Device specific help funktioniert nicht mehr richtig
Begonnen von Invers, 10 Februar 2016, 16:39:08
Invers
Wenn ich Device specific help klicke (z.B. bei DOIF), sehe ich folgendes:
Possible commands: Command Parameter Description ---------------------------------------------------------------------- use "help " for more help IF () () ELSE () executes FHEM commands depending on the condition addstruct add <devspec> to <structure> apptime use "help apptime" for more help attr [] set attribute for <devspec> attributes use "help attributes" for more help cancel [ [quiet]] list sleepers, cancel sleeper with <id> command use "help command" for more help commands use "help commands" for more help createlog create log/weblink for <device> define define a device defmod define or modify a device delete delete the corresponding definition(s) deleteattr [] delete attribute for <devspec> deletereading [] delete user defined reading for <devspec> delstruct delete <devspec> from <structure> devspec use "help devspec" for more help displayattr [attrname] display attributes fheminfo use "help fheminfo" for more help get request data from <devspec> getstate use "help getstate" for more help global use "help global" for more help help [] get help (this screen or module dependent docu) include read the commands from <filenname> iowrite write raw data with iodev list [devspec] list definitions and status info modify device modify the definition (e.g. at, notify) notice use "help notice" for more help perl use "help perl" for more help reload reload the given module (e.g. 99_PRIV) rename rename a definition rereadcfg [configfile] read in the config after deleting everything restore [list] [] restore files saved by update save [configfile] write the configfile and the statefile set transmit code for <devspec> setdefaultattr set attr for following definitions setreading set reading for <devspec> setstate set the state shown in the command list shutdown [restart|exitValue] terminate the server sleep [] [quiet] sleep for sec, 3 decimal places trigger trigger notify command update [|all|check|force] [http://.../controlfile] update FHEM usb [scan|create] display or create fhem-entries for USB devices
Ich weiss nicht, seit wann das so ist, aber länger als 3 Tage garantiert nicht.
Kann den Fehler jemand bestätigen?
knochenmuehle
kann ich genau so bestätigen ... suche mir auch gerade nen Wolf nach der Lösung
Andreas
FranzB94
Benni
Zitat von: FranzB94 am 10 Februar 2016, 17:59:41
also das funktioniert bei mir auf alle Fälle :http://fhem.de/commandref.html
Das ist ja auch was anderes!
Nein!
Gerade ein update gemacht - shutdown restart - DOIF definiert und device-specific help aufgerufen.
Alles ganz normal!
stromer-12
Hier ebenfalls fehlerhafte Ausgabe nach heutigen Update.
FHEM (SVN) auf RPi1B mit HMser | ESPLink
FHEM (SVN) virtuell mit HMLAN | HMUSB | CUL
Invers
Ich danke allen wür die Rückmeldungen und natürlich auch für die angekündigte Korrektur.
