FB_CALLLIST: don't create html code in readings when create-readings attribute is activated and number-cmd attribute is set.
Begonnen von System, 13 März 2016, 17:45:03
System
FB_CALLLIST: don't create html code in readings when create-readings attribute is activated and number-cmd attribute is set.View Changes
Source: FB_CALLLIST: don't create html code in readings when create-readings attribute is activated and number-cmd attribute is set.
