Uneindeutige Logeinträge
Begonnen von Pythonf, 24 Juni 2016, 17:49:00
Pythonf
Ich habe folgende Log-Einträge, mit denen Ich nichts anzufangen weiß:
2016.06.24 17:43:37 1: PERL WARNING: Use of uninitialized value in hash element at ./FHEM/10_CUL_HM.pm line 2797.
2016.06.24 17:43:37 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/10_CUL_HM.pm line 2797.
2016.06.24 17:43:51 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4529.
2016.06.24 17:43:52 1: Error:  has no TYPE
2016.06.24 17:44:04 3: CUL_HM set Wohnzimmer.HZG01_Clima desired-temp 9.0
2016.06.24 17:44:13 3: Device Wohnzimmer.HZG02 added to ActionDetector with 000:10 time
2016.06.24 17:44:22 1: Error:  has no TYPE
2016.06.24 17:44:25 3: CUL_HM set Schalter01.Mareike_Sw_01 on
2016.06.24 17:44:42 3: CUL_HM set Schalter01.Mareike getConfig
2016.06.24 17:44:53 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4529.
2016.06.24 17:44:58 1: PERL WARNING: Use of uninitialized value $id in hash element at ./FHEM/00_CUL.pm line 640.
2016.06.24 17:44:58 1: PERL WARNING: Use of uninitialized value $id in hash element at ./FHEM/00_CUL.pm line 641.
2016.06.24 17:45:27 1: Error:  has no TYPE
2016.06.24 17:45:28 1: Error:  has no TYPE
2016.06.24 17:45:30 1: PERL WARNING: Use of uninitialized value in regexp compilation at ./FHEM/98_HMinfo.pm line 280.
2016.06.24 17:45:30 1: Error:  has no TYPE
2016.06.24 17:45:31 1: Error:  has no TYPE
2016.06.24 17:45:35 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4529.
2016.06.24 17:45:35 1: Error:  has no TYPE
2016.06.24 17:45:35 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/01_FHEMWEB.pm line 519.
2016.06.24 17:45:55 1: PERL WARNING: Use of uninitialized value in string eq at fhem.pl line 4529.
Hat jemand eine Idee? Ich liefere gerne weiter Informationen, weiß aber nicht genau was die Ursache sein könnte.
FHEM ist up-to-date
Fabian
franky08
#1
Nimm mal die SuFu "has no TYPE" da wirst du fündig
es gibt auch cmdalias um das device rauszubekommen: http://www.fhemwiki.de/wiki/Cmdalias
Zitatshownotypedevices
Auflisten von Geräten ohne TYPE Definition (sollte nur bei einer fehlerhaften Definition eine Ausgabe erstellen):
define c_shownotypedevices cmdalias shownotypedevices AS { join("\n", grep { !defined($defs{$_}{TYPE}) } keys %defs) }
VG
Frank
mit FHEM aktuell
Pythonf
Die Funktion kannte ich nicht, werd ich mir merken. Das Problem ist allerdings, dass keine Devices aufgelistet werden. Weder über cmdalias noch wenn ich den Befehl direkt eingebe.
Fabian
franky08
Hast du mal shutdown restart gemacht?
mit FHEM aktuell
Pythonf
shutdown restart, update force und auch global verbose 4 konnte ich persönlich nichts rauß schließen, was aber nichts heißen muss.
Fabian
franky08
Dann könntest du noch deine devices nachsehen, gerade hm, ob da ein subType vergeben ist. Das hatte ich bei mir einmal und dann ebenfalls eine Meldung im Log.
VG
Frank
mit FHEM aktuell
