[FHZ] cm15pro efl
Begonnen von Guest, 18 April 2009, 17:31:14
Guest
Hi!
Does FHEM support device cm15pro?
bessarabov
You received this message because you are subscribed to the Google Groups "FHEM users on Linux" group.
To post to this group, send email to fhem-users@googlegroups.com
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en
Dr. Boris Neubert
Am Samstag, 18. April 2009 schrieb bessarabov:
> Hi!
I am currently checking with someone to what extend (none, partially, fully)
it does. Do you have such a device? If so, just try to use it as if it wee a
CM11.
Boris
Globaler Moderator, Developer, aktives Mitglied des FHEM e.V. (Marketing, Verwaltung)
Yes, today I've got such a device and now I'm trying to use it with FHEM.
Still no succes.
The problem is that I don't have /dev/ttyUSB* aftre plugging this
device to my linux box.
dmesg shows that it is connected:
usb 4-2: new low speed USB device using uhci_hcd and address 9
usb 4-2: configuration #1 chosen from 1 choice
and I can see it with lsusb:
Bus 004 Device 009: ID 0bc7:0001 X10 Wireless Technology, Inc.
ActiveHome (ACPI-compliant)
After plugging this device I'm expecting that some /dev/ttyUSB* will
be created. But it does not appear.
2009/4/18 Boris Neubert :
>> Hi!
> CM11.
> Boris
bessarabov.
Dr. Boris Neubert
Hi Иван,
Linux instantiates a generic device file for every USB file, e.g.
/sys/bus/usb/devices/1-0:1.0
If the device is recognized as a serial tty, a symlink to /dev/ttyUSB*
is generated by a secondary process (usually defined in
/etc/udev/rules.d). For the CM15 this is obviously not the case as it is
  not recognized. Try to put a new rule file in /etc/udev/rules.d with
the following content:
SYSFS{idVendor}=="0bc7", SYSFS{idProduct}=="0001",  SYMLINK+="cm15"
After hotplugging the device, a device file /dev/cm15 should appear.
Try whether you can access it via fhem (as CM11 device).
Good luck,
Boris
Guest
Thank you very much!
Yes, the device apperd in /dev, but it is still not working =(
Here is the details.
I've created file /etc/udev/rules.d/82-cm15pro.rules and after restarting
udev (sudo /etc/init.d/udev restart) and pluggin cm15pro in usb i've got
/dev/cm15
When I start fhem, I can see in log:
2009.04.22 12:08:42 3: CM11 opening CM11 device /dev/cm15
can't getattr: Inappropriate ioctl for device at
/home/bessarabov/tmp/FHEM/fhem-4.5//FHEM/00_CM11.pm line 177
2009.04.22 12:08:42 3: Can't open /dev/cm15: Inappropriate ioctl for device
2009.04.22 12:08:42 3: No I/O device found for lamp1
2009.04.22 12:08:42 3: No I/O device found for lamp2
2009.04.22 12:08:42 0: Server started (version 4.5 from 2008-12-23 ($Id:
fhem.pl,v 1.59 2008/12/09 14:12:40 rudolfkoenig Exp $), pid 603)
The commands like "set lamp1 off" are not working (but there is no error in
log file)
I've created the simple perl file:
#! /usr/bin/perl
use Device::SerialPort;
my $dev = "/dev/cm15";
$po = new Device::SerialPort ($dev);
print "Can't open $dev: $!\n" if(!$po);
When I execute it, i've got the error:
can't getattr: Inappropriate ioctl for device at ./test.pl line 5
Maybe you can recoomend something is this case?
2009/4/21 Dr. Boris Neubert
> Hi Иван,
> Good luck,
> Boris
bessarabov.
Dr. Boris Neubert
Sorry, I am lost. Maybe one of the experts on serial port settings on
that mailing list can comment on this. If not, someone has to go the
hard way and re-engineer the existing device driver on linuxha.com.
Boris
