[FHZ] CVS update (mainly 98_autocreate.pm related)
Begonnen von Guest, 05 Januar 2010, 00:23:21
Guest
Fixes/reduced logging on 70_WS3600.pm
Made CUL_FHTTK work with 98_autocreate.pm, (first) GPLOT info is now used
Added sanity checking to fhem.pl, does not save undefined fields anymore
Added fht80tf.gplot, may need (re-)work
CVS: ----------------------------------------------------------------------
CVS: Enter Log.  Lines beginning with `CVS:' are removed automatically
CVS:
CVS: Committing in .
CVS:
CVS: Modified Files:
CVS:    fhem.pl FHEM/70_WS3600.pm FHEM/98_autocreate.pm
CVS: Added Files:
CVS:    FHEM/fht80tf.gplot
Hopefully I didn't break anything; works for me though ;)
Working towards less perl errors, I added sanity checks to the save routine
in fhem.pl:
2010.01.04 23:57:48 3: Sanitizer: not saving READING measured-temp of FHT_0a55 due to missing VAL and/or TIME.
2010.01.04 23:57:48 3: Sanitizer: not saving READING measured-temp of FHT_3202 due to missing VAL and/or TIME.
2010.01.04 23:57:48 3: Sanitizer: not saving READING measured-temp of FHT_3315 due to missing VAL and/or TIME.
That is, malformatted data is no longer saved to the fhem.save file, thus
restarting fhem.pl frees you from this messages (and the bad data).
Long-term solution would be to make the corresponding modules not to generate
that bad data, so keep bugging the list with these messages ;)
98_autocreate.pm has been touch so that it now uses this dataset:
my %flogpar = (
   "CUL_EM:.*"      => { GPLOT => "cul_em:Power,", FILTER => "%NAME:CNT:.*" },
   "CUL_WS:.*"      => { GPLOT => "hms:Temp/Hum,",  FILTER => "%NAME" },
   "CUL_FHTTK:.*"   => { GPLOT => "fht80tf:Window,", FILTER => "%NAME" },
   "FHT:.*"         => { GPLOT => "fht:Temp/Act,", FILTER => "%NAME" },
   "HMS:HMS100TFK_.*" => { GPLOT => "fht80tf:Contact,", FILTER => "%NAME" },
   "HMS:HMS100T._.*" => { GPLOT => "hms:Temp/Hum,", FILTER => "%NAME:T:.*" },
   "KS300:.*"       => { GPLOT => "ks300:Temp/Rain,ks300_2:Wind/Hum,",
CUL_WS-devices now run with humidity as well. As for CUL_FHTTK and HMS100TFK,
the gplot-stuff seems to need some work. Haven't used that yet (using rrdtool
for data storage and presentation normally) and first shoot doesn't seem to
catch; hints/help appreciated.
I'm not sure what GPLOT => "ks300:Temp/Rain,ks300_2:Wind/Hum," is supposed to
do; but as I split(/:/, $gplot) -- which yields ks300, like $lctype before --
my changes shouldn't break it, whatever this does ;)
         kai
You received this message because you are subscribed to the Google Groups "FHEM users" group.
To post to this group, send email to fhem-users@googlegroups.com.
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en.
> do;
See my posting (2010-01-03, about 12:00) in the "S555TH plot ist leer" thread.
Thanks for the changes, they should not break anything.
Guest
>> do;
Ah. Currently (I don't own KS300 unfortunately; it would be rather helpful to
see "list" output e. g. of WS2000 and KS300 devices, thus I could e. g. model
the WS3600 behaviour along those) it would write only one weblink fileplot
definition with "ks300"; does KS300 need more or is it purely something that
is handled via attr for weblink?
