[ AMAD2 - obsolete] 74_AMAD.pm zur Steuerung eines Androidgerätes
Begonnen von CoolTux, 02 März 2016, 11:14:41
Tommy82
Also bei mir werden die readings nicht gepusht.....
Die readings stehen immer noch auf 21:xx Uhr, bzw. einige auch noch älter
   APSSID     T&T,T&T5GHZ
   DEF        192.168.188.23 T&T,T&T5GHZ
   HOST       192.168.188.23
   NAME       Android_Tablett_Wohnzimmer
   NR         291
   PORT       8090
   STATE      read from to http://192.168.188.23:8090 timed out
   TYPE       AMAD
   VERSIONFLOWSET 2.0.0
   VERSIONMODUL 2.0.0
   Helper:
     Dblog:
       Androidversion:
         Mydblog:
           TIME       1460228802.47294
           VALUE      4.2 - 4.2.2 Jelly Bean MR1
       Automagicstate:
         Mydblog:
           TIME       1460228803.94909
           VALUE      not supported from your device
       Bluetooth:
         Mydblog:
           TIME       1460228803.73804
           VALUE      on
       Currentmusicalbum:
         Mydblog:
           TIME       1460228803.66388
           VALUE      no soundplayer activ
       Currentmusicartist:
         Mydblog:
       Currentmusictrack:
         Mydblog:
       Devicestate:
         Mydblog:
           TIME       1460228793.91108
           VALUE      online
       Display:
         Mydblog:
           TIME       1460211280.63384
           VALUE      an
       Dockingstate:
         Mydblog:
           TIME       1460228803.59551
           VALUE      undocked
       Keyguardset:
         Mydblog:
           TIME       1460228803.80882
           VALUE      0
       Laststatusrequeststate:
         Mydblog:
           TIME       1460228830.42849
           VALUE      statusRequest_error
       Nextalarmday:
         Mydblog:
           TIME       1460228803.52841
           VALUE      off
       Nextalarmtime:
         Mydblog:
           VALUE      off
       Powerlevel:
         Mydblog:
           TIME       1460228802.62524
           VALUE      100.0
       Powerplugged:
         Mydblog:
           VALUE      1
       Screen:
         Mydblog:
           TIME       1460228807.62487
           VALUE      off unlocked
       Screenbrightness:
         Mydblog:
           TIME       1460228802.40722
           VALUE      157
       Screenorientation:
         Mydblog:
           TIME       1460228804.28922
           VALUE      landscape
       Screenorientationmode:
         Mydblog:
           VALUE      auto
       State:
         Mydblog:
           VALUE      read from to http://192.168.188.23:8090 timed out
       Volume:
         Mydblog:
           TIME       1460228804.14617
           VALUE      0
       Volumenotification:
         Mydblog:
           TIME       1460228802.34118
           VALUE      0
   Readings:
     2016-04-09 21:06:42   androidVersion  4.2 - 4.2.2 Jelly Bean MR1
     2016-04-09 21:06:43   automagicState  not supported from your device
     2016-04-09 21:06:43   bluetooth       on
     2016-04-09 14:43:34   checkActiveTask
     2016-04-09 21:06:43   connectedBTdevices
     2016-04-09 21:06:43   connectedBTdevicesMAC
     2016-04-09 21:06:43   currentMusicAlbum no soundplayer activ
     2016-04-09 21:06:43   currentMusicArtist no soundplayer activ
     2016-04-09 21:06:43   currentMusicTrack no soundplayer activ
     2016-04-09 21:06:33   deviceState     online
     2016-04-09 16:14:40   display         an
     2016-04-09 21:06:43   dockingState    undocked
     2016-04-09 14:43:34   flow_SetCommands aktiv
     2016-04-09 14:43:34   flow_informations aktiv
     2016-04-09 21:06:43   keyguardSet     0
     2016-03-02 20:42:54   lastSetCommandState cmd_done
     2016-03-31 07:49:20   lastStatusRequestError 192.168.188.23: No route to host
     2016-04-09 21:07:10   lastStatusRequestState statusRequest_error
     2016-04-09 21:06:43   nextAlarmDay    off
     2016-04-09 21:06:43   nextAlarmTime   off
     2016-04-09 21:06:42   powerLevel      100.0
     2016-04-09 21:06:42   powerPlugged    1
     2016-04-09 21:06:47   screen          off unlocked
     2016-04-09 21:06:42   screenBrightness 157
     2016-04-09 21:06:44   screenOrientation landscape
     2016-04-09 21:06:44   screenOrientationMode auto
     2016-04-09 21:07:10   state           read from to http://192.168.188.23:8090 timed out
     2016-04-09 21:06:44   volume          0
     2016-04-09 14:43:34   volumeMusikBluetooth
     2016-04-09 14:43:34   volumeMusikSpeaker 0
     2016-04-09 21:06:42   volumeNotification 0
   Helper:
     infoErrorCounter 1
     setCmdErrorCounter 0
   room       Wohnzimmer
Das sollte doch so nicht sein oder?
Wenn ich dann ein statusRequest mache, werden fast alle aktualisiert
Fhem Cubitruck  Armbian Buster with Linux 5.3.9-sunxi
HM-CC_RT-DN, HM-Sec-RHS,HM-Sec-SD, HM-Sec-SCo,IT1500,1xIT GRR-3500 Fritz!Dect200,Powerline546E,Enigma2 Modul mit 3 Vu+,Wol Modul für WinServer2016 und WinServer 2019,FB6590
Allnetl Wandtablett mit FTUI
CoolTux
Zitat von: Helmi55 am 09 April 2016, 22:52:16
Yepp Danke - hält aber nur bis zum nächsten restart/reread von fhem
Sag und wie sehe ich jetzt den Batteriezustand - hatte ich unter 1.0 schon
Und Danke für deine tollen Arbeiten du steckst wirklich sehr viel Zeit in die Projekte
Nach dem Du auf active gewechselt hast von Hand musst Du auf jeden Fall einen sauberen statusRequest hinbekommen.
Wenn das Device im initial festhängt sollte mit Verbose 4 und höher im Log stehen warum das so ist.
Ansonsten brauche ich list von Device und Bridge und verbose 5 Logausgaben vom Device und der Bridge.
Das TuxNet Wiki:
https://www.cooltux.net
CoolTux
   APSSID     T&T,T&T5GHZ
   HOST       192.168.188.23
   NR         291
   PORT       8090
   TYPE       AMAD
   VERSIONMODUL 2.0.0
   Helper:
     Dblog:
       Androidversion:
         Mydblog:
       Automagicstate:
         Mydblog:
       Bluetooth:
         Mydblog:
           VALUE      on
       Currentmusicalbum:
         Mydblog:
       Currentmusicartist:
         Mydblog:
       Currentmusictrack:
         Mydblog:
       Devicestate:
         Mydblog:
           VALUE      online
       Display:
         Mydblog:
           VALUE      an
       Dockingstate:
         Mydblog:
           VALUE      undocked
       Keyguardset:
         Mydblog:
           VALUE      0
         Mydblog:
       Nextalarmday:
         Mydblog:
           VALUE      off
       Nextalarmtime:
         Mydblog:
           VALUE      off
       Powerlevel:
         Mydblog:
           VALUE      100.0
       Powerplugged:
         Mydblog:
           VALUE      1
       Screen:
         Mydblog:
           VALUE      off unlocked
       Screenbrightness:
         Mydblog:
           VALUE      157
       Screenorientation:
         Mydblog:
           VALUE      landscape
         Mydblog:
           VALUE      auto
       State:
         Mydblog:
       Volume:
         Mydblog:
           VALUE      0
       Volumenotification:
         Mydblog:
           VALUE      0
   Readings:
   Helper:
     infoErrorCounter 1
   room       Wohnzimmer
Kann schon sein. Denn es werden nur die Readings gepusht welche auch eine Änderung erfahren. Aber sowas wie screen sollte natürlich sich ändern wenn man an und aus macht und auch Batterie sollte sich über Nacht so um 1-2 Prozent verändern.
Das TuxNet Wiki:
hyper2910
Zitat von: Clyde am 09 April 2016, 18:32:29
Ein Tablet ist jetzt auf
"read from to http://192.168.1.58:8090 timed out"
gewechselt. Mit
set TabletNickel statusRequest
geht es für 30s auf active, die Readings kommen und dann wechselt er zurück auf obiges timeout.
Dies ist reproduzierbar. Die anderen Geräte bleiben auf initialized.
das gleiche bei mir.
