Lightning5 - IT
Begonnen von Jimmy, 02 Juni 2016, 17:53:12
Jimmy
Hello all,
I have a couple of switches from a dutch store (Action) and i can't get them to work with FHEM. If i press a button on the remote it reads a TRX_ARC and a TRX_AC command.
If i use these commands in FHEM the switches don't work.
If i send a command from RFXManager with the following settings, it works.
Lightning5
Type: IT (Intertek, FA500, PROMax)
ID: 00 00 01
Unit Code: A
Level: 1
Command: On
Can i send "Lightning5" type "IT" commands from FHEM?
Thank you for helping me out here :-)
Gr. Jimmy
fruit
It's a long time since I played with TRX switches and none of them were Lighting5.
Have you looked at the wiki http://www.fhemwiki.de and commandref http://fhem.de/commandref.html?
A search for Lighting5 gives a single hit https://forum.fhem.de/index.php/topic,20075.0.html if that is any use.
A couple of old definitions from when I used HomEasy switches in case you are looking for format...
define Kitchen_Switch TRX_LIGHT ARC F5 light
define TRX_AC_0000215003 TRX_LIGHT AC 0000215003 light
define TRX_HOMEEASY_0000215003 TRX_LIGHT HOMEEASY 0000215003 light
Feel free to follow up in German if you prefer
Jimmy
I do have more TRX switches and they all work, it's just that these (cheap/Action) switchen dont work from within FHEM, but they do work if i send a command directly from RFXManager. Strange...
Thanks again.
fruit
Another place to look for info on your device if you haven't been there already is http://www.domoticaforum.eu/viewforum.php?f=27 though it's not fhem :/
I suggest you click the 'Report to Moderator' link in this thread/post and ask for this thread to be moved to the RFXTRX board - they are usually quite friendly there towards us non-German posters ;)
KölnSolar
Interesting issue. The protocol was added in Firmware ext2 since release 1001(18-02-2016). I think, if possible, it's not yet implemented in TRX_LIGHT.
Problem might be, that the protocol is similar to ARC and/or AC but repetition, pulsewidth, bitcoding or ... is different and the RFXTRX is not able to differentiate from the other protocols, therfore not implemented as receiveable :(
We need at least the raw code of the command send with Lighting5. But how to get if RFXTRX doesn't receive ?  :'(
Regards, Markus
Jimmy
Thank you so far, hopefully the protocol will be added.
This is what i found on the domoticz forum:
Action Intertek 75.006:
Use Ext2 firmware and configure an IT On/Off module in Domoticz.
The PROmax and FA500 use only the IT protocol which can be transmitted by the RFXtrx433E - Ext2 firmware.
The remote transmits 3 protocols, IT, AC and ARC. IT is received by the RFXtrx433E as Lighting4 but this can not be used.
Regards, Jimmy
KölnSolar
Zitat....as Lighting4 but this can not be used.
Why not ? (Or was it just the comment in the domoticz Forum ? If yes, did you receive a Lighting4 in the rfxmgr too ?)
Are you able to get the switch work, if you send Lighting4 (or ARC or AC) with the rfxmgr, or only with Lighting5 ?
Please describe the switch a little bit more: selflearning, dip-Switches....
Do You have other Transceivers/receivers or more than one rfxtrx ?
Jimmy
That was just the comment in the domoticz forum.
They are self-learning switches and they do not respond to any lightning4 command from the rfxmngr.
They only respond to the lightning5 (IT - Intertek, FA500,PROmax) command.
I have one rfxtrx433e and one Z-Wave.me tranceiver connected. All other rfx switches/temp sensors work fine and no problems with Z-wave devices.
Thank you
fruit
A google search for
Action Intertek protocol
brings up some results including this one https://www.domoticz.com/forum/viewtopic.php?t=10174 which may help you - if you discard the remote
Jimmy
Tried that, but the switch is not responding. I tried to pair with the remote and add these settings to fhem and i tried to pair directly from fhem.
It's just not working with ARC, AC or homeEasy, it seems to be needing the Lighting5 - IT protocol.
Thanks anyway  :)
RaspiCOC
Not having read all the thread: But is it eventually a "Flamingo FA500D" (compatible or vice versa). RFXTRX can only send but not receive these signals (See page 9 of the RFXTRX-Manual)
