Umwandeln eines triggers mittels VCCU
Begonnen von TechMech, 13 September 2016, 10:52:59
TechMech
folgendes Problem:
Physikalische Tasterschnittstelle....
   CUL_0_MSGCNT 59
   CUL_0_RAWMSG A0B42A44048D9B8999001011C::-79.5:CUL_0
   CUL_0_RSSI -79.5
   CUL_0_TIME 2016-09-12 21:12:28
   DEF        48D9B8
   IODev      VCCU
   LASTInputDev CUL_0
   MSGCNT     59
   NAME       FL.TUER
   NOTIFYDEV  global
   NR         463
   NTFY_ORDER 50-FL.TUER
   STATE      CMDs_pending
   TYPE       CUL_HM
   channel_01 FL.TUER.01
   channel_02 FL.TUER.02
   channel_03 FL.TUER.03
   lastMsg    No:42 - t:40 s:48D9B8 d:999001 011C
   protCmdDel 9
   protCmdPend 4 CMDs_pending
   protLastRcv 2016-09-12 21:12:28
   protResndFail 2 last_at:2016-09-12 21:11:19
   protSnd    59 last_at:2016-09-12 21:12:28
   protState  CMDs_pending
   rssi_at_CUL_0 avg:-68.09 min:-83.5 max:-54 lst:-79.5 cnt:59
   Readings:
     2016-09-12 20:34:07   CommandAccepted yes
     2016-09-12 21:11:21   D-firmware      1.3
     2016-09-12 21:11:21   D-serialNr      NEQ0185369
     2016-09-12 20:34:07   PairedTo        0x999001
     2016-09-12 20:34:07   R-pairCentral   0x999001
     2016-09-12 21:12:28   battery         ok
     2016-09-13 08:39:01   state           CMDs_pending
   cmdStack:
     ++A001F1000048D9B801019990010100
     ++A001F1000048D9B801059990010104
     ++A001F1000048D9B801080100
     ++A001F1000048D9B80106
   Helper:
     HM_CMDNR   66
     cSnd       0199900148D9B800040000000000,0199900148D9B801019990010100
     mId        0046
     rxType     4
     Expert:
       def        1
       det        1
       raw        0
       tpl        0
     Io:
       newChn     +48D9B8,00,00,00
       nextSend   1473707548.71296
       rxt        0
       vccu       VCCU
       p:
         48D9B8
         00
         00
         00
     Mrssi:
       mNo        42
       Io:
         CUL_0      -77.5
     Prt:
       bErr       0
       sProc      2
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rpt:
       IO         CUL_0
       flg        A
       ts         1473707548.6176
       ack:
         HASH(0x2dabbb0)
         42800299900148D9B800
     Rssi:
       At_cul_0:
         avg        -68.093220338983
         cnt        59
         lst        -79.5
         max        -54
         min        -83.5
   IODev      VCCU
   IOgrp      VCCU
   alias      Schließkontakt Haustür
   autoReadReg 0_off
   expert     1_allReg
   firmware   1.3
   model      HM-SWI-3-FM
   room       CUL_HM
   serialNr   NEQ0185369
   subType    swi
   webCmd     getConfig:clear msgEvents
... mit ihrem Kontakt.
   DEF        48D9B801
   NAME       FL.TUER.01
   NOTIFYDEV  global
   NR         465
   NTFY_ORDER 50-FL.TUER.01
   STATE      Short (to VCCU)
   TYPE       CUL_HM
   chanNo     01
   device     FL.TUER
   peerList   VCCU_Btn1,
   Readings:
     2016-09-12 21:11:05   R-VCCU_Btn1-expectAES set_off
     2016-09-12 21:11:05   R-VCCU_Btn1-peerNeedsBurst set_off
     2016-09-12 20:49:25   peerList        VCCU_Btn1,
     2016-09-12 21:12:28   state           Short (to VCCU)
     2016-09-12 21:12:28   trigger         Short_28
     2016-09-12 21:12:28   trigger_cnt     28
   Helper:
     BNO        28
     BNOCNT     1
     getCfgList all
     getCfgListNo ,4
     peerIDsRaw ,99900101,00000000
     Expert:
       def        1
       det        1
       raw        0
       tpl        0
     Role:
       chn        1
     Shadowreg:
       RegL_04.VCCU_Btn1  01:00
   model      HM-SWI-3-FM
   peerIDs    00000000,99900101,
VCCU...
