homebridge/homekit
Begonnen von justme1968, 01 Februar 2016, 16:16:37
Yil
ich hab mir meine Homebridge-Installation verschlimmbessert und bekomme sie nicht mehr zum Laufen. Hat jemand eine gute Deinstallationsbeschreibung, damit ich nochmal neu aufsetzen kann?
Das zeigt der Raspi an, wenn ich Homebridge starten möchte:
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[Fri Dec 09 2016 19:41:29 GMT+0100 (CET)] Loaded plugin: homebridge-fhem
homebridge API version: 2.1
this homebridge-fhem 0.2.65
[Fri Dec 09 2016 19:41:29 GMT+0100 (CET)] Registering platform 'homebridge-fhem.FHEM'
[Fri Dec 09 2016 19:41:29 GMT+0100 (CET)] ---
[Fri Dec 09 2016 19:41:29 GMT+0100 (CET)] Loaded plugin: homebridge-harmonyhub
[Fri Dec 09 2016 19:41:32 GMT+0100 (CET)] Registering platform 'homebridge-harmonyhub.HarmonyHub'
[Fri Dec 09 2016 19:41:32 GMT+0100 (CET)] ---
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] Loaded plugin: homebridge-homematic
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] Registering platform 'homebridge-homematic.HomeMatic'
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] ---
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] ====================
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] ERROR LOADING PLUGIN homebridge-lightify:
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
    at exports.runInThisContext (vm.js:53:16)
    at Module._compile (module.js:414:25)
    at Object.Module._extensions..js (module.js:442:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:311:12)
    at Module.require (module.js:366:17)
    at require (module.js:385:17)
    at Plugin.load (/usr/local/lib/node_modules/homebridge/lib/plugin.js:65:22)
    at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:131:14)
    at Array.forEach (native)
    at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:127:22)
    at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:50:24)
    at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
    at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:435:26)
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] Loaded config.json with 0 accessories and 2 platforms.
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] Loading 2 platforms...
[Fri Dec 09 2016 19:41:34 GMT+0100 (CET)] [FHEM] Initializing FHEM platform...
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [FHEM] Checking devices and attributes...
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D&XHR=1
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20TYPE=siri&XHR=1
starting longpoll: http://127.0.0.1:8083/fhem.pl?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON&timestamp=1481308896431
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [FHEM] Fetching FHEM devices...
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [FHEM] fetching: http://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=Homekit&XHR=1
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Initializing HomeMatic platform...
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Homematic Plugin Version 0.0.55
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Plugin by thkl  https://github.com/thkl
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Homematic is a registered trademark of the EQ-3 AG
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Please report any issues to https://github.com/thkl/homebridge-homematic/issues
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] init RPC
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Local IP: 192.168.1.5
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] XML-RPC server for interface BidCos-RF.is listening on port 9090
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Creating Local HTTP Client for CCU RPC Events
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] CCU RPC Init Call on port 2001 for interface BidCos-RF.
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [HomeMatic CCU] Fetching Homematic devices...
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] Loading 0 accessories...
Load homebridge-harmonyhub.HarmonyHub
[Fri Dec 09 2016 19:41:36 GMT+0100 (CET)] [homebridge-harmonyhub.HarmonyHub] Ignoring Harmony Platform setup because it is not configured
Server error: Error: listen EADDRINUSE :::8282
Server listening on: http://<ip>:8283
events.js:141
      throw er; // Unhandled 'error' event
Error: listen EADDRINUSE 192.168.1.5:9090
    at Object.exports._errnoException (util.js:874:11)
    at exports._exceptionWithHostPort (util.js:897:20)
    at Server._listen2 (net.js:1234:14)
    at listen (net.js:1270:10)
    at net.js:1379:9
    at doNTCallback3 (node.js:450:9)
    at process._tickCallback (node.js:356:17)
    at Function.Module.runMain (module.js:469:11)
    at startup (node.js:134:18)
    at node.js:961:3
Vielen Dank im voraus!
HM CCU3 und HCU mit ca. 50 HM-Komponenten inkl. Bausätzen
fhem auf RPi mit Sonos, EnOcean-CUL, ZWAVE-CUL und Bluetooth,
HUE, UniFi
justme1968
das schaut aus als ob noch etwas läuft und du versuchts noch mal zu starten.
warum verwendest du die ganzen plugins und machst nicht alles über das fhem plugin? das ist resource schonender.
Praktiker
Hallo FHEM Gemeinde
Ich habe heute gemerkt das ich mit "Siri öffne die Haustür " nur noch die Tür ausschließen kann aber nicht mehr öffnen.
Bis vor kurzem ging es. Kann aber nicht genau sag n seit wann nicht mehr.
Aktor ist ein hm-sec-key
Kennt jemand das Problem?
Grüße aus dem Pott
Praktiker
Yil
also müsste ich nur homebridge-fhem als plugin installieren?
HUE, UniFi
homekid
Hallo
Ich Kämpfe immer noch mit meinem GarageDoorOpener und irgendwie bekomme ich es nicht hin
Habe einen Dummy konfiguriert der die "Jalousie" entsprechend öffnen und schliessen soll (0/100).
currentDoorState=tahoma_495548:position,values=100:CLOSED;0:OPEN
TargetDoorState=dim:tahoma_495548:setClosure,values=open:OPEN;close:CLOSE
Vielleicht hat jemand eine Lösung für mich, vorab vielen Dank
WolfgangV
seit einigen Tagen funktioniert meine Hombridge Installation nicht mehr. Sie hat vorher über Monate tadellos funktioniert. Jetzt erhalte ich in der Home-app die Meldung:"keine Antwort".
Auch zwei verschiedene Rücksicherungen von funktinierenden Installationen auf die SD-Karte des Raspi haben nichts gefruchtet. Also liegt eigentlich die Vermutung nahe, dass irgendwas am Iphone geändert wurde. Allerdings habe ich da bewusst nichts verändert und bis jetzt ziemlich ratlos.
Wenn ich Homebridge händisch auf dem Raspi starte, kommt gleich am Anfang die Meldung: "no siri device found. please define it".
