[FHZ] Homematic
Begonnen von Dr. Boris Neubert, 25 Februar 2008, 21:16:17
Dr. Boris Neubert
weiß jemand ob das FHEM auch auf der Homematic CCU läuft um so beide
Systeme zu verbinden. Habe leider momentan weder FHZ1300, noch CCU um
es selber zu testen.
danke
Andreas
You received this message because you are subscribed to the Google Groups "FHZ1000 users on Linux" group.
To post to this group, send email to FHZ1000-users-on-unix@googlegroups.com
To unsubscribe from this group, send email to FHZ1000-users-on-unix-unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/FHZ1000-users-on-unix?hl=en
Guest
the CCU runs linux, but it does not use apache but a VERRY light httpd,
with only tcl scripting supported.
but i think its possible to run it (you have to modify the root file
image before you upload to to make it accessable tho).
Remco
aolschewski@googlemail.com wrote:
> Hallo zusammen,
> danke
> Andreas
