FGMS-001 ZME_UZB1 anlern-probleme
Begonnen von the ratman, 27 Februar 2016, 14:05:01
the ratman
hiho
ich hab heute den stick zme_uzb1 und den fibaro motionsensor fgms-001 bekommen. beide eu-verison. meine allerersten z-wave geräte!
gut - brav nach wiki den stick angelernt - der scheint auch zu funzen.version Z-Wave 3.99 STATIC_CONTROLLER
nodeList Z_Wave UNKNOWN_2
caps Vers:5 Rev:2 ManufID:0115 ProductType:0400 ProductID:0001 SERIAL_API_GET_INIT_DATA SERIAL_API_APPL_NODE_INFORMATION APPLICATION_COMMAND_HANDLER ZW_GET_CONTROLLER_CAPABILITIES SERIAL_API_SET_TIMEOUTS SERIAL_API_GET_CAPABILITIES SERIAL_API_SOFT_RESET UNKNOWN_09 UNKNOWN_0a ZW_SET_R_F_RECEIVE_MODE ZW_SET_SLEEP_MODE ZW_SEND_NODE_INFORMATION ZW_SEND_DATA ZW_SEND_DATA_MULTI ZW_GET_VERSION ZW_SEND_DATA_ABORT ZW_R_F_POWER_LEVEL_SET ZW_SEND_DATA_META ZW_GET_RANDOM MEMORY_GET_ID MEMORY_GET_BYTE MEMORY_PUT_BYTE MEMORY_GET_BUFFER MEMORY_PUT_BUFFER FLASH_AUTO_PROG_SET UNKNOWN_28 NVM_GET_ID NVM_EXT_READ_LONG_BUFFER NVM_EXT_WRITE_LONG_BUFFER NVM_EXT_READ_LONG_BYTE NVM_EXT_WRITE_LONG_BYTE ZW_GET_NODE_PROTOCOL_INFO ZW_SET_DEFAULT ZW_REPLICATION_COMMAND_COMPLETE ZW_REPLICATION_SEND_DATA ZW_ASSIGN_RETURN_ROUTE ZW_DELETE_RETURN_ROUTE ZW_REQUEST_NODE_NEIGHBOR_UPDATE ZW_APPLICATION_UPDATE ZW_ADD_NODE_TO_NETWORK ZW_REMOVE_NODE_FROM_NETWORK ZW_CREATE_NEW_PRIMARY ZW_CONTROLLER_CHANGE ZW_SET_LEARN_MODE ZW_ASSIGN_SUC_RETURN_ROUTE ZW_REQUEST_NETWORK_UPDATE ZW_SET_SUC_NODE_ID ZW_DELETE_SUC_RETURN_ROUTE ZW_GET_SUC_NODE_ID ZW_SEND_SUC_ID ZW_EXPLORE_REQUEST_INCLUSION ZW_REQUEST_NODE_INFO ZW_REMOVE_FAILED_NODE_ID ZW_IS_FAILED_NODE ZW_REPLACE_FAILED_NODE UNKNOWN_66 UNKNOWN_67 UNKNOWN_78 GET_ROUTING_TABLE_LINE LOCK_ROUTE_RESPONSE UNKNOWN_92 UNKNOWN_93 UNKNOWN_98 ZW_SET_WUT_TIMEOUT ZW_WATCHDOG_ENABLE ZW_WATCHDOG_DISABLE ZW_WATCHDOG_CHECK ZW_SET_EXT_INT_LEVEL ZW_RF_POWERLEVEL_GET ZW_TYPE_LIBRARY ZW_SEND_TEST_FRAME ZW_GET_PROTOCOL_STATUS WATCHDOG_START WATCHDOG_STOP UNKNOWN_d4 UNKNOWN_ef ZME_FREQ_CHANGE ZME_BOOTLOADER_FLASH UNKNOWN_f5
homeId HomeId:vielezahlen CtrlNodeId:01
dann hab ich versucht, den sensor einzubinden - also den stick auf addnode on bzw auch mal onNW ...
3 mal schnell im sensor die taste drücken - der sensor leuchtet blau für ne zeit
und das wars dann auch - nichts passiert. der sensor hört auf zu leuchten und bei fhem gibts weder ne fehlermeldung und schon gar keinen gefundene sensor.
wenn noch irgendwelche benötigten infos fehlen, liefer ich die sehr gerne nach! aber bitte noob-gerecht anfordern *g*.
kann ich den sensor eventuell "händisch" in fhem bringen? was bräuchte ich von wo dafür?
was mach ich falsch? ich wäre für jede hilfe dankbar!
→do↑p!dnʇs↓shit←
Ich kennen das fgms-001 nicht, ich vermute aber, dass bei diesem Problem das Geraet bereits angelernt wurde, und zunaechst zurueckgesetzt werden muss. Oder die Knoepfe wurden nicht schnell genug gedrueckt: bei einem anderen Geraet hatte ich mit dem dreifach-Klick meine Probleme.
the ratman
leider sehr einfach bei dem ding:
nach anleitung ( http://www.fibaro.com/manuals/de/FGMS-001/FGMS-001-DE-A-v1.00.pdf )
reset:
ZitatReset des Fibaro Motion Sensors:
1)
Stellen Sie sicher, dass das Gerät an die Stromquelle
angeschlossen ist.