Liegt es also doch am Handy?????
pi@raspberrypi:~ $ homebridge
*** WARNING *** The program 'nodejs' uses the Apple Bonjour compatibility layer                                                         of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd                                                        ns_sd&e=nodejs>
*** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not                                                         supported (or only supported partially) in the Apple Bonjour compatibility layer                                                         of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd                                                        ns_sd&e=nodejs&f=DNSServiceRegister>
[12/13/2016, 1:49:53 PM] Loaded plugin: homebridge-fhem
this homebridge-fhem 0.2.67
[12/13/2016, 1:49:53 PM] Registering platform 'homebridge-fhem.FHEM'
[12/13/2016, 1:49:53 PM] ---
[12/13/2016, 1:49:53 PM] Loaded config.json with 0 accessories and 1 platforms.
[12/13/2016, 1:49:53 PM] Loading 1 platforms...
[12/13/2016, 1:49:53 PM] [FHEM] Initializing FHEM platform...
[12/13/2016, 1:49:54 PM] [FHEM] Checking devices and attributes...
[12/13/2016, 1:49:54 PM] [FHEM]   executing: https://127.0.0.1:8083/fhem?cmd=%7B                                                        AttrVal(%22global%22,%22userattr%22,%22%22)%7D&XHR=1
[12/13/2016, 1:49:54 PM] [FHEM]   executing: https://127.0.0.1:8083/fhem?cmd=jso                                                        nlist2%20TYPE=siri&XHR=1
starting longpoll: https://127.0.0.1:8083/fhem.pl?XHR=1&inform=type=status;addgl                                                        obal=1;filter=.*;since=null;fmt=JSON&timestamp=1481633394293
[12/13/2016, 1:49:54 PM] [FHEM] Fetching FHEM devices...
[12/13/2016, 1:49:54 PM] [FHEM] fetching: https://127.0.0.1:8083/fhem?cmd=jsonli                                                        st2%20room=Homekit&XHR=1
[12/13/2016, 1:49:54 PM] Loading 0 accessories...
Server listening on: http://<ip>:8282
[12/13/2016, 1:49:54 PM] [FHEM] no siri device found. please define it.
[12/13/2016, 1:49:56 PM] [FHEM] got: 56 results
[12/13/2016, 1:49:56 PM] [FHEM] Ambilight is light
Wolfgang
Raspi5  HmUART, Jeelink, VU+Duo2, Viera, Sonos, HM-CC-RT-DN,
HM-WDS30-OT2-SM, HM-LC-Dim1TPBU-FM,
Jeelink, TUL
gloob
#1731
Wenn ich die Fehlermeldung richtig verstehe musst du ein Siri Device in deinem FHEM konfigurieren.
Hat sich vielleicht die IP Adresse von deinem FHEM geändert?
Siehe Commandref:
siri
Module to control the FHEM/Siri integration.
Notes: ◦
Attr ◦siriName
The name to use for a device with siri.
http://fhem.de/commandref.html#siri
WolfgangV
ZitatWenn ich die Fehlermeldung richtig verstehe musst du ein Siri Device in deinem FHEM konfigurieren.
Das ist ja das erste, was ich in dieser Hinsicht lese. Ist das neu? Auch im Wiki taucht sowas überhaupt nicht auf.
Und wie muss ich das Device definieren und benennen?
Die Fehlermeldung taucht jetzt nicht mehr beim Raspi-Start von Homebridge auf, aber anscheinend habe ich noch nicht den richtigen Namen ausgewählt.
Habe erfolglos "Homebridge" (so wird es auf dem Iphone gefunden) und die IP-Adresse des Raspi versucht.
Wolfgang
Jeelink, TUL
gloob
Im Wiki wird sogar empfohlen ein Alexa Device anzulegen:
ZitatFHEM konfigurieren
Es empfiehlt sich ein alexa Gerät in FHEM anzulegen.
Die benötigten Attribute werden inzwischen beim ersten Start des von hombridge-fhem automatisch auf FHEM Seite eingetragen.
Mehr zu den inzwischen verfügbaren Konfigurationsmöglichkeiten findet sich auf den github und npmjs Seiten des Plugins und im ersten Beitrag des zugehörigen Thread im Diskussion im FHEM-Forum
https://wiki.fhem.de/wiki/Homebridge_einrichten#FHEM_konfigurieren
WolfgangV
ZitatEs empfiehlt sich ein alexa Gerät in FHEM anzulegen.
Ich verfolge die Diskussionen hier nicht so intensiv. Die Integration von alexa hat erst im November begonnen, soweit ich das rückwirkend lesen konnte.
Heißt das also, dass es jetzt nicht mehr ohne alexa geht???
Hätte ich das gewusst, hätte ich auf die letzten Fhem-Updates verzichtet.
Ich war eigentlich bislang ganz zufrieden und froh, nicht schon wieder irgendwelche frickeligen Installationen durchführen zu müssen, bei denen man wie in der Homebridge-Anfangszeit ziemlich schnell scheitern konnte.
Nochmal meine Frage: Wie muss ich denn das siri-device definieren?
Wolfgang
Jeelink, TUL
justme1968
das ist keine fehler meldung sondern ein hinweis. es läuft prinzipiell auch alles ohne siri device.
das im wiki ist ein tippfehler. es muss in diesem fall siri device heissen.
fhem updates haben damit nichts zu tun. du hast scheinbar homebrige-fhem aktualisiert.
das siri device definiert man wie jedes andere device auch in in der commandref beschrieben so: define siri siri
ansonsten: ja, alexa-fhem und homebridge-fhem werden demnächst zusammengeführt. das hat aber weder auf bestehende laufende installationen einfluss noch ändert es irgendetwas für jemanden der nur homebridge verwendet.
WolfgangV
Zitatfhem updates haben damit nichts zu tun. du hast scheinbar homebrige-fhem aktualisiert.
Die Veränderung habe ich vorgenommen, nachdem Homebridge nicht mehr laufen wollte, weil ich dachte, vielleicht liegts an dem fehlenden Update...
mit oder ohne definierte siri funktioniert es aber trotzdem nicht.
Die folgenden Meldungen stammen jetzt von einem gerade eingespielten Backup, bei dem ich noch nichts an homebridge-fhem verändert hatte.
$ homebridge
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs&f=DNSServiceRegister>
[12/13/2016, 5:33:45 PM] Loaded plugin: homebridge-fhem
[12/13/2016, 5:33:45 PM] Registering platform 'homebridge-fhem.FHEM'
[12/13/2016, 5:33:45 PM] ---
[12/13/2016, 5:33:45 PM] Loaded config.json with 0 accessories and 1 platforms.
[12/13/2016, 5:33:45 PM] Loading 1 platforms...
[12/13/2016, 5:33:45 PM] [FHEM] Initializing FHEM platform...
starting longpoll: https://127.0.0.1:8083/fhem.pl?XHR=1&inform=type=status;addglobal=1;filter=.*;since=null;fmt=JSON&timestamp=1481646826559
[12/13/2016, 5:33:46 PM] [FHEM] Checking genericDeviceType...
[12/13/2016, 5:33:46 PM] [FHEM]   executing: https://127.0.0.1:8083/fhem?cmd=%7BAttrVal(%22global%22,%22userattr%22,%22%22)%7D&XHR=1
[12/13/2016, 5:33:46 PM] [FHEM] Fetching FHEM devices...
[12/13/2016, 5:33:46 PM] [FHEM] fetching: https://127.0.0.1:8083/fhem?cmd=jsonlist2%20room=Homekit&XHR=1
[12/13/2016, 5:33:46 PM] Loading 0 accessories...
[12/13/2016, 5:33:50 PM] [FHEM] got: 56 results
light
Wolfgang
Jeelink, TUL
justme1968
das log muss noch weiter gehen
WolfgangV
wollte dir nicht den kompletten Bandwurm zumuten  ;)
Biddeschöön:
Die Geräte sprechen  auf dem Iphone weiterhin nicht an. Merkwürdigerweise ist aber der Bewegungsmelder_Hof, den ich vorher nicht im Raum Homekit hatte, jetzt bei Eve im Standardraum enthalten.
[code]:~ $ homebridge
[12/13/2016, 5:57:54 PM] Loaded plugin: homebridge-fhem
[12/13/2016, 5:57:54 PM] Registering platform 'homebridge-fhem.FHEM'
[12/13/2016, 5:57:54 PM] ---
[12/13/2016, 5:57:54 PM] Loaded config.json with 0 accessories and 1 platforms.
[12/13/2016, 5:57:54 PM] Loading 1 platforms...
[12/13/2016, 5:57:54 PM] [FHEM] Initializing FHEM platform...
starting longpoll: https://127.0.0.1:8083/fhem.pl?XHR=1&inform=type=status;addgl                   obal=1;filter=.*;since=null;fmt=JSON&timestamp=1481648275470
[12/13/2016, 5:57:55 PM] [FHEM] Checking genericDeviceType...
[12/13/2016, 5:57:55 PM] [FHEM]   executing: https://127.0.0.1:8083/fhem?cmd=%7B                   AttrVal(%22global%22,%22userattr%22,%22%22)%7D&XHR=1
[12/13/2016, 5:57:55 PM] [FHEM] Fetching FHEM devices...
[12/13/2016, 5:57:55 PM] [FHEM] fetching: https://127.0.0.1:8083/fhem?cmd=jsonli                   st2%20room=Homekit&XHR=1
[12/13/2016, 5:57:55 PM] Loading 0 accessories...
[12/13/2016, 5:57:57 PM] [FHEM] got: 56 results
light
[12/13/2016, 5:57:57 PM] [FHEM] Ambilight is light
[12/13/2016, 5:57:57 PM] [FHEM] Ambilight has
[12/13/2016, 5:57:57 PM] [FHEM]   On [onoff;on,off]
[12/13/2016, 5:57:57 PM] [FHEM]   Brightness [brightness]
[12/13/2016, 5:57:57 PM] [FHEM]   Hue [hue;hue;0-359]
[12/13/2016, 5:57:57 PM] [FHEM]   Saturation [saturation;saturation;0-100]
  2016-12-13 17:57:57 caching: Ambilight-brightness: 0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: Brightness: 0 (as number; from '0')
  2016-12-13 17:57:57 caching: Ambilight-hue: 0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: Hue: 0 (as number; from '0')
  2016-12-13 17:57:57 caching: Ambilight-saturation: 0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: Saturation: 0 (as number; from '0')
thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Arbeitszimmer_Clima is thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Arbeitszimmer_Clima has
[12/13/2016, 5:57:57 PM] [FHEM]   CurrentTemperature [measured-temp]
[12/13/2016, 5:57:57 PM] [FHEM]   TargetTemperature [desired-temp]
  2016-12-13 17:57:57 caching: Arbeitszimmer_Clima-measured-temp: 19.4
[12/13/2016, 5:57:57 PM] [FHEM]     caching: CurrentTemperature: 19.4 (as number                   ; from '19.4')
  2016-12-13 17:57:57 caching: Arbeitszimmer_Clima-desired-temp: 18.0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: TargetTemperature: 18 (as number; f                   rom '18.0')
switch
[12/13/2016, 5:57:57 PM] [FHEM] Aussenschalter_2 is switch
[12/13/2016, 5:57:57 PM] [FHEM] Aussenschalter_2 has
[12/13/2016, 5:57:57 PM] [FHEM]   FirmwareRevision [D-firmware]
[12/13/2016, 5:57:57 PM] [FHEM]   On [state;on,off]
  2016-12-13 17:57:57 caching: Aussenschalter_2-D-firmware: 2.5
[12/13/2016, 5:57:57 PM] [FHEM]     caching: FirmwareRevision: 2.5 (as string; f                   rom '2.5')
  2016-12-13 17:57:57 caching: Aussenschalter_2-state: on
[12/13/2016, 5:57:57 PM] [FHEM]     caching: On: true (as boolean; from 'on')
thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Bad_oben_Clima is thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Bad_oben_Clima has
  2016-12-13 17:57:57 caching: Bad_oben_Clima-measured-temp: 20.6
[12/13/2016, 5:57:57 PM] [FHEM]     caching: CurrentTemperature: 20.6 (as number                   ; from '20.6')
  2016-12-13 17:57:57 caching: Bad_oben_Clima-desired-temp: 19.0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: TargetTemperature: 19 (as number; f                   rom '19.0')
thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Bad_unten_Clima is thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Bad_unten_Clima has
  2016-12-13 17:57:57 caching: Bad_unten_Clima-measured-temp: 21.7
[12/13/2016, 5:57:57 PM] [FHEM]     caching: CurrentTemperature: 21.7 (as number                   ; from '21.7')
  2016-12-13 17:57:57 caching: Bad_unten_Clima-desired-temp: 22.0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: TargetTemperature: 22 (as number; f                   rom '22.0')
undefined
[12/13/2016, 5:57:57 PM] [FHEM] Bewegungsmelder_Hof: no service type detected
[12/13/2016, 5:57:57 PM] [FHEM] no accessory created for Bewegungsmelder_Hof (CU                   L_HM)
thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Dach_links_Clima is thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Dach_links_Clima has
  2016-12-13 17:57:57 caching: Dach_links_Clima-measured-temp: 22.8
[12/13/2016, 5:57:57 PM] [FHEM]     caching: CurrentTemperature: 22.8 (as number                   ; from '22.8')
  2016-12-13 17:57:57 caching: Dach_links_Clima-desired-temp: 23.0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: TargetTemperature: 23 (as number; f                   rom '23.0')
thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Dach_rechts_Clima is thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Dach_rechts_Clima has
  2016-12-13 17:57:57 caching: Dach_rechts_Clima-measured-temp: 23.3
[12/13/2016, 5:57:57 PM] [FHEM]     caching: CurrentTemperature: 23.3 (as number                   ; from '23.3')
  2016-12-13 17:57:57 caching: Dach_rechts_Clima-desired-temp: 23.0
light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Bad_oben_Sw is light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Bad_oben_Sw has
[12/13/2016, 5:57:57 PM] [FHEM]   On [pct;on,off]
[12/13/2016, 5:57:57 PM] [FHEM]   Brightness [pct]
  2016-12-13 17:57:57 caching: Dimmer_Bad_oben_Sw-pct: 0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: On: false (as boolean; from '0')
light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Eingang_Sw is light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Eingang_Sw has
  2016-12-13 17:57:57 caching: Dimmer_Eingang_Sw-pct: 0
light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Flur_Bad_oben_Sw is light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Flur_Bad_oben_Sw has
  2016-12-13 17:57:57 caching: Dimmer_Flur_Bad_oben_Sw-pct: 0
light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Flur_oben_Sw is light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Flur_oben_Sw has
  2016-12-13 17:57:57 caching: Dimmer_Flur_oben_Sw-pct: 0
light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Flur_unten_Sw is light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Flur_unten_Sw has
  2016-12-13 17:57:57 caching: Dimmer_Flur_unten_Sw-pct: 0
light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Wohnzimmer_Sw1 is light
[12/13/2016, 5:57:57 PM] [FHEM] Dimmer_Wohnzimmer_Sw1 has
  2016-12-13 17:57:57 caching: Dimmer_Wohnzimmer_Sw1-pct: 8
[12/13/2016, 5:57:57 PM] [FHEM]     caching: On: true (as boolean; from '8')
[12/13/2016, 5:57:57 PM] [FHEM]     caching: Brightness: 8 (as number; from '8')
thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Flur_oben_Clima is thermostat
[12/13/2016, 5:57:57 PM] [FHEM] Flur_oben_Clima has
  2016-12-13 17:57:57 caching: Flur_oben_Clima-measured-temp: 17.5
[12/13/2016, 5:57:57 PM] [FHEM]     caching: CurrentTemperature: 17.5 (as number                   ; from '17.5')
  2016-12-13 17:57:57 caching: Flur_oben_Clima-desired-temp: 17.0
[12/13/2016, 5:57:57 PM] [FHEM]     caching: TargetTemperature: 17 (as number; f                   rom '17.0')
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Flur_unten_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Flur_unten_Clima has
[12/13/2016, 5:57:58 PM] [FHEM]   CurrentTemperature [measured-temp]
[12/13/2016, 5:57:58 PM] [FHEM]   TargetTemperature [desired-temp]
  2016-12-13 17:57:58 caching: Flur_unten_Clima-measured-temp: 14.7
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 14.7 (as number                   ; from '14.7')
  2016-12-13 17:57:58 caching: Flur_unten_Clima-desired-temp: 16.0
[12/13/2016, 5:57:58 PM] [FHEM]     caching: TargetTemperature: 16 (as number; f                   rom '16.0')
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Gaeste_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Gaeste_Clima has
  2016-12-13 17:57:58 caching: Gaeste_Clima-measured-temp: 12.3
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 12.3 (as number                   ; from '12.3')
  2016-12-13 17:57:58 caching: Gaeste_Clima-desired-temp: 12.0
[12/13/2016, 5:57:58 PM] [FHEM]     caching: TargetTemperature: 12 (as number; f                   rom '12.0')
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Garderobe_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Garderobe_Clima has
  2016-12-13 17:57:58 caching: Garderobe_Clima-measured-temp: 18.6
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 18.6 (as number                   ; from '18.6')
  2016-12-13 17:57:58 caching: Garderobe_Clima-desired-temp: 18.0
[12/13/2016, 5:57:58 PM] [FHEM]     caching: TargetTemperature: 18 (as number; f                   rom '18.0')
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Gartenkammer is thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Gartenkammer has
[12/13/2016, 5:57:58 PM] [FHEM]   CurrentTemperature [temperature]
[12/13/2016, 5:57:58 PM] [FHEM]   StatusLowBattery [battery]
  2016-12-13 17:57:58 caching: Gartenkammer-temperature: 5.9
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 5.9 (as number;                    from '5.9')
  2016-12-13 17:57:58 caching: Gartenkammer-battery: ok
[12/13/2016, 5:57:58 PM] [FHEM]     caching: StatusLowBattery: 0 (as number; mea                   ns BATTERY_LEVEL_NORMAL; from 'ok')
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Gewaechshaus is thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Gewaechshaus has
  2016-12-13 17:57:58 caching: Gewaechshaus-temperature: 4.4
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 4.4 (as number;                    from '4.4')
  2016-12-13 17:57:58 caching: Gewaechshaus-battery: ok
switch
[12/13/2016, 5:57:58 PM] [FHEM] Gewaechshausheizung_Sw is switch
[12/13/2016, 5:57:58 PM] [FHEM] Gewaechshausheizung_Sw has
[12/13/2016, 5:57:58 PM] [FHEM]   On [state;on,off]
  2016-12-13 17:57:58 caching: Gewaechshausheizung_Sw-state: off
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: false (as boolean; from 'off')
lock
[12/13/2016, 5:57:58 PM] [FHEM] Haustuerschloss is lock
[12/13/2016, 5:57:58 PM] [FHEM] Haustuerschloss has
[12/13/2016, 5:57:58 PM] [FHEM]   PositionState [direction]
[12/13/2016, 5:57:58 PM] [FHEM]   FirmwareRevision [D-firmware]
[12/13/2016, 5:57:58 PM] [FHEM]   TargetDoorState []
[12/13/2016, 5:57:58 PM] [FHEM]   LockCurrentState [lock]
[12/13/2016, 5:57:58 PM] [FHEM]   LockTargetState [lock]
  2016-12-13 17:57:58 caching: Haustuerschloss-direction: none
[12/13/2016, 5:57:58 PM] [FHEM]     caching: PositionState: 2 (as number; means                    STOPPED; from 'none')
  2016-12-13 17:57:58 caching: Haustuerschloss-battery: ok
  2016-12-13 17:57:58 caching: Haustuerschloss-D-firmware: 2.5
[12/13/2016, 5:57:58 PM] [FHEM]     caching: FirmwareRevision: 2.5 (as string; f                   rom '2.5')
[12/13/2016, 5:57:58 PM] [FHEM]     caching: TargetDoorState: 1 (as number; mean                   s CLOSED; from 'mapping.default')
  2016-12-13 17:57:58 caching: Haustuerschloss-lock: unlocked
[12/13/2016, 5:57:58 PM] [FHEM]     caching: LockCurrentState: 0 (as number; mea                   ns UNSECURED; from 'unlocked')
[12/13/2016, 5:57:58 PM] [FHEM]     caching: LockTargetState: 0 (as number; mean                   s UNSECURED; from 'unlocked')
switch
[12/13/2016, 5:57:58 PM] [FHEM] Heizungsschalter is switch
[12/13/2016, 5:57:58 PM] [FHEM] Heizungsschalter has
  2016-12-13 17:57:58 caching: Heizungsschalter-D-firmware: 1.12
[12/13/2016, 5:57:58 PM] [FHEM]     caching: FirmwareRevision: 1.12 (as string;                    from '1.12')
  2016-12-13 17:57:58 caching: Heizungsschalter-state: on
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: true (as boolean; from 'on')
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Hof is thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Hof has
  2016-12-13 17:57:58 caching: Hof-temperature: 4.4
  2016-12-13 17:57:58 caching: Hof-battery: ok
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Klavierzimmer_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Klavierzimmer_Clima has
  2016-12-13 17:57:58 caching: Klavierzimmer_Clima-measured-temp: 19.0
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 19 (as number;                    from '19.0')
  2016-12-13 17:57:58 caching: Klavierzimmer_Clima-desired-temp: 18.0
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Kleiderschrank_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Kleiderschrank_Clima has
  2016-12-13 17:57:58 caching: Kleiderschrank_Clima-measured-temp: 18.7
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 18.7 (as number                   ; from '18.7')
  2016-12-13 17:57:58 caching: Kleiderschrank_Clima-desired-temp: 18.0
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Klo_Clima is thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Klo_Clima has
  2016-12-13 17:57:58 caching: Klo_Clima-measured-temp: 20.9
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 20.9 (as number                   ; from '20.9')
  2016-12-13 17:57:58 caching: Klo_Clima-desired-temp: 21.0
[12/13/2016, 5:57:58 PM] [FHEM]     caching: TargetTemperature: 21 (as number; f                   rom '21.0')
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Kueche_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Kueche_Clima has
  2016-12-13 17:57:58 caching: Kueche_Clima-measured-temp: 20.4
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 20.4 (as number                   ; from '20.4')
  2016-12-13 17:57:58 caching: Kueche_Clima-desired-temp: 18.0
light
[12/13/2016, 5:57:58 PM] [FHEM] Licht_Kueche is light
[12/13/2016, 5:57:58 PM] [FHEM] Licht_Kueche has
[12/13/2016, 5:57:58 PM] [FHEM]   On [onoff;on,off]
[12/13/2016, 5:57:58 PM] [FHEM]   Brightness [bri]
[12/13/2016, 5:57:58 PM] [FHEM] Licht_Kueche-bri not a number: undefined
light
[12/13/2016, 5:57:58 PM] [FHEM] Licht_Wohnzimmerschrank is light
[12/13/2016, 5:57:58 PM] [FHEM] Licht_Wohnzimmerschrank has
[12/13/2016, 5:57:58 PM] [FHEM] Licht_Wohnzimmerschrank-bri not a number: undefi                   ned
light
[12/13/2016, 5:57:58 PM] [FHEM] Lichtschalter_Dach is light
[12/13/2016, 5:57:58 PM] [FHEM] Lichtschalter_Dach has
  2016-12-13 17:57:58 caching: Lichtschalter_Dach-D-firmware: 2.3
[12/13/2016, 5:57:58 PM] [FHEM]     caching: FirmwareRevision: 2.3 (as string; f                   rom '2.3')
  2016-12-13 17:57:58 caching: Lichtschalter_Dach-state: on
undefined
[12/13/2016, 5:57:58 PM] [FHEM] Panasonic: no service type detected
[12/13/2016, 5:57:58 PM] [FHEM] no accessory created for Panasonic (VIERA)
light
[12/13/2016, 5:57:58 PM] [FHEM] Schalter_Esstisch is light
[12/13/2016, 5:57:58 PM] [FHEM] Schalter_Esstisch has
  2016-12-13 17:57:58 caching: Schalter_Esstisch-D-firmware: 2.3
  2016-12-13 17:57:58 caching: Schalter_Esstisch-state: on
light
[12/13/2016, 5:57:58 PM] [FHEM] Schalter_Hof is light
[12/13/2016, 5:57:58 PM] [FHEM] Schalter_Hof has
  2016-12-13 17:57:58 caching: Schalter_Hof-D-firmware: 2.4
[12/13/2016, 5:57:58 PM] [FHEM]     caching: FirmwareRevision: 2.4 (as string; f                   rom '2.4')
  2016-12-13 17:57:58 caching: Schalter_Hof-state: off
light
[12/13/2016, 5:57:58 PM] [FHEM] Schalter_Kueche is light
[12/13/2016, 5:57:58 PM] [FHEM] Schalter_Kueche has
  2016-12-13 17:57:58 caching: Schalter_Kueche-D-firmware: 2.3
  2016-12-13 17:57:58 caching: Schalter_Kueche-state: IOerr
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: true (as boolean; from 'IOerr')
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Schlafzimmer_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Schlafzimmer_Clima has
  2016-12-13 17:57:58 caching: Schlafzimmer_Clima-measured-temp: 17.0
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 17 (as number;                    from '17.0')
  2016-12-13 17:57:58 caching: Schlafzimmer_Clima-desired-temp: 16.0
undefined
[12/13/2016, 5:57:58 PM] [FHEM] Sonos: no service type detected
[12/13/2016, 5:57:58 PM] [FHEM] no accessory created for Sonos (SONOS)
switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Bad is switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Bad has
[12/13/2016, 5:57:58 PM] [FHEM]   Custom Volume [Volume;not cached]
[12/13/2016, 5:57:58 PM] [FHEM]   On [transportState;play,pause]
  2016-12-13 17:57:58 caching: Sonos_Bad-Volume: 46
[12/13/2016, 5:57:58 PM] [FHEM]     caching: Custom Volume: 46 (as number; from                    '46')
  2016-12-13 17:57:58 caching: Sonos_Bad-transportState: STOPPED
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: false (as boolean; from 'STOPPE                   D')
switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Dach is switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Dach has
  2016-12-13 17:57:58 caching: Sonos_Dach-Volume: 27
[12/13/2016, 5:57:58 PM] [FHEM]     caching: Custom Volume: 27 (as number; from                    '27')
  2016-12-13 17:57:58 caching: Sonos_Dach-transportState: PLAYING
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: true (as boolean; from 'PLAYING                   ')
switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Kueche is switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Kueche has
  2016-12-13 17:57:58 caching: Sonos_Kueche-Volume: 11
[12/13/2016, 5:57:58 PM] [FHEM]     caching: Custom Volume: 11 (as number; from                    '11')
  2016-12-13 17:57:58 caching: Sonos_Kueche-transportState: STOPPED
switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Wohnzimmer is switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Wohnzimmer has
  2016-12-13 17:57:58 caching: Sonos_Wohnzimmer-Volume: 72
[12/13/2016, 5:57:58 PM] [FHEM]     caching: Custom Volume: 72 (as number; from                    '72')
  2016-12-13 17:57:58 caching: Sonos_Wohnzimmer-transportState: PAUSED_PLAYBACK
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: false (as boolean; from 'PAUSED                   _PLAYBACK')
switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Wohnzimmer_RF is switch