   CUL_0_MSGCNT 52
   CUL_0_RAWMSG A0F3C943F311FC400000002041F6A65D8::-80.5:CUL_0
   CUL_0_RSSI -80.5
   CUL_0_TIME 2016-09-13 09:23:11
   DEF        999001
   IODev      CUL_0
   LASTInputDev CUL_0
   MSGCNT     52
   NAME       VCCU
   NOTIFYDEV  global
   NR         457
   NTFY_ORDER 50-VCCU
   STATE      CUL_0:ok,
   TYPE       CUL_HM
   assignedIOs CUL_0
   channel_01 VCCU_Btn1
   Readings:
     2016-09-13 10:13:59   state           CUL_0:ok,
     2016-09-06 21:14:18   trigLast        FL.TUER.01:short
     2016-09-06 21:14:18   trig_FL.TUER.01 Short_79
     2016-09-13 09:23:11   unknown_311FC4  received
     2016-09-13 08:37:41   unknown_3B50D0  received
     2016-09-13 04:00:00   unknown_3B50F2  received
   Helper:
     HM_CMDNR   1
     mId        FFF0
     rxType     1
     Expert:
       def        1
       det        0
       raw        0
       tpl        0
     Io:
       prefIO
       vccu
       ioList:
         CUL_0
     Mrssi:
       mNo
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
       vrt        1
   IODev      CUL_0
   IOList     CUL_0
   group      Homematic
   icon       hm_ccu@3399FF
   model      CCU-FHEM
   room       Gateway
   sortby     2
   subType    virtual
   webCmd     virtual:update
....mit ihrem Kontakt
   DEF        99900101
   NAME       VCCU_Btn1
   NOTIFYDEV  global
   NR         471
   NTFY_ORDER 50-VCCU_Btn1
   STATE      set_press short
   TYPE       CUL_HM
   chanNo     01
   device     VCCU
   peerList   FL.TUER.01,
   Readings:
     2016-09-13 10:13:59   peerList        FL.TUER.01,
     2016-09-12 20:35:17   state           set_press short
     2016-09-12 21:12:28   trigLast        FL.TUER.01:short
     2016-09-12 21:12:28   trig_FL.TUER.01 Short_28
   Helper:
     Expert:
       def        1
       det        0
       raw        0
       tpl        0
     Role:
       chn        1
       vrt        1
   peerIDs    48D9B801,
   webCmd     press short:press long
Hier mein CUL_HM
   CMDS       BbCFiAZEGMKUYRTVWXefmltux
   CUL_0_MSGCNT 111
   Clients    :CUL_HM:HMS:CUL_IR:STACKABLE_CC:
   DEF        /dev/ttyACM0@9600 1034
   DeviceName /dev/ttyACM0@9600
   FD         14
   FHTID      1034
   NAME       CUL_0
   NR         322
   NR_CMD_LAST_H 59
   PARTIAL
   RAWMSG     A0F3C943F311FC400000002041F6A65D8F3
   RSSI       -80.5
   STATE      Initialized
   TYPE       CUL
   VERSION    V 1.61 CUL868
   initString X21
Ar
   owner_CCU  VCCU
   Matchlist:
     1:CUL_HM   ^A....................
     8:HMS      ^810e04....(1|5|9).a001
     D:CUL_IR   ^I............
     H:STACKABLE_CC ^\*
   Readings:
     2016-09-08 09:36:26   ccconf          freq:868.300MHz bWidth:101KHz rAmpl:33dB sens:8dB
     2016-09-12 20:46:19   cmds             B b C F i A Z E G M K U Y R T V W X e f m l t u x
     2016-09-08 09:34:48   raw             No answer
     2016-09-13 09:23:11   state           Initialized
     2016-05-31 20:42:52   uptime          0 00:07:15
     2016-05-31 20:43:01   version         V 1.61 CUL868
   XMIT_TIME:
     1473706143.66723
     1473706144.01436
     1473706146.04775
     1473706146.29975
     1473706146.55257
     1473706147.04412
     1473706147.2979
     1473706147.79463
     1473706165.14579
     1473706165.41033
     1473706165.51372
     1473706165.69163
     1473706168.00466
     1473706168.29512
     1473706168.54769
     1473706176.50393
     1473706262.79933
     1473706263.00821
     1473706263.30056
     1473706267.30009
     1473706267.55394
     1473706268.30057
     1473706268.55448
     1473706270.30122
     1473706270.55513
     1473706984.8429
     1473706985.09238
     1473706985.58774
     1473706985.84271
     1473707187.34985
     1473707196.59935
     1473707196.85297
     1473707264.11436
     1473707264.35679
     1473707317.856
     1473707318.85576
     1473707475.36855
     1473707475.6302
     1473707477.61306
     1473707478.11431
     1473707482.82142
     1473707483.36422
     1473707483.86583
     1473707513.13024
     1473707513.36912
     1473707515.36629
     1473707515.86655
     1473707516.12025
     1473707516.61689
     1473707516.87046
     1473707517.12444
     1473707517.39437
     1473707517.63358
     1473707517.88757
     1473707518.1411
     1473707546.86771
     1473707547.12148
     1473707548.11841
     1473707548.61829
   Helper:
     48d9b8:
       QUEUE:
   alias      CUL HomeMatic
   group      Homematic
   hmId       999001
   icon       cul_cul@3399FF
   model      CUL
   rfmode     HomeMatic
   room       Gateway
   sortby     1
   verbose    1
Ich bekomme es einfach nicht hin, dass der Trigger der Funk-Schalterschnittstelle ( HM-SWI-3-FM ) sich in state:"on" oder "off" der VCCU_Btn1 wandelt, um das Reading weiter zu verarbeiten.
