Autor Thema: [Gelöst!] Probleme beim Betrieb von 2 MySensors-Devices  (Gelesen 4600 mal)
Offline StefanW
  • Full Member
Ich fange langsam an, mich mit MySensors zu beschäftigen und habe momentan 1 WiFi Gateway und 2 Sensoren im Einsatz.
Diese sind wie folgt in FHEM angelegt:
Wifi-Gateway:
   DEF        192.168.178.146:5003
   DeviceName 192.168.178.146:5003
   FD         74
   NAME       MysensorsGateway
   NOTIFYDEV  global
   NR         30
   NTFY_ORDER 50-MysensorsGateway
   PARTIAL
   STATE      startup complete
   TYPE       MYSENSORS
   ack        1
   inclusion-mode 1
   outstandingAck 0
   version    1.5.4
   Readings:
     2016-05-06 07:08:33   connection      startup complete
     2016-05-06 07:08:28   state           opened
   Messagesforradioid:
     1:
       lastseen   -1
       nexttry    1462799493.00403
       numtries   543
   autocreate 1
   first-sensorid 1
   group      Interfaces
   icon       esp8266
   requestAck 1
   room       Technik
   stateFormat connection
Sensor 1 (Airwick-Sensor):
   DEF        1
   IODev      MysensorsGateway
   I_REQUEST_SIGNING 0
   I_SKETCH_NAME Airwick Sensor
   I_SKETCH_VERSION 1.0
   NAME       MYSENSOR_1
   NR         209
   STATE      1090519089 ppm
   TYPE       MYSENSORS_DEVICE
   ack        1
   protocol   1.5.4
   radioId    1
   repeater   0
   Readings:
     2016-05-07 21:58:47   SKETCH_NAME     Airwick Sensor
     2016-05-07 21:58:47   SKETCH_VERSION  1.0
     2016-05-08 20:08:01   level           1090519089
     2016-05-07 21:58:45   parentId        0
   Readingmappings:
     0:
       37:
         name       level
   Sensormappings:
     0:
       receives:
       sends:
         16
         15
     1:
       receives:
       sends:
         16
     10:
       receives:
       sends:
         6
         7
     11:
       receives:
       sends:
         11
     12:
       receives:
       sends:
         12
         14
     13:
       receives:
         24
       sends:
         17
         18
         24
     14:
       receives:
       sends:
         45
         21
         0
     15:
       receives:
       sends:
         13
     16:
       receives:
       sends:
         23
     17:
       receives:
       sends:
     18:
       receives:
       sends:
     19:
       receives:
         36
       sends:
         36
     2:
       receives:
       sends:
         16
         15
     20:
       receives:
         32
       sends:
         33
     21:
       receives:
         24
       sends:
         34
         35
         24
     22:
       receives:
       sends:
         37
         43
     23:
       receives:
         24
         25
         26
         27
         28
       sends:
         24
         25
         26
         27
         28
     24:
       receives:
       sends:
         37
         43
     25:
       receives:
       sends:
         19
         20
     26:
       receives:
         40
         17
       sends:
         40
         17
     27:
       receives:
         41
         17
       sends:
         41
         17
     28:
       receives:
         40
       sends:
         40
     29:
       receives:
       sends:
         45
         44
         21
         46
         22
     3:
       receives:
         2
         17
       sends:
         2
         17
     30:
       receives:
       sends:
         38
         39
         14
     31:
       receives:
       sends:
         2
         16
     32:
       receives:
       sends:
         16
         15
     33:
       receives:
       sends:
         37
         16
         15
     34:
       receives:
       sends:
         37
         16
         15
     35:
       receives:
       sends:
         37
         16
         15
     4:
       receives:
         2
         3
         17
       sends:
         2
         3
         17
     5:
       receives:
         29
         30
         31
         3
       sends:
         3
     6:
       receives:
       sends:
         0
     7:
       receives:
       sends:
         1
     8:
       receives:
       sends:
         4
         5
     9:
       receives:
       sends:
         8
         9
   Sets:
     reboot
     time
   Typemappings:
     0:
       type       temperature
     1:
       type       humidity
     10:
       type       direction
     11:
       type       uv
     12:
       type       weight
     13:
       type       distance
     14:
       type       impedance
     15:
       type       armed
       Val:
         0          off
         1          on
     16:
       type       tripped
       Val:
         0          off