[12/13/2016, 5:57:58 PM] [FHEM] Sonos_Wohnzimmer_RF has
  2016-12-13 17:57:58 caching: Sonos_Wohnzimmer_RF-Volume: 72
  2016-12-13 17:57:58 caching: Sonos_Wohnzimmer_RF-transportState: STOPPED
light
[12/13/2016, 5:57:58 PM] [FHEM] TV_Licht is light
[12/13/2016, 5:57:58 PM] [FHEM] TV_Licht has
[12/13/2016, 5:57:58 PM] [FHEM] TV_Licht-bri not a number: undefined
switch
[12/13/2016, 5:57:58 PM] [FHEM] TV_Schalter_Wohnzimmer is switch
[12/13/2016, 5:57:58 PM] [FHEM] TV_Schalter_Wohnzimmer has
  2016-12-13 17:57:58 caching: TV_Schalter_Wohnzimmer-D-firmware: 2.5
  2016-12-13 17:57:58 caching: TV_Schalter_Wohnzimmer-state: unreachable
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: true (as boolean; from 'unreach                   able')
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Thermometer_Feuchtemesser_Bad_oben is thermomete                   r
[12/13/2016, 5:57:58 PM] [FHEM] Thermometer_Feuchtemesser_Bad_oben has
[12/13/2016, 5:57:58 PM] [FHEM]   CurrentRelativeHumidity [humidity]
  2016-12-13 17:57:58 caching: Thermometer_Feuchtemesser_Bad_oben-temperature: 1                   7.8
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 17.8 (as number                   ; from '17.8')
  2016-12-13 17:57:58 caching: Thermometer_Feuchtemesser_Bad_oben-humidity: 70
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentRelativeHumidity: 70 (as num                   ber; from '70')
  2016-12-13 17:57:58 caching: Thermometer_Feuchtemesser_Bad_oben-battery: ok
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Thermometer_Feuchtemesser_Bad_unten is thermomet                   er
[12/13/2016, 5:57:58 PM] [FHEM] Thermometer_Feuchtemesser_Bad_unten has
  2016-12-13 17:57:58 caching: Thermometer_Feuchtemesser_Bad_unten-temperature:                    19.2
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 19.2 (as number                   ; from '19.2')
  2016-12-13 17:57:58 caching: Thermometer_Feuchtemesser_Bad_unten-humidity: 60
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentRelativeHumidity: 60 (as num                   ber; from '60')
  2016-12-13 17:57:58 caching: Thermometer_Feuchtemesser_Bad_unten-battery: ok
switch
[12/13/2016, 5:57:58 PM] [FHEM] VUDuoPlus is switch
[12/13/2016, 5:57:58 PM] [FHEM] VUDuoPlus has
[12/13/2016, 5:57:58 PM] [FHEM]   Custom Volume [volume;cached]
[12/13/2016, 5:57:58 PM] [FHEM]   Custom Power [power]
  2016-12-13 17:57:58 caching: VUDuoPlus-volume: -
[12/13/2016, 5:57:58 PM] [FHEM] VUDuoPlus-volume not a number: -
  2016-12-13 17:57:58 caching: VUDuoPlus-power: off
[12/13/2016, 5:57:58 PM] [FHEM] VUDuoPlus-power not a number: off
  2016-12-13 17:57:58 caching: VUDuoPlus-state: off
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] WS1600 is thermometer
[12/13/2016, 5:57:58 PM] [FHEM] WS1600 has
  2016-12-13 17:57:58 caching: WS1600-temperature: 7.3
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 7.3 (as number;                    from '7.3')
  2016-12-13 17:57:58 caching: WS1600-humidity: 75
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentRelativeHumidity: 75 (as num                   ber; from '75')
  2016-12-13 17:57:58 caching: WS1600-battery: ok
thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Werkstatt is thermometer
[12/13/2016, 5:57:58 PM] [FHEM] Werkstatt has
  2016-12-13 17:57:58 caching: Werkstatt-temperature: 5.5
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 5.5 (as number;                    from '5.5')
  2016-12-13 17:57:58 caching: Werkstatt-battery: ok
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Wohnzimmer_links_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Wohnzimmer_links_Clima has
  2016-12-13 17:57:58 caching: Wohnzimmer_links_Clima-measured-temp: 22.9
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 22.9 (as number                   ; from '22.9')
  2016-12-13 17:57:58 caching: Wohnzimmer_links_Clima-desired-temp: 21.0
thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Wohnzimmer_rechts_Clima is thermostat
[12/13/2016, 5:57:58 PM] [FHEM] Wohnzimmer_rechts_Clima has
  2016-12-13 17:57:58 caching: Wohnzimmer_rechts_Clima-measured-temp: 22.8
[12/13/2016, 5:57:58 PM] [FHEM]     caching: CurrentTemperature: 22.8 (as number                   ; from '22.8')
  2016-12-13 17:57:58 caching: Wohnzimmer_rechts_Clima-desired-temp: 21.0
switch
[12/13/2016, 5:57:58 PM] [FHEM] Wohnzimmerlicht_mit_Giselas_Fernbedienung_aus is                    switch
[12/13/2016, 5:57:58 PM] [FHEM] Wohnzimmerlicht_mit_Giselas_Fernbedienung_aus ha                   s
OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] iPhoneGisela is OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] iPhoneGisela has
[12/13/2016, 5:57:58 PM] [FHEM]   OccupancyDetected [state]
  2016-12-13 17:57:58 caching: iPhoneGisela-state: present
[12/13/2016, 5:57:58 PM] [FHEM]     caching: OccupancyDetected: 1 (as number; me                   ans OCCUPANCY_DETECTED; from 'present')
OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] iPhoneWolfgang is OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] iPhoneWolfgang has
  2016-12-13 17:57:58 caching: iPhoneWolfgang-state: present
OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] homebridgeMapping: On=state,valueOn=/home|awoken                   |asleep|gotosleep/,valueOff=/gone|absent/,cmdOn=home,cmdOff=absent
[12/13/2016, 5:57:58 PM] [FHEM] rr_Gisela is OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] rr_Gisela has
[12/13/2016, 5:57:58 PM] [FHEM]   OccupancyDetected [presence]
[12/13/2016, 5:57:58 PM] [FHEM]   On [state;home,absent]
  2016-12-13 17:57:58 caching: rr_Gisela-presence: present
  2016-12-13 17:57:58 caching: rr_Gisela-state: home
[12/13/2016, 5:57:58 PM] [FHEM]     caching: On: true (as boolean; from 'home')
OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] rr_Wolfgang is OccupancySensor
[12/13/2016, 5:57:58 PM] [FHEM] rr_Wolfgang has
  2016-12-13 17:57:58 caching: rr_Wolfgang-presence: present
  2016-12-13 17:57:58 caching: rr_Wolfgang-state: home
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Ambilight'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Ambilight
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Ambilight
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Ambilight
[12/13/2016, 5:57:58 PM] [FHEM]   Lightbulb service for Ambilight
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Ambilight:onoff
[12/13/2016, 5:57:58 PM] [FHEM]     Brightness characteristic for Ambilight:brig                   htness
