DOIF Rollosteuerung
Begonnen von skuggy, 22 Oktober 2015, 19:12:27
skuggy
ich bin dabei meine Rollosteuerung per DOIF zu steuern. Leider funktioniert nur ein Teil. Hier der Code und das List:
Code:
([du_Rollo_Art:state] eq "Normal" and ([[du_Rollo_Zeit_ho] |8] or [[du_Rollo_Zeit_ho_WE] |7])) (set test_rollo_hoch on, set test_rollo_hoch_we on)
DOELSEIF ([du_Rollo_Art:state] eq "Normal" and ([[du_Rollo_Zeit_ho_Schlaf] |8] or [[du_Rollo_Zeit_ho_WE_Schlaf] |7])) (set test_rollo_hoch_we_schlaf on, set test_rollo_hoch_schlaf on)
DOELSEIF ([du_Rollo_Art:state] eq "Normal" and [du_Sonnenuntergang]) (set test_rollo_ru off)
DOELSEIF ([du_Rollo_Art:state] eq "Normal" and [du_Rollo_Zeit_ru_Schlaf]) (set test_rollo_ru_schlaf off)
List:
   DEF        ([du_Rollo_Art:state] eq "Normal" and ([[du_Rollo_Zeit_ho] |8] or [[du_Rollo_Zeit_ho_WE] |7])) (set test_rollo_hoch on, set test_rollo_hoch_we on)
   NAME       Rollo_Settings
   NR         422
   NTFY_ORDER 50-Rollo_Automatik
   STATE      cmd_3
   TYPE       DOIF
   Readings:
     2015-10-22 03:05:00   Device          du_Sonnenuntergang
     2015-10-21 19:59:07   cmd_event       du_Rollo_Art
     2015-10-21 19:59:07   cmd_nr          3
     2015-10-21 20:42:32   e_du_Rollo_Art_state Normal
     2015-10-21 19:46:53   e_du_Rollo_Zeit_ru_Schlaf_STATE 19:48
     2015-10-22 03:05:00   e_du_Sonnenuntergang_STATE 18:51:04
     2015-10-21 19:59:07   state           cmd_3
     2015-10-21 19:38:04   timer_1_c1      22.10.2015 19:21:00|8
     2015-10-21 19:38:04   timer_2_c1      22.10.2015 19:24:00|7
     2015-10-21 19:38:04   timer_3_c2      22.10.2015 19:22:00|8
     2015-10-21 19:38:04   timer_4_c2      22.10.2015 19:23:00|7
   Condition:
     0          ReadingValDoIf('du_Rollo_Art','state','') eq "Normal" and (DOIF_time_once($hash,$hash->{timer}{0},$wday,"8") or DOIF_time_once($hash,$hash->{timer}{1},$wday,"7"))
     1          ReadingValDoIf('du_Rollo_Art','state','') eq "Normal" and (DOIF_time_once($hash,$hash->{timer}{2},$wday,"8") or DOIF_time_once($hash,$hash->{timer}{3},$wday,"7"))
     2          ReadingValDoIf('du_Rollo_Art','state','') eq "Normal" and InternalDoIf('du_Sonnenuntergang','STATE','')
     3          ReadingValDoIf('du_Rollo_Art','state','') eq "Normal" and InternalDoIf('du_Rollo_Zeit_ru_Schlaf','STATE','')
   Days:
     0          8
     1          7
     2          8
     3          7
   Devices:
     0           du_Rollo_Art
     1           du_Rollo_Art
     2           du_Rollo_Art du_Sonnenuntergang
     3           du_Rollo_Art du_Rollo_Zeit_ru_Schlaf
     all         du_Rollo_Art du_Sonnenuntergang du_Rollo_Zeit_ru_Schlaf
   Do:
     0:
       0          set test_rollo_hoch on, set test_rollo_hoch_we on
     1:
       0          set test_rollo_hoch_we_schlaf on, set test_rollo_hoch_schlaf on
     2:
       0          set test_rollo_ru off
     3:
       0          set test_rollo_ru_schlaf off
     4:
   Helper:
     globalinit 1
     last_timer 4
     sleeptimer -1
     2           du_Sonnenuntergang:STATE
     3           du_Rollo_Zeit_ru_Schlaf:STATE
     all         du_Sonnenuntergang:STATE du_Rollo_Zeit_ru_Schlaf:STATE
   Itimer:
     all         du_Rollo_Zeit_ho du_Rollo_Zeit_ho_WE du_Rollo_Zeit_ho_Schlaf du_Rollo_Zeit_ho_WE_Schlaf
   Readings:
     0           du_Rollo_Art:state
     1           du_Rollo_Art:state
     2           du_Rollo_Art:state
     3           du_Rollo_Art:state
     all         du_Rollo_Art:state
   Realtime:
     0          19:21:00
     1          19:24:00
     2          19:22:00
     3          19:23:00
   State:
   Time:
     0          [du_Rollo_Zeit_ho]
     1          [du_Rollo_Zeit_ho_WE]
     2          [du_Rollo_Zeit_ho_Schlaf]
     3          [du_Rollo_Zeit_ho_WE_Schlaf]
   Timecond:
     0          0
     1          0
     2          1
     3          1
   Timer:
     0          0
     1          0
     2          0
     3          0
   Timerfunc:
   Timers:
     0           0  1
     1           2  3
   Trigger:
Die Rollo on DOIF´s funktionieren aber die off´s nicht.
