Ende des Update-Prozesses an was zu erkennen?
Begonnen von walterschmitz, 26 Oktober 2015, 17:48:46
walterschmitz
ich habe soeben ein Update ausgeführt und seit längerem steht der Server jetzt mit der Anzeige wie folgt:
2015-10-26 17:44:33 Global global UPD www/images/default/remotecontrol/black_btn_VID2.png
2015-10-26 17:44:33 Global global UPD www/images/default/remotecontrol/black_btn_VID3.png
2015-10-26 17:44:33 Global global New entries in the CHANGED file:
2015-10-26 17:44:33 Global global - feature: contrib/98_openweathermap.pm - add support for stationByZip.
2015-10-26 17:44:33 Global global e.g. 76133,de will find weather data for Karlsruhe,Germany
2015-10-26 17:44:33 Global global - bugfix: 38_CO20: fixed error messages on timeout
2015-10-26 17:44:33 Global global - feature: codemirror modules now loaded by default: search.js, comment.js
2015-10-26 17:44:33 Global global dialog.js, autorefresh.js, searchcursor.js, dialog.css
2015-10-26 17:44:33 Global global codemirror search & replace is now activated by default.
2015-10-26 17:44:33 Global global to use this feature now you must only load in fhemweb
2015-10-26 17:44:33 Global global attribute 'JavaScripts' the codemirror/fhem_codemirror.js file
2015-10-26 17:44:33 Global global new extraKeys for 'TAB', 'Shift+Tab', 'STRG+Q', 'STRG+UP',
2015-10-26 17:44:33 Global global and 'STRG+DOWN' are added.
2015-10-26 17:44:33 Global global codemirror default parameters are now:
2015-10-26 17:44:33 Global global indentUnit:4, indentWithTabs:false, autoCloseBrackets:false,
2015-10-26 17:44:33 Global global matchBrackets:true, autofocus:true, theme:"blackboard",
2015-10-26 17:44:33 Global global lineNumbers:true, autoRefresh:true
2015-10-26 17:44:33 Global global this can be overwritten with fhemweb attribute 'codemirrorParam'
2015-10-26 17:44:33 Global global - updated: codemirror version to 5.8
2015-10-26 17:44:34 Global global the default codemirror javascript files are now minified
2015-10-26 17:44:34 Global global - feature: 70_XBMC: -added disable attribute
2015-10-26 17:44:34 Global global -added reading tvshowid
2015-10-26 17:44:34 Global global - feature: new module 00_SIGNALduino.pm and 90_SIGNALduino_un: added
2015-10-26 17:44:34 Global global SIGNALduino module and firmware
2015-10-26 17:44:34 Global global - feature: new module 14_Hideki.pm: added module for sensors with hideki
2015-10-26 17:44:34 Global global protocol
2015-10-26 17:44:34 Global global - feature: new module 14_SD_WS07.pm: added module for sensor devices with
2015-10-26 17:44:34 Global global protocol id7
2015-10-26 17:44:34 Global global Calling /usr/bin/perl ./contrib/commandref_join.pl, this may take a while
2015-10-26 17:45:12 Global global
Leider läuft aktuell auch nichts weiter... der FHEM an sich läuft aber irgendwie.
Früher war das Ende immer angezeigt mit einem empfohlenen Neustart. Gibt es das nicht mehr?
Tommy82
Das ist bei mir auch schon seit einiger Zeit so, bzw. meistens kommt irgendwann "Die Seite wurde nicht gefunden" wenn ich die Seite dann neu lade ist alles da und das Update durchgelaufen
Allnetl Wandtablett mit FTUI
Das Generieren der commandref kann durchaus mehrere Minuten dauern. Wenn Du die commandref in Deinem fhem gar nicht brauchst, kannst Du die lokale Generierung auch einfach komplett abschalten, indem Du die commandref in exclude_from_update einträgst.
walterschmitz
Aber...
das Generieren der CommandRef ist ja okay, aber dauert doch nicht wirklich über 30 min, oder?
Mir geht es eigentlich wirklich nur darum, ob ich irgendwann dem Update-Prozess den Prozess durch einen Reload kille und damit FHEM kaputt machen würde.
Trotzdem überlege ich mir mal, ob ich dann deinen Hinweis befolge... und die Commandref ausnehme!
Danke dir / Euch.
