[FHZ] CUL_FTTK bug
Begonnen von Dr. Boris Neubert, 13 Dezember 2009, 17:38:12
Dr. Boris Neubert
I experimented with CUL today. CUL_FTTK apparently has a software defect
which manifests itself as follows:
fhem.log:
2009.12.13 17:25:24 0: Server started (version =VERS= from =DATE= ($Id:
fhem.pl,v 1.91 2009/12/09 13:29:47 rudolfkoenig E
xp $), pid 31035)
2009.12.13 17:26:04 3: FHTTK skipping state 02 as last similar telegram
was received less than 5 secs ago
2009.12.13 17:26:05 3: FHTTK skipping state 02 as last similar telegram
Use of uninitialized value $self in hash element at
/data/Homeautomation/fhem/FHEM/09_CUL_FHTTK.pm line 189.
/data/Homeautomation/fhem/FHEM/09_CUL_FHTTK.pm line 199.
/data/Homeautomation/fhem/FHEM/09_CUL_FHTTK.pm line 201.
etc.
Many perl error message follow.
xmllist lists an unnamed device at the beginning which breaks pgm3:
                < name="" state="" sets="" attrs="room comment">
                        measured="2009-12-13 17:28:46"/>
        <_internal__LIST>
                <_internal_ name="global" state="<no definition>"
sets="" attrs="room comment archivecmd allowfrom archivedir configfile
lastinclude logfile modpath nrarchive pidfilename port statefile title
userattr verbose:1,2,3,4,5 mseclog version nofork logdir holiday2we">
etc.
The fhem.save contains invalid (unnamed) devices:
#Sun Dec 13 17:25:17 2009
setstate   Battery
setstate   PREV
setstate   Reliability
setstate   Warning
setstate  2009-12-13 17:24:31 Window Closed
How to fix this?
Regards,
Boris
You received this message because you are subscribed to the Google Groups "FHEM users" group.
To post to this group, send email to fhem-users@googlegroups.com.
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en.
Guest
Dr. Boris Neubert wrote:
> Hi,
> fhem.log:
> xp $), pid 31035)
Haven't ugraded to latest release yet, therefore I can't reproduce this
right now. I don't have the perl errors in my development code, as for
XML and fhem.save, XML I never (knowingly) used, in my fhem.save I don't
have strange entries without a device name.
"Server started (version =VERS= from =DATE=", which version are you using?
Mine says:
2009.12.13 12:31:31 0: Server started (version 4.7 from 2009-10-23 ($Id: fhem.pl,v 1.80 2009/09/11 07:34:12 rudolfkoenig Exp $), pid 30648)
Regards,
         kai
Dr. Boris Neubert
I use the CVS version as of 2009-12-12 (yesterday) of fhem and culfw V1.33.
The error occurs after 0 .. 2 minutes, presumably after having received
the first message.
Maybe the following may hint to the source of the problem: I did not
define a device for all FHT80TFK because I did not receive a telegram
from one of them. Could the problem be caused by this unknown device?
grep Window fhem.log
2009.12.13 18:28:02 4: FHTTK Device  (Window: Closed)
<----- this is the rogue device
2009.12.13 18:29:56 4: FHTTK Device x.5.fk (Window: Closed)
2009.12.13 18:30:36 4: FHTTK Device x.2.fk (Window: Closed)
Regards,
Boris
Dr. Boris Neubert
Hello,
I would like to confirm the defect in CUL_FTTK. It is easy to reproduce
for me:
1. Do not define any CUL_FTTK device.
2. Connect to fhem and load the module:
        reload 09_CUL_FHTTK.pm
3. Wait until the first datagram from a window sensor is received.
=> There appear many messages about unitialized variables from the perl
module. I presume that the Parse function does not handle undefined
devices well.
Regards,
Boris
> for me:
I'm afraid this is not a special problem of the CUL_FTTK module, but it is a
general problem of the reload function. Each module remembers the code ->
device structure information in a local hash (%defptr). It was reported, that
this data structure gets lost after a reload. We have to verify it and think
about a solution.
Dr. Boris Neubert
#5
Am 19.12.2009 17:44, schrieb Rudolf Koenig:
>> for me:
> about a solution.
I would like to add that I executed the sequence in my original post
after a restart of fhem with no devices defined. The reload command was
issued to bring the CUL_FTTK module to live without the need to define a
window sensor.
Regards,
Boris
Guest
Hallo Zusammen,
> Each module remembers the code ->device structure information in a local hash (%defptr).
By reloading a Modul this structure %defptr gets lost.
F.e.:
- define KS1 ks300 1234
- MyCUN: K97250108001B46 -74.5
- reload 13_KS300.pm
- Unkown KS300 ... please define it
- Modify KS1: change code form 1234 to 4321
Schöne Grüße
Axel