2)
Drücken Sie die B-Taste für 4-6 Sekunden bis die LED gelb
leuchtet und den Übergang in die 2. Position des Menüs anzeigt.
3)
Lassen Sie die B-Taste wieder los.
4)
Drücken Sie noch einmal kurz die B-Taste.
Bei erfolgreichem Ablauf des Verfahrens  leuchtet die LED-Anzeige
rot und dann wird sie gelöscht
und genau so verhällt er sich auch
und einbinden:
Zitat1)
Legen Sie die Batterie in den Fibaro Motion Sensor ein. Die
Verbindung der beiden Gehäuseteile ist mit einem Punkt markiert.
Prüfen Sie, ob sich das Gerät in direkter Reichweite des Controllers
befindet.
2)
Bringen Sie den Controller in den Inklusionsmodus (siehe
Bedienungsanleitung des Controllers).
3)
Drücken Sie dreimal hintereinander die B-Taste – die LED leuchtet
blau.
4)
Der Fibaro Motion Sensor wird erkannt und in das Netzwerk
inkludiert.
5)
Warten Sie bis das Gerät von Ihrem Controller richtig konfiguriert
wird.
6)
Bei Bedarf drücken Sie die B-Taste, um den Fibaro Motion Sensor
aufzuwecken.
7)
Die LED leuchtet blau und bestätigt dadurch was das Aufwecken
des Gerätes.
auch das macht er richtig.
leider mit dem selben ergebnis wie vorher, also keinem.
→do↑p!dnʇs↓shit←
Sieht man waehrend das Anlernens im Event-Monitor oder Log etwas auffaelliges?
the ratman
#4
zumindest mir fällt nix auf (was aber nix heißen soll *g*)
mit verbos5 kommt:2016.02.27 16:16:17 1: Logfile gelöscht
2016.02.27 16:16:33 4: ZWDongle set Z_Wave addNode on
2016.02.27 16:16:33 5: ZWDongle_Write 004a8110 ()
2016.02.27 16:16:33 5: SW: 0105004a811021
2016.02.27 16:16:33 5: ACK received, removing 0105004a811021 from dongle sendstack
2016.02.27 16:16:33 4: ZWDongle_Read Z_Wave: sending ACK, processing 004a10010000
2016.02.27 16:16:33 5: SW: 06
2016.02.27 16:16:33 5: Z_Wave dispatch 004a10010000
nachtrag:
ganz vergessen, die internals werden bei jedem anlernen um 1 hochgezähltCallbackNr 17
ich hab jetzt in meiner verzweiflung probiert, das ding mit einem erstellten networkkey und addnode onnwsec bzw onsec zu finden versucht (natürlich mit passender perl-lib).
auch da ändert sich leider nix
→do↑p!dnʇs↓shit←
Nur als info: so schaut ein Exclusion/Inclusion aus Event-Sicht aus:
fhem> info timer
fhem> set zwd removeNode on
2016-02-27 19:19:51.245 ZWDongle zwd removeNode on
2016-02-27 19:19:51.253 ZWDongle zwd ZW_REMOVE_NODE_FROM_NETWORK learnReady
2016-02-27 19:19:58.203 ZWave as6 config_85: 5
2016-02-27 19:20:02.590 ZWDongle zwd ZW_REMOVE_NODE_FROM_NETWORK nodeFound
2016-02-27 19:20:03.274 ZWDongle zwd ZW_REMOVE_NODE_FROM_NETWORK slave
2016-02-27 19:20:03.277 ZWDongle zwd ZW_REMOVE_NODE_FROM_NETWORK done
fhem> set zwd addNode on
2016-02-27 19:20:14.934 ZWDongle zwd addNode on
2016-02-27 19:20:14.936 ZWDongle zwd ZW_ADD_NODE_TO_NETWORK learnReady
2016-02-27 19:20:17.861 ZWDongle zwd ZW_ADD_NODE_TO_NETWORK nodeFound
2016-02-27 19:20:18.075 Global global UNDEFINED ZWave_SWITCH_BINARY_56 ZWave deadbeef 56 5e25263370273281855972867a7398ef5a82
2016-02-27 19:20:18.075 Global global DEFINED ZWave_SWITCH_BINARY_56
2016-02-27 19:20:18.075 Global global SAVE
2016-02-27 19:20:19.016 ZWave ZWave_SWITCH_BINARY_56 associationAdd 1 01
2016-02-27 19:20:19.566 ZWave ZWave_SWITCH_BINARY_56 modelConfig: aeotec/ss6.xml
2016-02-27 19:20:19.566 ZWave ZWave_SWITCH_BINARY_56 model: Aeotec Smart Switch 6
2016-02-27 19:20:19.566 ZWave ZWave_SWITCH_BINARY_56 modelId: 0086-0003-0060
fhem> set zwd addNode off
2016-02-27 19:20:30.006 ZWDongle zwd addNode off
2016-02-27 19:20:30.156 ZWDongle zwd ZW_ADD_NODE_TO_NETWORK done
Das war ein ZWdongle. Mit ZWCUL schaut das leicht anders aus.
the ratman
#6
schöne zeilen -  nur was mach ich damit und wo und wie kann ich das bei mir vergleichen?
aber ne andere dumme frage:
kann überhaupt jemand bestätigen, dass mein stick mit dem sensor zusammen arbeitet? nicht, dass wir hier tote pferde reiten.
ich hab halt dummer weise nichts weiter zum testen hier - vom verlauf dieses tests wollt ich ja abhängig machen, ob ich z-wave überhaupt in mein haus aufnehmen will.