Cubietruck mit FHEM, CUL V3 443MHz, 2 x CULV3 868MHz, Milights, Max Heizungssteuerung, Homematic, IT,
Helmi55
Servus
hier mein Log
2016.04.10 10:21:45 3: [Daemmerung] 0 attempt(s) needed to get valid weather data from yahoo
2016.04.10 10:21:46 3: AMAD (TabletGarage) - defined with host 192.168.0.117 on port 8090 and AccessPoint-SSID dlink-D22C,Garage
2016.04.10 10:21:46 3: AMAD (AMADCommBridge) - defined Bridge with Socketport 8090
2016.04.10 10:21:46 3: AMAD (AMADCommBridge) - Attention!!! By the first run, dont forget to "set AMADCommBridge fhemServerIP <IP-FHEM>"
2016.04.10 10:21:46 3: AMADCommBridge: port 8090 opened
2016.04.10 10:22:01 5: AMAD (TabletGarage) - Send statusRequest with URL: "http://192.168.0.117:8090/fhem-amad/deviceInfo/" and Header: "fhemIP: 192.168.0.117
fhemDevice: TabletGarage
activeTask: none
apSSID: dlink-D22C,Garage"
2016.04.10 10:22:01 4: Connection accepted from AMADCommBridge_192.168.0.117_53705
2016.04.10 10:22:01 5: AMAD (AMADCommBridge) - Receive RAW Message in Debugging Mode: GET /fhem-amad/deviceInfo/ HTTP/1.0
Host: 192.168.0.117
User-Agent: fhem
fhemip: 192.168.0.117
fhemdevice: TabletGarage
activetask: none
apssid: dlink-D22C,Garage
bport: 8090
2016.04.10 10:22:01 1: PERL WARNING: Use of uninitialized value $device in hash element at ./FHEM/74_AMAD.pm line 1057.
2016.04.10 10:22:01 1: PERL WARNING: Use of uninitialized value $fhemcmd in pattern match (m//) at ./FHEM/74_AMAD.pm line 1090.
2016.04.10 10:22:01 1: PERL WARNING: Use of uninitialized value $fhemcmd in pattern match (m//) at ./FHEM/74_AMAD.pm line 1107.
2016.04.10 10:22:01 1: PERL WARNING: Use of uninitialized value $fhemcmd in pattern match (m//) at ./FHEM/74_AMAD.pm line 1124.
2016.04.10 10:22:01 1: PERL WARNING: Use of uninitialized value $fhemcmd in pattern match (m//) at ./FHEM/74_AMAD.pm line 1143.
2016.04.10 10:22:01 1: PERL WARNING: Use of uninitialized value $fhemcmd in pattern match (m//) at ./FHEM/74_AMAD.pm line 1158.
2016.04.10 10:22:01 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/74_AMAD.pm line 144.
2016.04.10 10:22:15 3: EMONITOR_Init2: found 6 devices
2016.04.10 10:23:16 5: AMAD (TabletGarage) - set TabletGarage statusRequest
2016.04.10 10:23:16 5: AMAD (TabletGarage) - Send statusRequest with URL: "http://192.168.0.117:8090/fhem-amad/deviceInfo/" and Header: "fhemIP: 192.168.0.117
activeTask: none
2016.04.10 10:23:16 4: Connection accepted from AMADCommBridge_192.168.0.117_53707
2016.04.10 10:23:16 5: AMAD (AMADCommBridge) - Receive RAW Message in Debugging Mode: GET /fhem-amad/deviceInfo/ HTTP/1.0
Host: 192.168.0.117
User-Agent: fhem
activetask: none
bport: 8090
Helmut
System1 fhem 6.1 auf RPi 4B mit 4GB, HMUSBConfig, DS9490R-1Wire, Busware USB 868, Pool-Solarsteuerung mit FHEM. System2 fhem 6.1 auf RPi 4B mit 4GB (Bullseye) mit Busware USB 868 und 433 und HMUARTLGW für Haussteuerung
https://www.flickr.com/photos/canonhelmi/
ext23
ich sehe hier werden Ports geöffnet/benötigt bei der neuen Version, so eine Comm Bridge hatte ich bis jetzt noch nicht :-).
