nach Update Tablet Ui im select widget keine Auswahl von Uhrzeit mehr
Begonnen von Mpomp, 03 März 2016, 06:05:48
Mpomp
bis zum vorletzten Update des Tablet Ui habe ich mit einem Select Widget die Auswahl einer Uhrzeit realisiert, jetzt funktioniert dies nicht mehr.
<div data-type="select" data-device="HZProfilBad"
                          data-items=["off","00:00","00:15","00:30","00:45","01:00","01:15","01:30","01:45","02:00","02:15","02:30","02:45","03:00","03:15","03:30","03:45","04:00","04:15","04:30","04:45","05:00","05:15","05:30","05:45","06:00","06:15","06:30","06:45","07:00","07:15","07:30","07:45","08:00","08:15","08:30","08:45","09:00","09:15","09:30","09:45","10:00","10:15","10:30","10:45","11:00","11:15","11:30","11:45","12:00","12:15","12:30","12:45","13:00","13:15","13:30","13:45","14:00","14:15","14:30","14:45","15:00","15:15","15:30","15:45","16:00","16:15","16:30","16:45","17:00","17:15","17:30","17:45","18:00","18:15","18:30","18:45","19:00","19:15","19:30","19:45","20:00","20:15","20:30","20:45","21:00","21:15","21:30","21:45","22:00","22:15","22:30","22:45","23:00","23:15","23:30","23:45"]
                          data-get="BWeek_1"
                          data-set="BWeek_1"
                          data-cmd="setreading">
            </div>
An was kann das liegen?
Ich vermute es liegt an den Doppelpunkten.
Keine Funktion bedeutet ich bekomme nur noch "off" oder "00" zur Auswahl. Damit legte ich meine Profile für meine Heizungzeiten fest.
Vielen Dank.
Ubuntu 14.04 auf Atom Zotac IONITX-E/ FHEM 5.7 / Homematic LAN und HM Aktoren, LMS, AVR Denon 3808, mehrere RasPi´s als Squeezebox.
Andy89
Servus,
das gleiche Problem habe ich auch.
Konntest du es lösen?
Beste Grüße
Andy
FHEM 6.0 auf rPi4 docker (mit Alexa & Siri); dbLog, FTUI, Sonos, XiaomiMapCreator auf rPi4 docker;
raspimatic auf rPi3+ > diverse Aktoren und Sensoren;
LGW > (PCA301),EC3000,LaCrosse; MQTT2 > WLAN-Steckdosen,Xiaomi Map;
Harmony Hub;Sonos;Onkyo AVR;RGB WLAN Controller;Netatmo;Withings;Unifi;AMAD
Mpomp
sorry für die späte Antwort, hatte keine Zeit und auch keine Idee.
Laut Doku ist es so das der Doppelpunkt als Trennzeichen verwendet wird.
Ich umging das Problem indem ich Heating_Control und das wdtimer_ftui Widget verwendet habe.
