[FHZ] fhem logfile hygiene: CUL
Begonnen von Dr. Boris Neubert, 19 Dezember 2009, 13:42:15
Dr. Boris Neubert
I use CUL with CUL_WS to receive S555TH.
My log file is spilled with the following messages (several times a minute):
2009.12.19 13:34:44 2: CUL: unknown message ? (? is unknown) Use one of
B C F R T V W X e f l t x
fhem is CVS version from last week, CUL firmware is v1.35 plain.
How can this be avoided?
Regards,
Boris
You received this message because you are subscribed to the Google Groups "FHEM users" group.
To post to this group, send email to fhem-users@googlegroups.com.
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en.
Globaler Moderator, Developer, aktives Mitglied des FHEM e.V. (Marketing, Verwaltung)
Matthias Gehre
auch nach der gestrigen Inbetriebnahme meines CULs hagelt es diese
Meldungen.
Neben zwei S555TH steht draussen auch noch die KS300, evtl. hat die
was damit zu tun.
2009.12.19 09:20:54 2: CUL: unknown message ? (K is unknown) Use one
of B C F R T V W X e l t u x
2009.12.19 09:30:32 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 09:30:52 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 09:36:32 2: CUL: unknown message T4C
2009.12.19 09:40:10 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 09:51:41 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 10:03:33 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 10:07:07 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 10:28:04 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 10:31:21 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 10:44:01 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 11:33:44 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 11:39:31 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 11:49:08 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 12:29:53 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 12:44:52 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 13:10:29 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 13:10:49 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 13:11:59 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 13:23:28 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 13:25:42 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 13:58:39 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 14:58:04 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 15:07:25 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 15:21:14 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 15:24:45 2: CUL: unknown message ? (? is unknown) Use one
2009.12.19 15:28:01 2: CUL: unknown message ? (? is unknown) Use one
Grüße,
Martin
On 19 Dez., 13:42, "Dr. Boris Neubert" wrote:
> Hi,
> Regards,
> Boris
culfw received a command which starts with the ? character. Could you put a Log
line in 00_CUL.pm/CUL_SimpleWrite(), as all write operations should go through
this function. Another (remote) possibility is that the device driver repeats
some commands back to the device.
Matthias Gehre
Am 19.12.2009 17:38, schrieb Rudolf Koenig:
The Log line was already in but commented out. Activating it and
restarting fhem gives me
2009.12.19 18:43:55 5: Cmd: >define CUL CUL /dev/ttyACM0 0000<
2009.12.19 18:43:55 5: Loading /data/Homeautomation/fhem/FHEM/00_CUL.pm
2009.12.19 18:43:55 3: CUL opening CUL device /dev/ttyACM0
2009.12.19 18:43:55 3: CUL opened /dev/ttyACM0 for CUL
2009.12.19 18:43:55 5: CUL/RAW (ReadAnswer): T513A00A62817
2009.12.19 18:43:55 5: CUL/RAW (ReadAnswer): F0001000025
2009.12.19 18:43:55 1: CUL_SimpleWrite >V
2009.12.19 18:43:55 5: CUL/RAW (ReadAnswer): ? (? is unknown) Use one of
2009.12.19 18:43:55 5: CUL/RAW (ReadAnswer): V 1.35 CUL868
2009.12.19 18:43:55 1: CUL_SimpleWrite >X21
2009.12.19 18:43:55 1: CUL_SimpleWrite >T01
2009.12.19 18:43:55 5: CUL/RAW (ReadAnswer): 0000
2009.12.19 18:43:55 5: GOT CUL fhtid: 0000
2009.12.19 18:43:55 5: Triggering CUL (1 changes)
etc.
The messages
2009.12.19 18:46:08 2: CUL: unknown message ? (? is unknown) Use one of
are unrelated to any SimpleWrite.
Regards,
Boris