Uff ;)
         kai
Here is my KS300, I do not have any WSxxx
   CODE       1234
   CUL_MSGCNT 3313
   CUL_RAWMSG K9730705600D968F7
   CUL_RSSI   -78.5
   CUL_TIME   2010-01-05 15:32:58
   DEF        1234
   IODev      CUL
   LASTIODev  CUL
   MSGCNT     4871
   NAME       out1
   NR         89
   RAINUNIT   255
   RFR_MSGCNT 3371
   RFR_RAWMSG K9723800600D948E6
   RFR_RSSI   -87
   RFR_TIME   2010-01-05 15:07:33
   STATE      T: -3  H: 67  W: 0.5  R: 577.6  IR: no
   TYPE       KS300
   WINDUNIT   1
   Readings:
     2010-01-05 15:32:58   avg_day         T: -9.4  H: 77  W: 0.3  R: 0.3
     2010-01-05 00:00:06   avg_month       T: -1.4  H: 37  W: 39.2  R: 0.2
     2010-01-05 15:32:58   cum_day         2010-01-05 00:00:06 T: -526641.7  H: 4360784  W: 14385.9  R: 577.3
     2010-01-05 00:00:06   cum_month       4 T: -5.5  H: 149  W: 156.8  R: 0.2
     2010-01-05 15:32:58   humidity        67 (%)
     2010-01-05 15:32:58   israining       no (yes/no)
     2010-01-05 15:32:58   rain            577.6 (l/m2)
     2010-01-05 15:32:58   rain_raw        2265 (counter)
     2010-01-05 15:32:58   rain_raw_adj    2265
     2010-01-05 15:32:58   temperature     -3 (Celsius)
     2010-01-05 15:32:58   tsecs           1262701978
     2010-01-05 15:32:58   unknown1        6
     2010-01-05 15:32:58   unknown2        7
     2010-01-05 15:32:58   unknown3        9
     2010-01-05 15:32:58   wind            0.5 (km/h)
In a gplot file I can only display two units (on the left and right) but the
KS300 delivers 4 (temp/hum/rain/wid).
Martin Fischer
Am Dienstag 05 Januar 2010 schrieb Kai 'wusel' Siering:
>  to see "list" output e. g. of WS2000 and KS300 devices, thus I could e. g.
>  model the WS3600 behaviour along those) it would write only one weblink
ich habe eine KS-555.
fhem> list GH.ga.WE.01
   CODE       0b0b
   CUL868_MSGCNT 299
   CUL868_RAWMSG K97807008006FCDEE
   CUL868_RSSI -83
   CUL868_TIME 2010-01-05 17:23:16
   DEF        0b0b 255 10
   IODev      CUL868
   LASTIODev  CUL868
   MSGCNT     299
   NAME       GH.ga.WE.01
   NR         9
   RAINUNIT   255
   STATE      T: -8  H: 87  W: 0.0  R: 876.9  IR: no
   TYPE       KS300
   WINDUNIT   10
   Readings:
     2010-01-05 17:23:16   avg_day         T: -4.0  H: 81  W: 0.0  R: 0.0
     2010-01-05 00:03:39   avg_month       T: -4.1  H: 43  W: 44.0  R: 0.0
     2010-01-05 17:23:16   cum_day         2010-01-05 00:03:39 T: -251521.6
H: 5099513  W: 0  R: 876.9
     2010-01-05 00:03:39   cum_month       4 T: -16.3  H: 172  W: 176.0  R:
0.0
     2010-01-05 17:23:16   humidity        87 (%)
     2010-01-05 17:23:16   israining       no (yes/no)
     2010-01-05 17:23:16   rain            876.9 (l/m2)
     2010-01-05 17:23:16   rain_raw        3439 (counter)
     2010-01-05 17:23:16   rain_raw_adj    3439
     2010-01-05 17:23:16   temperature     -8 (Celsius)
     2010-01-05 17:23:16   tsecs           1262708596
     2010-01-05 17:23:16   unknown1        c
     2010-01-05 17:23:16   unknown2        7
     2010-01-05 17:23:16   unknown3        9
     2010-01-05 17:23:16   wind            0.0 (km/h)
   comment    Wetterstation
   room       Garten
Admin, Developer, Gründungsmitglied des FHEM e.V.
Guest
Rudolf & Martin, danke für die WS300/KS555-Werte!
Fragen:
> Internals:
>    CODE       0b0b
>    CUL868_MSGCNT 299
>    CUL868_RSSI -83
>    DEF        0b0b 255 10
>    IODev      CUL868
>    LASTIODev  CUL868
>    MSGCNT     299
>    NAME       GH.ga.WE.01
>    NR         9
>    RAINUNIT   255
>    TYPE       KS300
>    WINDUNIT   10
>    Readings:
Bei "T:" & "H:" habt Ihr beide da ziemlich wurstige Werte ...