[12/13/2016, 5:57:58 PM] [FHEM]     Hue characteristic for Ambilight:hue
[12/13/2016, 5:57:58 PM] [FHEM]     Saturation characteristic for Ambilight:satu                   ration
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Arbeitszimmer_C                   lima'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Arbeitszimmer_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Arbeitszimmer_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Arbeitszimmer_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Arbeitszimmer_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Arbeit                   szimmer_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Arbeits                   zimmer_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Aussenschalter_                   2'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Aussenschalter_2
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Aussenschalter_2
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Aussenschalter_2
[12/13/2016, 5:57:58 PM] [FHEM]     firmware revision characteristic for Aussens                   chalter_2
[12/13/2016, 5:57:58 PM] [FHEM]   Switch service for Aussenschalter_2
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Aussenschalter_2:state
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Bad_oben_Clima'                   ...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Bad_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Bad_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Bad_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Bad_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Bad_ob                   en_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Bad_obe                   n_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Bad_unten_Clima                   '...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Bad_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Bad_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Bad_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Bad_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Bad_un                   ten_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Bad_unt                   en_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dach_links_Clim                   a'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dach_links_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dach_links_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dach_links_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Dach_links_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Dach_l                   inks_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Dach_li                   nks_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dach_rechts_Cli                   ma'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dach_rechts_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dach_rechts_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dach_rechts_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Dach_rechts_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Dach_r                   echts_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Dach_re                   chts_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dimmer_Bad_oben                   _Sw'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dimmer_Bad_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dimmer_Bad_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dimmer_Bad_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   Lightbulb service for Dimmer_Bad_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Dimmer_Bad_oben_Sw:pct
[12/13/2016, 5:57:58 PM] [FHEM]     Brightness characteristic for Dimmer_Bad_obe                   n_Sw:pct
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dimmer_Eingang_                   Sw'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dimmer_Eingang_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dimmer_Eingang_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dimmer_Eingang_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   Lightbulb service for Dimmer_Eingang_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Dimmer_Eingang_Sw:pct
[12/13/2016, 5:57:58 PM] [FHEM]     Brightness characteristic for Dimmer_Eingang                   _Sw:pct
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dimmer_Flur_Bad                   _oben_Sw'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dimmer_Flur_Bad_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dimmer_Flur_Bad_oben_S                   w
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dimmer_Flur_Bad_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   Lightbulb service for Dimmer_Flur_Bad_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Dimmer_Flur_Bad_oben_S                   w:pct
[12/13/2016, 5:57:58 PM] [FHEM]     Brightness characteristic for Dimmer_Flur_Ba                   d_oben_Sw:pct
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dimmer_Flur_obe                   n_Sw'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dimmer_Flur_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dimmer_Flur_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dimmer_Flur_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   Lightbulb service for Dimmer_Flur_oben_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Dimmer_Flur_oben_Sw:pc                   t
[12/13/2016, 5:57:58 PM] [FHEM]     Brightness characteristic for Dimmer_Flur_ob                   en_Sw:pct
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dimmer_Flur_unt                   en_Sw'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dimmer_Flur_unten_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dimmer_Flur_unten_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dimmer_Flur_unten_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   Lightbulb service for Dimmer_Flur_unten_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Dimmer_Flur_unten_Sw:p                   ct
[12/13/2016, 5:57:58 PM] [FHEM]     Brightness characteristic for Dimmer_Flur_un                   ten_Sw:pct
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Dimmer_Wohnzimm                   er_Sw1'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Dimmer_Wohnzimmer_Sw1
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Dimmer_Wohnzimmer_Sw1
