cul_max aculfw maxcube
Begonnen von masterpete23, 12 Dezember 2015, 17:17:31
masterpete23
habe meinen maxcube zum cun mit aculfw gemacht
nun kam beim pairen
2015.12.12 17:06:27 2: autocreate: define MAX_027419 MAX HeatingThermostat 027419
2015.12.12 17:06:27 2: autocreate: define FileLog_MAX_027419 FileLog ./log/MAX_027419-%Y.log MAX_027419
2015.12.12 17:06:28 2: autocreate: define MAX_07b0cf MAX HeatingThermostat 07b0cf
2015.12.12 17:06:28 2: autocreate: define FileLog_MAX_07b0cf FileLog ./log/MAX_07b0cf-%Y.log MAX_07b0cf
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f1 in addition (+) at ./FHEM/14_CUL_MAX.pm line 321.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f3 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 323.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f4 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 324.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f5 in bitwise and (&) at ./FHEM/14_CUL_MAX.pm line 325.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f4 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 326.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f5 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 326.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f3 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 327.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f4 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 328.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $f5 in right bitshift (>>) at ./FHEM/14_CUL_MAX.pm line 329.
2015.12.12 17:09:54 1: PERL WARNING: Use of uninitialized value $day in concatenation (.) or string at ./FHEM/14_CUL_MAX.pm line 331.
Muss mich das stören?
# $Id: 14_CUL_MAX.pm 9233 2015-09-11 21:43:59Z mgehre $
masterpete23
Niemand eine Idee? Bestimmt alle im Weihnachtsstress
Gesendet von meinem Huawei Honor 7
Matthias Gehre
Da kam anscheinend ein TimeInformation Paket ohne Payload, aber die werden eh ignoriert. Ist also kein Problem.
masterpete23
ok.
Habe das Pairen hinbekommen.
Habe es vorher komplett resetten müssen.
Irgendwie habe ich das Gefühl das readings fehlen - kann ich die anfordern?
Matthias Gehre
Das kann die MAX Hardware nicht. Kannst nur neue (bzw. die alte nochmal) Konfiguration setzten.
masterpete23
Also einfach attr oder mit set?
