[Gelöst] Pairing
Begonnen von Tedious, 23 Februar 2016, 19:01:35
Tedious
da ich noch einen ungenutzten CUL868 habe dachte ich ich teste das mal und habe ein MAX! Heizungsregler gekauft. Bekomme aber nur eine Fehlermeldung und das Ganze nicht gepaart, Googlen bringt mich leider irgendwie nicht weiter. Jemand einen heißen Tip für mich?
Hier das Log:
2016.02.23 18:58:28 3: CUL_MAX_Parse: Re-Pairing device 137a8b of type HeatingThermostat with serial MKF0053403
2016.02.23 18:58:28 1: ERROR: empty name in readingsBeginUpdate
2016.02.23 18:58:28 3: stacktrace:
2016.02.23 18:58:28 3:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2016.02.23 18:58:28 3:     main::MAX_Parse                     called by fhem.pl (3306)
2016.02.23 18:58:28 3:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (356)
2016.02.23 18:58:28 3:     main::CUL_MAX_Parse                 called by fhem.pl (3306)
2016.02.23 18:58:28 3:     main::Dispatch                      called by ./FHEM/00_CUL.pm (951)
2016.02.23 18:58:28 3:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (807)
2016.02.23 18:58:28 3:     main::CUL_Read                      called by fhem.pl (3147)
2016.02.23 18:58:28 3:     main::CallFn                        called by fhem.pl (654)
2016.02.23 18:58:28 1: readingsUpdate(,groupid,0) missed to call readingsBeginUpdate first.
2016.02.23 18:58:28 1: readingsUpdate(,state,waiting for data) missed to call readingsBeginUpdate first.
2016.02.23 18:58:28 1: readingsUpdate(,RSSI,-51) missed to call readingsBeginUpdate first.
2016.02.23 18:58:28 3:     main::MAX_Parse                     called by fhem.pl (3323)
2016.02.23 18:58:28 3: cm: Unknown code MAX,1,define,137a8b,HeatingThermostat,MKF0053403,0, help me!
2016.02.23 18:58:28 3:     main::readingsBeginUpdate           called by ./FHEM/14_CUL_MAX.pm (361)
2016.02.23 18:58:28 1: readingsUpdate(,firmware,1.0) missed to call readingsBeginUpdate first.
2016.02.23 18:58:28 1: readingsUpdate(,testresult,160) missed to call readingsBeginUpdate first.
2016.02.23 18:58:29 1: ERROR: empty name in readingsBeginUpdate
2016.02.23 18:58:29 3: stacktrace:
2016.02.23 18:58:29 3:     main::readingsBeginUpdate           called by ./FHEM/10_MAX.pm (642)
2016.02.23 18:58:29 3:     main::MAX_Parse                     called by fhem.pl (3306)
2016.02.23 18:58:29 3:     main::Dispatch                      called by ./FHEM/14_CUL_MAX.pm (303)
2016.02.23 18:58:29 3:     main::CUL_MAX_Parse                 called by fhem.pl (3306)
2016.02.23 18:58:29 3:     main::Dispatch                      called by ./FHEM/00_CUL.pm (951)
2016.02.23 18:58:29 3:     main::CUL_Parse                     called by ./FHEM/00_CUL.pm (807)
2016.02.23 18:58:29 3:     main::CUL_Read                      called by fhem.pl (3147)
2016.02.23 18:58:29 3:     main::CallFn                        called by fhem.pl (654)
2016.02.23 18:58:29 3:     main::MAX_Parse                     called by ./FHEM/10_MAX.pm (839)
2016.02.23 18:58:29 1: readingsUpdate(,mode,manual) missed to call readingsBeginUpdate first.
2016.02.23 18:58:29 1: readingsUpdate(,battery,ok) missed to call readingsBeginUpdate first.
2016.02.23 18:58:29 1: readingsUpdate(,desiredTemperature,18.5) missed to call readingsBeginUpdate first.
2016.02.23 18:58:29 1: readingsUpdate(,valveposition,0) missed to call readingsBeginUpdate first.
2016.02.23 18:58:29 1: readingsUpdate(,state,waiting for data) missed to call readingsBeginUpdate first.
2016.02.23 18:58:29 1: readingsUpdate(,RSSI,-51) missed to call readingsBeginUpdate first.
2016.02.23 18:58:29 3:     main::MAX_Parse                     called by fhem.pl (3323)
2016.02.23 18:58:29 3: cm: Unknown code MAX,1,Ack,137a8b,01190025, help me!
EDIT: warum auch immer, trotz Autocreate - hab das Gerät mit der ID aus den Logs selbst angelent und ein Filelog definiert. Jetzt passts...
