HM-CC-RT-DN valve max. auf 87%
Begonnen von franky08, 01 Mai 2016, 12:25:07
franky08
Seit gestern geht ein Thermostat nur noch bis max. 87 %. Hier mal ein list:
   DEF        255544
   HMLAN1_MSGCNT 93
   HMLAN1_RAWMSG E255544,0000,6A327226,FF,FFDC,7B86102555440000000AD0EE115B40
   HMLAN1_RSSI -36
   HMLAN1_TIME 2016-05-01 12:16:25
   HMLAN2_MSGCNT 88
   HMLAN2_RAWMSG E255544,0000,23A89D12,FF,FFC0,7B86102555440000000AD0EE115B40
   HMLAN2_RSSI -64
   HMLAN2_TIME 2016-05-01 12:16:25
   HMLAN3_MSGCNT 95
   HMLAN3_RAWMSG E255544,0000,231DD7BC,FF,FFC5,7B86102555440000000AD0EE115B40
   HMLAN3_RSSI -59
   HMLAN3_TIME 2016-05-01 12:16:25
   HMLAN4_MSGCNT 89
   HMLAN4_RAWMSG E255544,0000,22E7D01C,FF,FFB0,7B86102555440000000AD0EE115B40
   HMLAN4_RSSI -80
   HMLAN4_TIME 2016-05-01 12:16:25
   IODev      HMLAN1
   LASTInputDev HMLAN3
   MSGCNT     365
   NAME       Heizung_WZ_rechts
   NR         1010
   NTFY_ORDER 50-Heizung_WZ_rechts
   STATE      CMDs_done
   TYPE       CUL_HM
   channel_01 WZ_rechts_Heizung_Weather
   channel_02 Heizung_WZ_rechts_Climate
   channel_03 WZ_rechts_Heizung_WindowRec
   channel_04 WZ_rechts_Heizung_Clima
   channel_05 Heizung_WZ_rechts_ClimaTeam
   channel_06 WZ_rechts_Heizung_remote
   lastMsg    No:7B - t:10 s:255544 d:000000 0AD0EE115B40
   protCondBurst on
   protLastRcv 2016-05-01 12:16:25
   protResnd  1 last_at:2016-05-01 10:01:47
   protSnd    35 last_at:2016-05-01 12:13:35
   protState  CMDs_done
   rssi_HMLAN1 avg:-35 min:-35 max:-35 lst:-35 cnt:2
   rssi_at_HMLAN1 avg:-35.98 min:-39 max:-35 lst:-36 cnt:93
   rssi_at_HMLAN2 avg:-65.39 min:-76 max:-61 lst:-64 cnt:88
   rssi_at_HMLAN3 avg:-59.07 min:-62 max:-57 lst:-59 cnt:95
   rssi_at_HMLAN4 avg:-78.41 min:-98 max:-68 lst:-80 cnt:89
   Helper:
     Dblog:
       Activity:
         Mydblog:
           TIME       1462090287.29234
           VALUE      alive
       Actuator:
         Mydblog:
           TIME       1462097785.70016
           VALUE      87
       Battery:
         Mydblog:
           VALUE      ok
       Batterylevel:
         Mydblog:
           VALUE      3.2
       Controlmode:
         Mydblog:
           TIME       1462097632.72334
           VALUE      manual
       Desired-temp:
         Mydblog:
           VALUE      26.0
       Measured-temp:
         Mydblog:
           VALUE      23.8
       Motorerr:
         Mydblog:
           VALUE      ok
       State:
         Mydblog:
           TIME       1462097615.39476
           VALUE      CMDs_done
   Readings:
     2016-05-01 10:11:27   Activity        alive
     2016-05-01 12:13:33   CommandAccepted yes
     2015-03-26 13:03:55   D-firmware      1.4
     2015-03-26 13:03:55   D-serialNr      KEQ1038977
     2016-05-01 12:13:25   PairedTo        0x123ABC
     2015-01-04 21:57:36   R-backOnTime    10 s
     2015-01-04 21:57:36   R-btnLock       off
     2015-01-04 21:57:36   R-burstRx       on
     2015-01-04 21:57:36   R-cyclicInfoMsg on
     2015-06-23 15:26:10   R-cyclicInfoMsgDis 0
     2015-01-04 21:57:36   R-globalBtnLock off
     2015-01-04 21:57:36   R-localResDis   off
     2015-01-04 21:57:36   R-lowBatLimitRT 2.1 V
     2015-01-04 21:57:36   R-modusBtnLock  off
     2015-01-04 21:57:36   R-pairCentral   0x123ABC
     2016-05-01 12:16:25   actuator        87
     2016-05-01 12:16:25   battery         ok
     2016-05-01 12:16:25   batteryLevel    3.2
     2016-05-01 12:13:52   controlMode     manual
     2016-05-01 12:16:25   desired-temp    26.0
     2016-05-01 12:16:25   measured-temp   23.8
     2016-05-01 12:16:25   motorErr        ok
     2016-04-30 20:25:27   powerOn         2016-04-30 20:25:27
     2016-04-30 20:25:27   recentStateType info
     2016-01-03 22:01:43   sabotageAttack  ErrIoAttack cnt:3
     2016-05-01 12:13:35   state           CMDs_done
     2016-04-30 20:25:29   time-request    -
   Helper:
     HM_CMDNR   123
     cSnd       01123ABC2555440603,01123ABC25554406040000000001
     mId        0095
     rxType     140
     Expert:
       def        1
       det        1
       raw        0
       tpl        0
     Io:
       newChn     +255544,00,00,00
       nextSend   1462097785.72904
       rxt        2
       vccu       vccu
       p:
         255544
         00
         00
         00
     Mrssi:
       mNo        7B
       Io:
         HMLAN1     -34
