecken?
Raspberry Pi2 B+, CC1101, FHEM 5.7, 7x HM-LC-Bl1PBU-FM, HM-Sec-SC-2 (opt), HM-Sec-SC-2 (reed), VU+ duo, VU+ solo2, IT-Dosen
vielleicht stört der Tick (') nach Az.Rolladen:
   Thorsten
FUIP
Ban-ya
Hallo Torsten, was so ein kleiner Tick ausmacht ...
Jetzt funzt es  :)
Danke, für Deine Mühe. Nun muss ich nur noch die Richtung umdrehen, weil wir ja umgekehrt die Motoren  angeklemmt haben  :)
Später kommt dann meine Frage zur Zeitsteuerung  ;)
Gute Nacht, für heute.
Gruß Uwe
kvo1
Hi Thorsten,
habe das mal mit einem dummy nachgebaut.
Funktioniert auch nur das Symbol ändert sich nicht. Wenn ich den symbolteil in einem anderen Beispiel ohne <table> verwende dann tut´s  :-[
@Ban-ya , ändert sich bei Dir das Symbol ?
ZitatSpäter kommt dann meine Frage zur Zeitsteuerung  ;)
jeppp , da würde mich auch interessieren  ;)
Zitat von: kvo1 am 17 Februar 2016, 23:35:23habe das mal mit einem dummy nachgebaut.
Ich mache das auch gerade mit Dummys. Es ist dabei wesentlich, dass man nicht state als Reading nimmt, sondern so etwas wie level. Gib Deinem Dummy mal ein User Reading:
userReadings
level { ReadingsVal("sz_Rollladen","state",0) }
...und nimm dann als data-get "level".
Zumindest war das bei mir das Problem mit dem Symbol.
   Thorsten
FUIP
Ban-ya
Jens_B
Zitat von: Thorsten Pferdekaemper am 17 Februar 2016, 17:34:30
Im Reading "level"? Das ist seltsam. Ist das ein Funk-Aktor oder Wired?
Homematic Funkaktor HM-LC-BL1PBU-FM
Jens
RaspberryPi 4 (Raspian Buster)FHEM+Homebridge
HMLAN für Homematic
Z-Wave USB Stick
Shelly Devices
Fritz!Box 7590Ax
kvo1
Hallo Jens / Thorsten,
@jens , ich habe die gleichen!
Richtig muss das dann aber so ausschauen..    Set deinrollo pct 70    Für 70% auf
100 ist bei mir ganz oben
Der Wert steht in drei Readings ... state, level und pct
Gruss
Jens_B
Gruss
Ja. Die Werte stehen ja auch in den readings, aber beim ausführen der Befehle steht kurzzeitig in den readings set_ vor dem Befehl .
Ich kann das hier ganz gut in der logdatei des jeweiligen aktors sehen.
Das steht dann :
ROLLLADEN_SZ_LINKS level: set_20
HMLAN für Homematic
Z-Wave USB Stick
Shelly Devices
Fritz!Box 7590Ax
Jens_B
#55
Ich hab es glaube ich: ich muss Data-Part= Für den Regex nehmen und nicht Substitution .
Nach meinem Verständnis müsste der Regex so aussehen: (^[set_]+)
Heißt für mich "nimm alles was nicht set_ ist"?
Wenn ich dann nicht Level sondern STATE prüfe habe ich sogar on/off als Anzeige :-)(oder auf/zu)
Jens
HMLAN für Homematic
Z-Wave USB Stick
Shelly Devices
Fritz!Box 7590Ax
Das steht dann :
mit HM-Wired wäre das nicht passiert. SCNR...
Vielleicht solltest Du das auch mal im HM-Bereich posten. Meiner Meinung nach ist das Verhalten nicht ganz so toll.
So etwas ist für state ja ok, aber die anderen Readings sollten schon die Werte passend zum Wertebereich haben.
   Thorsten
FUIP
kvo1
userReadings
   Thorsten
Hi Thorsten,
das war´s  ;)  , Danke !
kvo1
Ban-ya
ich habe auch diese: Homematic Funkaktor HM-LC-BL1PBU-FM
kvo1
#59
jetzt wäre halt die Einstellung an der Reihe ...
Meine Idee ist dabei, wenn man das "edit_settings"-ICON anklickt öffnet sich ein popup für die Einstellung der Betriebsart (hier habe ich
mir 3 Möglichkeiten eingebaut FHEM / ASTRO / HAND) und die Einstellung der verschiedenen Zeiten (Woche hoch) , (Wochenende hoch) , (runter),
das halt mit der timerfunktion (weekdaytimer).
Das mit der  Betriebsart würde ich so lösen ...
<div class="cell wider">
          <div data-type="label" class="inline wider">Rollo_AZ</div>
          <div data-type="select" data-device="RolloModTimeAZ" data-items='["FHEM","ASTRO","HAND"]' data-get="Modus" data-set="Modus" class="cell w2x" ></div>
</div>
oder so....
<div data-type="switch"
data-get="Modus"
        data-set="Modus"
data-set-states='["ASTRO","HAND","FHEM"]'
        data-states='["FHEM","ASTRO","HAND"]'
        data-icons='["oa-fts_shutter_automatic","oa-fts_shutter_down","oa-fts_shutter_manual"]'
        data-colors='["white","white","white"]'
        data-background-colors='["green","cornflowerblue","red"]'
       class="bigger top-space"></div>
