nanoCUL flashen
Begonnen von hyper2910, 29 August 2016, 20:47:36
hyper2910
ich bekomme einen nanoCUL einfach nicht geflasht.
Ich bin nach dieser Anleitung vorgegangen:
http://raspberry.tips/raspberrypi-tutorials/hausautomatisierung-mit-fhem-teil-1-cul-stick-selbstbau-868mhz-cul-am-raspberry-pi/
als Ergebnis bekomme ich immer :
pi@raspberrypi:~/culfw-code/culfw/Devices/nanoCUL $ lsusb
Bus 001 Device 008: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. LAN9500 Ethernet 10/100 Adapter / SMSC9512/9514 Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@raspberrypi:~/culfw-code/culfw/Devices/nanoCUL $ make program
#@if test ! -d /sys/class/gpio/gpio17; then echo 17 > /sys/class/gpio/export; fi
#@if test ! -d /sys/class/gpio/gpio18; then echo 18 > /sys/class/gpio/export; fi
#echo out > /sys/class/gpio/gpio17/direction
#echo out > /sys/class/gpio/gpio18/direction
#echo 0 > /sys/class/gpio/gpio17/value
#echo 0 > /sys/class/gpio/gpio18/value
#sleep 1
#echo 1 > /sys/class/gpio/gpio17/value
#sleep 1
#echo 1 > /sys/class/gpio/gpio18/value
avrdude -D -p atmega328p -P /dev/ttyUSB0 -b 57600 -c arduino -U flash:w:nanoCUL.hex
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
makefile:216: recipe for target 'program' failed
make: *** [program] Error 1
mit gedrückter Taste eingesteckt und auch ohne, FHEM läuft nicht auf dem PI.
Wer kann mir helfen?
Cubietruck mit FHEM, CUL V3 443MHz, 2 x CULV3 868MHz, Milights, Max Heizungssteuerung, Homematic, IT,
