FHEM -> Samsung TV mit Tizen
Begonnen von Florian_GT, 12 September 2016, 00:15:35
Gisbert
Hallo Markus,
ich hab die Version vom 8. November runtergeladen und Fhem neugestartet:
https://forum.fhem.de/index.php/topic,57595.msg855402.html#msg855402
In Fhem global habe ich exclude-from-update 70_STV.pm entfernt, d.h. ich bekomme weitere updates über den offizielen Weg, ist das so richtig?
Ein list meines Devices:
   .triggerUsed 0
   .validcommands 0:noArg 1:noArg 2:noArg 3:noArg 4:noArg 5:noArg 6:noArg 7:noArg 8:noArg 9:noArg AV1:noArg AV2:noArg CHDOWN:noArg CHUP:noArg CH_LIST:noArg CLEAR:noArg COMPONENT1:noArg COMPONENT2:noArg CONTENTS:noArg CONVERGENCE:noArg CYAN:noArg DOWN:noArg ENTER:noArg ESAVING:noArg EXIT:noArg GUIDE:noArg GREEN:noArg HDMI:noArg HDMI1:noArg HDMI2:noArg HELP:noArg HOME:noArg INFO:noArg LEFT:noArg MENU:noArg MUTE:noArg PIP_CHDOWN:noArg PIP_CHUP:noArg PIP_ONOFF:noArg POWER:noArg POWEROFF:noArg POWERON:noArg PRECH:noArg PROGRAM:noArg RED:noArg RETURN:noArg RIGHT:noArg SLEEP:noArg TOOLS:noArg TTX_MIX:noArg TV:noArg TV_MODE:noArg UP:noArg VOLDOWN:noArg VOLUP:noArg YELLOW:noArg querystate:noArg 0_text_line 0_macro G_AUTO_:AUTO_ARC_ANTENNA_AIR,AUTO_ARC_ANTENNA_CABLE,AUTO_ARC_ANTENNA_SATELLITE,AUTO_ARC_ANYNET_AUTO_START,AUTO_ARC_ANYNET_MODE_OK,AUTO_ARC_AUTOCOLOR_FAIL,AUTO_ARC_AUTOCOLOR_SUCCESS,AUTO_ARC_CAPTION_ENG,AUTO_ARC_CAPTION_KOR,AUTO_ARC_CAPTION_OFF,AUTO_ARC_CAPTION_ON,AUTO_ARC_C_FORCE_AGING,AUTO_ARC_JACK_IDENT,AUTO_ARC_LNA_OFF,AUTO_ARC_LNA_ON,AUTO_ARC_PIP_CH_CHANGE,AUTO_ARC_PIP_DOUBLE,AUTO_ARC_PIP_LARGE,AUTO_ARC_PIP_LEFT_BOTTOM,AUTO_ARC_PIP_LEFT_TOP,AUTO_ARC_PIP_RIGHT_BOTTOM,AUTO_ARC_PIP_RIGHT_TOP,AUTO_ARC_PIP_SMALL,AUTO_ARC_PIP_SOURCE_CHANGE,AUTO_ARC_PIP_WIDE,AUTO_ARC_RESET,AUTO_ARC_USBJACK_INSPECT,AUTO_FORMAT,AUTO_PROGRAM G_EXTx:EXT1,EXT2,EXT3,EXT4,EXT5,EXT6,EXT7,EXT8,EXT9,EXT10,EXT11,EXT12,EXT13,EXT14,EXT15,EXT16,EXT17,EXT18,EXT19,EXT20,EXT21,EXT22,EXT23,EXT24,EXT25,EXT26,EXT27,EXT28,EXT29,EXT30,EXT31,EXT32,EXT33,EXT34,EXT35,EXT36,EXT37,EXT38,EXT39,EXT40,EXT41 G_Others:3SPEED,4_3,16_9,AD,ADDDEL,ALT_MHP,ANGLE,ANTENA,ANYNET,ANYVIEW,APP_LIST,ASPECT,AV3,BACK_MHP,BOOKMARK,CALLER_ID,CAPTION,CATV_MODE,CLOCK_DISPLAY,CONVERT_AUDIO_MAINSUB,CUSTOM,DEVICE_CONNECT,DISC_MENU,DMA,DNET,DNIe,DNSe,DOOR,DSS_MODE,DTV,DTV_LINK,DTV_SIGNAL,DVD_MODE,DVI,DVR,DVR_MENU,DYNAMIC,ENTERTAINMENT,FACTORY,FAVCH,FF,FF_,FM_RADIO,GAME,HDMI3,HDMI4,ID_INPUT,ID_SETUP,INSTANT_REPLAY,LINK,LIVE,MAGIC_BRIGHT,MAGIC_CHANNEL,MDC,MIC,MORE,MOVIE1,MS,MTS,NINE_SEPERATE,OPEN,PANNEL_CHDOWN,PANNEL_CHUP,PANNEL_ENTER,PANNEL_MENU,PANNEL_POWER,PANNEL_SOURCE,PANNEL_VOLDOW,PANNEL_VOLUP,PANORAMA,PAUSE,PCMODE,PERPECT_FOCUS,PICTURE_SIZE,PIP_SCAN,PIP_SIZE,PIP_SWAP,PLAY,PLUS100,PMODE,POWER,PRINT,QUICK_REPLAY,REC,REPEAT,RESERVED1,REWIND,REWIND_,RSS,RSURF,SCALE,SEFFECT,SETUP_CLOCK_TIMER,SOUND_MODE,SOURCE,SRS,STANDARD,STB_MODE,STILL_PICTURE,STOP,SUB_TITLE,SVIDEO1,SVIDEO2,SVIDEO3,TOPMENU,TTX_SUBFACE,TURBO,VCHIP,VCR_MODE,WHEEL_LEFT,WHEEL_RIGHT,W_LINK,ZOOM1,ZOOM2,ZOOM_IN,ZOOM_MOVE,ZOOM_OUT caller:noArg screen:noArg
