Springende Temperaturwerte mit TX 37 IT und Jeelink CUL
Begonnen von Fredi69, 03 April 2016, 16:28:31
Fredi69
Hallo, ich betreibe mehrere Temperatursensoren der Technoline Reihe an einem Jeelink CUL.
Bei einem Sensor springt die Temperatur seit einiger Zeit immer zwischen zwei Werten, siehe log.
2016-04-03_16:25:01 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:01 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:05 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:05 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:13 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:13 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:17 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:17 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:21 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:21 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:25 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:25 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:29 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:29 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:33 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:33 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:37 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:38 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:41 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:42 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:45 LaCrosse_08 temperature: 18.9
2016-04-03_16:25:46 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:49 LaCrosse_08 temperature: 19
2016-04-03_16:25:50 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:54 LaCrosse_08 temperature: 19
2016-04-03_16:25:54 LaCrosse_08 temperature: 20.9
2016-04-03_16:25:58 LaCrosse_08 temperature: 19
2016-04-03_16:25:58 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:02 LaCrosse_08 temperature: 19
2016-04-03_16:26:02 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:06 LaCrosse_08 temperature: 19
2016-04-03_16:26:06 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:10 LaCrosse_08 temperature: 19
2016-04-03_16:26:18 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:22 LaCrosse_08 temperature: 19
2016-04-03_16:26:22 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:26 LaCrosse_08 temperature: 19
2016-04-03_16:26:26 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:30 LaCrosse_08 temperature: 19
2016-04-03_16:26:30 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:34 LaCrosse_08 temperature: 19
2016-04-03_16:26:38 LaCrosse_08 temperature: 20.9
2016-04-03_16:26:42 LaCrosse_08 temperature: 19
2016-04-03_16:26:43 LaCrosse_08 temperature: 20.8
2016-04-03_16:26:46 LaCrosse_08 temperature: 19
2016-04-03_16:26:47 LaCrosse_08 temperature: 20.8
2016-04-03_16:26:54 LaCrosse_08 temperature: 19
2016-04-03_16:26:55 LaCrosse_08 temperature: 20.8
2016-04-03_16:26:59 LaCrosse_08 temperature: 19
2016-04-03_16:26:59 LaCrosse_08 temperature: 20.8
2016-04-03_16:27:03 LaCrosse_08 temperature: 19
Hat jemand eine Idee warum das so ist?
fhem auf Raspberry Pi 3
FRITZ!Box7490, Fritz!Box 3270 AP, 3xHMLAN, CUL868, nanoCUL 433 für IT, JeeLink für LaCrosse, HUE Bridge 2.0, Samsung UE46C8790 (STV), mehrere Homematic, Intertechno, Shelly und LaCrosse Komponenten
HCS
Was ist ein JeeLink CUL?
Ich vermute, dass zwei Sensoren die gleiche ID (08) haben.
Fredi69
HCS
Das ist ein JeeLink. Und ein CUL ist ein CUL. Drum habe ich mich gefragt, was ein "JeeLink CUL" wohl sein könnte.
Fredi69
ID's geprüft, alle sind unterschiedlich.
HCS
Ich meinte damit, dass zwei Sensoren (die Hardware) mit dieser ID senden.
Was für Sensoren sind es denn?
Fredi69
Wie bereits geschrieben ist es ein TX 37 IT von Technoline
HCS
Ahh, klar, im Titel  :)
Schau mal hier: https://forum.fhem.de/index.php?topic=34337.0
Du hast vermutlich mehrere Sensoren mit gleicher ID, bist nicht der Erste.
Steht auf den Sensoren eine ID drauf?
Fredi69
Nein, auch das wurde geprüft. Nur der eine Sensor hat die Adresse 08.
HCS
Kommen an dem LaCrosse device in FHEM noch Daten an, wenn Du nur aus diesem einen Sensor die Batterien raus nimmst?
Fredi69
Das war ein entscheidender Tipp, es kommen weiterhin Daten.
Das ganze hat vor nachvollziehbar vor 25 Tagen begonnen.
Wahrscheinlich hat an diesem Tag ein Nachbar auch ein TX 37 in Betrieb genommen.
Kann man die ID verändern?
Vielen Dank für Eure Unterstützung.
HCS
Den Verdacht hatte ich auch schon.
Ich glaube nein.
