Unterstützt SYSMON den Kernel 4.4.1 aus dem IGOR Image?
Begonnen von Klaus Rubik, 20 Februar 2016, 13:17:34
Klaus Rubik
Unterstützt SYSMON den Kernel 4.4.1 aus dem IGOR Image? Seit dem Update auf diese Image, liefert mir SYSMON keine Power-Werte mehr.
list device output:
   CFGFN
   CHANGED
   DEF        local 5 5 5 10
   INTERVAL_BASE 60
   INTERVAL_MULTIPLIERS 5 5 5 10
   MODE       local
   NAME       FHEMserver
   NR         246
   STATE      Active
   TYPE       SYSMON
   Readings:
     2016-02-20 13:15:58   cpu0_freq       528
     2016-02-20 13:15:58   cpu0_freq_stat  528.00 960.00 563.84
     2016-02-20 13:15:59   cpu0_idle_stat  52.07 97.56 92.35
     2016-02-20 13:15:59   cpu0_temp       31.60
     2016-02-20 13:15:59   cpu0_temp_avg   32.1
     2016-02-20 13:15:59   cpu0_temp_stat  30.50 37.60 32.16
     2016-02-20 13:15:58   cpu1_freq       528
     2016-02-20 13:15:58   cpu1_freq_stat  528.00 960.00 563.84
     2016-02-20 13:15:59   cpu1_idle_stat  49.47 96.20 90.02
     2016-02-19 08:49:38   cpu_bogomips    50.52
     2016-02-20 13:15:59   cpu_core_count  4
     2016-02-20 13:15:58   cpu_freq        528
     2016-02-20 13:15:58   cpu_freq_stat   528.00 960.00 563.84
     2016-02-20 13:15:59   cpu_idle_stat   51.30 96.87 91.18
     2016-02-19 08:49:38   cpu_model_name  ARMv7 Processor rev 4 (v7l)
     2016-02-20 13:15:59   cpu_temp        31.60
     2016-02-20 13:15:59   cpu_temp_avg    32.1
     2016-02-20 13:15:59   cpu_temp_stat   30.40 37.60 32.16
     2016-02-20 13:15:59   eth0            RX: 1561.32 MB, TX: 3386.24 MB, Total: 4947.56 MB
     2016-02-20 13:15:59   eth0_diff       RX: 0.24 MB, TX: 0.59 MB, Total: 0.83 MB
     2016-02-20 13:15:59   eth0_ip         192.168.0.26
     2016-02-20 13:15:59   eth0_rx         1637157607
     2016-02-20 13:15:59   eth0_speed      1000
     2016-02-20 13:15:59   eth0_tx         3550730254
     2016-02-20 13:15:59   fhemstarttime   1455868142
     2016-02-20 13:15:59   fhemstarttime_text 19.02.2016 08:49:02
     2016-02-20 13:15:59   fhemuptime      102416
     2016-02-20 13:15:59   fhemuptime_text 1 days, 04 hours, 26 minutes
     2016-02-20 13:15:59   idletime        269995 45.78 %
     2016-02-20 13:15:59   idletime_text   3 days, 02 hours, 59 minutes (45.78 %)
     2016-02-20 13:15:59   loadavg         0.03 0.14 0.19
     2016-02-19 08:49:38   perl_version    v5.20.2
     2016-02-20 13:15:59   ram             Total: 2017.02 MB, Used: 286.55 MB, 14.21 %, Free: 1730.46 MB
     2016-02-20 13:15:59   ram_used_stat   144.86 344.70 288.18
     2016-02-20 13:15:59   starttime       1455380738
     2016-02-20 13:15:59   starttime_text  13.02.2016 17:25:38
     2016-02-20 13:15:59   stat_cpu        7012808 415275 1833910 106121523 566726 0 122081
     2016-02-20 13:15:59   stat_cpu0       2728630 221919 948275 53160703 292431 0 12631
     2016-02-20 13:15:59   stat_cpu0_diff  1561 534 546 26442 126 0 6
     2016-02-20 13:15:59   stat_cpu0_percent 5.34 1.83 1.87 90.51 0.43 0.00 0.02
     2016-02-20 13:15:59   stat_cpu0_text  user: 5.34 %, nice: 1.83 %, sys: 1.87 %, idle: 90.51 %, io: 0.43 %, irq: 0.00 %, sirq: 0.02 %
