bekomme EnOcean Pig an CUNx nicht ans Laufen
Begonnen von MarkusAutomaticus, 28 Juli 2016, 22:35:30
MarkusAutomaticus
ich versuche ein CUNx von busware mit dem EnOcean Modul ans Laufen zu bekommen.
Während die Hauptplatine zu funktionieren scheint, verhält sich das Tochterplatinchen seltsam.
Hauptplatine:
   CMDS       BbCFikApZGMKUYRTVWXefmltuxEz
   CUN1_MSGCNT 40
   CUN1_TIME  2016-07-28 22:23:59
   Clients    :CUL_HM:HMS:CUL_IR:STACKABLE_CC:
   DEF        192.168.178.66:2323 0000
   DeviceName 192.168.178.66:2323
   FD         34
   FHTID      0000
   NAME       CUN1
   NR         123
   PARTIAL
   RAWMSG     A0A088002206EA7339C950052
   RSSI       -33
   STATE      Initialized
   TYPE       CUL
   VERSION    V 2.66 CUL868
   initString X21
Ar
   Matchlist:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
   Readings:
     2016-07-28 22:14:12   cmds             B b C F i k A p Z G M K U Y R T V W X e f m l t u x E z
     2016-07-28 22:23:59   state           Initialized
     2016-07-27 22:43:01   version         V 2.66 CUL868
   hmId       A1B2C3
   icon       cul_868
   rfmode     HomeMatic
   room       HomeMatic
EnOcean Tocherplatine:
   CMDS
   Clients    :FS20:FHT.*:KS300:USF1000:BS:HMS: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY: :STACKABLE_CC:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
   DEF        192.168.178.66:2324 0000
   DeviceName 192.168.178.66:2324
   FHTID      0000
   NAME       CUN2
   NR         124
   PARTIAL
   STATE      opened
   TYPE       CUL
   initString X21
   Matchlist:
     1:USF1000  ^81..(04|0c)..0101a001a5ceaa00....
     2:BS       ^81..(04|0c)..0101a001a5cf
     3:FS20     ^81..(04|0c)..0101a001
     4:FHT      ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     5:KS300    ^810d04..4027a001
     6:CUL_WS   ^K.....
     7:CUL_EM   ^E0.................$
     9:CUL_FHTTK ^T[A-F0-9]{8}
     A:CUL_RFR  ^[0-9A-F]{4}U.
     B:CUL_HOERMANN ^R..........
     C:ESA2000  ^S................................$
     E:CUL_TX   ^TX[A-F0-9]{10}
     F:Revolt   ^r......................$
     G:IT       ^i......
     H:STACKABLE_CC ^\*
     I:UNIRoll  ^[0-9A-F]{5}(B|D|E)
     J:SOMFY    ^Y[r|t|s]:?[A-F0-9]+
     K:CUL_TCM97001 ^s[A-F0-9]+
     L:CUL_REDIRECT ^o+
   Readings:
     2016-07-28 22:14:15   state           opened
     2016-07-28 22:17:30   version         No answer
   icon       Icon_Fisch
   room       EnOcean
   verbose    5
Laut Wiki muss man sich für ein EnOcean Gateway erst mal per
get <device> baseID
die baseId holen.
Dieses argument ist aber gar nicht zulässig:
Unknown argument baseID, choose one of ccconf:noArg cmds:noArg credit10ms:noArg fhtbuf:noArg raw uptime:noArg version:noArg
Per set steht mir folgendes zur Verfügung:
ITClock bWidth freq hmPairForSec hmPairSerial led patable rAmpl raw reopen sens
Ich stehe etwas auf dem Schlauch.
Ist das Modul defekt, oder muss ich noch etwas konfigurieren?
Eingerichtet habe ich den CUNx nach folgenden Anleitungen
https://www.fam-moser.de/blog/kmosers-tech-blog/computer/fhem/cunx-vorbereiten.html
https://www.fam-moser.de/blog/kmosers-tech-blog/computer/fhem/cunx-in-fhem-einbinden.html
Markus
FHEM 5.8 |intel NUC Core i3: Ubuntu 22.04 | z-Wave: Aeon Labs USB Stick | Jeelink (v3c): LaCrosse-Sensoren | DuoFern Stick: Rademacher Gurtwickler | Philips Hue Bridge | CUNX: HomeMatic, EnOcean-Pigator
krikan
#1
Hallo Markus,
Probiere mal für die EnOcean-Platine eine TCM-Defintion http://fhem.de/commandref#TCM zu nutzen; statt einem CUL define.
Also so etwas in der Art:
define EnOGateway TCM ESP3 192.168.178.66:2324
Gruß, Christian
MarkusAutomaticus
Hallo Christian,
vielen Dank für deinen Hinweis.
Da wäre ich im Leben nicht drauf gekommen.
Jetzt freue ich mich noch mehr auf den Feierabend, als sonst  :D
Schade, dass es noch nicht bis zu busware vorgedrungen ist,
dass zu einem Produkt auch ein Mindestmaß an Dokumentation gehöhrt.
Ich habe gestern alleine eine halbe Stunde gepuzzelt bis ich das Gehäuse zusammen hatte,
den Rest muss man sich im Internet zusammensuchen.
Ich finde, dass man da bei den aufgerufenen Preisen eigentlich mehr erwarten kann.
Markus
