get ... config... -> Timeout
Begonnen von toms01, 08 November 2015, 14:40:09
toms01
Hallo allerseits,
seit dem eben getätigten Update kann ich keine Configs mehr lesen:
2015.11.08 14:30:08 2: ZWave get ID007_SW_KINO_AMBIENTE configALARMFLASHINGAlarmTime
2015.11.08 14:30:11 1: configALARMFLASHINGAlarmTime: Timeout reading answer for get configALARMFLASHINGAlarmTime
2015.11.08 14:30:11 2: ZWave get ID007_SW_KINO_AMBIENTE configAutoOffForRelay1
2015.11.08 14:30:14 1: configAutoOffForRelay1: Timeout reading answer for get configAutoOffForRelay1
2015.11.08 14:30:14 2: ZWave get ID007_SW_KINO_AMBIENTE configAutoOffForRelay2
2015.11.08 14:30:17 1: configAutoOffForRelay2: Timeout reading answer for get configAutoOffForRelay2
2015.11.08 14:30:17 2: ZWave get ID007_SW_KINO_AMBIENTE configAutoOffRelayAfterSpecifiedTime
2015.11.08 14:30:20 1: configAutoOffRelayAfterSpecifiedTime: Timeout reading answer for get configAutoOffRelayAfterSpecifiedTime
2015.11.08 14:30:20 2: ZWave get ID007_SW_KINO_AMBIENTE configControlKey2Behaviour
2015.11.08 14:30:20 2: ERROR: ID007_SW_KINO_AMBIENTE: cleaning commands without ack after 10s
2015.11.08 14:30:23 1: configControlKey2Behaviour: Timeout reading answer for get configControlKey2Behaviour
2015.11.08 14:30:23 2: ZWave get ID007_SW_KINO_AMBIENTE configDimmerRollerShutterControl
2015.11.08 14:30:26 1: configDimmerRollerShutterControl: Timeout reading answer for get configDimmerRollerShutterControl
2015.11.08 14:30:26 2: ZWave get ID007_SW_KINO_AMBIENTE configEnableDisableALLONOFF
2015.11.08 14:30:29 1: configEnableDisableALLONOFF: Timeout reading answer for get configEnableDisableALLONOFF
2015.11.08 14:30:29 2: ZWave get ID007_SW_KINO_AMBIENTE configInputsBehaviour
2015.11.08 14:30:32 1: configInputsBehaviour: Timeout reading answer for get configInputsBehaviour
2015.11.08 14:30:32 2: ZWave get ID007_SW_KINO_AMBIENTE configInputsButtonSwitchConfiguration
2015.11.08 14:30:32 2: ERROR: ID007_SW_KINO_AMBIENTE: cleaning commands without ack after 10s
2015.11.08 14:30:35 1: configInputsButtonSwitchConfiguration: Timeout reading answer for get configInputsButtonSwitchConfiguration
2015.11.08 14:30:35 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay1ResponseToGeneralAlarm
2015.11.08 14:30:38 1: configRelay1ResponseToGeneralAlarm: Timeout reading answer for get configRelay1ResponseToGeneralAlarm
2015.11.08 14:30:38 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay1ResponseToSmokeCOCO2Alarm
2015.11.08 14:30:41 1: configRelay1ResponseToSmokeCOCO2Alarm: Timeout reading answer for get configRelay1ResponseToSmokeCOCO2Alarm
2015.11.08 14:30:41 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay1ResponseToTemperatureAlarm
2015.11.08 14:30:44 1: configRelay1ResponseToTemperatureAlarm: Timeout reading answer for get configRelay1ResponseToTemperatureAlarm
2015.11.08 14:30:44 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay1ResponseToWaterFloodAlarm
2015.11.08 14:30:44 2: ERROR: ID007_SW_KINO_AMBIENTE: cleaning commands without ack after 10s
2015.11.08 14:30:47 1: configRelay1ResponseToWaterFloodAlarm: Timeout reading answer for get configRelay1ResponseToWaterFloodAlarm
2015.11.08 14:30:47 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay2ResponseToGeneralAlarm
2015.11.08 14:30:50 1: configRelay2ResponseToGeneralAlarm: Timeout reading answer for get configRelay2ResponseToGeneralAlarm
2015.11.08 14:30:50 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay2ResponseToSmokeCOCO2Alarm
2015.11.08 14:30:53 1: configRelay2ResponseToSmokeCOCO2Alarm: Timeout reading answer for get configRelay2ResponseToSmokeCOCO2Alarm
2015.11.08 14:30:53 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay2ResponseToTemperatureAlarm
2015.11.08 14:30:56 1: configRelay2ResponseToTemperatureAlarm: Timeout reading answer for get configRelay2ResponseToTemperatureAlarm
2015.11.08 14:30:56 2: ZWave get ID007_SW_KINO_AMBIENTE configRelay2ResponseToWaterFloodAlarm
2015.11.08 14:30:56 2: ERROR: ID007_SW_KINO_AMBIENTE: cleaning commands without ack after 10s
2015.11.08 14:30:59 1: configRelay2ResponseToWaterFloodAlarm: Timeout reading answer for get configRelay2ResponseToWaterFloodAlarm
2015.11.08 14:30:59 2: ZWave get ID007_SW_KINO_AMBIENTE configSavingStateBeforePowerFaillure
2015.11.08 14:31:02 1: configSavingStateBeforePowerFaillure: Timeout reading answer for get configSavingStateBeforePowerFaillure
2015.11.08 14:31:02 2: ZWave get ID007_SW_KINO_AMBIENTE configSeparationOfAssociationSending6
2015.11.08 14:31:05 1: configSeparationOfAssociationSending6: Timeout reading answer for get configSeparationOfAssociationSending6
initiiert mit ConfigRequestAll - aber auch einzelnd
Da ich das Senden gerade umgebaut habe: kannst du das bitte mit dem update von morgen (ab 8:00) pruefen?
