MySensors - Parking Sensor
Begonnen von zurli, 24 Januar 2016, 15:49:53
zurli
Hallo zusammen
Ich habe das Beispiel Parking getestet und mit einer Antenne zum Gateway gesendet.
Code Arduino:
* The MySensors Arduino library handles the wireless radio link and protocol
* between your home built sensors/actuators and HA controller of choice.
* The sensors forms a self healing radio network with optional repeaters. Each
* repeater and gateway builds a routing tables in EEPROM which keeps track of the
* network topology allowing messages to be routed to nodes.
* Created by Henrik Ekblad <henrik.ekblad@mysensors.org>
* Copyright (C) 2013-2015 Sensnology AB
* Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
* Documentation: http://www.mysensors.org
* Support Forum: http://forum.mysensors.org
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License
* version 2 as published by the Free Software Foundation.
* REVISION HISTORY
* Version 1.0 - Created by Henrik Ekblad
* DESCRIPTION
* Parking sensor using a neopixel led ring and distance sensor (HC-SR04).
* Configure the digital pins used for distance sensor and neopixels below.
* NOTE! Remeber to feed leds and distance sensor serparatly from your Arduino.
* It will probably not survive feeding more than a couple of LEDs. You
* can also adjust intesity below to reduce the power requirements.
* Sends parking status to the controller as a DOOR sensor if SEND_STATUS_TO_CONTROLLER
* is defined below. You can also use this _standalone_ without any radio by
* removing the SEND_STATUS_TO_CONTROLLER define.
#define SEND_STATUS_TO_CONTROLLER  // Put a comment on this line for standalone mode
#include <Adafruit_NeoPixel.h>
#include <NewPing.h>
#ifdef SEND_STATUS_TO_CONTROLLER
#include <SPI.h>
#include <MySensor.h>
#endif
#define NEO_PIN      4 // NeoPixels input pin
#define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define NUMPIXELS      24 // Number of nexpixels in ring/strip
#define MAX_INTESITY   10  // Intesity of leds (in percentage). Remeber more intesity requires more power.
// The maximum rated measuring range for the HC-SR04 is about 400-500cm.
#define MAX_DISTANCE 120 // Max distance we want to start indicating green (in cm)
#define PANIC_DISTANCE 30 // Mix distance we red warning indication should be active (in cm)
#define PARKED_DISTANCE 50 // Distance when "parked signal" should be sent to controller (in cm)
#define PARK_OFF_TIMEOUT 20000 // Number of milliseconds until turning off light when parked.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, NEO_PIN, NEO_GRB + NEO_KHZ400);
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
#define CHILD_ID 1
MySensor gw;
MyMessage msg(CHILD_ID,V_TRIPPED);
#endif
unsigned long sendInterval = 5000;  // Send park status at maximum every 5 second.
unsigned long lastSend;
int oldParkedStatus=-1;
unsigned long blinkInterval = 100; // blink interval (milliseconds)
unsigned long lastBlinkPeriod;
bool blinkColor = true;
// To make a fading motion on the led ring/tape we only move one pixel/distDebounce time
unsigned long distDebounce = 30;
unsigned long lastDebouncePeriod;
int numLightPixels=0;
int skipZero=0;
void setup() {
  Serial.begin(115200);
  Serial.println("Starting distance sensor");
  pixels.begin(); // This initializes the NeoPixel library.
  Serial.println("Neopixels initialized");
  gw.begin();
  gw.sendSketchInfo("Parking Sensor", "1.0");
  gw.present(CHILD_ID, S_DOOR, "Parking Status");
#endif
void loop() {
  unsigned long now = millis();
  int fullDist = sonar.ping_cm();
//  Serial.println(fullDist);
  int displayDist = min(fullDist, MAX_DISTANCE);
  if (displayDist == 0 && skipZero<10) {
    // Try to filter zero readings
    skipZero++;
    return;
  // Check if it is time to alter the leds
  if (now-lastDebouncePeriod > distDebounce) {
    lastDebouncePeriod = now;
    // Update parked status
    int parked = displayDist != 0 && displayDist<PARKED_DISTANCE;
    if (parked != oldParkedStatus && now-lastSend > sendInterval) {
      if (parked)
        Serial.println("Car Parked");
      else
        Serial.println("Car Gone");
      gw.send(msg.set(parked));
#endif
      oldParkedStatus = parked;
      lastSend = now;
    if (parked && now-lastSend > PARK_OFF_TIMEOUT) {
      // We've been parked for a while now. Turn off all pixels
      for(int i=0;i<NUMPIXELS;i++){
        pixels.setPixelColor(i, pixels.Color(0,0,0));
    } else {
      if (displayDist == 0) {
        // No reading from sensor, assume no object found
        numLightPixels--;
      } else {
        skipZero = 0;
        int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/MAX_DISTANCE);
        if (newLightPixels>numLightPixels) {
          // Fast raise
          numLightPixels += max((newLightPixels - numLightPixels) / 2, 1);
        } else if (newLightPixels<numLightPixels) {
          // Slow decent
          numLightPixels--;
      if (numLightPixels>=NUMPIXELS) {
        // Do some intense red blinking
        if (now-lastBlinkPeriod > blinkInterval) {
          blinkColor = !blinkColor;
          lastBlinkPeriod = now;
        for(int i=0;i<numLightPixels;i++){
          pixels.setPixelColor(i, pixels.Color(blinkColor?255*MAX_INTESITY/100:0,0,0));
      } else {
          int r = 255 * i/NUMPIXELS;
          int g = 255 - r;
          // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
          pixels.setPixelColor(i, pixels.Color(r*MAX_INTESITY/100,g*MAX_INTESITY/100,0));
        // Turn off the rest
        for(int i=numLightPixels;i<NUMPIXELS;i++){
    pixels.show(); // This sends the updated pixel color to the hardware.
Im FHEM wird der Parksensor erkannt, jedoch sind die Readings meiner Meinung nach vom Fensteröffner.
(http://imageshack.com/a/img633/8932/kMkmwn.png)
Wie kann ich den Status Car parked / Car gone in FHEM anzeigen?
Wird dieser Sketch von FHEM schon unterstützt?
Gruss Zurli
Hauswart
Schaue es mir morgen an. Gruß
1. Installation:
KNX, Tasmota (KNX), Sonos, Unifi
2. Installation:
HM-CFG-USB, Unifi (, SIGNALduino 868, MySensors, SIGNALduino 433)
Hauswart
Du hast Recht im Sketch werden die Variablen des Fensteröffners verwendet:
Zitat* Sends parking status to the controller as a DOOR sensor if SEND_STATUS_TO_CONTROLLER
Er sendet also nur einen Status "geparkt" oder "nicht geparkt" an FHEM.
1. Installation:
2. Installation:
