Selbstbau CUL, bekomme ihn nicht geflasht
Begonnen von rubi007, 13 Juni 2016, 22:50:27
rubi007
egal was ich anstell, ich bekomme es einfach nicht hin ihn zu flashen..
ich bin bis jetzt so weit gekommen
root@raspberrypi3:/opt/culfw/Devices/nanoCUL# make
Size before:
   text    data     bss     dec     hex filename
  22498      74     831   23403    5b6b nanoCUL.elf
Compiling C: nanoCUL.c
Compiling C: ../../clib/cc1100.c
Compiling C: ../../clib/cc1101_pllcheck.c
Compiling C: ../../clib/clock.c
Compiling C: ../../clib/delay.c
Compiling C: ../../clib/display.c
Compiling C: ../../clib/stringfunc.c
Compiling C: ../../clib/fncollection.c
Compiling C: ../../clib/ringbuffer.c
Compiling C: ../../clib/fht.c
Compiling C: ../../clib/rf_send.c
Compiling C: ../../clib/rf_receive.c
Compiling C: ../../clib/rf_asksin.c
Compiling C: ../../clib/rf_moritz.c
Compiling C: ../../clib/rf_rwe.c
Compiling C: ../../clib/somfy_rts.c
Compiling C: ../../clib/fastrf.c
Compiling C: ../../clib/intertechno.c
Compiling C: ../../clib/kopp-fc.c
Compiling C: ../../clib/memory.c
Compiling C: ../../clib/serial.c
Compiling C: ../../clib/ttydata.c
Compiling C: ../../clib/spi.c
Compiling C: ../../clib/rf_mbus.c
Compiling C: ../../clib/mbus/manchester.c
Compiling C: ../../clib/mbus/3outof6.c
Compiling C: ../../clib/mbus/mbus_packet.c
Compiling C: ../../clib/mbus/crc.c
Linking: nanoCUL.elf
Creating load file for Flash: nanoCUL.hex
Creating load file for EEPROM: nanoCUL.eep
Creating Extended Listing: nanoCUL.lss
Creating Symbol Table: nanoCUL.sym
Size after:
root@raspberrypi3:/opt/culfw/Devices/nanoCUL# make program
#@if test ! -d /sys/class/gpio/gpio17; then echo 17 > /sys/class/gpio/export; fi
#@if test ! -d /sys/class/gpio/gpio18; then echo 18 > /sys/class/gpio/export; fi
#echo out > /sys/class/gpio/gpio17/direction
#echo out > /sys/class/gpio/gpio18/direction
#echo 0 > /sys/class/gpio/gpio17/value
#echo 0 > /sys/class/gpio/gpio18/value
#sleep 1
#echo 1 > /sys/class/gpio/gpio17/value
#sleep 1
#echo 1 > /sys/class/gpio/gpio18/value
avrdude -D -p atmega328p -P /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 -c arduino    -U flash:w:nanoCUL.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done.  Thank you.
makefile:218: recipe for target 'program' failed
make: *** [program] Error 1
ka was ich falsch mach
weis von euch jemand rat ?
MadMax-FHEM
Hast du ihn bereits in fhem eingebunden?
Oder mit sonst etwas drauf zugegriffen?
So wie es aussieht könnte es sein (bzw. hatte ich das auch solange fhem lief, hatte ihn aber bereit s"defined"), dass avrdude (das flash-Programm) nicht zugreifen kann weil (evtl.) der Port bereits von einem anderen Programm (fhem) geöffnet ist...
Gruß, Joachim
FHEM PI3 Buster (Test)
rubi007
Floca
Wenn er sich nicht Synchronisieren lässt und du dir sicher bist, dass er sonst nicht verwendet wird, probier es nochmal mit der Arduino IDE am PC. Sollte die was ähnliches werfen ist der Arduino defekt.
rubi007
hab jetzt versucht die https://forum.fhem.de/index.php/topic,35064.0.html Alternative culfw drauf bekommen und er blinkt wie wild... nach einem reboot blinkr er garnicht meht ... komisch
rubi007
bin jetzt ein stück weiter... im windows steht usb-serial CH340 (COM7)
und bei Arduino steht
BN: Unknown board
VID: 1A86
PID: 7523
SN: Upload any sketch to obtain it
MadMax-FHEM
Wild blinken nach dem Flashen oder beim Flashen?
Beim Flashen ist (könnte) normal sein, weil er ja per serieller Schnittstelle mit Daten (FW) versorgt wird...
Flashen ohne Fehler!?
Danach gar nicht blinken weiß ich jetzt nicht, was die FW so von sich gibt an Blinkmeldungen...
killah78
#7
flasht du am raspberry?
Dieses wilde blinken NACH dem flashen hatte ich auch mal. Sieht so aus, als würde er immernoch weiterflashen. Habe dann nanoCUL vom USB getrennt und wieder angestöpselt, danach hat der Flashvorgang dann funktioniert.
Hast du den Arduino nachgelötet bezüglich des Reset-Bugs? War bei mir notwendig, weil er sonst nach neustart nicht richtig initialisiert wurde. Da half dann immer nur ab- und wieder anstöpseln.
Edit: Ahh, das mit dem Löten betrifft nur FTDI Clones. Trifft bei dir ja nicht zu. Aber probier mal mit vorher ab- und anstöpseln.
BN: Unknown board
VID: 1A86
PID: 7523
Für das Flashen war es bei mir (aber aus Linux heraus) hin und wieder erforderlich, den "Reset"-Button am Arduino zu drücken, kurz bevor die Arduino-IDE den flash-Vorgang gestartet hat (mehrere Nano- bzw. Micro-Boards, mit und ohne CH340). Dann natürlich warten, bis die IDE "upload completed" (oder so) meldet.
Damit habe ich auch Nanos wieder "eingefangen", bei denen der flash-Vorgang nur teilweise geklappt hatte (wackeliges Kabel :'().  8)
riker1
Hallo
hatte das gleiche problem.
habe dann manuell mittels
sudo avrdude -p atmega328p -c arduino -P /dev/ttyUSB0 -b 57600 -D -Uflash:w:~/Downloads/cul/nano868CUL.hex:i
flashen können.
kein reset button erforderlich.
hoffe es hilft
FHEM    5.26.1 Ubuntu 18, FHEM    5.26.1 RPI 3 , Actoren: IT ,Tasmota, ESPEasy,
MAX CUBE, MAX HT, MAX WT, Selbstbau nanoCULs, FS 20,Tasmota, Homematic, FTK, SW. DIM, Smoke,KODI,Squeezebox
micky0867
Zitat von: riker1 am 30 September 2017, 14:47:53
Hallo
flashen können.
hoffe es hilft
Einige meiner Nano-China--Klone haben das gleiche Problem, dass ein flashen per USB nicht geht.
Da half nur ein richtiger "Programmer" (z. B.  AVR-ISP)
Bei einigen funzte das flashen per USB dann auch, nachdem ich den Bootloader neu geflasht hatte.
Bei anderen bekomme ich den Sketch nur per richtigem Programmer drauf, egal, was ich anstelle.
Gesendet von meinem ONEPLUS A3003 mit Tapatalk