         1          on
     17:
       type       power
     18:
       type       energy
     19:
       type       button_on
     2:
       type       status
       Val:
         0          off
         1          on
     20:
       type       button_off
     21:
       type       hvacflowstate
     22:
       type       hvacspeed
     23:
       type       brightness
       Range:
         max        100
         min        0
         step       1
     24:
       type       value1
     25:
       type       value2
     26:
       type       value3
     27:
       type       value4
     28:
       type       value5
     29:
       type       up
     3:
       type       percentage
       Range:
         max        100
         min        0
         step       1
     30:
       type       down
     31:
       type       stop
     32:
       type       ir_send
     33:
       type       ir_receive
     34:
       type       flow
     35:
       type       volume
     36:
       type       lockstatus
       Val:
         0          off
         1          on
     37:
       type       level
     38:
       type       voltage
     39:
       type       current
     4:
       type       pressure
     40:
       type       rgb
     41:
       type       rgbw
     42:
       type       id
     43:
       type       unitprefix
     44:
       type       hvacsetpointcool
     45:
       type       hvacsetpointheat
     46:
       type       hvacflowmode
     5:
       type       forecast
       Val:
         0          stable
         1          sunny
         2          cloudy
         3          unstable
         4          thunderstorm
         5          unknown
     6:
       type       rain
     7:
       type       rainrate
     8:
       type       wind
     9:
       type       gust
   alias      Airwick Sensor
   group      Sensoren
   mapReading_level 0 level
   mode       node
   requestAck 1
   room       Buero
   stateFormat level ppm
   version    1.5.4
Sensor 2 (Dallas DS18B20):
   CFGFN
   DEF        2
   I_REQUEST_SIGNING 0
   I_SKETCH_NAME Temperature Sensor
   I_SKETCH_VERSION 1.1
   NAME       MYSENSOR_2
   NR         5342
   STATE      23.4°C
   ack        0
   protocol   1.5.4
   radioId    2
   repeater   0
   Readings:
     2016-05-08 05:55:31   SKETCH_NAME     Temperature Sensor
     2016-05-08 05:55:31   SKETCH_VERSION  1.1
     2016-05-08 05:55:29   parentId        0
     2016-05-09 15:13:53   temperature     23.4
   Readingmappings:
     2:
       0:
         name       temperature
   Sensormappings:
     0:
       receives:
       sends:
         16
         15
     1:
       receives:
       sends:
         16
     10:
       receives:
       sends:
         6
         7
     11:
       receives:
       sends:
         11
     12:
       receives:
       sends:
         12
         14
     13:
       receives:
         24
       sends:
         17
         18
         24
     14:
       receives:
       sends:
         45
         21
         0
     15:
       receives:
       sends:
         13
     16:
       receives:
       sends:
         23
     17:
       receives:
       sends:
     18:
       receives:
       sends:
     19:
       receives:
         36
       sends:
         36
     2:
       receives:
       sends:
         16
         15
     20:
       receives:
         32
       sends:
         33
     21:
       receives:
         24
       sends:
         34
         35
         24
     22:
       receives:
       sends:
         37
         43
     23:
       receives:
         24
         25
         26
         27
         28
       sends:
         24
         25
         26
         27
         28
     24:
       receives:
       sends:
         37
         43
     25:
       receives:
       sends:
         19
         20
     26:
       receives:
         40
         17
       sends:
         40
         17
     27:
       receives:
         41
         17
       sends:
         41
         17
     28:
       receives:
         40
       sends:
         40
     29:
       receives:
       sends:
         45
         44
         21
         46
         22
     3:
       receives:
         2
         17
       sends:
         2
         17
     30:
       receives:
       sends:
         38
         39
         14
     31:
       receives:
       sends:
         2
         16
     32:
       receives:
       sends:
         16
         15
     33:
       receives:
       sends:
         37
         16
         15
     34:
       receives:
       sends:
         37
         16
         15
     35:
       receives:
       sends:
         37
         16
         15
     4:
       receives:
         2
         3
         17
       sends:
         2
         3
         17
     5:
       receives:
         29
         30
         31
         3
       sends:
         3
     6:
       receives:
       sends:
         0
     7:
       receives:
       sends:
         1
     8:
       receives:
       sends:
         4
         5
     9:
       receives:
       sends:
         8
         9
   Sets:
     reboot
     time
   Typemappings:
     0:
       type       temperature
     1:
       type       humidity
     10:
       type       direction
     11:
       type       uv
     12:
       type       weight
     13:
       type       distance
     14:
       type       impedance
     15:
       type       armed
       Val:
         0          off
         1          on
     16:
       type       tripped
       Val:
         0          off
         1          on
     17:
       type       power
     18:
       type       energy
     19:
       type       button_on
     2:
       type       status
       Val:
         0          off
         1          on
     20:
       type       button_off
     21:
       type       hvacflowstate
     22:
       type       hvacspeed
     23:
       type       brightness
       Range:
         max        100
         min        0
         step       1
     24:
       type       value1
     25:
       type       value2
     26:
       type       value3
     27:
       type       value4
     28:
       type       value5
     29:
       type       up
     3:
       type       percentage
       Range:
         max        100
         min        0
         step       1
     30:
       type       down
     31:
       type       stop
     32:
       type       ir_send
     33:
       type       ir_receive
     34:
       type       flow
     35:
       type       volume
     36:
       type       lockstatus
       Val:
         0          off
         1          on
     37:
       type       level
     38:
       type       voltage
     39:
       type       current
     4:
       type       pressure
     40:
       type       rgb
     41:
       type       rgbw
     42:
       type       id
     43:
       type       unitprefix
     44:
     45:
     46:
       type       hvacflowmode
     5:
       type       forecast
       Val:
         0          stable
         1          sunny
         2          cloudy
         3          unstable
         4          thunderstorm
         5          unknown
     6:
       type       rain
     7:
       type       rainrate
     8:
       type       wind
     9:
       type       gust
   mapReading_temperature 2 temperature
   mode       node
   stateFormat temperature°C
   version    1.5.4
Nun habe ich folgendes Problem:
Sobald ich Sensor 1 & 2 gleichzeitig in Betrieb habe, kommt bei Sensor 1 nur noch Blödsinn als Reading an (1090519089 anstatt irgendwas zwischen 0-4092).
Sensor 2 hat korrekte Readings.
Jeder Sensor im alleinigen Betrieb liefert auch richtige Readings. Nur halt im gleichzeitigen Betrieb nicht.
Beide Sensoren schicken auch die korrekten Werte los. (Nachgesehen im SerialMonitor in der ArduinoIDE)
Beispiel Sensor 1: send: 1-1-0-0 s=0,c=1,t=37,pt=3,l=2,sg=0,st=ok:1199
Als Reading kommt aber 1090520239 an.
Wo liegt da der Fehler?
Stefan
« Letzte Änderung: 13 Mai 2016, 17:28:20 von StefanW »
Offline Beta-User
  • Moderator
Antw:Probleme beim Betrieb von 2 MySensors-Devices
« Antwort #1 am: 11 Mai 2016, 16:30:07 »
Grundsätzlich gehen mehrere Nodes an einem Gateway.
Kannst Du mal die "normalen" Definitionen liefern?
Vermuten würde ich, dass beide Nodes die gleiche ID haben und sich deswegen die readings wechselseitig in die Quere kommen (das kommt evtl. daher, dass irgendwann mal derselbe NRF an beiden Arduinos war)? Dann einfach für beide eine unterschiedliche ID vergeben (im Sketch läßt sich die NODE_ID per #define festlegen).
Komisch kommt mir vor, dass der 2. Sensor die Nummer 5342 haben soll?
Server: HP-T620@Debian 11, aktuelles FHEM + ConfigDB | CUL_HM (VCCU) | MQTT2: MiLight@ESP-GW, BT@OpenMQTTGw | MySensors: seriell, v.a. 2.3.1@RS485 | ZWave | ZigBee@deCONZ | SIGNALduino | MapleCUN | RHASSPY
svn:MySensors, Weekday-&RandomTimer, Twilight,  AttrTemplate {u.a. mqtt2, mysensors, zwave}
Offline StefanW
  • Full Member
« Antwort #2 am: 12 Mai 2016, 16:29:14 »
Also, ich habe jetzt noch mal beide Devices in FHEM gelöscht und per autocreate neu anlegen lassen.
Fazit: Immer noch das gleiche Ergebnis.  :'(
Vorher habe ich bei beiden Sensoren die NRF gegen nagelneue ausgetauscht.
