FHEM dienst stirbt sporadisch
Begonnen von Kharim, 23 Dezember 2015, 15:26:34
Kharim
Hallo Zusammen,
bei mir verabschiedet sich sporadisch ein/der FHEM Dienst und ich habe keinen blassen Schimmer warum....
FHEM Log:
2015.12.23 08:36:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 08:41:13 3: get Cube credit10ms : Cube credit10ms => 1766
2015.12.23 08:46:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 08:51:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 08:56:13 3: get Cube credit10ms : Cube credit10ms => 1556
2015.12.23 09:01:13 3: get Cube credit10ms : Cube credit10ms => 1622
2015.12.23 09:06:13 3: get Cube credit10ms : Cube credit10ms => 1376
2015.12.23 09:11:13 3: get Cube credit10ms : Cube credit10ms => 1658
2015.12.23 09:16:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 09:21:16 3: get Cube credit10ms : Cube credit10ms => 1498
2015.12.23 09:26:13 3: get Cube credit10ms : Cube credit10ms => 1796
2015.12.23 09:31:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 09:36:13 3: get Cube credit10ms : Cube credit10ms => 1616
2015.12.23 09:41:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 09:46:13 3: get Cube credit10ms : Cube credit10ms => 1436
2015.12.23 09:51:13 3: get Cube credit10ms : Cube credit10ms => 1736
2015.12.23 09:56:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 10:01:13 3: get Cube credit10ms : Cube credit10ms => 1520
2015.12.23 10:06:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 10:11:13 3: get Cube credit10ms : Cube credit10ms => 1376
2015.12.23 10:16:13 3: get Cube credit10ms : Cube credit10ms => 1667
2015.12.23 10:21:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 10:26:13 3: get Cube credit10ms : Cube credit10ms => 1496
2015.12.23 10:31:13 3: get Cube credit10ms : Cube credit10ms => 1558
2015.12.23 10:36:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 10:41:13 3: get Cube credit10ms : Cube credit10ms => 1616
2015.12.23 10:46:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 10:51:13 3: get Cube credit10ms : Cube credit10ms => 1427
2015.12.23 10:56:13 3: get Cube credit10ms : Cube credit10ms => 1727
2015.12.23 11:01:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 11:06:16 3: get Cube credit10ms : Cube credit10ms => 1549
2015.12.23 11:11:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 11:16:13 3: get Cube credit10ms : Cube credit10ms => 1376
2015.12.23 11:21:13 3: get Cube credit10ms : Cube credit10ms => 1667
2015.12.23 11:26:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 11:31:13 3: get Cube credit10ms : Cube credit10ms => 1496
2015.12.23 11:36:13 3: get Cube credit10ms : Cube credit10ms => 1796
2015.12.23 11:41:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 11:46:13 3: get Cube credit10ms : Cube credit10ms => 1616
2015.12.23 11:51:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 11:56:13 3: get Cube credit10ms : Cube credit10ms => 1436
2015.12.23 12:01:13 3: get Cube credit10ms : Cube credit10ms => 1736
2015.12.23 12:06:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 12:11:13 3: get Cube credit10ms : Cube credit10ms => 1775
2015.12.23 12:16:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 12:21:13 3: get Cube credit10ms : Cube credit10ms => 1376
2015.12.23 12:26:13 3: get Cube credit10ms : Cube credit10ms => 1676
2015.12.23 12:31:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 12:36:13 3: get Cube credit10ms : Cube credit10ms => 1496
2015.12.23 12:41:13 3: get Cube credit10ms : Cube credit10ms => 1796
2015.12.23 12:46:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 12:51:16 3: get Cube credit10ms : Cube credit10ms => 1618
2015.12.23 12:56:13 3: get Cube credit10ms : Cube credit10ms => 1800
2015.12.23 13:01:13 3: get Cube credit10ms : Cube credit10ms => 1436
2015.12.23 15:21:12 2: MAX MaxScan: UtilsMaxScan_Initialize.86 MaxScan is starting
2015.12.23 15:21:12 1: Including fhem.cfg
2015.12.23 15:21:13 3: telnetPort: port 7072 opened
2015.12.23 15:21:13 3: WEB: port 8083 opened
2015.12.23 15:21:13 3: WEBphone: port 8084 opened
2015.12.23 15:21:13 3: WEBtablet: port 8085 opened
2015.12.23 15:21:14 2: eventTypes: loaded 846 events from ./log/eventTypes.txt
2015.12.23 15:21:14 3: Opening FritzCM device 192.168.100.10:1012
2015.12.23 15:21:14 3: FritzCM device opened
2015.12.23 15:21:15 3: Opening Cube device 192.168.100.25:2323
2015.12.23 15:21:15 3: Cube device opened
2015.12.23 15:21:16 3: Cube: Possible commands: BbCFiAZNEkGMKLUYRTVWXefltxz
2015.12.23 15:21:16 2: Switched Cube rfmode to MAX
2015.12.23 15:21:16 3: CUL_MAX_Check: Detected firmware version 154 of the CUL-compatible IODev
2015.12.23 15:21:16 3: TABLETUI: new ext defined infix:ftui/: dir:./www/tablet:
2015.12.23 15:21:16 3: Registering HTTPSRV TABLETUI for URL /ftui   and assigned link ftui/ ...
