(Gelöst) PERL WARNING: Use of uninitialized value in pattern match (m//) at .
Begonnen von P.A.Trick, 20 August 2016, 10:57:29
P.A.Trick
Ich bekomme beim pairen von neuen Homematic Geräten folgende Info Meldung:
2016.08.20 10:37:59.990 3: CUL_HM pair: HM_49E737 switch, model HM-LC-Sw1PBU-FM serialNr
2016.08.20 10:37:59.987 3:     main::CallFn                        called by fhem.pl (668)
2016.08.20 10:37:59.987 3:     main::HMLAN_Read                    called by fhem.pl (3201)
2016.08.20 10:37:59.986 3:     main::HMLAN_Parse                   called by ./FHEM/00_HMLAN.pm (589)
2016.08.20 10:37:59.986 3:     main::Dispatch                      called by ./FHEM/00_HMLAN.pm (764)
2016.08.20 10:37:59.986 3:     main::CUL_HM_Parse                  called by fhem.pl (3362)
2016.08.20 10:37:59.985 3:     main::CUL_HM_parseCommon            called by ./FHEM/10_CUL_HM.pm (1338)
2016.08.20 10:37:59.985 3:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (3018)
2016.08.20 10:37:59.985 3: stacktrace:
2016.08.20 10:37:59.984 1: PERL WARNING: Use of uninitialized value in pattern match (m//) at ./FHEM/10_CUL_HM.pm line 3018.
2016.08.20 10:37:59.983 1: General  --------- start me
2016.08.20 10:37:59.758 3: [sendmsg] - [MSG] 10:37:59: [error] Undefined device found! - UNDEFINED HM_49E737 CUL_HM 49E737
2016.08.20 10:37:59.288 3: [sendmsg] - [MSG] 10:37:59: [info] FHEM Konfiguration wurde gesichert
2016.08.20 10:37:58.865 2: autocreate: define FileLog_HM_49E737 FileLog ./log/HM_49E737-%Y.log HM_49E737
2016.08.20 10:37:58.835 2: autocreate: define HM_49E737 CUL_HM 49E737
2016.08.20 10:37:58.823 2: CUL_HM Unknown device HM_49E737 is now defined
Funktion ist dennoch gegeben!
Cubietruck,RPI,QNAP Ts-419p+, FS20, FRITZ!DECT200, 7 MAX! Thermostate, 3 MAX! Fensterkontakte, Kodi, CUL V3.3, EM1000S, LW12, LD382, HUE, HM-CFG-USB-2, 1x HM-LC-SW1-FM, 2x HM-LC-SW2-FM, 2x HM-LC-Sw1PBU-FM, 3xHM-LC-Bl1PBU-FM,HM-SEC-RHS, 2xHM-SEC-SD,HM-WDS30-T-O, 3x HM-LC-Dim1TPBU-FM, RPI+AddOn
P.A.Trick