Oder sofort mit dem 00_ZWDongle.pm/10_ZWave.pm aus SVN.
Chlorex
reicht es einfach
update 00_ZWDongle.pm
update 10_ZWave.pm
einzugeben?
krikan
Morgen ab 8 Uhr: ja
Heute musst Du die beiden Dateien manuell aus dem SVN http://sourceforge.net/p/fhem/code/HEAD/tree/ herunterladen und in das passende Verzeichnis Deiner Installation kopieren.
Gruß, Christian
toms01
Hab ich gemacht..
leider keine Änderung. Die Configs können nicht mehr gelesen werden.
krikan
Kannst Du das bitte genauer erläutern; am Besten per Fhem-Logauszug.
toms01
sieht aus wie oben. Soll ich am verbose was ändern?
krikan
Funktioniert denn die Ansteuerung der Geräte?
Kannst Du an ZWDongle die caps abrufen?
Ansonsten bitte volles Programm an Infos, wenn keine anderen Ideen kommen: http://www.fhemwiki.de/wiki/Z-Wave#Welche_Infos_sollten_Anfragen_im_ZWave-Forum_enthalten.3F Für mich sind die Infos noch zu schmal.
Gruß, Christian
toms01
Die Ansteuerung funktioniert.
Hier die Dongle-Caps:
Vers:1 Rev:0 ManufID:0086 ProductType:0001 ProductID:005a SERIAL_API_GET_INIT_DATA SERIAL_API_APPL_NODE_INFORMATION APPLICATION_COMMAND_HANDLER ZW_GET_CONTROLLER_CAPABILITIES SERIAL_API_SET_TIMEOUTS SERIAL_API_GET_CAPABILITIES SERIAL_API_SOFT_RESET UNKNOWN_09 ZW_SET_R_F_RECEIVE_MODE ZW_SET_SLEEP_MODE ZW_SEND_NODE_INFORMATION ZW_SEND_DATA ZW_SEND_DATA_MULTI ZW_GET_VERSION ZW_SEND_DATA_ABORT ZW_R_F_POWER_LEVEL_SET ZW_SEND_DATA_META ZW_GET_RANDOM MEMORY_GET_ID MEMORY_GET_BYTE MEMORY_PUT_BYTE MEMORY_GET_BUFFER MEMORY_PUT_BUFFER FLASH_AUTO_PROG_SET NVM_GET_ID NVM_EXT_READ_LONG_BUFFER NVM_EXT_WRITE_LONG_BUFFER NVM_EXT_READ_LONG_BYTE NVM_EXT_WRITE_LONG_BYTE ZW_GET_NODE_PROTOCOL_INFO ZW_SET_DEFAULT ZW_REPLICATION_COMMAND_COMPLETE ZW_REPLICATION_SEND_DATA ZW_ASSIGN_RETURN_ROUTE ZW_DELETE_RETURN_ROUTE ZW_REQUEST_NODE_NEIGHBOR_UPDATE ZW_APPLICATION_UPDATE ZW_ADD_NODE_TO_NETWORK ZW_REMOVE_NODE_FROM_NETWORK ZW_CREATE_NEW_PRIMARY ZW_CONTROLLER_CHANGE ZW_SET_LEARN_MODE ZW_ASSIGN_SUC_RETURN_ROUTE ZW_REQUEST_NETWORK_UPDATE ZW_SET_SUC_NODE_ID ZW_DELETE_SUC_RETURN_ROUTE ZW_GET_SUC_NODE_ID ZW_SEND_SUC_ID ZW_EXPLORE_REQUEST_INCLUSION ZW_REQUEST_NODE_INFO ZW_REMOVE_FAILED_NODE_ID ZW_IS_FAILED_NODE ZW_REPLACE_FAILED_NODE UNKNOWN_66 UNKNOWN_67 GET_ROUTING_TABLE_LINE LOCK_ROUTE_RESPONSE UNKNOWN_92 UNKNOWN_93 UNKNOWN_98 UNKNOWN_b4 ZW_WATCHDOG_ENABLE ZW_WATCHDOG_DISABLE ZW_WATCHDOG_CHECK ZW_SET_EXT_INT_LEVEL ZW_RF_POWERLEVEL_GET ZW_TYPE_LIBRARY ZW_SEND_TEST_FRAME ZW_GET_PROTOCOL_STATUS WATCHDOG_START WATCHDOG_STOP UNKNOWN_d4 UNKNOWN_ee UNKNOWN_ef
toms01
Ist der AEOTEC-Stick mit Akku.