2015.12.23 15:21:36 1: Including ./log/fhem.save
2015.12.23 15:21:36 0: Featurelevel: 5.7
2015.12.23 15:21:36 0: Server started with 117 defined entities (fhem.pl:10116/2015-12-06 perl:5.020002 os:linux user:fhem pid:409)
2015.12.23 15:21:36 3: telnetForBlockingFn: port 46495 opened
Sagt also quasi nichts aus....scheint einfach weg zu sein.
Ein "ps -ax | grep fhem" bringt normaler Weise folgendes Ergebnis:
409 ?        S      0:05 perl fhem.pl fhem.cfg
  884 pts/0    S+     0:00 grep fhem
Im Fehlerfall fehlt die erste Zeile komplett...FHEM scheint also wirklich beendet zu sein...nur warum?
Bräuchte bitte mal Tips wie und wo ich ein genaueres Logging für FHEM selbst aktivieren kann...
Danke und ein schönes Weihnachtsfest,
Kharim
Raspberry Pi 2 + Minibian + 2x MAX Cube CUN (868/433Mhz) + Thermostate + Fensterkontakte + Taster+RGB-LED Band über pigpiod + TFA Sensoren 30.3169/3125
Raspberry Pi 2 + Minibian +Z-Wave (USB) + Bewegungsmelder + Fensterkontakt + Sirene + SMS Steuer-/Benachrichtigung (ohne Internet)
Wernieman
Du hattest den dienst wieder gestartet?
Was sagt denn zu der Uhrzeit das "/var/log/kern.log"?
Ansonsten kannst Du nur probieren, den Loglevel hochzudrehen, d.h. verbose auf 5 setzen
- Bitte um Input für Output
Kharim
Jap..."irgendwann" merkt man ja mal, dass die FHEM Seite nicht erreichbar ist und da hab ich den Pi neu gestartet.
kern.log sagt auch nicht mehr....erstaunlicher Weise sogar noch viel weniger.....
Dec 22 20:56:07 minibian kernel: [    7.550814] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Dec 22 20:56:07 minibian kernel: [    7.559779] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
Dec 22 20:56:07 minibian kernel: [    9.483193] random: nonblocking pool is initialized
Dec 23 15:21:11 minibian kernel: [    0.000000] Booting Linux on physical CPU 0xf00
Dec 23 15:21:11 minibian kernel: [    0.000000] Initializing cgroup subsys cpuset
Dec 23 15:21:11 minibian kernel: [    0.000000] Initializing cgroup subsys cpuacct
Blöde Frage ich weiß....aber wo muss ich das verbose 5 einstellen?
Kenne das bisher nur an einzelnen Geräten (zb. CUL) oder eben an Notifys....aber am FHEM selbst?
Danke,
Kharim
franky08
global verbose auf 5 setzen  ;)
VG
Frank
mit FHEM aktuell
Wernieman
Siehe auch die Doku:
http://fhem.de/commandref.html
ZitatGlobal attributes used by all devices
    verbose
    Set the verbosity level. Possible values:
        0 - server start/stop
        1 - error messages or unknown packets
        2 - major events/alarms.
