Pachube - 2 Feeds, FHT80B-2
Begonnen von Guest, 03 Mai 2010, 23:41:31
Guest
Hi all, I have both a FHT80B-2 and a HMS100-TF.
Both work correctly, however for some reason the FHT80B-2 measured
temperature is not reported to Pachube, the HMS100-TF values are
nicely reported.
In the FHEM web-portal the temperature is updated frequently.
Can the Pachube module handle 2 feeds with one API?
Am I doing something wrong here?
Before I installed the latest CVS I removed all files in /usr/local/
lib/FHEM/
And installation was done with  make install-pgm2 and mv back the
config file.
In case you need additional information, let me know, advice or tips
are welcome.
Thanks in advance for the advice.
-- Facts --
>From my fhem.conf:
attr Buiten model hms100-tf
attr Thermostaat model FHT80B
set Pachube_data ADD Buiten 6769:0:temperature:1:humidity
set Pachube_data ADD Thermostaat 7022:0:measured-temp
(I also did try set Pachube_data ADD Thermostaat 7022:0:temperature)
CVS version:
v 1.105 2010/04/02 16:26:58
In my log file I find lines like:
0: PachLog_Define => main: /usr/local/bin/fhem.pl LINE: 548 SUB:
main::AnalyzeCommand
3: PACHLOG[Buiten] => Unkown READING >temperature<
3: PACHLOG[Thermostaat] => Unkown READING >measured-temp<
3: PACHLOG => Update[Buiten]: 18.1,48.6 >> SUCCESS
3: PACHLOG => Update[Buiten]: 18.1,49.9 >> SUCCESS
3: PACHLOG => Update[Buiten]: 17.9,50.3 >> SUCCESS
3: PACHLOG => Update[Buiten]: 15.6,61.7 >> SUCCESS
Sie haben diese Nachricht erhalten, da Sie der Google Groups-Gruppe FHEM users beigetreten sind.
Wenn Sie Nachrichten in dieser Gruppe posten möchten, senden Sie eine E-Mail an fhem-users@googlegroups.com.
Wenn Sie aus dieser Gruppe austreten möchten, senden Sie eine E-Mail an fhem-users+unsubscribe@googlegroups.com.
Besuchen Sie die Gruppe unter http://groups.google.com/group/fhem-users?hl=de, um weitere Optionen zu erhalten.
Guest
With attr global verbose 5....
5: Triggering global (1 changes)
5: global trigger: Checking Pachube_data for notify
5: PACHLOG[INFO] => global => Nicht definiert
5: Triggering Buiten (5 changes)
5: Buiten trigger: Checking Logfile for notify
5: Buiten trigger: Checking Pachube_data for notify
5: PACHLOG[INFO] => Buiten => Nicht definiert
5: Triggering Thermostaat (1 changes)
5: Thermostaat trigger: Checking Logfile for notify
5: Thermostaat trigger: Checking Pachube_data for notify
5: PACHLOG[INFO] => Thermostaat => Nicht definiert
Guest
Hi Zaleo,
Yes
Can you please try the following sequence in fhem.conf:
- first define all Devices
- in the end of fhem.conf define PachLog
[fhem.conf]
define Buiten HMS 1234
define Thermostaat FHT 4321
define PachLog ********************
[END fhem.conf]
No set´s for PachLog in fhem.conf
Wait until you receiving data f.e. Thermostaat -> measured-temp
Then "set Pachube_data ADD Thermostaat 7022:0:measured-temp" via
fhemweb.
The set´s are stored via fhem.save
Greetings
Axel