     2016-02-20 13:15:59   stat_cpu1       4284178 193356 885635 52960820 274295 0 109450
     2016-02-20 13:15:59   stat_cpu1_diff  1927 591 526 26721 106 0 9
     2016-02-20 13:15:59   stat_cpu1_percent 6.45 1.98 1.76 89.43 0.35 0.00 0.03
     2016-02-20 13:15:59   stat_cpu1_text  user: 6.45 %, nice: 1.98 %, sys: 1.76 %, idle: 89.43 %, io: 0.35 %, irq: 0.00 %, sirq: 0.03 %
     2016-02-20 13:15:59   stat_cpu_diff   3488 1125 1072 53163 232 0 15
     2016-02-20 13:15:59   stat_cpu_percent 5.90 1.90 1.81 89.96 0.39 0.00 0.03
     2016-02-20 13:15:59   stat_cpu_text   user: 5.90 %, nice: 1.90 %, sys: 1.81 %, idle: 89.96 %, io: 0.39 %, irq: 0.00 %, sirq: 0.03 %
     2016-02-20 13:15:59   swap            Total: 128.00 MB, Used: 0.00 MB,  0.00 %, Free: 128.00 MB
     2016-02-20 13:15:59   swap_used_stat  0.00 0.00 0.00
     2016-02-20 13:15:59   uptime          589819
     2016-02-20 13:15:59   uptime_text     6 days, 19 hours, 50 minutes
   Helper:
     sys_cpu0_freq 1
     sys_cpu0_temp 1
     sys_cpu1_freq 1
     sys_cpu1_temp 0
     sys_cpu2_freq 0
     sys_cpu2_temp 0
     sys_cpu3_freq 0
     sys_cpu3_temp 0
     sys_cpu4_freq 0
     sys_cpu4_temp 0
     sys_cpu5_freq 0
     sys_cpu5_temp 0
     sys_cpu6_freq 0
     sys_cpu6_temp 0
     sys_cpu7_freq 0
     sys_cpu7_temp 0
     sys_cpu_freq_rpi_bbb 1
     sys_cpu_temp_rpi 1
     sys_fb     0
     sys_power_ac 0
     sys_power_bat 0
     sys_power_usb 0
     u_first_mark 1
     Cur_readings_map:
       /          Mount point /
       /_free     Mount point / (free)
       /_used     Mount point / (used)
       /_used_percent Mount point / (used %)
       cpu0_freq  CPU frequency (core 0)
       cpu0_freq_stat CPU frequency (core 0) stat
       cpu0_idle_stat CPU0 min/max/avg (idle)
       cpu0_temp  CPU temperature (core 0)
       cpu0_temp_avg Average CPU temperature (core 0)
       cpu0_temp_stat CPU temperature stat (core 0)
       cpu1_freq  CPU frequency (core 1)
       cpu1_freq_stat CPU frequency (core 1) stat
       cpu1_idle_stat CPU1 min/max/avg (idle)
       cpu2_idle_stat CPU2 min/max/avg (idle)
       cpu3_idle_stat CPU3 min/max/avg (idle)
       cpu4_idle_stat CPU4 min/max/avg (idle)
       cpu5_idle_stat CPU5 min/max/avg (idle)
       cpu6_idle_stat CPU6 min/max/avg (idle)
       cpu7_idle_stat CPU7 min/max/avg (idle)
       cpu_bogomips BogoMIPS
       cpu_core_count Number of CPU cores
       cpu_freq   CPU frequency
       cpu_freq_stat CPU frequency stat
       cpu_idle_stat CPU min/max/avg (idle)
       cpu_model_name CPU model name
       cpu_temp   CPU temperature
       cpu_temp_avg Average CPU temperature
       cpu_temp_stat CPU temperature stat
       date       Date
       eth0       Ethernet
       eth0_diff  Ethernet (diff)
       eth0_ip    Ethernet (IP)
       eth0_ip6   Ethernet (IP6)
       eth0_rx    Ethernet (RX)
       eth0_speed Ethernet (speed)
       eth0_tx    Ethernet (TX)
       fhemstarttime Fhem start time
       fhemstarttime_text Fhem start time
       fhemuptime System up time
       fhemuptime_text FHEM up time
       idletime   Idle time
       idletime_text Idle time
       io_sda     TEST