        3 - commands sent out will be logged.
        4 - you'll see whats received by the different devices.
        5 - debugging.
    The value for the global device is a default for other devices without own verbose attribute set.
Kharim
Alles klar, ich danke.
Ist nun eingestellt....mal schauen was die nächsten Tage bringen.
Schöne Weihnacht,
Kharim
Kharim
Soo hier nun mal ein Stück Log zum Zeitpunkt eines Restarts:
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4090 Execute '[ -f /sys/class/net/eth0/statistics/rx_bytes ] && echo 1 || echo 0'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4103 Result '1'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4090 Execute 'cat /sys/class/net/eth0/statistics/rx_bytes'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4103 Result '2310924'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4090 Execute 'cat /sys/class/net/eth0/statistics/tx_bytes'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4103 Result '8244045'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4090 Execute '[ -f /sys/class/net/eth0/speed ] && cat /sys/class/net/eth0/speed 2>/dev/null || echo not available'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4103 Result '100'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: getNetworkInfo.2650 get wlan0
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4090 Execute 'ifconfig wlan0 2>&1'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: Exec_Local.4103 Result 'wlan0: Fehler beim Auslesen der Schnittstelleninformation: Ger�t nicht gefunden'
2015.12.24 12:50:00 5: SYSMON RaspiDaten: getNetworkInfo.2662 SYSMON_getNetworkInfo>>>>>>>>>>>>>>>>$VAR1 = 'wlan0: Fehler beim Auslesen der Schnittstelleninformation: Ger�t nicht gefunden';
2015.12.24 12:50:00 4: Connection accepted from telnet:127.0.0.1:53631
2015.12.24 12:50:00 5: Cmd: >{SYSMON_blockingFinish('name|RaspiDaten|cpu0_idle_stat|31.04 99.86 95.99|uptime_text|0 days, 04 hours, 49 minutes|stat_cpu0_percent|3.33 0.00 6.36 90.21 0.02 0.00 0.08|cpu_core_count|4|eth0_tx|8244045|stat_cpu2_diff|390 0 346 5618 0 0 7|stat_cpu0_diff|203 0 387 5491 1 0 5|stat_cpu_diff|930 0 1442 22541 1 0 39|stat_cpu_text|user: 3.73 %, nice: 0.00 %, sys: 5.78 %, idle: 90.33 %, io: 0.00 %, irq: 0.00 %, sirq: 0.16 %|uptime|17369|stat_cpu3_diff|181 0 391 5692 0 0 16|cpu3_idle_stat|32.93 99.94 96.39|cpu_temp_avg|48.3|stat_cpu1_diff|156 0 318 5740 0 0 11|cpu_temp_stat|40.08 57.30 48.23|ram_used_stat|101.02 171.26 155.61|fhemstarttime_text|24.12.2015 08:00:51|stat_cpu2|29554 0 22262 1671830 502 0 301|cpu2_idle_stat|28.27 99.90 95.08|loadavg|0.24 0.12 0.12|starttime|1450940430|idletime|16815 96.81 %|eth0|RX: 2.20 MB, TX: 7.86 MB, Total: 10.06 MB|stat_cpu3|30539 0 23491 1669993 365 0 361|fhemstarttime|1450940451|eth0_diff|RX: 0.01 MB, TX: 0.00 MB, Total: 0.01 MB|ram|Total: 973.46 MB, Used: 156.45 MB, 16.07 %, Free: 817.01 MB|eth0_ip|192.168.100.30|wlan0_diff|not available|eth0_speed|100|stat_cpu1|33894 0 22555 1671743 345 0 346|starttime_text|24.12.2015 