unsupported character in reading ... notify the OWServer module maitainer
Begonnen von octek0815, 04 Januar 2016, 20:52:54
octek0815
bekomme seit dem Update von Heute folgende Meldungen im Logfile:
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/directory (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/ftp (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/ha7 (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/network (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/presence (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/serial (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/server (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/stable (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/uncached (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/usb (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/volatile (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/timeout/w1 (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/units/pressure_scale (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading /settings/units/temperature_scale (not A-Za-z\d_\.-), notify the OWServer module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading .OW_Strom_Gas_Zaehler:displayA (not A-Za-z\d_\.-), notify the statistics module maintainer.
2016.01.04 18:57:46 3: WARNING: unsupported character in reading .OW_Strom_Gas_Zaehler:displayB (not A-Za-z\d_\.-), notify the statistics module maintainer.
Wird hier schon an einer Lösung gearbeitet?
Olli
Dr. Boris Neubert
mache bitte morgen ein Update. Dann ist das wieder weg. Sonst bitte wieder hier melden.
Boris
Globaler Moderator, Developer, aktives Mitglied des FHEM e.V. (Marketing, Verwaltung)
octek0815
Hallo Boris,
danke für die schnelle Antwort.
Mach ich. Ich gebe dir Bescheid ob alles wieder Ok ist.
Oliver
octek0815
Boris
Hallo Boris,
die Meldungen sind nun weg.
Grüße und danke.
Olli
cruser1800
ich hatte die Meldungen auch schon bemerkt und Heute das Update gemacht. Leider sind die Meldungen (nur beim Start von FHEM) immernoch da! Oder ist es Modulbezogen? Bei mir 'dummy' und 'statistics' Modul!
2016.01.06 20:03:24 3: WARNING: unsupported character in reading Haustür (not A-Za-z/\d_\.-), notify the dummy module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Gaszaehler:gasCnt (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Gaszaehler:gasPowerDay (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Gaszaehler:gasPowerHour (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Gaszaehler:gasPowerMonth (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Gaszaehler:gasPowerYear (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .001_Wetterstation:rain (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .001_Wetterstation:rain_calc_h_currDay (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .001_Wetterstation:rain_calc_h_currHour (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .001_Wetterstation:rain_calc_h_currMonth (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .001_Wetterstation:rain_calc_h_currYear (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Stromzaehler:energy (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Stromzaehler:powerDay (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Stromzaehler:powerHour (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Stromzaehler:powerMonth (not A-Za-z/\d_\.-), notify the statistics module maintainer.
2016.01.06 20:03:24 3: WARNING: unsupported character in reading .Stromzaehler:powerYear (not A-Za-z/\d_\.-), notify the statistics module maintainer.
Gruß Lutz
octek0815
Gruß Lutz
du musst schon schauen von welchem Modul die Meldungen kommen.
Bei mir ging es um des OWSERVER Modul, und diese Meldungen sind dank Boris definitiv weg.
Bei deinen Meldungen geht es um das statistics und dummy Modul.
Diese habe ich leider auch.
Olli
cruser1800
dev0
Für das Reading Haustür im Dummy device bist du wohl selbst verantwortlich ;)
cruser1800
Danke für die Antworten! Wuste nicht, dass FHEM auf die Umlaute so reagiert! ;)
