(Gelöst) Error:Modul 10_CUL_HM deactivated: Global symbol "$dName" requires
Begonnen von Leeloo_Dallas, 27 Mai 2016, 12:48:11
Leeloo_Dallas
nach dem Einspielen des Updates von Heute erhalte ich folgende Einträge im Fhem-Log.
FHEM ist leider nicht mehr funktionsfähig. Kann mir bitte jemand helfen?
2016.05.27 12:13:35 1 : RMDIR: ./restoreDir/2016-05-23
2016.05.27 12:13:35 1 : UPD FHEM/10_CUL_HM.pm
2016.05.27 12:13:36 1 : UPD FHEM/30_DUOFERN.pm
2016.05.27 12:13:36 1 : UPD FHEM/37_plex.pm
2016.05.27 12:13:36 1 : UPD FHEM/70_ONKYO_AVR.pm
2016.05.27 12:13:36 1 : UPD FHEM/71_ONKYO_AVR_ZONE.pm
2016.05.27 12:13:36 1 : UPD FHEM/98_HMinfo.pm
2016.05.27 12:13:37 1 : UPD FHEM/HttpUtils.pm
2016.05.27 12:13:37 1 : UPD www/pgm2/fhemweb_uzsu.js
2016.05.27 12:13:37 1 : Calling /usr/bin/perl ./contrib/commandref_join.pl -noWarnings, this may take a while
2016.05.27 12:16:01 1 : *** EN FHEM/23_WEBTHERM.pm: No document text found
2016.05.27 12:16:02 1 :
2016.05.27 12:16:02 1 : update finished, "shutdown restart" is needed to activate the changes.
2016-05-27 12:16:02 Global global UPDATE
2016.05.27 12:25:42 1 : reload: Error:Modul 10_CUL_HM deactivated: Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 7911.
2016.05.27 12:25:42 0 : Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 7911.
2016.05.27 12:25:42 0 : ERROR: Cannot autoload CUL_HM
2016.05.27 12:25:42 3 : Zentrale_CCD: Unknown code A0F4486102E70540000000A24D90D0040::-71.5:Zentrale_CCD, help me!
2016.05.27 12:25:45 1 : reload: Error:Modul 10_CUL_HM deactivated: Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 7911.
2016.05.27 12:25:45 0 : Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. Global symbol "$dName" requires explicit package name at ./FHEM/10_CUL_HM.pm line 7832. BEGIN not safe after errors--compilation aborted at ./FHEM/10_CUL_HM.pm line 7911.
2016.05.27 12:25:45 0 : ERROR: Cannot autoload CUL_HM
Zentrale_CCD => ist die Hardware von Busware.
Eine aktuelle List von Zentrale_CCD kann ich nicht liefern, da im WebFrontEnd folgendes steht:
Messages collected while initializing FHEM:
configfile: Cannot load module CUL_HM
Hier eine ältere List von Zentrale_CCD (sollte sich aber nichts geändert haben):
   CFGFN      /opt/fhem/mycfg/10_Zentrale_CCD.cfg
   CMDS       <xxxxxx>
   Clients    :CUL_HM:HMS:CUL_IR:STACKABLE_CC:
   DEF        /dev/ttyAMA0@<xxxxxx> <xxxx>
   DeviceName /dev/ttyAMA0@<xxxxxx>
   FD         8
   FHTID      <xxxxxx>
   NAME       Zentrale_CCD
   NR         67
   NR_CMD_LAST_H 38
   PARTIAL
   RAWMSG     A0F9386103106290000000A24DB0E0040F7
   RSSI       -78.5
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.61 CSM868
   Zentrale_CCD_MSGCNT 3981
   Zentrale_CCD_TIME 2016-05-15 14:26:41
   initString X21
Ar
   owner_CCU  Zentrale_VCCU
   Matchlist:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
   Readings:
     2016-02-05 13:47:02   ccconf          freq:868.300MHz bWidth:101KHz rAmpl:33dB sens:8dB
     2017-10-03 10:33:34   cmds            m b C F i A Z G M R T V W X e f l t u x
     2016-02-05 14:12:23   raw             V 1.61 CSM868
     2016-05-15 14:26:41   state           Initialized
     2016-02-05 13:52:28   version         V 1.61 CSM868
   XMIT_TIME:
     1463311488.92733
     1463311490.98559
     1463311491.08831
     1463311628.32814
     1463311628.43071
     1463311885.25925
     1463311886.61493
     1463311886.71761
     1463312014.92738
     1463312015.03032
     1463312155.23643
     1463312155.3392
     1463312325.71955
     1463312325.82196
     1463312737.3904
     1463314236.84321
     1463314314.63694
     1463314314.73976
     1463314502.70083
     1463314502.8035
     1463314629.45898
     1463314629.56141
     1463314692.04359
     1463314729.38664
     1463314749.96054
     1463314750.06327
     1463314844.23809
     1463314844.8759
     1463314845.5113
     1463314846.15129
     1463314870.22856
     1463314870.33106
     1463314895.96837
     1463314896.79956
     1463314896.89358
     1463314897.09109
     1463314973.06148
     1463315016.64932
   Helper:
     221c39:
       QUEUE:
     221d09:
       QUEUE:
     2b18dc:
       QUEUE:
     2e6f6a:
       QUEUE:
     2e7054:
       QUEUE:
     3103bd:
       QUEUE:
     310629:
       QUEUE:
     3755c6:
       QUEUE:
     3755e6:
       QUEUE:
     3929d7:
       QUEUE:
     3ba003:
       QUEUE:
     3e1423:
       QUEUE:
     40900f:
       QUEUE:
     409117:
       QUEUE:
     409f4a:
       QUEUE:
     43ea72:
       QUEUE:
     45b846:
       QUEUE:
   group      System
   hmId       <xxxxxx>
   icon       scc_868
   rfmode     HomeMatic
   room       SYSTEM
Zentrale_CCD_HM => hminfo:
   NAME       Zentrale_CCD_HM
   NR         114
   STATE      ???
   TYPE       HMinfo
   Version    01
   Nb:
     cnt        47
   group      System
   icon       system_fhem
   room       SYSTEM
   sumERROR   battery:ok,sabotageError:off,powerError:ok,overload:off,overheat:off,reduced:off,motorError:no,error:none,uncertain:yes,smoke_detect:none,cover:closed
   sumStatus  battery,sabotageError,powerError,motor
   webCmd     update:protoEvents short:rssi:peerXref:configCheck:models
Schon mal Danke für's lesen.
Leeloo
Greatz Leeloo
Leeloo_Dallas
Greatz Leeloo