Hier die Definitionen aus der .cfg:
define MYSENSOR_1 MYSENSORS_DEVICE 1
attr MYSENSOR_1 IODev MysensorsGateway
attr MYSENSOR_1 mapReading_level 0 level
attr MYSENSOR_1 mapReading_unitprefix 0 unitprefix
attr MYSENSOR_1 mode node
attr MYSENSOR_1 stateFormat level ppm
attr MYSENSOR_1 version 1.5.4
define MYSENSOR_2 MYSENSORS_DEVICE 2
attr MYSENSOR_2 IODev MysensorsGateway
attr MYSENSOR_2 mapReading_temperature 2 temperature
attr MYSENSOR_2 mode node
attr MYSENSOR_2 stateFormat temperature°C
attr MYSENSOR_2 version 1.5.4
Sensor 1 hat automatisch die Nr 31836, Sensor 2 die Nr 31684 bekommen.
Beide Sensoren haben auch definitv nicht die gleiche radioId (1 & 2)
parentId ist bei beiden 0
Stefan
Offline Beta-User
  • Moderator
« Antwort #3 am: 13 Mai 2016, 08:31:07 »
Schade. Bist du sicher, dass wirklich beide Nodes für sich im Dauerbetrieb funktionieren? V.a. der reine Dallas-Temp sollte eigentlich überhaupt kein Thema sein, bei mir jedenfalls laufen 2 Nodes mit u.A. 2 bzw. 5 Temperaturen schon seit Monaten problemlos nebeneinander, allerdings habe ich ein serielles GW.
Willst du beide Sensoren im selben Raum nutzen? Dann könntest du den Dallas noch als weiteren Child auf den Airwick packen...
Ansonsten: Bei den ESPs gibt/gab es ständig Änderungen (letzter ESP-Commit auf github ist 10 Tage alt). Vielleicht hilft es, zumindest das Gateway auf die 2.0.0-beta umzustellen. FHEM scheint damit keine Probleme zu haben (das Protokoll ist gleich, daher kann man Nodes unterschiedlicher Versionen auch mischen).
Online gloob
« Antwort #4 am: 13 Mai 2016, 09:23:47 »
Ich habe zwar keine Lösung für dein Problem, allerdings habe ich den gleichen Fehler.
Ich nutze ein ESP-Gateway und mehrere Nodes mit Temperatur und Feuchtigkeitssensore. Die Temperatur wird von allen Nodes richtig übertragen, jedoch bekomme ich bei der Luftfeuchtigkeit extreme hohe Werte: 1090519094
Es hat definitiv etwas mit dem ESP-Gateway zu tun, denn vorher habe ich ein serielles Gateway benutzt und dort keine Probleme. Die Firmware der Nodes wurde nicht geändert.
Offline Beta-User
  • Moderator
« Antwort #5 am: 13 Mai 2016, 10:08:20 »
...extreme hohe Werte: 1090519094
Welchen SW-Stand hast Du für's GW: 1.5.4 oder 2.0.0-beta?
Was dann noch sonderbar ist: alle eure hohen Werte beginnen (mindestens) mit 10905
Online gloob
« Antwort #6 am: 13 Mai 2016, 10:20:11 »
Ich hab sowohl auf den Nodes als auch auf dem Gateway die Version 1.5.4 laufen.
Im Moment gehe ich von irgendeinem Überlauf bei den Werten aus.
Offline Beta-User
  • Moderator
« Antwort #7 am: 13 Mai 2016, 11:43:01 »
Nehmt doch wirklich mal die aktuelle Dev.-Version der MySensors-lib.
1.5.4 hatte den letzten Change bei den ESP-Themen vor 9 Monaten, der Development-tree vor 11 Tagen: https://github.com/mysensors/Arduino/tree/development/libraries/MySensors.
Der ESP ist wohl Timing-kritisch, die dev.-Version schließt einige Issues und ansonsten habe ich damit auch positive Erfahrungen gemacht. Das betrifft ja nur das GW, es muß nix an den (anderen) Sensor-Sketchen geändert werden, die können bleiben wie sie sind...
Offline StefanW
  • Full Member
« Antwort #8 am: 13 Mai 2016, 14:53:32 »
Danke!!
Das scheint es gewesen zu sein.
Gateway mit der aktuellen 2.0.0-beta neu kompiliert und bis jetzt zeigen beide Sensoren auch im Parallelbetrieb das an, was sie sollen.  :D
Offline Beta-User
  • Moderator
« Antwort #9 am: 13 Mai 2016, 15:58:21 »
Freut mich und Danke für die Rückmeldung 8).
Hab's gleich noch hier verwurschtelt:
https://forum.fhem.de/index.php?action=post;quote=450195;topic=51325.0;last_msg=450195
