EnOcean Gateway läuft Amok
Begonnen von MarkusAutomaticus, 02 August 2016, 22:34:55
MarkusAutomaticus
Bis vor kurzem hat mein EnOcean Pigator noch anstandslos funktioniert.
Jetzt scheint er nichts mehr zu empfangen und seine BaseID ist 0, während ein Wert PARTIAL überzulaufen scheint.
Hier das list:
   BaseID     00000000
   DEF        ESP3 192.168.178.66:2324
   DeviceName 192.168.178.66:2324
   FD         50
   LastID     00000000
   MODEL      ESP3
   NAME       EnOGateway
   NOTIFYDEV  global
   NR         129
   NTFY_ORDER 50-EnOGateway
   PARTIAL    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
   STATE      initialized
   TYPE       TCM
   Readings:
     2016-08-02 22:05:56   baseID          BaseID: FFAC0600 RemainingWriteCycles: 0A
     2016-08-01 18:39:45   maturity        01
     2016-08-01 18:39:45   repeater        RepEnable: 00 RepLevel: 00
     2016-07-29 21:50:57   smartAckLearnedClients ClientID:CtrlID:Mailbox:
     2016-08-01 18:39:45   state           initialized
     2016-08-01 18:38:40   version         APIVersion: 02050000 APPVersion: 020A0000 ChipID: 0190580C ChipVersion: 454F0103 Desc: GATEWAYCTRL
   icon       Icon_Fisch
   room       EnOcean,IOGateways
   sendInterval 0
   smartAckMailboxMax 0
Was macht man in einem solchen Fall?
Markus
FHEM 5.8 |intel NUC Core i3: Ubuntu 22.04 | z-Wave: Aeon Labs USB Stick | Jeelink (v3c): LaCrosse-Sensoren | DuoFern Stick: Rademacher Gurtwickler | Philips Hue Bridge | CUNX: HomeMatic, EnOcean-Pigator
krikan
Hallo Markus!
Steht etwas besonderes im Log?
Bei den USB-Sticks ist baseId 00000000 ein Hinweis auf ein Problem bei der Ermittlung der baseID beim Start von FHEM und das siehst Du. Allerdings sollte das nicht zu Empfangsproblemen führen.
Tritt das auch nach einem shutdown restart noch reproduzierbar auf?
Ansonsten derzeit keine Ideen bei der nicht gerade alltäglichen Hardware. Du suchst wohl die Herausforderung  :) .
Gruß, Christian
MarkusAutomaticus
Gruß, Christian
Hallo Christian,
das nun nicht gerade ;)
Es war einfach zu verlockend, die drangvolle Enge um den kleinen Raspi etwas zu entzerren und Gateways per Netzwerk auszulagern.
Da ich die EnOcean und HM -Devices im vorderen Teil des Hauses habe, habe ich mir eben das CUNx besorgt und stolz im Arbeitszimmer an die Wand gehängt.
Inkl. Gehäuse und Antennen hat der Spaß fast 200,- € gekostet.
Ich bin quasi zum Erfolg verdammt. ::)
Die Logs seit dem ersten Anschluss und heute bin ich durchgegangen und habe alles, was ich EnOcean zuordnen konnte in eine eigene Datei kopiert.
Vieles wiederholt sich, weil ich FHEM regelmäßig aktualisiert und neu gestartet habe. Aber mit meiner bescheidenen Erfahrung in diesem Bereich ist mir nichts Besonderes aufgefallen:
2016.07.29 21:10:46 3: Opening EnOGateway device 192.168.178.66:2324
2016.07.29 21:10:46 3: EnOGateway device opened
2016.07.29 21:13:02 3: TCM get EnOGateway baseID
2016.07.29 21:13:02 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.07.29 21:18:18 3: TCM get EnOGateway baseID
2016.07.29 21:18:18 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.07.30 20:37:43 1: 192.168.178.66:2324 reappeared (EnOGateway)
2016.07.30 20:47:57 1: 192.168.178.66:2323 disconnected, waiting to reappear (CUN1)
2016.07.30 20:47:58 1: 192.168.178.66:2323 reappeared (CUN1)
2016.07.31 10:58:51 3: Opening EnOGateway device 192.168.178.66:2324
2016.07.31 10:58:51 3: EnOGateway device opened
2016.07.31 10:58:52 2: EnOcean Cryptographic functions are not available.