ConfigRequestAll hat bisher immer funktioniert, ging recht schnell und hat bisher fast immer alle Configs in einem Rutsch gelesen.
Sind etwa 30 Geräte - seit dem Update funktioniert es bei keinem mehr. Manchmal (sehr selten) sporadisch bei Einzelwerten.
Meldungen von z.B. Bewegungsmeldern bekomme ich auch noch.
toms01
Hier ein verbose5-log von einem getconfig mit anschließendem Timeout:
2015.11.08 18:37:19 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 00041011033003ff
2015.11.08 18:37:19 5: SW: 06
2015.11.08 18:37:19 5: ZWDongle_1 dispatch 00041011033003ff
2015.11.08 18:37:19 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:11 ARG:033003ff
2015.11.08 18:37:19 2: ZWave set ID002_SW_VORFLUR on
2015.11.08 18:37:19 5: ZWDongle_Write 00 1302032501FF2502
2015.11.08 18:37:19 5: SW: 010a001302032501FF25021b
2015.11.08 18:37:19 5: ACK received, WaitForAck=>2 for 010a001302032501FF25021b
2015.11.08 18:37:19 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 011301
2015.11.08 18:37:19 5: ZWDongle_1 dispatch 011301
2015.11.08 18:37:19 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 001302000007
2015.11.08 18:37:19 5: device ack reveived, removing 010a001302032501FF25021b from dongle sendstack
2015.11.08 18:37:19 5: ZWDongle_1 dispatch 001302000007
2015.11.08 18:37:19 4: ZWDongle_1 CMD:ZW_SEND_DATA ID:00 ARG:0007
2015.11.08 18:37:19 4: ZWDongle_1 transmit OK for 02
2015.11.08 18:37:20 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 00041011033003ff
2015.11.08 18:37:20 5: SW: 06
2015.11.08 18:37:20 5: ZWDongle_1 dispatch 00041011033003ff
2015.11.08 18:37:20 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:11 ARG:033003ff
2015.11.08 18:37:21 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 00041002032503ff
2015.11.08 18:37:21 5: SW: 06
2015.11.08 18:37:21 5: ZWDongle_1 dispatch 00041002032503ff
2015.11.08 18:37:21 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:02 ARG:032503ff
2015.11.08 18:37:22 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 00041002032503ff
2015.11.08 18:37:22 5: SW: 06
2015.11.08 18:37:22 5: ZWDongle_1 dispatch 00041002032503ff
2015.11.08 18:37:22 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:02 ARG:032503ff
2015.11.08 18:37:23 2: ZWave get ID002_SW_VORFLUR configActionOnButtonDoublePressOrHold
2015.11.08 18:37:23 5: ZWDongle_Write 00 13020370050e2502
2015.11.08 18:37:23 5: SW: 010a0013020370050e2502bb
2015.11.08 18:37:23 4: ZWDongle_ReadAnswer arg:configActionOnButtonDoublePressOrHold regexp:^00040002..70
2015.11.08 18:37:23 5: ACK received, WaitForAck=>2 for 010a0013020370050e2502bb
2015.11.08 18:37:23 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 011301
2015.11.08 18:37:23 5: SW: 06
2015.11.08 18:37:23 5: ZWDongle_1 dispatch 011301
2015.11.08 18:37:23 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 001302000006
2015.11.08 18:37:23 5: device ack reveived, removing 010a0013020370050e2502bb from dongle sendstack
2015.11.08 18:37:23 5: ZWDongle_1 dispatch 001302000006
2015.11.08 18:37:23 4: ZWDongle_1 CMD:ZW_SEND_DATA ID:00 ARG:0006
2015.11.08 18:37:23 4: ZWDongle_1 transmit OK for 02
2015.11.08 18:37:24 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 000410020570060e0100
2015.11.08 18:37:24 5: SW: 06
2015.11.08 18:37:24 5: ZWDongle_1 dispatch 000410020570060e0100
2015.11.08 18:37:24 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:02 ARG:0570060e0100
2015.11.08 18:37:25 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 000410020570060e0100
2015.11.08 18:37:25 5: SW: 06
2015.11.08 18:37:25 5: ZWDongle_1 dispatch 000410020570060e0100
2015.11.08 18:37:25 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:02 ARG:0570060e0100
2015.11.08 18:37:28 5: ZWDongle_ReadAnswer: select timeout
toms01
und hier ein Log von einem Schaltvorgang (funktioniert!)