       io_sda_diff TEST
       io_sda_raw TEST
       loadavg    Load average
       loadavg_1  Load average 1
       loadavg_15 Load average 15
       loadavg_5  Load average 5
       perl_version Perl Version
       ram        RAM
       ram_free   RAM free
       ram_free_percent RAM free %
       ram_total  RAM total
       ram_used   RAM used
       ram_used_stat RAM used stat
       starttime  System start time
       starttime_text System start time
       stat_cpu   CPU statistics
       stat_cpu0  CPU0 statistics
       stat_cpu0_diff CPU0 statistics (diff)
       stat_cpu0_percent CPU0 statistics (diff, percent)
       stat_cpu0_text CPU0 statistics (text)
       stat_cpu1  CPU1 statistics
       stat_cpu1_diff CPU1 statistics (diff)
       stat_cpu1_percent CPU1 statistics (diff, percent)
       stat_cpu1_text CPU1 statistics (text)
       stat_cpu2  CPU2 statistics
       stat_cpu2_diff CPU2 statistics (diff)
       stat_cpu2_percent CPU2 statistics (diff, percent)
       stat_cpu2_text CPU2 statistics (text)
       stat_cpu3  CPU3 statistics
       stat_cpu3_diff CPU3 statistics (diff)
       stat_cpu3_percent CPU3 statistics (diff, percent)
       stat_cpu3_text CPU3 statistics (text)
       stat_cpu4  CPU4 statistics
       stat_cpu4_diff CPU4 statistics (diff)
       stat_cpu4_percent CPU4 statistics (diff, percent)
       stat_cpu4_text CPU4 statistics (text)
       stat_cpu5  CPU5 statistics
       stat_cpu5_diff CPU5 statistics (diff)
       stat_cpu5_percent CPU5 statistics (diff, percent)
       stat_cpu5_text CPU5 statistics (text)
       stat_cpu6  CPU6 statistics
       stat_cpu6_diff CPU6 statistics (diff)
       stat_cpu6_percent CPU6 statistics (diff, percent)
       stat_cpu6_text CPU6 statistics (text)
       stat_cpu7  CPU7 statistics
       stat_cpu7_diff CPU7 statistics (diff)
       stat_cpu7_percent CPU7 statistics (diff, percent)
       stat_cpu7_text CPU7 statistics (text)
       stat_cpu_diff CPU statistics (diff)
       stat_cpu_idle_percent CPU statistics idle %
       stat_cpu_io_percent CPU statistics io %
       stat_cpu_irq_percent CPU statistics irq %
       stat_cpu_nice_percent CPU statistics nice %
       stat_cpu_percent CPU statistics (diff, percent)
       stat_cpu_sirq_percent CPU statistics sirq %
       stat_cpu_sys_percent CPU statistics sys %
       stat_cpu_text CPU statistics (text)
       stat_cpu_user_percent CPU statistics user %
       swap       swap
       swap_free  swap free
       swap_total swap total
       swap_used  swap used
       swap_used_percent swap used %
       swap_used_stat swap used stat
       uptime_text System up time
     Excludes:
   event-min-interval .*:300
   event-on-update-reading .*_info,.*_text,eth0_diff,cpu_.*,.*_stat
   filesystems /
   icon       it_server
   network-interfaces eth0:eth0:Ethernet
   room       System
   stateFormat uptime_text
klaus
FHEM 6.0 auf RPI4 mit CUL868, AEOTEC, RFXTRX 433
CUL_WS  : S300TH              FHT         : FHT80B, FHT80TF
HMS        : HMS100-TF         FBDECT   : DECT!200, FRITZ!Powerline 546E
FS20       : FS20DI10, FS20ST, FS20WS1, FS20DU-2, FS20 FMS