2016.07.31 10:58:55 3: TCM set EnOGateway reset
2016.07.31 10:58:55 2: TCM EnOGateway RESPONSE: OK
2016.07.31 10:58:55 3: TCM set EnOGateway smartAckMailboxMax 0
2016.07.31 10:58:58 2: TCM EnOGateway Timeout reading answer for set smartAckMailboxMax
2016.07.31 10:58:58 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.07.31 10:58:58 3: TCM set EnOGateway repeater 0000
2016.07.31 10:58:58 2: TCM EnOGateway RESPONSE: OK
2016.07.31 10:58:58 2: TCM EnOGateway repeater 0000 restored
2016.07.31 10:58:58 3: TCM set EnOGateway maturity 01
2016.07.31 10:58:58 2: TCM EnOGateway maturity 01 restored
2016.07.31 10:58:58 3: TCM set EnOGateway mode 00
2016.07.31 10:58:58 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.07.31 10:58:58 3: TCM get EnOGateway baseID
2016.07.31 10:58:58 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.07.31 10:58:58 3: TCM get EnOGateway version
2016.07.31 10:58:58 2: TCM EnOGateway RESPONSE: APIVersion: 02050000 APPVersion: 020A0000 ChipID: 0190580C ChipVersion: 454F0103 Desc: GATEWAYCTRL
2016.07.31 10:58:58 2: TCM EnOGateway initialized
2016.07.31 18:21:47 3: EnOGateway device opened
2016.07.31 18:21:48 2: EnOcean Cryptographic functions are not available.
2016.07.31 18:21:48 1: PERL WARNING: Constant subroutine main::URL redefined at /usr/share/perl/5.20/constant.pm line 156, <$fh> line 1175.
2016.07.31 18:21:49 1: Including ./log/fhem.save
2016.07.31 18:21:49 3: Device WC.Fenster added to ActionDetector with 028:00 time
2016.07.31 18:21:52 3: TCM set EnOGateway reset
2016.07.31 18:21:52 2: TCM EnOGateway RESPONSE: OK
2016.07.31 18:21:52 3: TCM set EnOGateway repeater 0000
2016.07.31 18:21:52 2: TCM EnOGateway repeater 0000 restored
2016.07.31 18:21:52 3: TCM set EnOGateway maturity 01
2016.07.31 18:21:52 2: TCM EnOGateway maturity 01 restored
2016.07.31 18:21:52 3: TCM set EnOGateway mode 00
2016.07.31 18:21:52 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.07.31 18:21:52 3: TCM set EnOGateway smartAckMailboxMax 0
2016.07.31 18:21:52 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.07.31 18:21:52 3: TCM get EnOGateway baseID
2016.07.31 18:21:52 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.07.31 18:21:52 3: TCM get EnOGateway version
2016.07.31 18:21:52 2: TCM EnOGateway RESPONSE: APIVersion: 02050000 APPVersion: 020A0000 ChipID: 0190580C ChipVersion: 454F0103 Desc: GATEWAYCTRL
2016.07.31 18:21:52 2: TCM EnOGateway initialized
2016.07.31 18:25:49 3: TCM set EnOGateway reset
2016.07.31 18:25:49 2: TCM EnOGateway RESPONSE: OK
2016.07.31 18:25:49 3: TCM set EnOGateway smartAckMailboxMax 0
2016.07.31 18:25:49 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.07.31 18:25:49 3: TCM set EnOGateway repeater 0000
2016.07.31 18:25:49 2: TCM EnOGateway repeater 0000 restored
2016.07.31 18:25:49 3: TCM set EnOGateway mode 00
2016.07.31 18:25:49 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.07.31 18:25:49 3: TCM set EnOGateway maturity 01
2016.07.31 18:25:49 2: TCM EnOGateway maturity 01 restored
2016.07.31 18:25:49 3: TCM get EnOGateway baseID
2016.07.31 18:25:49 2: TCM EnOGateway wrong data checksum: got 0A, computed 1D
2016.07.31 18:25:49 3: TCM get EnOGateway version
2016.07.31 18:25:49 2: TCM EnOGateway get version: Bogus answer received: 65550021000226
2016.07.31 18:25:49 2: TCM EnOGateway initialized
2016.07.31 18:26:50 3: Opening EnOGateway device 192.168.178.66:2324
2016.07.31 18:26:50 3: EnOGateway device opened
2016.07.31 18:26:51 2: EnOcean Cryptographic functions are not available.