... und bei "W:" und "R:", grade bei Schneefall, ebenfalls ziemlich
deftige Werte. Liefert das die Anlage so gruselig oder bastelt sich
FHEM das zusammen? (Und was soll bitte kumulierte Windgeschwindigkeit
sein? "Ich hatte aber mehr Wind als wie Du, ätsch bätsch!"? ;) Bei
Regen sehe ich ja noch 'nen Sinn, das aufzusummieren, aber bei Wind?!)
Wird cum_* (oder irgendwas von den READINGS) von Frontends benutzt?
>      2010-01-05 00:03:39   cum_month       4 T: -16.3  H: 172  W: 176.0  R:  0.0
Das erste Feld ist die Anzahl der Tage?
Hintergrund der Fragen: ich möchte einerseits die WS3600.pm-Ausgabe mög-
lichst nahe an der der bestehenden Wetterstationen halten (und fragte mich,
wie diese vielen Werte im "Status" wohl repräsentiert würden), ohne aber
natürlich Infos der WS3600 zu verlieren oder zu verfälschen. (Ja, use the
source ging notfalls auch, aber da Ihr wohl Ersthanderfahrungen mit diesen
Geräten habt ... ;))
Danke & Ciao,
         kai
Dr. Boris Neubert
die kumulierten Werte werden benoetigt, um den Tages-/Monatsdurchschnitt
zu berechnen. Da wird jeweils beim ersten Datagramm nach Mitternacht
erledigt. Die Webfrontends benutzen die cum_*-Werte m.W. nicht, wohl
aber die daraus abgeleiteten avg_*-Werte.
Gruesse,
Boris
Globaler Moderator, Developer, aktives Mitglied des FHEM e.V. (Marketing, Verwaltung)
Guest
> zu berechnen.
Okay, das macht die WS3600 für 1h, 24h, 1W, 1M sowie absolut seit
Rain-total-Date, Rain-total-Time (18-09-2005, 03:29 bei mir) selbst;
denke, das muß man wohl nicht nachbauen.
Hmm, vielleicht kann ich das basierend auf den vorhandenen Daten ja
zurechtfaken, um den Aufwand da gering zu halten. WS3600.pm gibt jetzt
'nen ähnlichen Status raus (klein-i ist der Wert für Innen, DP der
Taupunkt, WC "Wind Chill" (gefühlte Temperatur?), P der rel. Druck),
sieht zumindest in pgm2 schon mal besser aus ;)
Frage an die Frontend-Tüftler: macht das die Integration einfacher?
fhem> list WS3600
    DEF        /usr/local/bin/fetch3600.real
    DeviceName /usr/local/bin/fetch3600.real |
    NAME       WS3600
    NR         4
    STATE       Ti: 22.2 T: -4.2 DP: -6.1 Hi: 36 H: 87 W: 0.0 Dir: W WC: -4.2 R: 0.00 P: 990.100 Tendency: Falling Forecast: Rainy
    TMPSTATE
    TYPE       WS3600
    Timer      64
    pipeopentime 1262743203
    Readings:
      2010-01-06 03:00:21   Date            06-Jan-2010
      2010-01-06 03:00:21   Dew-Point       -6.1
      2010-01-06 03:00:21   Dew-Point-max   20.3
      2010-01-06 03:00:21   Dew-Point-min   -17.2
      2010-01-06 03:00:21   Dew-Point-min-Date 20-08-2009
      2010-01-06 03:00:21   Dew-Point-min-Time 11:58
      2010-01-06 03:00:21   Forecast        Rainy
      2010-01-06 03:00:21   Rain-1M         61.64
      2010-01-06 03:00:21   Rain-1M-max     117.58
      2010-01-06 03:00:21   Rain-1M-max-Date 01-11-2009
      2010-01-06 03:00:21   Rain-1M-max-Time 00:00
      2010-01-06 03:00:21   Rain-1h         0.00
      2010-01-06 03:00:21   Rain-1h-hmax    24.34
      2010-01-06 03:00:21   Rain-1h-hmax-Date 07-10-2009
      2010-01-06 03:00:21   Rain-1h-hmax-Time 22:34
      2010-01-06 03:00:21   Rain-1w         11.39
      2010-01-06 03:00:21   Rain-1w-max     95.83
      2010-01-06 03:00:21   Rain-1w-max-Date 12-10-2009
      2010-01-06 03:00:21   Rain-1w-max-Time 00:00
      2010-01-06 03:00:21   Rain-24-hmax    55.42
      2010-01-06 03:00:21   Rain-24h        0.00
      2010-01-06 03:00:21   Rain-24h-max-Date 08-10-2009
      2010-01-06 03:00:21   Rain-24h-max-Time 07:11