   CFGFN      ./FHEM/Anwesenheitserkennung.cfg
   DEF        192.168.1.32 55000
   Host       192.168.1.32
   MAC        b8:27:eb:5f:20:94
   Mode
   MyIP       192.168.1.26
   NAME       SamsungTV
   NR         242
   Port       55000
   STATE      disconnected
   TYPE       STV
   .attraggr:
   .attrminint:
     2018-12-21 10:54:34   state           disconnected
   helper:
     bm:
       STV_Attr:
         cnt        4
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        21.12. 10:37:39
         max        0.000102996826171875
         tot        0.000319004058837891
         mAr:
           set
           SamsungTV
           delayRC
           600000
       STV_Define:
         cnt        2
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        21.12. 10:41:31
         max        0.116321802139282
         tot        0.19838285446167
         mAr:
           HASH(0x4913830)
           SamsungTV STV 192.168.1.32 55000
       STV_Set:
         cnt        175
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        21.12. 10:54:19
         max        18.3977360725403
         tot        24.6261892318726
         mAr:
           HASH(0x4913830)
           SamsungTV
           POWERON
   callerURI  http://192.168.1.26:8083/fhem
   delayMacro 300000
   delayRC    600000
   icon       it_television
   screenURI  http://192.168.1.26:8083/fhem
Ich kann Programme schalten, auch Ausschalten des Fernsehers geht, aber nicht Einschalten.
Der Wechsel des state zwischen connected/disconnetced (oder Gegenrichtung) dauert so 30 bis 40 Sekunden, nachdem der Fernseher ein- bzw. ausgeschaltet wurde.
Ist das so in Ordnung?
Siehst du bei dem list etwas Auffälliges?
Was kann ich noch mit diesem Modul sinnvolles anstellen?
Viele Grüße Gisbert
KölnSolar
Hi Gisbert,
ZitatIst das so in Ordnung?
Ja. Prüfung erfolgt zyklisch alle 60s.
ZitatIch kann Programme schalten, auch Ausschalten des Fernsehers geht, aber nicht Einschalten.
Auch das ist korrekt. Kein Lautstärke ? keine sonstigen RC-commands ?
Was ist das denn ?
     bm:
       STV_Attr:
         cnt        4
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        21.12. 10:37:39
         mAr:
           set
           SamsungTV
           delayRC
           600000
       STV_Define:
         cnt        2
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        21.12. 10:41:31
         mAr:
           HASH(0x4913830)
       STV_Set:
         cnt        175
         dmx        -1000
         dtot       0
         dtotcnt    0
         mTS        21.12. 10:54:19
         mAr:
           HASH(0x4913830)
           SamsungTV
           POWERON
ZitatSiehst du bei dem list etwas Auffälliges?