2016.07.31 18:26:55 3: TCM set EnOGateway reset
2016.07.31 18:26:55 2: TCM EnOGateway RESPONSE: OK
2016.07.31 18:26:55 3: TCM set EnOGateway repeater 0000
2016.07.31 18:26:55 2: TCM EnOGateway repeater 0000 restored
2016.07.31 18:26:55 3: TCM set EnOGateway maturity 01
2016.07.31 18:26:55 2: TCM EnOGateway maturity 01 restored
2016.07.31 18:26:55 3: TCM set EnOGateway smartAckMailboxMax 0
2016.07.31 18:26:55 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.07.31 18:26:55 3: TCM set EnOGateway mode 00
2016.07.31 18:26:55 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.07.31 18:26:55 3: TCM get EnOGateway baseID
2016.07.31 18:26:55 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.07.31 18:26:55 3: TCM get EnOGateway version
2016.07.31 18:26:55 2: TCM EnOGateway RESPONSE: APIVersion: 02050000 APPVersion: 020A0000 ChipID: 0190580C ChipVersion: 454F0103 Desc: GATEWAYCTRL
2016.07.31 18:26:55 2: TCM EnOGateway initialized
AUGUST *
2016.08.01 18:38:35 3: EnOGateway device opened
2016.08.01 18:38:36 2: EnOcean Cryptographic functions are not available.
2016.08.01 18:38:40 3: TCM set EnOGateway reset
2016.08.01 18:38:40 2: TCM EnOGateway RESPONSE: OK
2016.08.01 18:38:40 3: TCM set EnOGateway mode 00
2016.08.01 18:38:40 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.08.01 18:38:40 3: TCM set EnOGateway smartAckMailboxMax 0
2016.08.01 18:38:40 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.08.01 18:38:40 3: TCM set EnOGateway repeater 0000
2016.08.01 18:38:40 2: TCM EnOGateway repeater 0000 restored
2016.08.01 18:38:40 3: TCM set EnOGateway maturity 01
2016.08.01 18:38:40 2: TCM EnOGateway maturity 01 restored
2016.08.01 18:38:40 3: TCM get EnOGateway baseID
2016.08.01 18:38:40 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.08.01 18:38:40 3: TCM get EnOGateway version
2016.08.01 18:38:40 2: TCM EnOGateway RESPONSE: APIVersion: 02050000 APPVersion: 020A0000 ChipID: 0190580C ChipVersion: 454F0103 Desc: GATEWAYCTRL
2016.08.01 18:38:40 2: TCM EnOGateway initialized
2016.08.01 18:39:41 3: Opening EnOGateway device 192.168.178.66:2324
2016.08.01 18:39:41 3: EnOGateway device opened
2016.08.01 18:39:41 2: EnOcean Cryptographic functions are not available.
2016.08.01 18:39:45 2: TCM EnOGateway RESPONSE: OK
2016.08.01 18:39:45 3: TCM set EnOGateway repeater 0000
2016.08.01 18:39:45 2: TCM EnOGateway repeater 0000 restored
2016.08.01 18:39:45 3: TCM set EnOGateway mode 00
2016.08.01 18:39:45 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.08.01 18:39:45 3: TCM set EnOGateway maturity 01
2016.08.01 18:39:45 2: TCM EnOGateway maturity 01 restored
2016.08.01 18:39:45 3: TCM set EnOGateway smartAckMailboxMax 0
2016.08.01 18:39:45 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.08.01 18:39:45 3: TCM get EnOGateway baseID
2016.08.01 18:39:45 2: TCM EnOGateway wrong data checksum: got 0A, computed 1D
2016.08.01 18:39:45 3: TCM get EnOGateway version
2016.08.01 18:39:45 2: TCM EnOGateway get version: Bogus answer received: 6555002100022600
2016.08.01 18:39:45 2: TCM EnOGateway initialized
2016.08.02 22:05:56 3: TCM get EnOGateway baseID
2016.08.02 22:05:56 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.08.03 09:15:04 3: Opening EnOGateway device 192.168.178.66:2324
2016.08.03 09:15:04 3: EnOGateway device opened
2016.08.03 09:15:05 2: EnOcean Cryptographic functions are not available.
