Perl Warnigs im Log - na wo isser denn ??? .... der Fehler
Begonnen von Newbie, 22 Mai 2016, 14:22:45
Newbie
hab seit geraumer Zeit nach jedem Aufruf der FHEM-Seite folgende Zeilen im Log. Kann den Fehler aber nicht finden.
2016.05.22 11:30:44.329 4: Connection accepted from WEB_XXX.XXX.XXX.XXX_53587
2016.05.22 11:30:44.331 4: WEB_XXX.XXX.XXX.XXX_53587 GET /fhem?room=Home; BUFLEN:0
2016.05.22 11:30:44.368 1: PERL WARNING: Useless use of private variable in void context at (eval 33810) line 1.
2016.05.22 11:30:44.368 3: stacktrace:
2016.05.22 11:30:44.368 3:     main::__ANON__                      called by (eval 33810) (1)
2016.05.22 11:30:44.369 3:     (eval)                              called by ./FHEM/33_readingsGroup.pm (341)
2016.05.22 11:30:44.369 3:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (522)
2016.05.22 11:30:44.369 3:     main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (997)
2016.05.22 11:30:44.369 3:     main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1086)
2016.05.22 11:30:44.370 3:     main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (2749)
2016.05.22 11:30:44.370 3:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (1539)
2016.05.22 11:30:44.370 3:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (899)
2016.05.22 11:30:44.370 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (446)
2016.05.22 11:30:44.370 3:     main::FW_Read                       called by fhem.pl (3172)
2016.05.22 11:30:44.371 3:     main::CallFn                        called by fhem.pl (659)
2016.05.22 11:30:44.372 1: PERL WARNING: Useless use of private variable in void context at (eval 33811) line 1.
2016.05.22 11:30:44.372 3: stacktrace:
2016.05.22 11:30:44.372 3:     main::__ANON__                      called by (eval 33811) (1)
2016.05.22 11:30:44.372 3:     (eval)                              called by ./FHEM/33_readingsGroup.pm (341)
2016.05.22 11:30:44.372 3:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (522)
2016.05.22 11:30:44.373 3:     main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (997)
2016.05.22 11:30:44.373 3:     main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1086)
2016.05.22 11:30:44.373 3:     main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (2749)
2016.05.22 11:30:44.373 3:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (1539)
2016.05.22 11:30:44.373 3:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (899)
2016.05.22 11:30:44.374 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (446)
2016.05.22 11:30:44.374 3:     main::FW_Read                       called by fhem.pl (3172)
2016.05.22 11:30:44.374 3:     main::CallFn                        called by fhem.pl (659)
2016.05.22 11:30:44.375 1: PERL WARNING: Useless use of private variable in void context at (eval 33812) line 1.
2016.05.22 11:30:44.375 3: stacktrace:
2016.05.22 11:30:44.376 3:     main::__ANON__                      called by (eval 33812) (1)
2016.05.22 11:30:44.376 3:     (eval)                              called by ./FHEM/33_readingsGroup.pm (341)
2016.05.22 11:30:44.376 3:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (522)
2016.05.22 11:30:44.376 3:     main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (997)
2016.05.22 11:30:44.376 3:     main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1086)
2016.05.22 11:30:44.377 3:     main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (2749)
2016.05.22 11:30:44.377 3:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (1539)
2016.05.22 11:30:44.377 3:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (899)
2016.05.22 11:30:44.377 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (446)
2016.05.22 11:30:44.377 3:     main::FW_Read                       called by fhem.pl (3172)
2016.05.22 11:30:44.378 3:     main::CallFn                        called by fhem.pl (659)
2016.05.22 11:30:44.378 1: PERL WARNING: Useless use of private variable in void context at (eval 33813) line 1.
2016.05.22 11:30:44.379 3: stacktrace:
2016.05.22 11:30:44.379 3:     main::__ANON__                      called by (eval 33813) (1)
2016.05.22 11:30:44.379 3:     (eval)                              called by ./FHEM/33_readingsGroup.pm (341)
2016.05.22 11:30:44.379 3:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (522)
2016.05.22 11:30:44.380 3:     main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (997)
2016.05.22 11:30:44.380 3:     main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1086)
2016.05.22 11:30:44.380 3:     main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (2749)
2016.05.22 11:30:44.380 3:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (1539)
2016.05.22 11:30:44.380 3:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (899)
2016.05.22 11:30:44.381 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (446)
2016.05.22 11:30:44.381 3:     main::FW_Read                       called by fhem.pl (3172)
2016.05.22 11:30:44.381 3:     main::CallFn                        called by fhem.pl (659)
2016.05.22 11:30:44.382 1: PERL WARNING: Useless use of private variable in void context at (eval 33814) line 1.
2016.05.22 11:30:44.382 3: stacktrace:
2016.05.22 11:30:44.382 3:     main::__ANON__                      called by (eval 33814) (1)
2016.05.22 11:30:44.383 3:     (eval)                              called by ./FHEM/33_readingsGroup.pm (341)
2016.05.22 11:30:44.383 3:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (522)
2016.05.22 11:30:44.383 3:     main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (997)
2016.05.22 11:30:44.383 3:     main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1086)
2016.05.22 11:30:44.383 3:     main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (2749)
2016.05.22 11:30:44.384 3:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (1539)
2016.05.22 11:30:44.384 3:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (899)
2016.05.22 11:30:44.384 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (446)
2016.05.22 11:30:44.384 3:     main::FW_Read                       called by fhem.pl (3172)
2016.05.22 11:30:44.384 3:     main::CallFn                        called by fhem.pl (659)
2016.05.22 11:30:44.385 1: PERL WARNING: Useless use of private variable in void context at (eval 33815) line 1.
2016.05.22 11:30:44.385 3: stacktrace:
2016.05.22 11:30:44.385 3:     main::__ANON__                      called by (eval 33815) (1)
2016.05.22 11:30:44.385 3:     (eval)                              called by ./FHEM/33_readingsGroup.pm (341)
2016.05.22 11:30:44.386 3:     main::lookup2                       called by ./FHEM/33_readingsGroup.pm (522)
2016.05.22 11:30:44.386 3:     main::readingsGroup_value2html      called by ./FHEM/33_readingsGroup.pm (997)
2016.05.22 11:30:44.386 3:     main::readingsGroup_2html           called by ./FHEM/33_readingsGroup.pm (1086)
2016.05.22 11:30:44.386 3:     main::readingsGroup_detailFn        called by ./FHEM/01_FHEMWEB.pm (2749)
2016.05.22 11:30:44.386 3:     main::FW_devState                   called by ./FHEM/01_FHEMWEB.pm (1539)
2016.05.22 11:30:44.386 3:     main::FW_showRoom                   called by ./FHEM/01_FHEMWEB.pm (899)
2016.05.22 11:30:44.386 3:     main::FW_answerCall                 called by ./FHEM/01_FHEMWEB.pm (446)
2016.05.22 11:30:44.387 3:     main::FW_Read                       called by fhem.pl (3172)
2016.05.22 11:30:44.387 3:     main::CallFn                        called by fhem.pl (659)
2016.05.22 11:30:44.406 4: name: /fhem?room=Home / RL:7531 / text/html; charset=UTF-8 / Content-Encoding: gzip
kann mal bitte jemand drüberschauen.
danke, Jens
fhem-6.1 (configDB+DbLog)  auf ODROID-XU4
Dietmar63
Gruß Dietmar
FB7390, CUL, 2 FHT, FS20
Newbie
Fehler gefunden -
attr valueFormat
- war falsch definiert.
