HCS - eco mode not setting properly
Begonnen von gw0udm, 22 Januar 2016, 19:02:00
gw0udm
Hi
I am using HCS with MAX thermostats. I am using eco mode for when I am out of the house or overnight. My HCS module is named 'HeatingControl'
I have found that if you issue the command;
Zitatset HeatingControl eco on
the eco mode does not take effect unless you restart the HCS with
Zitatset HeatingControl on
This is a little awkward when changing modes automatically as really I'd like to switch eco on and off without restarting the whole service.
Am I doing something wrong? The documentation suggests that you should just be able to issue the 'eco' command by itself
Thanks
James
fruit
HCS is not a module I have used but could you restart HCS from a notify?
Are you able to see any more info from verbose 5?
If not you could add some additional debug log lines to the module (before reloading it), they may help you see what is happening.
Feel free to follow up in German if you prefer
gw0udm
Thanks
The logging does show the change in mode - it says something like "switching mode to eco". However, it doesn't actually do anything unless you then switch the module on again with 'set HCS on'
It may well be that this is by design, but it is a bit irritating because I've been trying to change eco mode whether HCS is on or not. So in other words if HCS is off, then I might inadvertenly switch it on by changing eco mode.
I've found a way round this now using IF statements but I'd still be interested to know whether HCS is meant to work this way. I feel it should be possible to change modes without reinitialising the module separately.
JAmes
stromer-12
I have HomeMatic RT. set HSC eco on works here after interval time.
FHEM (SVN) auf RPi1B mit HMser | ESPLink
FHEM (SVN) virtuell mit HMLAN | HMUSB | CUL
gw0udm
Thanks - I think I understand now! That makes sense. So I need to wait for the interval to refresh and at that point it will set the mode.
As above I have found a work around but I'm glad I understand how it works.
James