Vielen Dank für eure Hilfe im Voraus.
TechMech
lass doch auf alle Fälle den SWI mal alle seine CMDs abarbeiten:
Zitat2016-09-13 08:39:01   state           CMDs_pending
Also Knöpfchen drücken und warten.
TechMech
Hallo Otto,
vielen Dank für deine schnelle Antwort.
   CUL_0_MSGCNT 52
   CUL_0_RAWMSG A0B54A04048D9B8999001012D::-70.5:CUL_0
   CUL_0_RSSI -70.5
   CUL_0_TIME 2016-09-13 20:13:07
   DEF        48D9B8
   IODev      VCCU
   LASTInputDev CUL_0
   MSGCNT     52
   NAME       FL.TUER
   NOTIFYDEV  global
   NR         463
   STATE      FL.TUER.01 Short
   TYPE       CUL_HM
   lastMsg    No:54 - t:40 s:48D9B8 d:999001 012D
   protLastRcv 2016-09-13 20:13:07
   rssi_at_CUL_0 avg:-68.16 min:-83 max:-62 lst:-70.5 cnt:52
   Readings:
     2016-09-13 20:11:00   D-firmware      1.3
     2016-09-13 20:11:00   D-serialNr      NEQ0185369
     2016-09-13 20:13:07   battery         ok
     2016-09-13 20:13:07   state           FL.TUER.01 Short
   Helper:
     HM_CMDNR   84
     mId        0046
     rxType     4
     Expert:
       def        1
       det        1
       raw        0
       tpl        0
     Io:
       nextSend   1473790387.82714
       rxt        0
       vccu       VCCU
       p:
         48D9B8
         00
         00
         00
     Mrssi:
       mNo        54
       Io:
         CUL_0      -70.5
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rssi:
       At_cul_0:
         avg        -68.1634615384615
         cnt        52
         lst        -70.5
         max        -62
         min        -83
   IODev      VCCU
   IOgrp      VCCU
   autoReadReg 0_off
   expert     1_allReg
   firmware   1.3
   model      HM-SWI-3-FM
   room       CUL_HM
   serialNr   NEQ0185369
   subType    swi
Jetzt sieht es bei dem SWI schon anders aus, trotzdem bleibt der Zustand der VCCU unverändert.
Hallo TechMech,
ich habe die gleiche Konstruktion, zwei 4 Tasten FB von der  je ein Tastenpaar gepeert ist mit dem zweiten "Tastenpaar" der VCCU.
Das peering habe ich wegen der Quittung und weil mein HMLAN weiter empfängt als der Aktor den ich schalten will. Damit kann ich aus größerer Entfernung den Schaltvorgang auslösen. Ich werte nicht das reading aus sondern habe ein einfaches notify. Hier die DEF
VCCU_Btn4:trig_RC41_4:.*|VCCU_Btn4:trig_RC42_4:.* set <aktor> on-for-timer 1
Das erfüllt meinen Zweck.
Hier mal mein list, ein state gibt es nicht, bei Dir auch nicht. STATE zeigt was ähnliches wie bei Dir, ist also offenbar so.
   DEF        200DB803
   NAME       VCCU_Btn3
   NOTIFYDEV  global
   NR         306
   NTFY_ORDER 50-VCCU_Btn3
   TYPE       CUL_HM
   chanNo     03
   device     VCCU
   peerList   RC41_3,RC42_3,
   Readings:
     2016-09-12 12:28:26   peerList        RC41_3,RC42_3,
     2016-09-09 07:00:09   trigLast        RC41_3:short
     2016-09-09 07:00:09   trig_RC41_3     Short_10
   Helper:
     Expert:
       def        1
       det        1
       raw        0
       tpl        0
     Role:
       chn        1
       vrt        1
     Tmpl:
   expert     1_allReg
   model      CCU-FHEM
   peerIDs    1651C703,220D8C03,
TechMech
Hallo Otto,
der SWI sollte eigentlich als Schalter fungieren.
Der Wert ist ungerade bei geöffnetem Schaltkontakt...
trig_FL.TUER.01   Short_155
... und gerade bei geschlossenem Schaltkontakt.
trig_FL.TUER.01   Short_156
Daraus hatte ich vor ein "on" oder "off" zu generieren.
Gruß TechMech
#5
Ok jetzt habe ich verstanden was Du vor hast. Ich habe auch einen SWI mit einem SW1 gepeert. Da hat man genau dieses Verhalten als Standard. Allerdings ist nicht definierbar ob gerade on oder off ergibt. Aber bei jedem Short wechselt der Zustand.
Der virtuelle Kanal der VCCU macht dieses Verhalten offenbar nicht von sich aus so wie ein realer Schaltaktor.
Erster Gedanke: Du musst irgendwie gerade und ungerade zu on und off mappen. Also man bräuchte ein RegEx für gerade / ungerade Erkennung und dann das mapping.
Ich habe momentan leider keine konkrete Umsetzungsidee.
Du könntest es auch genauso unvollkommen umsetzen wie der reale Aktor und einfach einen Dummy mit einem notify bei jedem Short.* toggeln.
TechMech
Vielen dank für deine Lösungsansätze.
Ich habe gelesen, das ein virtueller Aktor das ganze automatisch wandelt.
http://www.fhemwiki.de/wiki/HM-PB-2-WM55_2fach-Funk-Wandtaster
Irgendwie habe ich gedacht, die VCCU könnte das auch und ich brauche keinen virtuellen Aktor.
Wo liest Du das in dem Artikel? Aus meiner Sicht ist der virtuelle Aktor und der virtuelle Kanal der VCCU das Gleiche?
ZitatNun drückt einmal einen Button eures Tasters. Wenn alles geklappt hatte, sollte bei Euren Kanälen im State ein (to virtueller_Aktor_Btn1) dahinter stehen und unter den Attributen etwas in den peerIDs auftauchen.
Dieser Satz beschreibt ja nur, was im State Deines Tasters passiert.
TechMech
So, ich habe nochmal alles gelöscht und den SWI neu angelernt.
Nach dieser Anleitung hab ich ein virtuellen Aktor erstellt und die Kontakte gepeert.
Jetzt funktioniert es!
Schalterschnittstelle HM-SwI-3-FM...
   CFGFN
   CUL_0_MSGCNT 57
   CUL_0_RAWMSG A0BFDA44048D9B812345601CB::-66:CUL_0
   CUL_0_RSSI -66
   CUL_0_TIME 2016-09-14 20:11:12
   DEF        48D9B8
   IODev      CUL_0
   LASTInputDev CUL_0
   MSGCNT     57
   NAME       HM_48D9B8
   NOTIFYDEV  global
   NR         492
   STATE      HM_48D9B8_Sw_01 Short
   TYPE       CUL_HM
   channel_01 HM_48D9B8_Sw_01
   channel_02 HM_48D9B8_Sw_02
   channel_03 HM_48D9B8_Sw_03
   lastMsg    No:FD - t:40 s:48D9B8 d:123456 01CB
   protLastRcv 2016-09-14 20:11:12
   protSnd    45 last_at:2016-09-14 20:11:12
   protState  CMDs_done
   rssi_at_CUL_0 avg:-65.61 min:-79.5 max:-59.5 lst:-66 cnt:57
   Readings:
     2016-09-14 19:54:32   CommandAccepted yes
     2016-09-14 19:54:37   D-firmware      1.3
     2016-09-14 19:54:37   D-serialNr      NEQ0185369
     2016-09-14 19:54:32   PairedTo        0x000000
     2016-09-14 19:54:32   R-pairCentral   0x000000
     2016-09-14 19:54:32   RegL_00.          02:00 0A:00 0B:00 0C:00 00:00
     2016-09-14 20:11:12   battery         ok
     2016-09-14 20:11:12   state           HM_48D9B8_Sw_01 Short
   Helper:
     HM_CMDNR   253
     PONtest    1
     cSnd       0199900148D9B80303,0199900148D9B801041234560104
     mId        0046
     rxType     4
     Ack:
       virtueller_Aktor HM_48D9B8_Sw_01:FD
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       nextSend   1473876672.4523
       prefIO
       rxt        0
       vccu
       p:
         48D9B8
         00
         00
         00
     Mrssi:
       mNo        FD
       Io:
         CUL_0      -64
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
     Rpt:
       IO         CUL_0
       flg        A
       ts         1473876672.35783
       ack:
         HASH(0x2af9500)
         FD800212345648D9B801010000
     Rssi:
       At_cul_0:
         avg        -65.6140350877193
         cnt        57
         lst        -66
         max        -59.5
         min        -79.5
     Shadowreg:
   IODev      CUL_0
   autoReadReg 4_reqStatus
   expert     2_raw
   firmware   1.3
   model      HM-SWI-3-FM
   room       CUL_HM
   serialNr   NEQ0185369
   subType    swi
...und sein Schaltkontakt
   CFGFN
   DEF        48D9B801
   NAME       HM_48D9B8_Sw_01
   NOTIFYDEV  global
   NR         494
   STATE      Short (to virtueller_Aktor)
   TYPE       CUL_HM
   chanNo     01
   device     HM_48D9B8
   peerList   virtueller_Aktor_Btn1,
   Readings:
     2016-09-14 19:54:33   R-virtueller_Aktor_Btn1-expectAES off
     2016-09-14 19:54:33   R-virtueller_Aktor_Btn1-peerNeedsBurst off
     2016-09-14 19:54:33   RegL_04.virtueller_Aktor_Btn1   01:00 00:00
     2016-09-14 19:54:32   peerList        virtueller_Aktor_Btn1,
     2016-09-14 20:11:12   state           Short (to virtueller_Aktor)
     2016-09-14 20:11:12   trigger         Short_203
     2016-09-14 20:11:12   triggerTo_virtueller_Aktor Short_203
     2016-09-14 20:11:12   trigger_cnt     203
   Helper:
     BNO        203
     BNOCNT     1
     peerIDsRaw ,12345601,00000000
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Role:
       chn        1
     Shadowreg:
   model      HM-SWI-3-FM
   peerIDs    00000000,12345601,
Virtueller Aktor...
   CFGFN
   DEF        123456
   IODev      CUL_0
   NAME       virtueller_Aktor
   NOTIFYDEV  global
   NR         512
   STATE      ???
   TYPE       CUL_HM
   channel_01 virtueller_Aktor_Btn1
   channel_02 virtueller_Aktor_Btn2
   Readings:
   Helper:
     HM_CMDNR   1
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Io:
       newChn     +123456,00,00,00
       prefIO
       rxt        0
       vccu
       p:
         123456
         00
         00
         00
     Mrssi:
       mNo
     Prt:
       bErr       0
       sProc      0
       Rspwait:
     Q:
       qReqConf
       qReqStat
     Role:
       dev        1
   IODev      CUL_0
   expert     2_raw
   model      virtual_2
   subType    virtual
...und sein virtueller Schaltkontakt (siehe "state")
   CFGFN
   DEF        12345601
   NAME       virtueller_Aktor_Btn1
   NOTIFYDEV  global
   NR         515
   STATE      OFF
   TYPE       CUL_HM
   chanNo     01
   device     virtueller_Aktor
   peerList   HM_48D9B8_Sw_01,
   Readings:
     2016-09-14 19:53:33   peerList        HM_48D9B8_Sw_01,
     2016-09-14 20:11:12   state           OFF
     2016-09-14 20:11:12   trigLast        HM_48D9B8_Sw_01:short
     2016-09-14 20:11:12   trig_HM_48D9B8_Sw_01 Short_203
     2016-09-14 20:11:12   virtActState    OFF
     2016-09-14 20:11:12   virtActTrigNo   203
     2016-09-14 20:11:12   virtActTrigRpt  1
     2016-09-14 20:11:12   virtActTrigType short_Release
     2016-09-14 20:11:12   virtActTrigger  HM_48D9B8_Sw_01
   Helper:
     trgLgRpt   0
     Expert:
       def        1
       det        0
       raw        1
       tpl        0
     Role:
       chn        1
       vrt        1
   model      virtual_2
   peerIDs    48D9B801,
Gruß TechMech
Hallo TechMech,
interessant. Muss ich mir näher anschauen. Bedeutet also, das ein virtueller Kanal der VCCU ganz was anderes ist als ein virtueller Kanal eines "virtuellen Aktors". Irgendwie kam mir das bisher "gleich" vor.
Schön das es geht.
martinp876
Der Channel der vccu ist anders wenn man hmlan o.ä. nutzt. Nicht bei cul.
Hmlan sendet ack wenn eine message an die vccu geht. Bei virtuellen channel muss es fhem richten. Auch beim senden geht das besser.
Aha, und ich habe mich irgendwie gewundert, dass es zwei Wege gibt. Also ist wirklich was anders, wieder was gelernt  8)