      2010-01-06 03:00:21   Rain-total      3133.30
      2010-01-06 03:00:21   Rain-total-Date 18-09-2005
      2010-01-06 03:00:21   Rain-total-Time 03:29
      2010-01-06 03:00:21   Temp-inside     22.2
      2010-01-06 03:00:21   Temp-inside-max 27.9
      2010-01-06 03:00:21   Temp-inside-max-Date 20-08-2009
      2010-01-06 03:00:21   Temp-inside-max-Time 23:31
      2010-01-06 03:00:21   Temp-inside-min 19.6
      2010-01-06 03:00:21   Temp-inside-min-Date 19-12-2009
      2010-01-06 03:00:21   Temp-inside-min-Time 12:42
      2010-01-06 03:00:21   Temp-outside    -4.2
      2010-01-06 03:00:21   Temp-outside-max 35.6
      2010-01-06 03:00:21   Temp-outside-max-Date 20-08-2009
      2010-01-06 03:00:21   Temp-outside-max-Time 16:52
      2010-01-06 03:00:21   Temp-outside-min -14.7
      2010-01-06 03:00:21   Temp-outside-min-Date 20-12-2009
      2010-01-06 03:00:21   Temp-outside-min-Time 00:42
      2010-01-06 03:00:21   Tendency        Falling
      2010-01-06 03:00:21   Time            03:00:08
      2010-01-06 03:00:21   Wind-Chill      -4.2
      2010-01-06 03:00:21   Wind-Chill-max  35.6
      2010-01-06 03:00:21   Wind-Chill-max-Date 20-08-2009
      2010-01-06 03:00:21   Wind-Chill-max-Time 16:52
      2010-01-06 03:00:21   Wind-Chill-min  -14.7
      2010-01-06 03:00:21   Wind-Chill-min-Date 20-12-2009
      2010-01-06 03:00:21   Wind-Chill-min-Time 00:42
      2010-01-06 03:00:21   Wind-DIR0       270.0
      2010-01-06 03:00:21   Wind-DIR1       270.0
      2010-01-06 03:00:21   Wind-DIR2       270.0
      2010-01-06 03:00:21   Wind-DIR3       270.0
      2010-01-06 03:00:21   Wind-DIR4       270.0
      2010-01-06 03:00:21   Wind-DIR5       270.0
      2010-01-06 03:00:21   Wind-Direction-Text W
      2010-01-06 03:00:21   Wind-Speed      0.0
      2010-01-06 03:00:21   Wind-Speed-max  25.6
      2010-01-06 03:00:21   Wind-Speed-max-Date 24-09-2009
      2010-01-06 03:00:21   Wind-Speed-max-Time 19:08
      2010-01-06 03:00:21   Wind-Speed-min  0.0
      2010-01-06 03:00:21   Wind-Speed-min-Date 02-01-2010
      2010-01-06 03:00:21   Wind-Speed-min-Time 08:34
      2010-01-06 03:00:21   abs-Pressure    993.800
      2010-01-06 03:00:21   rel-Humidity-inside 36
      2010-01-06 03:00:21   rel-Humidity-inside-max 57
      2010-01-06 03:00:21   rel-Humidity-inside-max-Date 07-10-2009
      2010-01-06 03:00:21   rel-Humidity-inside-max-Time 22:24
      2010-01-06 03:00:21   rel-Humidity-inside-min 18
      2010-01-06 03:00:21   rel-Humidity-inside-min-Date 19-12-2009
      2010-01-06 03:00:21   rel-Humidity-inside-min-Time 12:37
      2010-01-06 03:00:21   rel-Humidity-outside 87
      2010-01-06 03:00:21   rel-Humidity-outside-max 96
      2010-01-06 03:00:21   rel-Humidity-outside-max-Date 25-12-2009
      2010-01-06 03:00:21   rel-Humidity-outside-max-Time 09:43
      2010-01-06 03:00:21   rel-Humidity-outside-min 27
      2010-01-06 03:00:21   rel-Humidity-outside-min-Date 20-08-2009
      2010-01-06 03:00:21   rel-Humidity-outside-min-Time 16:41
      2010-01-06 03:00:21   rel-Pressure    990.100
      2010-01-06 03:00:21   rel-Pressure-max 1020.000
      2010-01-06 03:00:21   rel-Pressure-max-Date 11-09-2009
      2010-01-06 03:00:21   rel-Pressure-max-Time 09:19
      2010-01-06 03:00:21   rel-Pressure-min 967.600
      2010-01-06 03:00:21   rel-Pressure-min-Date 25-12-2009
      2010-01-06 03:00:21   rel-Pressure-min-Time 06:24
fhem>
Ciao,
         kai
Nicht direkt.