→do↑p!dnʇs↓shit←
Wenn die Zeilen "learnReady/etc" bei dir im EventLog oder im FHEM-Log bei "zwdongle verbose 4+" nicht auftauchen, dann ist mit dem Dongle was nicht in Ordnung.
krikan
Warum sollten die nicht zusammenarbeiten? Sind beide ZWave.
Zur Beruhigung: Ja, arbeiten hier problemlos zusammen.
the ratman
#9
@rudolfkoenig
jo, kommt eindeutig nicht - werd mal das ding raus löschen und neu anlernen - vielleicht hilfts ja?
wenn ja, werd ich hier berichten, wenn nein, geh ich mal ne runde heulen ...
@krikan
thx - deine info bingt meinen puls wieder in meßbare regionen *g*
nachtrag:
ein neustart!
dongle aus fhem gekilled - sicherheitshalber restart
sensor nochmal geressetted
usb create, stick wird erkannt
auf die suche schicken - der stick beginnt blau zu blinken
nix wird gefunden
node off - der stick hört auf, blau zu blinken
ergebnis:2016.02.27 20:15:57 4: ZWDongle set ZWDongle_0 addNode on
2016.02.27 20:15:57 5: ZWDongle_Write 004a8103 ()
2016.02.27 20:15:57 5: SW: 0105004a810332
2016.02.27 20:15:57 5: ACK received, removing 0105004a810332 from dongle sendstack
2016.02.27 20:15:57 4: ZWDongle_Read ZWDongle_0: sending ACK, processing 004a03010000
2016.02.27 20:15:57 5: SW: 06
2016.02.27 20:15:57 5: ZWDongle_0 dispatch 004a03010000
2016.02.27 20:15:57 4: CMD:ZW_ADD_NODE_TO_NETWORK ID:01 ARG:0000
2016.02.27 20:15:57 4: ZWDongle_0 ZW_ADD_NODE_TO_NETWORK learnReady
learn ready haben ma also nun
nur mein sensor ist nicht zu finden
mal ganz für dumme:
hab den stick jetzt an ner usb-verlängerung hängen, um eventuelle funkprobleme aus meinem "automatisations-kistchen" zu vermeiden.
ich hab also den stick in fhem angelernt, nix gemacht - ausser verbos 5
dann kann ich sofort den sensor mit get node on oder onnw suchen, brauche auch keinerlei readings setzen oder z.b. ein set nif machen?
ist das soweit korrekt?
→do↑p!dnʇs↓shit←
9zehn75
Ratman,
wie weit bist Du denn beim Anlernen von Deinem Stick entfernt? Gehe mal so nah wie möglich ran und versuche es nochmals. Ich musste bei einigen Fibaro-Fenstersensoren außerdem mehrfach dreimal drücken bis es geklappt hat. Die scheinen etwas wählerisch im Hinblick auf die genaue Druckfrequenz. Vielleicht ist das bei dem Motion Sensor auch so?
VG, 9zehn75
FHEM seit 02.02.2016: Raspberry Pi 2, ZME_UZB1, Fibaro WallPlugs, Fibaro Fenstersensoren, Aeon Indoor Sirene, Greenwave WallPlugs, Qubino Dimmer
the ratman
#11
ich probiere *g*
aber die entfernung liegt derzeit bei ca. 30 bis 50 cm - wenns daran liegt, schmeiß ich den krempel dem hersteller um den kopf.
ich geh jetzt mal 3-fach-klicks üben - vielleicht hilfts ja wirklich was, wenn ich den mehrfach ausprobier.
thx für den tipp!
nachtrag:
ich hab jetzt spaßehalber mal auf windoof domoticz installiert.
1:1 das selbe verhalten.
scheint dann wohl echt was kaputt zu sein  - ich frag mich nur, was ich tauschen soll. den sensor oder den stick?
→do↑p!dnʇs↓shit←
the ratman
hmm, keiner ne idee?
gut, dann bestell ich einfach neues zeug und schau mal, ob das geht ...
→do↑p!dnʇs↓shit←
9zehn75
Fibaro ist - nach allem was ich so gelesen habe - nicht gerade für gleichbleibende Qualität berüchtigt. Kann daher meines Erachtens schon sein, dass der Sensor defekt ist. Mehr wird dir hier niemand helfen können.
VG, 9zehn75
the ratman
danke, das wusst ich nicht.
immerhin ist die aussage ne gute entscheidungshilfe.
→do↑p!dnʇs↓shit←