08:00:30|stat_cpu2_percent|6.13 0.00 5.44 88.32 0.00 0.00 0.11|stat_cpu2_text|user: 6.13 %, nice: 0.00 %, sys: 5.44 %, idle: 88.32 %, io: 0.00 %, irq: 0.00 %, sirq: 0.11 %|stat_cpu_percent|3.73 0.00 5.78 90.33 0.00 0.00 0.16|stat_cpu1_text|user: 2.51 %, nice: 0.00 %, sys: 5.11 %, idle: 92.21 %, io: 0.00 %, irq: 0.00 %, sirq: 0.18 %|stat_cpu0_text|user: 3.33 %, nice: 0.00 %, sys: 6.36 %, idle: 90.21 %, io: 0.02 %, irq: 0.00 %, sirq: 0.08 %|fhemuptime|17349|fhemuptime_text|0 days, 04 hours, 49 minutes|cpu_idle_stat|55.74 99.18 95.85|cpu_temp|50.84|eth0_ip6|fe80::ba27:ebff:fef9:a119/64|idletime_text|0 days, 04 hours, 40 minutes (96.81 %)|stat_cpu1_percent|2.51 0.00 5.11 92.21 0.00 0.00 0.18|eth0_rx|2310924|stat_cpu|126071 0 90121 6676648 1883 1 1534|swap_used_stat|0.00 0.00 0.00|stat_cpu0|32084 0 21813 1663082 671 1 526|swap|n/a|cpu1_idle_stat|27.08 99.97 95.98|wlan0|not available|stat_cpu3_text|user: 2.88 %, nice: 0.00 %, sys: 6.23 %, idle: 90.64 %, io: 0.00 %, irq: 0.00 %, sirq: 0.25 %|stat_cpu3_percent|2.88 0.00 6.23 90.64 0.00 0.00 0.25')}<
2015.12.24 12:50:00 5: SYSMON RaspiDaten: blockingFinish.1034 name|RaspiDaten|cpu0_idle_stat|31.04 99.86 95.99|uptime_text|0 days, 04 hours, 49 minutes|stat_cpu0_percent|3.33 0.00 6.36 90.21 0.02 0.00 0.08|cpu_core_count|4|eth0_tx|8244045|stat_cpu2_diff|390 0 346 5618 0 0 7|stat_cpu0_diff|203 0 387 5491 1 0 5|stat_cpu_diff|930 0 1442 22541 1 0 39|stat_cpu_text|user: 3.73 %, nice: 0.00 %, sys: 5.78 %, idle: 90.33 %, io: 0.00 %, irq: 0.00 %, sirq: 0.16 %|uptime|17369|stat_cpu3_diff|181 0 391 5692 0 0 16|cpu3_idle_stat|32.93 99.94 96.39|cpu_temp_avg|48.3|stat_cpu1_diff|156 0 318 5740 0 0 11|cpu_temp_stat|40.08 57.30 48.23|ram_used_stat|101.02 171.26 155.61|fhemstarttime_text|24.12.2015 08:00:51|stat_cpu2|29554 0 22262 1671830 502 0 301|cpu2_idle_stat|28.27 99.90 95.08|loadavg|0.24 0.12 0.12|starttime|1450940430|idletime|16815 96.81 %|eth0|RX: 2.20 MB, TX: 7.86 MB, Total: 10.06 MB|stat_cpu3|30539 0 23491 1669993 365 0 361|fhemstarttime|1450940451|eth0_diff|RX: 0.01 MB, TX: 0.00 MB, Total: 0.01 MB|ram|Total: 973.46 MB, Used: 156.45 MB, 16.07 %, Free: 817.01 MB|eth0_ip|192.168.100.30|wlan0_diff|not available|eth0_speed|100|stat_cpu1|33894 0 22555 1671743 345 0 346|starttime_text|24.12.2015 08:00:30|stat_cpu2_percent|6.13 0.00 5.44 88.32 0.00 0.00 0.11|stat_cpu2_text|user: 6.13 %, nice: 0.00 %, sys: 5.44 %, idle: 88.32 %, io: 0.00 %, irq: 0.00 %, sirq: 0.11 %|stat_cpu_percent|3.73 0.00 5.78 90.33 0.00 0.00 0.16|stat_cpu1_text|user: 2.51 %, nice: 0.00 %, sys: 5.11 %, idle: 92.21 %, io: 0.00 %, irq: 0.00 %, sirq: 0.18 %|stat_cpu0_text|user: 3.33 %, nice: 0.00 %, sys: 6.36 %, idle: 90.21 %, io: 0.02 %, irq: 0.00 %, sirq: 0.08 %|fhemuptime|17349|fhemuptime_text|0 days, 04 hours, 49 minutes|cpu_idle_stat|55.74 99.18 95.85|cpu_temp|50.84|eth0_ip6|fe80::ba27:ebff:fef9:a119/64|idletime_text|0 days, 04 hours, 40 minutes (96.81 %)|stat_cpu1_percent|2.51 0.00 5.11 92.21 0.00 0.00 0.18|eth0_rx|2310924|stat_cpu|126071 0 90121 6676648 1883 1 1534|swap_used_stat|0.00 0.00 0.00|stat_cpu0|32084 0 21813 1663082 671 1 526|swap|n/a|cpu1_idle_stat|27.08 99.97 95.98|wlan0|not available|stat_cpu3_text|user: 2.88 %, nice: 0.00 %, sys: 6.23 %, idle: 90.64 %, io: 0.00 %, irq: 0.00 %, sirq: 0.25 %|stat_cpu3_percent|2.88 0.00 6.23 90.64 0.00 0.00 0.25
2015.12.24 12:50:00 5: SYSMON RaspiDaten: updateReadings.1053
2015.12.24 12:50:00 5: Triggering RaspiDaten (6 changes)
2015.12.24 12:50:00 5: Notify loop for RaspiDaten loadavg: 0.24 0.12 0.12
ERROR: dutycycle not 0-range (default 255)
-8
-8
-8
2015.12.24 12:50:09 5: redefine at command cpuscript as +*00:00:10 {my $value = qx(/Lars/Scripte/cpulast.sh &);fhem("set cpu $value")}
2015.12.24 12:50:09 5: redefine at command cputempscript as +*00:00:30 {my $value = qx(/Lars/Scripte/cputemp.sh &);fhem("set cputemp $value")}
-8
-8
-8
2015.12.24 12:50:19 5: redefine at command cpuscript as +*00:00:10 {my $value = qx(/Lars/Scripte/cpulast.sh &);fhem("set cpu $value")}
-8
-8
-8
2015.12.24 12:50:29 5: redefine at command cpuscript as +*00:00:10 {my $value = qx(/Lars/Scripte/cpulast.sh &);fhem("set cpu $value")}
-8
-8
-8
-8
2015.12.24 12:50:39 5: redefine at command cpuscript as +*00:00:10 {my $value = qx(/Lars/Scripte/cpulast.sh &);fhem("set cpu $value")}
2015.12.24 12:50:39 5: redefine at command cputempscript as +*00:00:30 {my $value = qx(/Lars/Scripte/cputemp.sh &);fhem("set cputemp $value")}
2015.12.24 12:50:39 5: redefine at command ramscript as +*00:01:00 {my $value = qx(/Lars/Scripte/memfree.sh &);fhem("set ram $value")}
2015.12.24 12:50:41 5: exec at command CreditsScript
2015.12.24 12:50:41 5: Cmd: >{my $value=fhem("get Cube credit10ms");;fhem("set aktCredits $value")}<
2015.12.24 12:50:41 5: Cmd: >get Cube credit10ms<
2015.12.24 12:50:41 5: Triggering Cube (1 changes)
2015.12.24 12:50:41 5: Notify loop for Cube UNKNOWNCODE 21 1536
2015.12.24 12:50:42 1: PERL WARNING: Use of uninitialized value $msg in pattern match (m//) at ./FHEM/00_CUL.pm line 135.
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
-8
2015.12.24 12:53:17 2: MAX MaxScan: UtilsMaxScan_Initialize.86 MaxScan is starting
2015.12.24 12:53:17 5: Initializing Type Library:
2015.12.24 12:53:17 1: Including fhem.cfg
2015.12.24 12:53:17 5: Cmd: >attr global userattr cmdIcon devStateIcon devStateStyle fm_fav fm_groups fm_name fm_order fp_Grundriss icon sortby structexclude webCmd widgetOverride<
2015.12.24 12:53:17 5: Cmd: >attr global autoload_undefined_devices 1<
2015.12.24 12:53:17 5: Cmd: >attr global logfile ./log/fhem/fhem-%Y-%m.log<
2015.12.24 12:53:17 5: Cmd: >attr global modpath .<
2015.12.24 12:53:17 5: Cmd: >attr global statefile ./log/fhem.save<
2015.12.24 12:53:17 5: Cmd: >attr global updateInBackground 1<
2015.12.24 12:53:17 5: Cmd: >attr global verbose 5<
2015.12.24 12:53:17 5: Cmd: >define telnetPort telnet 7072 global<
2015.12.24 12:53:17 5: Loading ./FHEM/98_telnet.pm
Für mich ist es nicht ganz klar erkennbar, ab wann hier der Reboot erfolgt - vermutlich ab MaxScan -> Die vorhergehenden Errors könnten also das Problem sein.
