[FHZ] 14_CUL_WS.pm, Rev. 1.25: CUL_WS now writes READINGS as well.
Begonnen von Guest, 25 Januar 2010, 20:59:29
Guest
FYI, as discussed: 14_CUL_WS.pm has been updated to write the
received values into READINGS as well. Please check -- and speak
up if it breaks anything.
         kai
You received this message because you are subscribed to the Google Groups "FHEM users" group.
To post to this group, send email to fhem-users@googlegroups.com.
To unsubscribe from this group, send email to fhem-users+unsubscribe@googlegroups.com.
For more options, visit this group at http://groups.google.com/group/fhem-users?hl=en.
Mr. P
On 25 Jan., 20:59, "Kai 'wusel' Siering"
>                         kai
Everything fine. Readings are shown.
Thx a lot! ;-)
Greetz,
   Mr. P
Mr. P
Hello Kai,
is it possible to get a separate output for temperature and humidity
at the READINGS?
Greetz,
   Mr. P
Guest
Gerhard Pfeffer wrote:
> Hello Kai,
> at the READINGS?
Hu?
list Bad_TH
    CODE       7
    CUL_MSGCNT 22
    CUL_RAWMSG K61041242EA
    CUL_RSSI   -85
    CUL_TIME   2010-01-26 16:20:25
    DEF        7
    IODev      CUL
    LASTIODev  CUL
    MSGCNT     22
    NAME       Bad_TH
    NR         34
    STATE      T: 20.4  H: 42.1
    TYPE       CUL_WS
    corr1      0
    corr2      0
    corr3      0
    corr4      0
    Readings:
      2010-01-26 16:20:25   DEVFAMILY       WS300
      2010-01-26 16:20:25   DEVTYPE         S300TH
      2010-01-26 16:20:25   humidity        42.1
      2010-01-26 16:20:25   state           T: 20.4  H: 42.1
      2010-01-26 16:20:25   temperature     20.4
    room       Bad
Which device are you using? SxxxTH should work (see above). Or do
I get you wrong?
         kai
Guest
wie waers denn wenn DEVFAMILY und DEVTYPE aus:
Readings:
nach $attr wandert ?
wegen der einheitlichen READINGs und so ;-))
Schoene Gruesse
Axel
Mr. P
Ok, my fault. I thought, a reload of the module is enough - but it
displayed not before a restart of fhem. :-/
On 26 Jan., 17:12, "Kai 'wusel' Siering"
> > Hello Kai,
> > at the READINGS?
> Hu?
> list Bad_TH
> Internals:
>     CODE       7
>     CUL_MSGCNT 22
>     CUL_RSSI   -85
>     DEF        7
>     IODev      CUL
>     LASTIODev  CUL
>     MSGCNT     22
>     NAME       Bad_TH
>     NR         34
>     TYPE       CUL_WS
>     corr1      0
>     corr2      0
>     corr3      0
>     corr4      0
>     Readings:
> Attributes:
>     room       Bad
> I get you wrong?
>                         kai
Greetz,
   Mr. P
Guest
Reloading the module should have worked in my opinion, but, well, I
usually just restart FHEM after changes; I rather prefer to have seen
a correct start, just in case there is a power outage or something,
dying with an error than would be undesirable.
         kai
> Readings:
Dies sind beim Empfang der Daten festgestellte Eigenschaften, und koennen nicht
vom Benutzer gesetzt werden. Insofern gehoeren sie m.A.n. zu Readings.
Fuer FS20 haben wir zwar das model Attribut, aber da kann das Modul nicht aus
dem RF-Nachricht das Geraetetyp rauslesen -> Der Benutzer muss es setzen.
Architektonisch sauberer waere CUL_WS in 11 Module aufzuteilen (CUL_WS_TH,
CUL_WS_PS50, CUL_WS_WIND, etc). Ich glaube nicht, dass es die Muehe Wert ist.
Manchmal ist is besser mit einer nicht ganz perfekten Loesung zu leben.