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Dimmer_Wohnzimmer_Sw1
[12/13/2016, 5:57:58 PM] [FHEM]   Lightbulb service for Dimmer_Wohnzimmer_Sw1
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Dimmer_Wohnzimmer_Sw1:                   pct
[12/13/2016, 5:57:58 PM] [FHEM]     Brightness characteristic for Dimmer_Wohnzim                   mer_Sw1:pct
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Flur_oben_Clima                   '...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Flur_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Flur_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Flur_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Flur_oben_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Flur_o                   ben_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Flur_ob                   en_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Flur_unten_Clim                   a'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Flur_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Flur_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Flur_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Flur_unten_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Flur_u                   nten_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Flur_un                   ten_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Gaeste_Clima'..                   .
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Gaeste_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Gaeste_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Gaeste_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Gaeste_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Gaeste                   _Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Gaeste_                   Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Garderobe_Clima                   '...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Garderobe_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Garderobe_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Garderobe_Clima
[12/13/2016, 5:57:58 PM] [FHEM]   Thermostat service for Garderobe_Clima
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Garder                   obe_Clima:measured-temp
[12/13/2016, 5:57:58 PM] [FHEM]     TargetTemperature characteristic for Gardero                   be_Clima:desired-temp
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Gartenkammer'..                   .
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Gartenkammer
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Gartenkammer
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Gartenkammer
[12/13/2016, 5:57:58 PM] [FHEM]   TemperatureSensor service for Gartenkammer
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Garten                   kammer:temperature
[12/13/2016, 5:57:58 PM] [FHEM]     StatusLowBattery characteristic for Gartenka                   mmer:battery
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Gewaechshaus'..                   .
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Gewaechshaus
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Gewaechshaus
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Gewaechshaus
[12/13/2016, 5:57:58 PM] [FHEM]   TemperatureSensor service for Gewaechshaus
[12/13/2016, 5:57:58 PM] [FHEM]     CurrentTemperature characteristic for Gewaec                   hshaus:temperature
[12/13/2016, 5:57:58 PM] [FHEM]     StatusLowBattery characteristic for Gewaechs                   haus:battery
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Gewaechshaushei                   zung_Sw'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Gewaechshausheizung_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Gewaechshausheizung_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Gewaechshausheizung_Sw
[12/13/2016, 5:57:58 PM] [FHEM]   Switch service for Gewaechshausheizung_Sw
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Gewaechshausheizung_Sw                   :state
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Haustuerschloss                   '...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Haustuerschloss
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Haustuerschloss
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Haustuerschloss
[12/13/2016, 5:57:58 PM] [FHEM]     firmware revision characteristic for Haustue                   rschloss
[12/13/2016, 5:57:58 PM] [FHEM]   LockMechanism service for Haustuerschloss
[12/13/2016, 5:57:58 PM] [FHEM]     PositionState characteristic for Haustuersch                   loss:direction
[12/13/2016, 5:57:58 PM] [FHEM]     StatusLowBattery characteristic for Haustuer                   schloss:battery
[12/13/2016, 5:57:58 PM] [FHEM]     TargetDoorState characteristic for Haustuers                   chloss:
[12/13/2016, 5:57:58 PM] [FHEM]     LockCurrentState characteristic for Haustuer                   schloss:lock
[12/13/2016, 5:57:58 PM] [FHEM]     LockTargetState characteristic for Haustuers                   chloss:lock
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Heizungsschalte                   r'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Heizungsschalter
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Heizungsschalter
[12/13/2016, 5:57:58 PM] [FHEM]     manufacturer, model and serial number charac                   teristics for Heizungsschalter
[12/13/2016, 5:57:58 PM] [FHEM]     firmware revision characteristic for Heizung                   sschalter
[12/13/2016, 5:57:58 PM] [FHEM]   Switch service for Heizungsschalter
[12/13/2016, 5:57:58 PM] [FHEM]     On characteristic for Heizungsschalter:state
[12/13/2016, 5:57:58 PM] [FHEM] Initializing platform accessory 'Hof'...
[12/13/2016, 5:57:58 PM] [FHEM] creating services for Hof
[12/13/2016, 5:57:58 PM] [FHEM]   information service for Hof
[12/13/2016, 5:57:58 PM] [FHEM]  &nb
Jeelink, TUL
justme1968
das schaut alles gut aus. das problem liegt nicht auf fhem seite und auch nicht bei homebridge-fhem.
ich weiss nicht genau was du aktualisiert hast und von welcher version auf welche, aber ich vermute das dabei etwas schief gegangen ist und hoemkit die bridge nicht mehr kennt, die bridge aber noch denkt das sie gepairt ist.
wenn du die homebridge beendest und danach in .homebridge das persist verzeichnis löschst solltest du nach einem neustart wieder mit iOS verbinden können.
dabei gehen aber vermutlich alle raum einstellungen verloren.
