93_PWMR.pm : new reading desired-temp-used (desired-temp used in calculation e.g. when window is set to state open)
Begonnen von System, 04 Dezember 2015, 18:00:04
System
93_PWMR.pm : new reading desired-temp-used (desired-temp used in calculation e.g. when window is set to state open)                           modification of definition in web gui will now also consider parameters changed by attributesView Changes
Source: 93_PWMR.pm : new reading desired-temp-used (desired-temp used in calculation e.g. when window is set to state open)