2016.08.03 09:15:09 3: TCM set EnOGateway reset
2016.08.03 09:15:09 2: TCM EnOGateway RESPONSE: OK
2016.08.03 09:15:09 3: TCM set EnOGateway maturity 01
2016.08.03 09:15:09 2: TCM EnOGateway maturity 01 restored
2016.08.03 09:15:09 3: TCM set EnOGateway repeater 0000
2016.08.03 09:15:09 2: TCM EnOGateway repeater 0000 restored
2016.08.03 09:15:09 3: TCM set EnOGateway smartAckMailboxMax 0
2016.08.03 09:15:09 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.08.03 09:15:09 3: TCM set EnOGateway mode 00
2016.08.03 09:15:09 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.08.03 09:15:09 3: TCM get EnOGateway baseID
2016.08.03 09:15:09 2: TCM EnOGateway RESPONSE: BaseID: FFAC0600 RemainingWriteCycles: 0A
2016.08.03 09:15:09 3: TCM get EnOGateway version
2016.08.03 09:15:09 2: TCM EnOGateway RESPONSE: APIVersion: 02050000 APPVersion: 020A0000 ChipID: 0190580C ChipVersion: 454F0103 Desc: GATEWAYCTRL
2016.08.03 09:15:09 2: TCM EnOGateway initialized
2016.08.03 09:16:10 3: Opening EnOGateway device 192.168.178.66:2324
2016.08.03 09:16:10 3: EnOGateway device opened
2016.08.03 09:16:11 2: EnOcean Cryptographic functions are not available.
2016.08.03 09:16:15 3: TCM set EnOGateway reset
2016.08.03 09:16:15 2: TCM EnOGateway RESPONSE: OK
2016.08.03 09:16:15 3: TCM set EnOGateway repeater 0000
2016.08.03 09:16:18 2: TCM EnOGateway Timeout reading answer for set repeater
2016.08.03 09:16:18 2: TCM EnOGateway repeater 0000 restored
2016.08.03 09:16:18 3: TCM set EnOGateway maturity 01
2016.08.03 09:16:18 2: TCM EnOGateway RESPONSE: OK
2016.08.03 09:16:18 2: TCM EnOGateway maturity 01 restored
2016.08.03 09:16:18 3: TCM set EnOGateway mode 00
2016.08.03 09:16:18 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.08.03 09:16:18 3: TCM set EnOGateway smartAckMailboxMax 0
2016.08.03 09:16:18 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.08.03 09:16:18 3: TCM get EnOGateway baseID
2016.08.03 09:16:18 2: TCM EnOGateway wrong data checksum: got 0A, computed 1D
2016.08.03 09:16:18 3: TCM get EnOGateway version
2016.08.03 09:16:18 2: TCM EnOGateway get version: Bogus answer received: 6555002100022600
2016.08.03 09:16:18 2: TCM EnOGateway initialized
2016.08.03 09:27:39 3: Opening EnOGateway device 192.168.178.66:2324
2016.08.03 09:27:39 3: EnOGateway device opened
2016.08.03 09:27:40 2: EnOcean Cryptographic functions are not available.
2016.08.03 09:27:44 3: TCM set EnOGateway reset
2016.08.03 09:27:44 2: TCM EnOGateway RESPONSE: OK
2016.08.03 09:27:44 3: TCM set EnOGateway maturity 01
2016.08.03 09:27:44 2: TCM EnOGateway maturity 01 restored
2016.08.03 09:27:44 3: TCM set EnOGateway mode 00
2016.08.03 09:27:44 2: TCM EnOGateway RESPONSE: NOT_SUPPORTED
2016.08.03 09:27:44 3: TCM set EnOGateway smartAckMailboxMax 0
2016.08.03 09:27:44 2: TCM EnOGateway smartAckMailboxMax 0 restored
2016.08.03 09:27:44 3: TCM set EnOGateway repeater 0000
2016.08.03 09:27:44 2: TCM EnOGateway repeater 0000 restored
2016.08.03 09:27:44 3: TCM get EnOGateway baseID
2016.08.03 09:27:44 2: TCM EnOGateway wrong data checksum: got 0A, computed 1D
2016.08.03 09:27:44 3: TCM get EnOGateway version
2016.08.03 09:27:44 2: TCM EnOGateway get version: Bogus answer received: 6555002100022600
2016.08.03 09:27:44 2: TCM EnOGateway initialized
Akutuell sieht das List so aus
   BaseID     00000000
   FD         51
   LastID     00000000
   MODEL      ESP3
   NAME       EnOGateway
   NOTIFYDEV  global
   NR         127
   STATE      initialized
   TYPE       TCM
   Readings:
     2016-08-03 09:15:09   baseID          BaseID: FFAC0600 RemainingWriteCycles: 0A
     2016-08-03 09:27:44   maturity        01
     2016-08-03 09:27:44   repeater        RepEnable: 00 RepLevel: 00
     2016-08-03 09:27:44   state           initialized
     2016-08-03 09:15:09   version         APIVersion: 02050000 APPVersion: 020A0000 ChipID: 0190580C ChipVersion: 454F0103 Desc: GATEWAYCTRL
   icon       Icon_Fisch
   sendInterval 0
Mal blöd gefragt: Kann man nicht einfach mit set EnoGateway BaseID FFAC0600 die Internals wieder gerade biegen und alles ist gut?