State ist fuers uebersicht, was man beim "list" sieht, bzw. in den Fronteds auf
dem ersten Blick.
Ansonsten gibt es die triggers, die fuers Loggen sorgen. Ich wuerde bei so
einem Geraet gerne nur eine Zeile Loggen. Der KS300 triggert fuer fast jeden
seiner Readings, das ist in meinem Augen ein Dorn, da jeder der notifys fuer
jeden Reading aufgerufen werden, was CPU kostet. Andererseits macht die
Ueberwachung von einem Parameter evtl. leichter.
Btw. es muesste reichen fuer die Frontend Leute (pgm{2,3,5} entsprechende
.gplot Files zu liefern).
Guest
> Nicht direkt.
> dem ersten Blick.
Ich glaube, den Mechanismus verstehe ich noch nicht.
Ich habe nun
       $hash->{CHANGED}[$i++] = "$reading: $val";
wieder eingefügt, am Ende des Lesens folgt ein
#   $hash->{CHANGED}[$i++] = "Status: $StateString";
   DoTrigger($name, undef);
-- mit "attr global verbose 5" sehe ich nur 1 Trigger durchlaufen.
Fragen:
1) Was sorgt dafür, daß -- und was -- ins Logfile geschrieben wird?
2) READINGS landen im fhem.save (wann eigentlich?), wofür ist CHANGED und wie
    ist die Verbindung der beiden?
Da WS3600 (in der Theorie; das klappt noch nicht so wirklich "as expected",
aber dazu mal an anderer Stelle was) alle Daten in einem Rutsch alle ~65
Sekunden liefert, habe ich mit nur 1 Trigger erst einmal kein Problem.
Yuk. Ich und gplot ... Nun denn, wie ist die Namenskonvention für >2 Werte?
Effektiv interessant sind IMHO T/H innen, T/H außen, T außen/DP/WC, Rain/Wind,
Wind/Pressure, ...
         kai
Guest
Hallo Zusammen,
Also soweit ich das verstanden habe...
Ein Device meldet sich...
Die Meldung wird per fhem.pl->Disptacher an die "zuständige" ParseFN
übergeben.
ParseFN schreibt die Werte in die READINGs und füllt das Array $hash->
{CHANGED}[]
Danach gehts weiter....an alle Module/Devices, die eine NotifyFN
haben...
Übergeben werden der Device-Name von z.B. einem Notify und der Name
des meldenden Devices...
Die NotifyFN "verarbeitet" dann $hash->{CHANGED}[]
> 1) Was sorgt daf r, da -- und was -- ins Logfile geschrieben wird?
Ein definiertes FileLog...
Das Modul FileLog hat eine NotifyFN...
> Der KS300 triggert fuer fast jeden seiner Readings,
Das doch auch nur wenn ich für jedes READING ein NOTIFY habe:
z.B. notify KS300 Temperature; notify KS300 Humidity; Notify KS300
Rain
oder ??
> wof r ist CHANGED und wie ist die Verbindung der beiden?
Dokumentation der geänderten Werte/READINGS eines Devices...
Ich denke mal, das ist einfacher als den TimeStamp der READINGs
auszuwerten ...{READINGS}{...}{TIME}
Schöne Grüße
Axel