Nur was sagen diese aus?
Wernieman
Stimmt es, das Deine Instanz nur 3! Minuten gelaufen ist?
viegener
Es könnte sein, dass die entsprechenden Meldungen:
-8
aus der C-Lib pigpio stammen --> https://github.com/joan2937/pigpio
Diese stellt auch PWM-Funktionen an den GPIO Pins bereit, dabei sind keine Werte ausserhalb von 0-255 erlaubt.
Nicht sicher ob Du damit den Verursacher identifizieren kannst.
Kharim
Hallo viegener,
dem Tipp werde ich auf jeden Fall mal nachgehen. Ich nutze pigpio tatsächlich zur Ansteuerung von PWM Transistoren, zur Steuerung meines LED Streifens.
Allerdings habe ich die Scripte schon vor FHEM so in der Form genutzt und nie Probleme gehabt.
Zwei Gedanken:
Wenn dies der Grund des FHEM Absturzes ist, dann kann es nur im Moment eines offenen Fensters sein. (Benachrichtigung das Fenster zu lange offen). Dann allerdings käme auch keine Bestätigung das Fenster geschlossen wurde. - Ich habe bisher nie einen Absturz zwischen Fenster geöffnet und wieder geschlossen gehabt. -
Ebenfalls wird ein Blinken ausgelöst, wenn ein Telefonanruf eingeht - aber auch hier bisher keine Parallelen....
viegener
Zitat von: Kharim am 27 Dezember 2015, 08:46:26
Zwei Gedanken:
Ich kann nicht unbedingt sagen, ob die Fehlermeldungen den Absturz verursachen, sie erscheinen nur relativ kurz vor dem Neustart und kommen nicht direkt aus FHEM. Ausserdem erscheinen sie gravierend genug, um zu vermuten, dass es einen Absturz verursachen könnte. Wobei noch nicht erklärt ist, warum FHEM dann neu startet?
Kharim
#11
Soooo,
also es war wirklich ein Fehler in meinem pigpio-Script. Unter bestimmten Umständen wurde wirklich versucht Werte über 255 zu setzen.
Dies ist nun behoben. - mal sehen ob/was das nächste Absturz-Log sagt.
Warum "FHEM neu startet" kann ich dir sagen:
Ich überwache auf Linux-Ebene alle 5 Minuten die Dienste, ob diese noch vorhanden sind. Fehlt hier der FHEM Dienst wird pauschal das PI neu gestartet und damit dann auch FHEM.
((( Die Error Meldung kam nachvollziehbar bei jedem Aufblinken des LED Bandes - wäre es der Absturzgrund, müsste FHEM bei Blinken der LEDs sterben - tut es aber nicht...es wird bei Fenster schließen korrekt das Blinken unterbrochen etc....."irgendwas" danach muss noch passiert sein.)))
viegener
Gut, dann ist zumindest ein Fehler behoben  ;)
und klar, das hatte ich angenommen, dass da irgendeine Überwachung läuft und nicht irgendetwas Amok läuft...
Wenn es nicht der Grund für den Absturz ist, dann ist weitersuchen angesagt...
Kharim
Guten Morgen Zusammen,
Ich glaube diese Nacht war der Teufel los.....mein Pi hat laut E-Mail Benachrichtigung und zugehörigem Log 6 Mal in kurzer Zeit neu gestartet.
Eigenartiger Weise ist das FHEM Log zu dieser Zeit leer.....