Gibt es da eine Komm Matrix zu? Ich müsste nämlich meine Firewall da auch freischalten.
Also TCP/UDP?  Protokoll, also HTTP oder was geht da ungefähr rüber etc. Gibt es Anforderungen wie lange eine Session mind. offen bleiben muss etc.?
Daniel
CoolTux
Hallo Helmut,
Kann es sein das Du, wie der Kollege ein paar Threads vor Dir, die selbe IP als Host IP und als Bridgereading fhemServerIP hast?
Lese ich jedenfalls aus dem Log so.
Das TuxNet Wiki:
CoolTux
Zitat von: ext23 am 10 April 2016, 10:32:55
Daniel
Guten Morgen Daniel,
Von FHEM zum Device muss TCP Port 8090 auf sein, diese Session bleibt nur so lange bestehen wie die Abarbeitung des HTTP Request dauert. Also paar Sekunden.
Vom Tablet zu FHEM ist das selbe, TCP Port 8090 als Protokoll ebenfalls HTTP aber hier hält der Socket der Bridge die Verbindung länger aufrecht da hier immer wieder Daten kommen.
Das TuxNet Wiki:
Helmi55
Ach du Schande
2016.04.10 10:39:40 5: AMAD (TabletGarage) - Send statusRequest with URL: "http://192.168.0.116:8090/fhem-amad/deviceInfo/" and Header: "fhemIP: 192.168.0.117
activeTask: none
2016.04.10 10:39:54 3: EMONITOR_Init2: found 6 devices
2016.04.10 10:40:28 5: AMAD (TabletGarage) - set TabletGarage statusRequest
2016.04.10 10:40:28 5: AMAD (TabletGarage) - Send statusRequest with URL: "http://192.168.0.116:8090/fhem-amad/deviceInfo/" and Header: "fhemIP: 192.168.0.117
activeTask: none
habe es händisch wieder auf active gesetzt aber es kommen keine readings rein........
ext23
Alles klar, danke.
Dann muss ich mal schauen, weil irgendwie bekomme ich keine Verbindung mehr hin. Ich hoffe die SSID braucht man nicht, weil ich habe kein WLAN ... Mein Tab hängt am LAN, ohne W ;-)
Dann werd ich mal forschen wo mein Problem liegt.
/Daniel
CoolTux
Oh man Du bist schon der zweite. Sowas habe ich so gar nicht beachtet. Wusste nicht das es sowas gibt. Ich werde im laufe der nächsten Woche mir da was einfallen lassen. Bis dahin kannst Du leider nichts machen. Sorry.
Das TuxNet Wiki:
CoolTux
Zitat von: Helmi55 am 10 April 2016, 10:46:42
Ach du Schande
activeTask: none
activeTask: none
Hast Du die fhemServerIP geändert oder die Host IP? Wenn Du die fhemServerIP geändert hast, dann lösche bitte die entsprechende globale Variable in Automagic oder passe sie an. Wenn Du sie löschst musst Du ein satusRequest machen damit die wieder gesetzt wird.
Das TuxNet Wiki:
ext23
Meinst du das mit dem WLAN, jo naja USB Adapter ran und gut ist ;-) WLAN ist mir alles zu instabil, unsicher und Strahlungsreich ;-)
Btw. es gibt auch genug Android Boxen/Sticks für den Fernseher die LAN haben, was bei Streaming auch mehr Sinn macht. Bzw. ganze Bildschirme mit Android drauf.
Ich installiere dann erst mal wieder die alte Version.
Helmi55
Ich habe nur die des Tablett geändert...
Die fhem IP ist die 117 geblieben. Das tablet hat 116
Habe danach nochmals aktiviert und einen Stausrequest ausgeführt?
CoolTux
#404
Ich werde die Tage ein Update vorbereiten. Es gibt kleine Features.
  • set notifySndFile - bekommt eine Attributangabe für den korrekten (System)Pfad
  • set ttsMsg - bekommt ein Attribut für die Auswahl der Sprachgeschwindigkeit bei der Ausgabe
  • es gibt einen neuen Trigger closed App, damit ist ein besseres arbeiten mit checkAktivTask möglich
  • der FHEM Pfad wird nun aus dem globalen Attribut modpath ermittelt. Danke an Andre(justme1968) für den Hinweis
Leon
Das TuxNet Wiki:
