Frage zur Tecalor THZ Wärmepumpe - Werte p01XXX
Begonnen von wla, 23 April 2016, 23:45:38
wla
Es werden u.a. folg. Werte ausgelesen:
p01RoomTempDayHC1                          22 °C
p01RoomTempDayHC1SummerMode     25 °C
p01RoomTempDayHC2                          21.9 °C
p01RoomTempDayHC2SummerMode     25 °C
p02RoomTempNightHC1                        22 °C
p02RoomTempNightHC1SummerMode   25 °C
p02RoomTempNightHC2                        21.9 °C
p02RoomTempNightHC2SummerMode   25 °C
Ich habe eine THZ404.
Wieso DayHC1 und DayHC1SummerMode?
Wo kann ich hier unterschiedliche Werte einstellen? An der Maschine und in der Dokumentation kann ich hier keine zwei Zustände ohne und mit SummerMode finden?
Vielleicht kann mir dies jemand erklären?
immi
Hi wla
when you are in wintermode p01RoomTempDayHC1  will be shown in your display and used from the heatpump
when you are in summermode p01RoomTempDayHC1SummerMode  will be shown in your display and used from the heatpump
feel free to ask tecalor why they do not document their firmware
immi
wla
Hi immi,
did you want to say, that if I set the RoomTempDay in wintermode (on display), this is not valide also in summer mode? I must wait for summer mode, to set the value for summer? It is not possible to set the value for summer in winter and vice versa?
And if I wish 22°C for winter, what is a good value for summer? Is this, to correct a never perfect heating curve?
Sorry for my bad english and thank you for answer!
Walter
micomat
Could it be that the summer-mode-temp is irrelevant anyway as when the THZ is in summer mode, the heating circles are "offline"?
My experience tells me that the THZ is never heating up the HC when in sommer mode.
Synology DS218+ with fhem+iobroker in docker, 2x RasPi w. ser2net, CUL433+868, IT, EGPM2LAN, THZ/LWZ, FB_Callmonitor, HMS100TF, Homematic, 2x TX3-TH, Pushover, USB-IR-SML-Head, SONOS, GHoma, MBus, KLF200
immi
Hi Markus
p01RoomTempDayHC1    remains important for the p75passiveCooling ( if you do not have an internal temperature sensor) and for active cooling (if your heapump is very new).
I do not need it, for the reason you already listed.
immi
micomat
Good hint immi, never thought about passive cooling in this context. But yes, you're right.
I checked my settings and found that the summer mode temp is even 1°C less than winter mode :D