Ja.
ZitatcallerURI  http://192.168.1.26:8083/fhem
Dort musst Du eine html-Seite oder ein rss.jpg eintragen, um es mit dem Befehl caller auf den TV zu streamen.
Und die Makrofunktion 0_macro ist auch nicht übel. Ggfs. auch 0_text_line bei der Bedienung von Apps.
Du hast eine Serie kleiner H ? Dann geht das auch ohne DLNARender über Port 7676(geht automatisch). Wobei der DLNARender noch kleinere Vorzüge hat. Da warte ich aber immer noch auf Reinerlein, damit er etwas an der Controlpoint.pm anpasst. :(
Grüße Markus
Gisbert
Hallo Markus,
leider habe ich keine Lautstärke-Regelung im Fernseher.
Ich leite den Ton an ein Surroundsystem; wenn man das einmal hat, will man den Ton vom Fernseher nicht mehr haben.
Leider kann ich den Ton mit der Fernbedienung des Fernsehers nicht bedienen, dafür aber mit einer einfachen Harmony-FB.
Andere RC-commands gibt es schon, da muss ich mal schauen, wie ich die sinnvoll nutzen kann.
Danke für den Hinweis auf das Attribut callerURI. Die Commandref sgat das folgende:
ZitatAttributes
    callerURI: path to an URI of a media(jpg,mp3...)to be displayed on screen
    main purpose: URI to be displayed on screen if a phone call comes in
Wie bekomme ich denn die Rufnummer vom Teilnehmer auf den Fernsehbildschirm?
Port 7676 ist anscheinend nicht kompatibel zur E-Serie; mit 55000 geht es.
Viele Grüße Gisbert
Gisbert
Hallo Markus,
set <device> caller oder screen führt dazu, dass Fhem nicht mehr erreichbar ist. Als Pfad und Datei habe ich ein SVG-Symbol aus Fhem eingetragen.
Viele​ Grüße​ Gisbert​
KölnSolar
Hi Gisbert,
was meinst Du mit
ZitatPort 7676 ist anscheinend nicht kompatibel zur E-Serie; mit 55000 geht es.
E-Serie muss man mit Port 55000 definieren. Modulintern erfolgt der Browseraufruf mit der eingetragenen URI über Port 7676.
ZitatWie bekomme ich denn die Rufnummer vom Teilnehmer auf den Fernsehbildschirm?
Notify auf das Anruferevent(bei mir Fritzbox). Ich hab dann ein RSS-device, welches ich als URI eintrage: http://....../fhem/rss/mycallrss.jpg Bei event Anrufannahme ein set TV EXIT, um wieder in den TV-Modus zu springen.
Zitatset <device> caller oder screen führt dazu, dass Fhem nicht mehr erreichbar ist. Als Pfad und Datei habe ich ein SVG-Symbol aus Fhem eingetragen.
Kannst es einfach mal mit z.B. fhem.de ausprobieren. Seitdem ich den N habe, habe ich E bei Moduländerungen nicht getestet. Könnte also auch ein Modulfehler sein....
Grüe Markus
Gisbert
Hallo Markus,
ZitatKannst es einfach mal mit z.B. fhem.de ausprobieren. Seitdem ich den N habe, habe ich E bei Moduländerungen nicht getestet. Könnte also auch ein Modulfehler sein....
Mit dem Attribute screenURI fhem.de erhält man den gleichen Fehler: Fhem ist nicht mehr erreichbar und nur durch Anwendung von sanfter Gewalt durch Neustart wieder zum Laufen zu bekommen.
Ich hab auch das Modul 98_DLNARenderer.pm nach /opt/fhem/FHEM kopiert und sowohl dieses Modul als auch 70_STV.pm vom update-Prozess ausgeschlossen.
Ich beobachte dann mal, was noch weiter geschieht.
Viele Grüße und ein Frohes Weihnachtsfest
Gisbert
KölnSolar
Hi Gisbert,
caller/screen ist ja quasi identisch(technisch).
Ich brauche zum einen die konkrete URI, die Du eingegeben hast und ob mit oder ohne DLNARenderer definiert ist. So
ist es ohne und dann kennt das STV auch keinen DLNARenderer.
Dir auch ein Besinnliches
Markus
Gisbert
Hallo Markus,
die Definition des Gerätes lautet:
defmod SamsungTV STV 192.168.1.32 55000
Das Attribut für die scren URl lautete:
fhem.de- so wie du es vorgegeben hattest.
KölnSolar
Dann spekulier ich mal auf einen Bug in der Port-7676-Funktionalität. Um das zu testen muss ich meinen E dann erst wieder ans LAN bringen  :'(
Im Log stand bei verbose=5 nichts ? Nicht mal die [STV] SamsungTV: 192.168.1.32:7676 connection message: ..... Dann hätte ich eine Idee  :) Klick mal hier. Und ? Steht da was von MainTVAgent2 im Browser ? Wenn nicht, probier mal beim Link die Zahlen 2-18 anstatt der 10. Den letzten underscore nicht vergessen.  ;)
Grüße Markus
Gisbert
#504
Hallo Markus,
bei der 2 kommt das:
<root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:sec="http://www.sec.co.kr/dlna" xmlns:dlna="urn:schemas-dlna-org:device-1-0">
<specVersion>...</specVersion>
<device>
<deviceType>urn:samsung.com:device:RemoteControlReceiver:1</deviceType>
<friendlyName>[TV]UE50ES6980</friendlyName>
<manufacturer>Samsung Electronics</manufacturer>
<manufacturerURL>http://www.samsung.com/sec</manufacturerURL>
<modelDescription>Samsung TV RCR</modelDescription>
<modelName>UE50ES6980</modelName>
<modelNumber>1.0</modelNumber>
<modelURL>http://www.samsung.com/sec</modelURL>
<serialNumber>20090804RCR</serialNumber>
<UDN>uuid:0db58580-00e6-1000-a60e-f47b5e48e6d6</UDN>
<sec:deviceID>RLCJEJIYQUFKC</sec:deviceID>
<sec:ProductCap>Resolution:1280X720,ImageZoom,ImageRotate,Y2012</sec:ProductCap>
<serviceList>
<service>
<serviceType>urn:samsung.com:service:MultiScreenService:1</serviceType>
<serviceId>urn:samsung.com:serviceId:MultiScreenService</serviceId>
<controlURL>/smp_4_</controlURL>
<eventSubURL>/smp_5_</eventSubURL>
<SCPDURL>/smp_3_</SCPDURL>
</service>
</serviceList>
</device>
</root>
bei der 18 das folgende:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
<scpd xmlns="urn:schemas-upnp-org:service-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<actionList>
<action>
<name>GetCurrentConnectionInfo</name>
<argumentList>
<argument>
<name>ConnectionID</name>
<direction>in</direction>
<relatedStateVariable>A_ARG_TYPE_ConnectionID</relatedStateVariable>
</argument>
<argument>
<name>RcsID</name>
<direction>out</direction>
<relatedStateVariable>A_ARG_TYPE_RcsID</relatedStateVariable>
</argument>
<argument>
<name>AVTransportID</name>
<relatedStateVariable>A_ARG_TYPE_AVTransportID</relatedStateVariable>
</argument>
<argument>
<name>ProtocolInfo</name>
<relatedStateVariable>A_ARG_TYPE_ProtocolInfo</relatedStateVariable>
</argument>
<argument>
<name>PeerConnectionManager</name>
<relatedStateVariable>A_ARG_TYPE_ConnectionManager</relatedStateVariable>
</argument>
<argument>
<name>PeerConnectionID</name>
</argument>
<argument>
<name>Direction</name>
<relatedStateVariable>A_ARG_TYPE_Direction</relatedStateVariable>
</argument>
<argument>
<name>Status</name>
<relatedStateVariable>A_ARG_TYPE_ConnectionStatus</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetProtocolInfo</name>
<argumentList>
<argument>
<name>Source</name>
<relatedStateVariable>SourceProtocolInfo</relatedStateVariable>
</argument>
<argument>
<name>Sink</name>
<relatedStateVariable>SinkProtocolInfo</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>GetCurrentConnectionIDs</name>
<argumentList>
<argument>
<name>ConnectionIDs</name>
<relatedStateVariable>CurrentConnectionIDs</relatedStateVariable>
</argument>
</argumentList>
</action>
<action>
<name>PrepareForConnection</name>
<argumentList>
<argument>
<name>RemoteProtocolInfo</name>
</argument>
<argument>
</argument>
<argument>
</argument>
<argument>
</argument>
<argument>
</argument>
<argument>
</argument>
<argument>
<name>RcsID</name>
</argument>
</argumentList>
</action>
<action>
<name>ConnectionComplete</name>
<argumentList>
<argument>
</argument>
</argumentList>
</action>
</actionList>
<serviceStateTable>
<stateVariable sendEvents="no">
<name>A_ARG_TYPE_ProtocolInfo</name>
<dataType>string</dataType>
</stateVariable>
<name>A_ARG_TYPE_ConnectionStatus</name>
<allowedValueList>
<allowedValue>OK</allowedValue>
<allowedValue>ContentFormatMismatch</allowedValue>
<allowedValue>InsufficientBandwidth</allowedValue>
<allowedValue>UnreliableChannel</allowedValue>
<allowedValue>Unknown</allowedValue>
</allowedValueList>
</stateVariable>
<name>A_ARG_TYPE_AVTransportID</name>
<dataType>i4</dataType>
<defaultValue>0</defaultValue>
</stateVariable>
<name>A_ARG_TYPE_RcsID</name>
</stateVariable>
<name>A_ARG_TYPE_ConnectionID</name>
</stateVariable>
<name>A_ARG_TYPE_ConnectionManager</name>
</stateVariable>
<stateVariable sendEvents="yes">
<name>SourceProtocolInfo</name>
</stateVariable>
<name>SinkProtocolInfo</name>
<defaultValue/>
</stateVariable>
<name>A_ARG_TYPE_Direction</name>
<allowedValueList>
<allowedValue>Input</allowedValue>
<allowedValue>Output</allowedValue>
</allowedValueList>
</stateVariable>
<name>CurrentConnectionIDs</name>
</stateVariable>
</serviceStateTable>
</scpd>
Edit: mit der 10 geht es nicht.
KölnSolar
#505
Und bei 3,4,5,6,7,8,9,10,11,12,13,14,15,16,17 ?  ::) ;D
Frohe Weihnachten
Markus
Edit: Aha, 10 geht nicht, schlecht. Ich hab mir noch aufgeschrieben, dass das früher(ältere frimware ?) mal 8 war.  :-\
Edit2: Du hast mich gerade noch auf die Idee gebracht, dass ich mal forsche, was der N so her gibt. Meines Wissens gibt es den Port und damit die UPnP-Services nicht mehr, aber wer weiß.....Denn dann gibt es schicke neue Readings.  ;D
Speedy1,8t
#506
ich hoffe dass ich hier richtig bin.
Seit ca einer Woche beschäftige ich mich damit meinen Samsung TV
der N Serie in Fhem einzubinden.
Vorgegangen bin ich wie in der Anleitung, der TV ist zwar connected, aber ich bekomme weder Readings noch kann ich ihn steuern.
Hier mal ein list
   DEF        192.168.178.31 8001
   Host       192.168.178.31
   Mode
   NAME       SamsungTV
   NR         137
   Port       8001
   STATE      connected
   TYPE       STV
     2018-12-30 16:38:37   state           connected
   delayMacro 300000
   delayRC    600000
Hat hier noch jemand einen Tipp oder Hinweis für mich?
LG Christian
KölnSolar
#507
Hallo Christian,
vermutlich das token-Problem. Habe ich zwar gelöst, bin aber seit Wochen dabei  das Modul auch für die TV-Altversionen lauffähig zu machen, was unendlich lange dauert. Vorher werde ich die neue Version nicht posten.  :'( Geduld.
Grüße Markus
Speedy1,8t
Hi Markus,
danke für deine Antwort.
Was ich nicht ganz verstehe ist deine Aussage ,,TV-Altversion", ich habe hier einen TV der
N-Serie, also doch relativ neu.
Gruß Christian
KölnSolar
#509
Altversion heißt: Baujahr älter 2016(J-Serie) Das Modul unterstützt alle LEDs. Und die habe ich nicht  ;D und bin bei Tests auf Fremdunterstützung angewiesen.  :'(  Versionsunterschiede
Grüße Markus