         HMLAN2     -64
         HMLAN3     -59
         HMLAN4     -80
     Prt:
       awake      0
       bErr       0
       brstWu     1
       sProc      0
       sleeping   1
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
       prs        1
     Rssi:
       Hmlan1:
         avg        -35
         cnt        2
         lst        -35
         max        -35
         min        -35
       At_hmlan1:
         avg        -35.989247311828
         cnt        93
         lst        -36
         max        -35
         min        -39
       At_hmlan2:
         avg        -65.3977272727273
         cnt        88
         lst        -64
         max        -61
         min        -76
       At_hmlan3:
         avg        -59.0736842105263
         cnt        95
         lst        -59
         max        -57
         min        -62
       At_hmlan4:
         avg        -78.4157303370786
         cnt        89
         lst        -80
         max        -68
         min        -98
     Shregw:
       07         04
     Shadowreg:
     Tmpl:
   IODev      HMLAN2
   IOgrp      vccu
   actCycle   000:10
   actStatus  alive
   autoReadReg 0_off
   burstAccess 1_auto
   expert     1_on
   firmware   1.4
   model      HM-CC-RT-DN
   room       Wohnzimmer
   serialNr   KEQ1038977
   subType    thermostat
   webCmd     getConfig:clear msgEvents:burstXmit
ein getConfig habe ich schon gemacht und probeweise die desired Temp mal hoch gedreht, bei max. 91% ist Schluss.
VG
Frank
mit FHEM aktuell
MadMax-FHEM
Hi Frank,
im _Klima Kanal schon mal geschaut, ob z.B. "R-valveMaxPos" zufällig auf 91% gesetzt ist...
Ansonsten hat sich (soweit ich mich erinnere) das expert-Attribut geändert, bei mir musste ich nach Update auf 5.7 (spät. bzw. habe ich es da gemerkt / wurde darauf aufmerksam gemacht) auf "1_allReg" umstellen...
(hat aber wahrsch. nix mit dem Problem zu tun)
Gruß, Joachim
FHEM PI3 Buster (Test)
franky08
Zitatim _Klima Kanal schon mal geschaut, ob z.B. "R-valveMaxPos" zufällig auf 91% gesetzt ist...
Nee, nee steht auf 100%. Seltsam ist auch das eine Adapterfahrt "ewig" dauert, habe das Teil jetzt mal abgebaut und alles gereinigt/kontrolliert ---> mal sehen...
mit FHEM aktuell
franky08
#3
So, nach dem ich jetzt den zweiten RT im Wohnzimmer abgebaut und neu installiert habe, zeigt der das gleiche Verhalten, jetzt sind es nicht mehr 91% max. Valve Position sondern jetzt gehen beide RT´s auf maximal 87% und das bei einer desired-temp von 30°C, da müssten die Teile doch eigentlich auf 100% gehen  :o
VG
Frank
mit FHEM aktuell
MadMax-FHEM
Hmmmm, eigenartig.
Allerdings hat meine Freundin "große" Heizkörper und da geht das Stellventil auch nie (bzw. ist es mir noch nicht aufgefallen) voll (100%) auf.
Bei mir ist es bei solchen "Sprüngen" wie du sie provozierst schon eher so, dass das Stellventil zu 100% auf geht.
Irgendwo habe ich auch mal gelesen (ELV-Forum?? Weiß nicht mehr wo), dass die Heizungsregler "lernen"...
...ob das stimmt, keine Ahnung.
Vielleicht musste das Stellventil in der Vergangenheit noch nie (selten) voll auf gehen und da dachte es sich, wird schon mit 90% (oder 80%) auch reichen... ;-)
Sorry...
Also wie gesagt bei mir (abgesehen von meiner Freundin) hatte ich das noch nie...
Hast du ein Wandthermostat (externen Tempgeber) zur Steuerung oder macht das der Thermostat "autark"??
Dann vielleicht Defekt??
Gruß, Joachim
stromer-12
Das komische verhalten hatte ich auch schon mal bei einen Thermostaten, das hat sich mit der Zeit gegeben.
FHEM (SVN) auf RPi1B mit HMser | ESPLink
FHEM (SVN) virtuell mit HMLAN | HMUSB | CUL
franky08
Bis gestern früh gingen noch 100% dann seit heute morgen nicht mehr, seltsam, ich  glaube das es nach der Entkalkungsfahrt angefangen hat. Na ja, Heizperiode ist ja vorbei  ;)
VG
Frank
mit FHEM aktuell
martinp876
Mal eine kalibrierfahrt machen?
franky08
Hab ich bei beiden Rts gemacht, hatte ja die Batterien raus und die Teile abgebaut. Dann wieder montiert und nach Ins, ada gemacht.
VG
Frank
mit FHEM aktuell
frank
vielleicht hilft ja ein reset auf werkseinstellungen, damit die "regler-history" gelöscht wird. ausserdem die lernfunktion abschalten.
FHEM: 6.0(SVN) => Pi3(buster)
franky08
Die scheinen noch beim lernen zu sein, jetzt bringen sie es schon auf maximal 97%.  ;)
VG
Frank
mit FHEM aktuell