2015.11.08 18:40:01 2: ZWave set ID002_SW_VORFLUR on
2015.11.08 18:40:01 5: ZWDongle_Write 00 1302032501FF2502
2015.11.08 18:40:01 5: SW: 010a001302032501FF25021b
2015.11.08 18:40:01 5: ACK received, WaitForAck=>2 for 010a001302032501FF25021b
2015.11.08 18:40:01 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 011301
2015.11.08 18:40:01 5: SW: 06
2015.11.08 18:40:01 5: ZWDongle_1 dispatch 011301
2015.11.08 18:40:01 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 001302000006
2015.11.08 18:40:01 5: device ack reveived, removing 010a001302032501FF25021b from dongle sendstack
2015.11.08 18:40:01 5: ZWDongle_1 dispatch 001302000006
2015.11.08 18:40:01 4: ZWDongle_1 CMD:ZW_SEND_DATA ID:00 ARG:0006
2015.11.08 18:40:01 4: ZWDongle_1 transmit OK for 02
2015.11.08 18:40:03 4: ZWDongle_Read ZWDongle_1: sending ACK, processing 00041002032503ff
2015.11.08 18:40:03 5: SW: 06
2015.11.08 18:40:03 5: ZWDongle_1 dispatch 00041002032503ff
2015.11.08 18:40:03 4: ZWDongle_1 CMD:APPLICATION_COMMAND_HANDLER ID:02 ARG:032503ff
krikan
Habe keine Ideen, woran das liegen könnte.
Neustart und kurz stromlos machen des Gateways/Servers hast Du sicherlich schon gemacht.
Von welcher Version hast Du denn das update gemacht? Schau mal bitte ins restoreDir-Verzeichnis.
toms01
Folgende Versionen sind darin enthalten:
2015-11-02  2015-11-07  2015-11-08
Allerdings weiss ich nicht, ob ich gestern auch Configs auslesen wollte/konnte.
ABER: ich habe den Rpi2 mal neugestartet - jetzt geht es wieder. Sonderbar, dachte es reicht ein shutdown restart.
Ich behalte das mal im Auge, vielen Dank für Deine Hilfe!
toms01
#14
Hallo allerseits!
Durch meine sonderbaren Probleme mit dem Raspberry2 bin ich jetzt auf einen Intel NUC umgezogen.
Ich habe meine fhem.conf und den AEOTEC-Gen5-Stick einfach mitgenommen.
Leider habe ich jetzt wieder neue Probleme mit batteriebetriebenen Geräten.  :'(
Ich erhalten beispielsweise bei der ZWave.me-Remote jetzt kein ZW_APPLICATION_UPDATE mehr bei 3xInclude-Button.
Genau das gleiche bei einem Fibaro-Motionsensor - es kommt einfach kein ZW_APPLICATION_UPDATE mehr an.
Werte (Temperatur, Helligkeit usw.) und auch gewünschte Schaltaktionen kommen aber beim Controller/FHEM an.
Dadurch kann ich leider meine Readings nicht mehr herstellen bei diesen Geräten.
Alle anderen stromversorgten Geräte funktionieren fehlerfrei. FHEM ist auf dem heutigen Stand.
Hat jemand Ahnung was da los sein könnte? Vielen Dank!
Thomas
Nachtrag:
Kurze Frage:
Ist es eigentlich normal, dass in keiner Neighbor-list mehr das Dongle (ID1) auftaucht?
Nachtrag2:
ZW_APPLICATION_UPDATE funktioniert nur in unmittelbarer Nähe zum Dongle.
Neighbor-List wird auch aktualisiert - leider kann ich mich trotzdem nicht weiter entfernen um die Fernbedienung dort anzulernen wo sie gebraucht wird, weil ja das ZW_APPLICATION_UPDATE beim Controller nicht ankommt.
Das war früher anders, da konnte ich vom Keller aus das Update anstossen.
Nachtrag3:
Zur ZWave-Me-Remote: Schaltvorgänge kommen ja wie gesagt beim Controller an, jetzt blinkt die LED jeweils 3x Rot nach jedem mal
Nachtrag 4:
associationRequestAll funktioniert nicht mit ZWave-Me-Remote. 12 = $0C Associations
PERL WARNING: Argument "0c" isn't numeric in numeric ge (>=) at ./FHEM/10_ZWave.pm line 1835.
