CC1101-USB-Lite 433MHz macht Probleme seid einigen tagen
Begonnen von Vladi2010, 03 Februar 2016, 21:54:31
Vladi2010
Hallo, ich habe sied ca 1 Jahr eine CC1101-USB-Lite 433MHz (CUL433)
neuerdings habe ich Aussetzer
ich habe die Aussetzer seid einem Update vor ein paar tagen festgestellt.
ein update der Firmware (V 1.61 CUL433) hat nicht geholfen, eine  zweite CUL (CC1101-USB-Lite 868MHz (CUL) ) die am gleichen HUB hängt macht keine Probleme.
LOG:
2016-02-03_17:34:10 CUL_1 DISCONNECTED
2016-02-03_17:34:11 CUL_1 UNKNOWNCODE ? ( is unknown) Use one of B b C F i A Z E G M K U Y R T V W X e f m l t u x
2016-02-03_17:34:14 CUL_1 Initialized
2016-02-03_17:34:14 CUL_1 CONNECTED
2016-02-03_17:40:27 CUL_1 DISCONNECTED
2016-02-03_17:40:32 CUL_1 Initialized
2016-02-03_17:40:32 CUL_1 CONNECTED
2016-02-03_17:46:42 CUL_1 DISCONNECTED
2016-02-03_17:46:43 CUL_1 UNKNOWNCODE ? (000FFV is unknown) Use one of B b C F i A Z E G M K U Y R T V W X e f m l t u x
2016-02-03_17:46:46 CUL_1 Initialized
2016-02-03_17:46:46 CUL_1 CONNECTED
2016-02-03_17:50:53 CUL_1 DISCONNECTED
2016-02-03_17:50:54 CUL_1 UNKNOWNCODE ? (000FFFV is unknown) Use one of B b C F i A Z E G M K U Y R T V W X e f m l t u x
2016-02-03_17:50:57 CUL_1 Initialized
2016-02-03_17:50:57 CUL_1 CONNECTED
2016-02-03_18:20:51 CUL_1 DISCONNECTED
2016-02-03_18:20:55 CUL_1 Initialized
2016-02-03_18:20:55 CUL_1 CONNECTED
2016-02-03_19:01:11 CUL_1 DISCONNECTED
2016-02-03_19:01:15 CUL_1 Initialized
2016-02-03_19:01:15 CUL_1 CONNECTED
2016-02-03_19:03:15 CUL_1 DISCONNECTED
2016-02-03_19:03:16 CUL_1 UNKNOWNCODE ? ( is unknown) Use one of B b C F i A Z E G M K U Y R T V W X e f m l t u x
2016-02-03_19:03:19 CUL_1 Initialized
2016-02-03_19:03:19 CUL_1 CONNECTED
2016-02-03_19:05:25 CUL_1 DISCONNECTED
2016-02-03_19:05:28 CUL_1 Initialized
2016-02-03_19:05:28 CUL_1 CONNECTED
2016-02-03_19:11:51 CUL_1 DISCONNECTED
2016-02-03_19:11:51 CUL_1 UNKNOWNCODE ? ( is unknown) Use one of B b C F i A Z E G M K U Y R T V W X e f m l t u x
2016-02-03_19:11:54 CUL_1 Initialized
2016-02-03_19:11:54 CUL_1 CONNECTED
2016-02-03_19:13:54 CUL_1 DISCONNECTED
2016-02-03_19:13:55 CUL_1 UNKNOWNCODE ? (000FFV is unknown) Use one of B b C F i A Z E G M K U Y R T V W X e f m l t u x
2016-02-03_19:13:58 CUL_1 Initialized
2016-02-03_19:13:58 CUL_1 CONNECTED
2016-02-03_19:28:26 CUL_1 DISCONNECTED
2016-02-03_19:28:30 CUL_1 Initialized
2016-02-03_19:28:30 CUL_1 CONNECTED
2016-02-03_19:32:37 CUL_1 DISCONNECTED
2016-02-03_19:32:38 CUL_1 UNKNOWNCODE ? ( is unknown) Use one of B b C F i A Z E G M K U Y R T V W X e f m l t u x
2016-02-03_19:32:41 CUL_1 Initialized
kann mir da jemand helfen ?
Grüsse Andreas
Kannst du bitte mit "get CUL uptime" pruefen, ob culfw neu bootet?
Passiert das Problem auch, wenn man das zweite CUL rauszieht?
Vladi2010
CUL_1 uptime => No answer
mit dem Befehl  Set CUL_1 reopen  funktioniert die CUL für einige Zeit ohne das ich sie rausstecken muss.
ZitatCUL_1 uptime => No answer
Was fuer eine culfw version ist geflasht?
Zitatmit dem Befehl  Set CUL_1 reopen  funktioniert die CUL für einige Zeit ohne das ich sie rausstecken muss.
Das wollte ich nicht wissen, bzw. das ist das Gleiche wie das automatische disconnect/connect.
Ich wollte testen, ob es nicht an der Stromversorgung liegt.
Bandit
Ich habe mit der 868 MHz Version das gleiche Problem. Daraufhin habe ich neueste V3.hex vom 27.12.15 geflasht und fhem aktualisiert. Der Start sieht so aus:
2016.02.05 22:19:39 5: Loading /opt/fhem/FHEM/00_CUL.pm
2016.02.05 22:19:39 3: Opening CUL0 device /dev/ttyACM0
2016.02.05 22:19:39 3: Setting CUL0 serial parameters to 38400,8,N,1
2016.02.05 22:19:39 3: CUL0 device opened
2016.02.05 22:19:39 5: CUL/RAW (ReadAnswer): A0D0084102C733400000006000030F9
A0C4F86702A76C500000000CD3F06
A0C6D86701F09A900000000D33C2C
A0CBA86701CCCAB00000000326306
A0CF286701F087200000000C842F8
A0C6
2016.02.05 22:19:39 1: /dev/ttyACM0 disconnected, waiting to reappear (CUL0)
2016.02.05 22:19:39 5: Triggering CUL0 (1 changes)
2016.02.05 22:19:39 5: Notify loop for CUL0 DISCONNECTED
2016.02.05 22:19:39 5: SW: V
2016.02.05 22:19:39 1: Cannot init /dev/ttyACM0, ignoring it (CUL0)
2016.02.05 22:19:39 5: Cmd: >attr CUL0 rfmode HomeMatic<
2016.02.05 22:19:39 5: SW: X21
2016.02.05 22:19:39 5: SW: Ar
2016.02.05 22:19:39 2: Switched CUL0 rfmode to HomeMatic
2016.02.05 22:19:39 5: Cmd: >define Wohnen_TempFeuchte CUL_HM 1F09A9<
2016.02.05 22:19:39 5: Loading /opt/fhem/FHEM/10_CUL_HM.pm
get CUL0 uptime wird beantwortet mit:
CUL0 uptime => No answer
Ein reopen geht manchmal, meistens jedoch nicht. Bei stundenlangem rumprobieren habe ich einmal Daten von Temperatur Sensoren empfangen, das war leider das einzige Lebenszeichen in 3 Wochen.
Der Stick hängt direkt an einem Port eines Laptops, die Stromversorgung sollte damit passen.
Vladi2010
 BEI MIR IST ALLES OK; ES LAG AN DER SPANNUNGSVERSORGUNG