Markus
krikan
Hallo Markus!
Zitat200,- € gekostet
Uff.
Da ich das Gerät nicht kenne, kann ich nur von meinen USB-Device Erfahrungen berichten und Du darfst ableiten.  ;)
Im Log findest Du häufiger so etwas:
Das führt zur baseId 0000000 in den Internals.
Bei den USB-Sticks hatte ich das teilweise, wenn der Stick am Raspi per HUB angebunden war. Restart hat dann geholfen bzw. hatte ich das Attribut baseId entgegen commandref zusätzlich gesetzt.
Wenn der Stick direkt am Raspi angeschlossen ist, kenne ich dieses Problem nicht. Darum vermute ich irgendwelche Timeing-Probleme.
Das Volllaufen von "Partial" habe ich noch nie beobachtet und keine Vorstellung, wodurch das entsteht.
Zitatset EnoGateway baseID FFAC0600
Das würde ich nicht machen.
Du musst mMn die baseId nicht im Chip neu setzen. Es scheitert doch "nur" teilweise das ordnungsgemäße Auslesen durch FHEM an falscher Checksumme.
Eigentlich wäre interessant, ob noch irgendwer CUNx mit EnOcean-Pigator nutzt und problemlosen Betrieb mit FHEM berichten kann. Mir sind keine Erfahrungsberichte in Erinnerung.
Gruß, Christian
MarkusAutomaticus
Hallo Christian,
vorab möchte ich dich mal loben und mich bei dir dafür bedanken, dass du dir immer so viel Zeit nimmst und mir schon oft aus der Patsche geholfen hast bei meinen ersten Schritten.
Überhaupt ist die stets hilfsbereite Community ein Riesenpfund mit dem Fhem wuchern kann.
Zurück zum eigentlichen Thema:
Bevor ich deine Antwort gelesen habe, habe ich schon versucht, die BaseID nochmal zu setzen.
Danach habe ich das komplette CUNx stromlos gemacht und dann neu gestartet.
Soweit ich  mich erinnere, habe ich auch Fhem neu gestartet.
Und was soll ich sagen?
Als ich die Schalter zuletzt probiert habe, hat alles wieder funktioniert.
Ein wohliges Gefühl der Zuverlässigkeit will sich an dieser Stelle allerdings nicht einstellen ::)
Ja das stimmt!
Es wäre schon cool, wenn wir so eine Art User-Verzeichnis hätten, um schnell die passenden Ansprechpartner zu finden.
Das wäre auch für die Entwickler der Module hilfreich, um schnell an Beta-Tester o.Ä. zu kommen.
Leider sind solche Übersichten sehr mühsam zu pflegen und schlafen meistens schnell wieder ein.
Markus
krikan
Bitte denke daran, dass man die baseId nur 10x setzen kann. Ob dabei auch das Setzen der gleichen baseId mitgezählt wird, ist mir unbekannt. Kannst Du anhand der "RemainingWriteCycles" bei der Abfrage der baseId erkennen.
Ja, das kann ich nachvollziehen und würde ich beobachten. Instabiles Gateway ist mMn nervend (-> WAF weg).
ser2net, FHEM2FHEM,... als alternativen Lösungsansätze zu einem reinen LAN-Gateway gibt es ja auch.
Gruß, Christian