Vielen Dank für eure Hilfe.
...Gruß skuggy
FHEM 5.6 auf Raspberry Pi 2, HM-CFG-LAN, 8x HM-LC-Bl1PBU-FM, 5 x HM-CC-RT-DN, 1 x HM-LC-Sw1-Ba-PCB, 1 x HM-RC-4-2, 1 x JeeLink Clone, 10 x TX29DTH-IT, Fritzbox 7270
moonsorrox
#1
weil dein DOIF nicht weiß welchen Zustand die beiden dummys als "state" haben
da muss soetwas wie hin wie
[du_Sonnenuntergang] eq "Ein"
[du_Rollo_Zeit_ru_Schlaf] eq "Ein"
Ellert
Die Dummies in deiner Bedingung eine Zeit enthalten oder "", 0, 1.
skuggy
hier mal die List der beiden Dummy´s:
   NAME       du_Rollo_Zeit_ru_Schlaf
   NR         480
   STATE      19:48
   TYPE       dummy
   Readings:
     2015-10-21 19:46:53   state           19:48
   alias      Zeit runter Schlaf
   devStateIcon .*:rc_BLANK
   group      Rollo_Settings
   icon       icoUhr
   room       Dummy,Jalousien
   setList    state:time
   webCmd     state
   CFGFN
   NAME       du_Sonnenuntergang
   NR         1574
   STATE      18:51:04
   TYPE       dummy
   Readings:
     2015-10-22 03:05:00   state           18:51:04
   icon       weather_sunset
   room       Dummy,Umwelt_Aussen
Aber so wie es aussieht, ist ein State vorhanden. Oder was meint Ihr?
...Gruß skuggy
moonsorrox
   NR         480
   STATE      19:48
   TYPE       dummy
   Readings:
   icon       icoUhr
   setList    state:time
   webCmd     state
   CFGFN
   NR         1574
   STATE      18:51:04
   TYPE       dummy
   Readings:
   icon       weather_sunset
so wie Ellert dir geschrieben hat, hier hat state eine Zeit...!
ZitatDie Dummies in deiner Bedingung eine Zeit enthalten oder "", 0, 1.
skuggy
Jetzt steh ich total auf dem Schlauch. Die Dummy´s müssen doch Zeiten enthalten, damit die Rollo runterfahren. Die anderen Dummy´s enthalten ebenfalls Zeiten. Hab ich Klammern vergessen oder wo liegt der Unterschied?
...Gruß skuggy
Ellert
Deine Dummies wurden nach der Initialisierung des DOIF gesetzt, das funktioniert so nicht die benötigen eine doppelte eckige Klammer, wenn sie dynamische Inhalte haben sollen.
Sie könnten auch 0,"" für Falsch oder alles was nicht 0,"" ist für wahr enthalten.
Was drinstehen sollte ging aus Deiner Fragestellung nicht hervor.
skuggy
Sorry für die fehlerhafte/mangelte Erklärung. Jetzt hab ich es aber verstanden. Ich habe eine doppelte Klammer gesetzt und siehe da, es funktioniert!
Danke...
...Gruß skuggy