2015.12.28 21:18:17 5: exec at command CreditsScript
2015.12.28 21:18:17 5: Cmd: >{my $value=fhem("get Cube credit10ms");;fhem("set aktCredits $value")}<
2015.12.28 21:18:17 5: Cmd: >get Cube credit10ms<
2015.12.28 21:18:17 3: get Cube credit10ms : Cube credit10ms => 1681
2015.12.28 21:18:17 5: Cmd: >set aktCredits Cube credit10ms => 1681<
2015.12.28 21:18:17 4: dummy set aktCredits Cube credit10ms => 1681
2015.12.28 21:18:17 5: Triggering aktCredits (1 changes)
2015.12.28 21:18:17 5: Notify loop for aktCredits Cube credit10ms => 1681
2015.12.28 21:18:17 5: redefine at command CreditsScript as +*00:05:00 {my $value=fhem("get Cube credit10ms");;fhem("set aktCredits $value")}
2015.12.28 21:44:37 2: MAX MaxScan: UtilsMaxScan_Initialize.86 MaxScan is starting
2015.12.28 21:44:37 5: Initializing Type Library:
2015.12.28 21:44:37 1: Including fhem.cfg
2015.12.28 21:44:37 5: Cmd: >attr global userattr cmdIcon devStateIcon devStateStyle fm_fav fm_groups fm_name fm_order fp_Grundriss icon sortby structexclude webCmd widgetOverride<
2015.12.28 21:44:37 5: Cmd: >attr global autoload_undefined_devices 1<
2015.12.28 21:44:37 5: Cmd: >attr global logfile ./log/fhem/fhem-%Y-%m.log<
2015.12.28 21:44:37 5: Cmd: >attr global modpath .<
2015.12.28 21:44:37 5: Cmd: >attr global motd Error messages while initializing FHEM:
statefile: ProgrammBad
ProgrammBad
ProgrammBad
ProgrammKinderzimmer
ProgrammKueche
ProgrammKueche
ProgrammKueche
ProgrammWohnzimmer
ProgrammWohnzimmer
ProgrammWohnzimmer<
2015.12.28 21:44:37 5: Cmd: >attr global statefile ./log/fhem.save<
2015.12.28 21:44:37 5: Cmd: >attr global updateInBackground 1<
2015.12.28 21:44:37 5: Cmd: >attr global verbose 5<
Reboot-Log:
Mo 28. Dez 21:20:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:23:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:26:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:29:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:32:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:35:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:38:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:41:01 CET 2015 FHEM-Reboot
Mo 28. Dez 21:44:01 CET 2015 FHEM-Reboot
(Das Script auf Systemebene prüft alle 5 Minuten ob der FHEM Dienst noch läuft (CronJob alle 3 Minuten + 2 Minuten Wartezeit im Script zur Vermeidung einer Rebootschleife))
Klar, die Vermutung liegt nahe, dass FHEM gar nicht erst gestartet wurde....fragt sich nur warum und wieso der erste Absturz entstand.....
viegener
Klingt nicht gut.
Da der log file weiterhin nichts hergibt fängt jetzt vermutlich eine grössere Suche an. Vorschläge:
- Sagt /var/log/syslog irgendetwas (vielleicht auch alte Dateien .1 etc)?
- Übertaktung? Wenn ja runterdrehen auf Standard
- Netzteil austauschen? Klingt banal, aber kann immer Einfluss auf die Stabilität des PI haben (normalerweise allerdings nicht auf einen einzelnen Prozess)
- Bist Du sicher, dass Dein Überwachungsskript nicht Amok läuft und nur annimmt FHEM läuft nicht mehr?
Dann würde ich anfangen Ursachen in FHEM auszuschliessen:
- Alle nicht zum Betrieb absolut notwendigen Teile von FHEM zeitweise inaktivieren -> Damit Du einen Basisstand hast, der notwendig ist und dann sehen kannst ob davon etwas Probleme macht (z.B. SYSMON?)
- Teile, die externe Programme oder Libraries nutzen sind per se eher verdächtig, da u.U. bei Problemen keine Rückmeldung an FHEM/Perl mehr ankommt (wie bei Dir) --> Diese würde ich wenn möglich zeitweise deaktivieren
Wie gesagt Stochern im Dunkeln, das sind Ansatzpunkte. Viel Glück bei der Suche!
